Results 1 to 19 of 19
Thread: FS: TAPP EURODYNE ECU for 1.8T
  1. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    2002 1.8T JETTA & 2000 TTQ
    08-26-2009 07:29 PM #1
    I have 1000cc EURODYNE/TAPP ECU for sale. It has both the race and 93 octane files which you can switch on the fly with your cruise control stalk. I made over 400whp on this with a gt30r on an AWP motor with stock head and stock intake manifold, of course upgraded rods, just check my signature for further details. Looking for 750 + your stock ecu. If you want a picture of it, I will take one, but I have been on these forums for a while and am a trusted seller.
    ^^^Above graph is 24psi, stock intake manifold, stock awp head and built bottom end^^^
    Feb 21st, 2004
    Stanceville
    94 Jetta scrapin pinch welds
    09-01-2009 09:51 PM #2
    Which 30r made that dyno on a stock motor?! How many PSI?
  3. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    09-02-2009 08:05 AM #3
    All your questions are answered in my thread in my sig.
  4. 10-10-2009 11:16 AM #4
    bump
    MK4 Junker : PAG 50trim Kit : AEB : RMR : Eurodyne
    P.P.T. - Pag Parts Turbo
    B6 A4 : Slow
  5. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    07-09-2012 01:17 PM #5
    Back from the dead, anyone want to buy my ECU? 500 shipped to your door, I will include a resistor box necessary for the 1000cc (low impedance injectors) I will also include instructions on how to install the injector box and I don't need any ecu in return.
    This is IMMO defeated and EMISSIONS deleted and it will work on any wideband 1.8t from 2001-2005, HS/LP/PL/DL etc
    There are actually 2 files on this ECU which you can switch using the cruise control stalk 93 octane file and c16 file
  6. 08-27-2012 11:54 AM #6
    1000cc is more than I was planning but at that price I may consider it. Ill let you know. Why not using it anymore?
  7. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    08-28-2012 10:51 AM #7
    Quote Originally Posted by bakana View Post
    I had the opportunity to use another software as the new tuner was local to me, so I switched over. Plus, I wanted to use e85 (hence why I went 1000cc), but Chris came out with Maestro and didn't have the time to re-do my file for e85, rather wanted me to upgrade to Maestro.
  8. Member one.fast.gti's Avatar
    Dec 21st, 2009
    AZ
    02 BT 337 1.8T to 2.0 conversion with PTE5857CDBB on E85, 2007 Fahrenheit edition GTI, 2002 Passat
    08-29-2012 03:47 PM #8
    So can one upgrade to maestro with this tune or no?
    2002 BT 337 Edition GTI... IE Rods with Mahle Power pack Pistons/Calico coated rod & main bearings/Billet Mains/ with built AEB head Supertech Inconel valves IE Springs with IE CVA1 Wild Grind Cams/PTE HP5857SP CDBB/ Custom KRM Tubular Exhaust manifold/Custom 2.5"Charge/IC piping/ custom built intake manifold/dual nozzle Snow Performance WMI/Unitronics MAFless 630cc/ E85 Flexfuel tuned.
  9. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    09-27-2012 09:44 AM #9
    Unfortunately, you cannot upgrade to Maestro from this tune. This is one of his older chips which aren't flashed, rather soldered in.
  10. 11-13-2012 09:21 AM #10
    Damn.. you're not getting out of the game are ya?
    Quote Originally Posted by gdoggmoney View Post
    There's been too much butt sniffing before this dog fight.
    GONZO tuning PagPartsTurbo www.speeding-g60.com INTEGRATEDengineering
  11. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    11-13-2012 05:35 PM #11
    Nope, just selling a spare ECU
  12. 11-13-2012 07:57 PM #12
    Quote Originally Posted by 18T_BT View Post
    Cool
  13. 12-14-2012 07:51 PM #13
  14. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    01-09-2013 04:10 PM #14
    Thanks for the
  15. 01-09-2013 11:22 PM #15
    Do you still have this?
  16. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    01-10-2013 02:25 PM #16
    Quote Originally Posted by B5Bombers View Post
    Yes I do
  17. 01-10-2013 09:33 PM #17
    PM'd
  18. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    01-11-2013 12:03 PM #18
    So, what you get is:
    1. 93 octane file
    2. C16 octane file (switch via cruise control stalk)
    3. ECU that has been IMMO and SAI and EVAP and VVT defeated and MAFLESS (usually ~100 bux from most tuners)
    4. ECU itself (usually ~100 bux)
    5. Injector Resistor Box (30 bux maybe cheaper in JY)
    6. Instructions on how to install the box, very easy basic soldering skills
    I have 1000cc injectors I can throw in as well
  19. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    02-07-2013 05:25 PM #19
    SOLD
