VWVortex.com - *** Kinetic VR6 Turbo Kit Specials from CTS Turbo ***
    Page 2 of 7 FirstFirst 123456 ... LastLast
    Results 26 to 50 of 172
    Thread: *** Kinetic VR6 Turbo Kit Specials from CTS Turbo ***
    1. 01-14-2010 12:46 AM #26
      Doing a build with a stage 5 kit . Hardest bit of gear to fit but am gonna make some bad ass numbers . [IMG]http://*****************.com/smile/emthup.gif[/IMG] to CTS
    2. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      01 S4, 02 996TT, 04 A4, 12 Golf R, 15 GTI, 12 TTRS
      01-14-2010 03:59 AM #27
      Quote, originally posted by Bug_racer »
      stage 5 FTW! Haldex shipping champion here!
    3. 01-19-2010 04:12 PM #28
      does the stage 4 kit go straight on a corrado ?
      also does the stock bottom and internals hold up to 400+ hp ?
      Quote Originally Posted by CAH8 View Post
      Yellow is one of the less common colors of corridors.
    4. Member wav3form's Avatar
      Dec 7th, 2008
      Virginia
      2002 Z28
      01-19-2010 04:49 PM #29
      Man I want the Stage 1 kit so bad... are there any sales coming up?
    5. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      01-20-2010 12:37 AM #30
      Quote, originally posted by hendrikbmx »
      The stage 4 wont, you need to modify the kit, and the ECU on a stock corrado wont work for the stage 4 software, you need an OBD2 ecu
    6. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      01-20-2010 12:38 AM #31
      Quote, originally posted by wav3form »
      Check your IM
    7. Member wav3form's Avatar
      Dec 7th, 2008
      Virginia
      2002 Z28
      01-23-2010 10:35 PM #32
      Quote, originally posted by CTS Turbo »
      Check your IM
      I pm'd you back but you never got back to me.... everything ok???
    8. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      01-24-2010 02:01 PM #33
      replied
    9. Member BiH's Avatar
      Nov 27th, 2000
      Fairfax, VA
      1990 JETTA VR6, 2003 JETTA 1.8T, 2010 TOUAREG TDI
      02-12-2010 11:27 PM #34
      Quote, originally posted by 98GTiVR698 »
      so wait the only difference between stage one and two is stage two has intercooler isnt it cheaper to just buy an intercooler and add it on and have a stage two insted of buy another kit for 3000 dollars
      youre not buying a add on stage 2 parts for $3000, the whole stage 2 kit is $3000, IC plus whats in stage 1.
      I do work on cars, anything short of engine and transmission rebuilding can be done. welding, custom and aftermarket as well as regular repairs. IM me for details, shop is in WOodbridge.
    10. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      02-13-2010 09:24 PM #35
      Quote, originally posted by BiH »
    11. 05-10-2010 01:07 PM #36
      PM's replied :bow
    12. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      05-13-2010 12:40 AM #37
      All PM's replied
    13. Member Stiglitz's Avatar
      Apr 30th, 2010
      ORD
      66' Bug/05.5' Jetta TDI/04' R
      05-13-2010 05:31 PM #38
      Do you have to run 94 or will the software pull enough timing to run 91?
      How safe is stage 1 when ran on 91?
      water/meth needed?
      What do you guys suggest for a clutch for stage 1? Will sachs oem handle that trq?
    14. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      05-13-2010 10:44 PM #39
      Quote Originally Posted by Stiglitz View Post
      water/meth needed?
      I would run 93 or 94 octane otherwise you'll have a lot of timing pull, to combat that you can get a simple water meth kit, which is about 3-400 usually.
      I would run a southbend stage 3 clutch with your stock flywheel, some guys get away with a stock clutch, I wouldn't do that myself. I run southbend on my car, it has nice engagement and good drivability for the power levels you're after. If you have any questions feel free to email: sales@ctsturbo.com
      cheers
      Clay
    15. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      05-23-2010 08:38 PM #40
      All PM's replied
    16. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      05-31-2010 01:44 PM #41
    17. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      06-07-2010 05:22 PM #42
      bump
    18. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      06-10-2010 05:15 PM #43
    19. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      06-14-2010 01:55 PM #44
    20. Member Justaviper's Avatar
      Jul 24th, 2007
      Fort Bragg - North Carolina
      1983 VW Golf II 16v
      06-15-2010 05:45 AM #45
      any special deals / sales / promo's for the VR6 Stage III for $4,250 right now ? or is that as low as it gets?
      Seriously considering it but i have a few questions:
      What cams would work best for this setup
      What is the turbo used in the kit
      Would a Garrett super60 work better?
    21. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      06-15-2010 06:35 PM #46
      Quote Originally Posted by Justaviper View Post
      Drop me an email, in Europe now, but will have access to emails occasionally: clay@ctsturbo.com
      cams are a good mod, we can use any turbo you'd like but hte super 60 is way too small for a VR6T they top out 250-270HP on a 4cylinder, the VR6 would choke it up too much.
    22. Member Justaviper's Avatar
      Jul 24th, 2007
      1983 VW Golf II 16v
      06-15-2010 09:34 PM #47
      Email sent
    23. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      08-12-2010 12:04 PM #48
      ttt
    24. 08-12-2010 03:20 PM #49
      a bit OT but still towards CTS turbos
      I'm getting a new 12v VR6 mk4 here soon, thinking of getting a stage one or two kit, but was wondering if I need to upgrade anything else on it for me to use it
      Sorry for the newb question haha
    25. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      08-12-2010 06:39 PM #50
      Quote Originally Posted by Kairu View Post
      A good exhaust system would work well with the turbo and probably an upgraded clutch, that's about it
