VWVortex.com - *** Kinetic 2L Turbo Kit Specials from CTS Turbo ***
    Page 3 of 8 FirstFirst 1234567 ... LastLast
    Results 51 to 75 of 189
    Thread: *** Kinetic 2L Turbo Kit Specials from CTS Turbo ***
    1. Banned the mad conductor's Avatar
      Nov 11th, 2009
      mesa az
      corrado
      01-11-2010 11:17 AM #51
      haahahaaah! What's the highest stage for obd1? And y does everyone hate obd1 when it comes to ecu chips?
    2. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      01 S4, 02 996TT, 04 A4, 12 Golf R, 15 GTI, 12 TTRS
      01-11-2010 09:55 PM #52
      Quote, originally posted by no_cash »
      stage 3
    3. Member MKIGTITDI's Avatar
      Aug 25th, 2007
      Roseburg Oregon
      2015 Jetta TDI 1977 VW Scirocco soon to have a tdi!
      02-18-2010 12:04 PM #53
      I know I asked earlier about a turbo kit for CIS but Im looking at going to megasquirt how would I do a stage 2 with that? Would I need new internals? Im at 10.5:1 compression right now would a head spacer be sufice to drop my compression. I have an OBD1 aba block so i know I have the forged internals.
      Rocco's getting a TDI!!!
    4. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      02-18-2010 08:50 PM #54
      Quote, originally posted by MKIGTITDI »
      I'm not sure what car you have, but our stage 2 and 3 kits are fine with stock internals.
    5. Member MKIGTITDI's Avatar
      Aug 25th, 2007
      Roseburg Oregon
      02-19-2010 12:52 AM #55
      Sorry I have an OBD1 ABA block with a solid lifter counterflow 8v head.
    6. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      02-22-2010 12:05 PM #56
      We don't have anything for the counterflows
    7. 03-02-2010 05:27 PM #57
      PMed you clay
    8. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      03-03-2010 12:06 AM #58
      Quote, originally posted by Lo5to4pathy7 »
      PMed you clay
      Replied
    9. 03-03-2010 08:28 AM #59
      Was talking to a friend said before i order the stage 3 i should get new fuel injectors, pistons, flywheel and clutch is this true or does it go just fine on a bone stock 2L 98 GTI
    10. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      03-03-2010 12:52 PM #60
      Quote, originally posted by qwerty1321 »
      injectors come with the kit, you dont need pistons because our kit uses a head spacer to drop the compression and thats included. You probably want to get a new clutch eventually.
    11. Member Salsa GTI's Avatar
      Aug 29th, 2000
      Venice Florida
      2000 GTI VR6 ....... A founding Member of the 8v 320+whp Club
      03-12-2010 01:33 PM #61
      Digi intake and fuel rail....the megasquirt...not sure if the turbo will clear the intake manifold...the innercooler kit wont work at all...wou will need to fab up your own..the downpipe will work as will the wastegate stuff..you need more research..also the head spacer will work and get 550 injectors and shoot for 20+psi boost..but this has little to do with the kit at this point
    12. Member Salsa GTI's Avatar
      Aug 29th, 2000
      Venice Florida
      03-12-2010 01:35 PM #62
      Quote, originally posted by serious a3 »
      I have a 2.0 8v womdering do I have to do internal work if I change the head spacer and boost up to 20lbs ..... I see ppl always say 15-18 I wanna know if they do internal motor work.....
      No they install the head spacer and boost till the fueling runs out...some place just north of 20psi
    13. Semi-n00b LawrenceMK3's Avatar
      Nov 29th, 2009
      Lawrence
      03-19-2010 02:00 AM #63
      ? real quick idk if u have answered this yet but u can run 15 - 18 lbs of boost on a stock aba
    14. Member waynecarpenter's Avatar
      Jul 17th, 2009
      my hood md
      none
      03-22-2010 11:49 AM #64
      i have a 98 2.0l golf. for stage 3 is it a direct bolt up system. after set up everything should be safe right like nothing should blow or fail. what would you recommend upgrading after this.
    15. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      03-23-2010 02:06 PM #65
      Quote, originally posted by waynecarpenter »
      Yes, it is, the only thing you should get is a clutch aside from the kit
    16. Member Two . Slow's Avatar
      Aug 4th, 2009
      wrightsville, PA
      82 caddy turbo diesel
      04-11-2010 12:34 AM #66
      so if i run 20 psi im not going to implant my rods into the pavement on a stock bottom end?
      Quote Originally Posted by McSlo2.0 View Post
      Oh that and the fact that more rice has been showing up here lately than in the stir fry I just cooked for dinner
    17. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      04-13-2010 02:29 PM #67
      Quote, originally posted by Two . Slow »
      We have had a few guys run 20psi on stock blocks, their rods are still in tact
    18. Member FNG21222's Avatar
      Feb 22nd, 2010
      dundalk,maryland
      Mk6 gti
      04-13-2010 04:29 PM #68
      so pretty much only thing i should upgrade is the clucth when buying the stage 3 kit.
    19. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      04-14-2010 05:05 PM #69
      Quote, originally posted by FNG21222 »
      True
    20. Member FNG21222's Avatar
      Feb 22nd, 2010
      dundalk,maryland
      Mk6 gti
      04-14-2010 11:30 PM #70
      Quote, originally posted by CTS Turbo »
      True
      thanks for the reply
    21. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      04-15-2010 01:48 AM #71
      No problem as long as you have the stage 3 it will include a pump and head spacer and you're good to go.
    22. 04-17-2010 03:41 PM #72
      Quote, originally posted by Sf01JeTTurbo »
      I disagree (AVH)
      Wow, 'looks great! What internals are you running?
    23. Member Sf01JeTTurbo's Avatar
      Jul 2nd, 2006
      williamsport/lancaster PA
      05 volvo S40 T5
      04-17-2010 07:26 PM #73
      stock, w the headspacer in stg3
      2005 Volvo S40 T5 M66 AWD; Samco Turbo Inlet, Injen CAI
    24. Member Two . Slow's Avatar
      Aug 4th, 2009
      wrightsville, PA
      04-22-2010 10:20 PM #74
      ok cool, i didnt know if a rebuild would be needed bc my car has 130,xxx on it. and i was going to build the internals and do a lightened fly wheel and what no. also what cam would you recomend?
    25. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      04-25-2010 11:56 AM #75
      The kinetic guys used to run a cam in some of the MK3's, I will see if I can track down which one it is.
