VWVortex.com - Have question about relay 173
    Results 1 to 12 of 12
    Thread: Have question about relay 173
    1. 08-26-2009 08:22 PM #1
      I have a 2000 Passat V6 and just put in a HID kit. I now want to remove my day time running lights because I hear it's the smart thing to do. When I went to pull relay 173, I found I don't have that specific one. However, I do have daytime running lights. Is it a different relay number for different models? Or does it all run the same? If so how is this possible?!? How hard is it to pull out the light dial to cover the pins?
      Also if I drive with the head light switch on, is that still bad considering I still have running lights? Is it even really bad?
      Any help would be great!
    2. 08-27-2009 11:02 AM #2
      Do peeps answer questions around here? did I post in the wrong spot?
      May 2nd, 2001
      CNY
      2012 CW Golf R 4dr, 2017 SB GSW 4MO
      08-27-2009 04:42 PM #3
      Check again. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. Awaiting Email Confirmation EchoOfGecko's Avatar
      Aug 8th, 2000
      Tigard, Orygun
      2002 Passat Wagon 1.8T, 1954 Ford Customline
      08-27-2009 05:55 PM #4
      Yea, I've never seen one without it, it's possible yours may have been replaced at some time with one that didn't have "173" marked on it, but never seen that before.
      As far as running with your lights on, that should be fine. The limited current can do weird things to the balast, but as long at their on full you'll be fine.
      BTW, if you want quicker answers, might also try posting on Passatworld.com, there's a lot more activity there than here. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by EchoOfGecko at 1:57 PM 8-27-2009
    5. 08-28-2009 12:48 PM #5
      yeah I do see that passatworld is bumping...anyhoo appreciate the answers guys, I still find it hard to believe there is no relay 173 in my car. So I just pulled out the light dial and covered TFL and solved it that way.
    6. Member Slimjimmn's Avatar
      Apr 8th, 2006
      Rochester, MN
      MK4 shaggin wagon
      08-29-2009 06:47 PM #6
      173 is in b5.5 cars
      the car is on an inclined driveway and up on jack stands in the front only
      04 Jetta Wagon 2.slow------>Family man now
    7. 09-04-2009 10:19 AM #7
      I have a 2003 Passat without DRL and I want to install it. So i saw here
      http://www.b5one.com/forum/viewtopic.php?t=422
      what i need to do it. I will have to buy one relay 173 and a socket for it. My lights switch has the code 1C0 941 531 A and looks like this
      The wires behind it are these
      When i will be going to make my connections, what pin of my light switch should I use, 3 or 6, cause they have same connection in light switch, look here what i am talking about
      Modified by vicius_the_one at 12:02 AM 9-5-2009
      May 2nd, 2001
      CNY
      09-04-2009 06:25 PM #8
      Why do you want DRLs?
      If you don't have the relay PM me. I'll send you one for $5 and the cost of the postage.
      You have an "Euro" switch so I believe you will also need a US switch to get your DRLs back.
    9. 09-04-2009 07:14 PM #9
      Thanks but i'm from Europe, Romania, so shipping would be more than if i would buy it from here - ~30$
    10. Member
      May 2nd, 2001
      CNY
      09-04-2009 08:58 PM #10
      Quote, originally posted by vicius_the_one »
      I'll be in Budapest from Sept 20 to Oct 3. Does that help?
    11. 09-04-2009 09:07 PM #11
      Of course. How could you send it to me and how could I pay you for it? My yahoo id is the same vicius_the_one. We could chat about without beeing offtopic here.
    12. 10-30-2009 10:37 AM #12
      Hi guys...check this out...my new mod http://www.youtube.com/watch?v=j1tmQvQk1x4
      Modified by vicius_the_one at 12:00 AM 11-1-2009
