Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 106 to 140 of 183
Thread: *** Kinetic 2L Turbo Kit Specials from CTS Turbo ***
  1. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    97 A4, 98 VRT, 01 S4, 02 996TT, 04 A4, 11 GTI, 12 Golf R, 13 ??
    03-10-2011 08:43 PM #106
    Quote Originally Posted by Strato50 View Post
    Ah, so I thought, thank you.
    Back I go into the nightmare that is trying to find part codes /engine codes for the City Golf.
    Unless someone knows better than I, how can i make this easier?
    Engine codes is on the head and ECU code is on the ECU
  2. n00b
    Mar 9th, 2011
    Hamilton, Ontario
    1997 Jetta, 2009 CityGolf
    03-12-2011 05:50 PM #107
    Thanks for the info, did some digging and all the City models run a 2.0L 8v BEV engine. Apparantly compatible with c2 software & the mkIV turbo kits
    Still waiting for a good day to dig open my ECU/ECM and figure out what code is in there, will keep posted.
    Mk4.5 and loving it!
  3. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    03-12-2011 06:17 PM #108
  4. n00b
    Mar 9th, 2011
    Hamilton, Ontario
    03-12-2011 08:59 PM #109
    Had the cowling apart to the ECU.. hesitated... so... will unplugging the ECU create any issues?
    I read in a manual that it might require a dealership reprogram.. *shudders*
    If not I'll have the code asap, hehe
  5. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    03-14-2011 10:50 AM #110
    It shouldn't. You shouldn't have to unplug the ecu to get the number off it.
  6. n00b
    Dec 26th, 2010
    SoCal
    2005 Volkswagen Jetta MKIV
    03-22-2011 08:44 PM #111
    I have the infamous BBW engine :/ can that still be turbo charged with one of these kits?
  7. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    03-23-2011 11:13 AM #112
    Quote Originally Posted by Bora824 View Post
    No idea, what's a BBW engine? This kit is designed to with with AEG engine.
  8. n00b
    Dec 26th, 2010
    SoCal
    03-23-2011 07:44 PM #113
    its a 2.0 8v like all the others the only difference is it was designed for certain states emission regulations so the put VVT on it, a self adjusting cam gear and a different camshaft to work with it, plus a sensor, everything else on the engine is the same, x-flow head..etc, oh it also supposedly has 3 O2 sensors
  9. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    03-23-2011 09:01 PM #114
    You may want to ask C2 if they have software for those beasts, then it could be possible
  10. n00b
    Dec 26th, 2010
    SoCal
    03-24-2011 12:03 AM #115
    Hmmm I'll have to check that out...it would be nice
  11. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    04-19-2011 11:41 AM #116
    A short clip of our fab shop and R&D bay. A glimpse of the men behind turbo kit development and fabrication.
  12. Member Dmoneythegreat's Avatar
    Jan 13th, 2010
    Texas
    04-26-2011 12:48 AM #118
    If I run the stage three kit with the GT3076 and with a built 2.0 (forged rods and pistons 9.5:1 CR) with a SRI and water meth. What kind of HP would you think I would be making @ 12-15 PSI??
  13. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    05-19-2011 02:09 PM #119
    Quote Originally Posted by Dmoneythegreat View Post
    240-280whp!!!
  14. Member 95jetta17's Avatar
    Jan 20th, 2008
    York, PA
    95 2.0 turbo, 97 vr6
    06-23-2011 08:50 PM #122
    hey clay any info on what the mk3 stage 3 dv can handle boost wise, and also the spring rate in the waste gate that comes with the kit. thanks buddy
    ctsturbo FTW
    OG suede
    I survived epic thread 2011 never forget 11/11/11
    Quote Originally Posted by vastxpunk View Post
    You have a harness you forgot to plug back in, and you want to know where it goes? Back where you found it would be my guess..
  15. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    06-24-2011 12:09 PM #123
    Quote Originally Posted by 95jetta17 View Post
    ctsturbo FTW
    The wastegates have a variety of spring options that are included in the wg box. Most of the time there is a 8-10psi spring installed in the wg when we ship out. We have consistently ran those DV's to 18-20psi, we even use them in our R32T kits.
  16. Member 95jetta17's Avatar
    Jan 20th, 2008
    York, PA
    06-24-2011 03:43 PM #124
    Quote Originally Posted by CTS Turbo View Post
    im running about 20 psi and my wastegate chatters alittle maybe it could use a higher spring. but it never came with them. thanks for the info
    OG suede
  17. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    06-29-2011 11:28 AM #125
    Sounds like a good plan
  18. 06-30-2011 02:43 AM #126
    Can this fit the 2 litre in the 2011 Jetta S?
  19. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    07-05-2011 02:18 PM #127
    This I don't know, but there may be some minor differences between the engines that may not let it work...
  20. 08-13-2011 11:40 AM #130
    Anyone making a ram horn turbo exhaust manifold for 2.0 aba
  21. 08-31-2011 03:41 AM #132
    How is the mileage on 2.0L AEG's with the stage 3 kit on it? Will I still be able to get above 24mpg?
  22. Member chasem407's Avatar
    Feb 18th, 2008
    Orlando, Florida
    2.1 20v BT
    08-31-2011 08:51 AM #133
    Quote Originally Posted by jpaquino23 View Post
    depends how u drive....and where u drive
  23. 09-01-2011 01:48 AM #134
    Well here's the thing. My friend and I both have AEG motors, and we just installed the stg 3 kit on his 2.0l. It boosts and everything, but his mpg went from 29 down to 10-15 mpg. Is that normal? Well, if it's only something wrong with his car, it doesn't worry me too much and I might consider getting the same kit also.
  24. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    09-01-2011 12:09 PM #135
    It will depend on how you drive the car, but the kit uses much larger injectors than stock. So yes, it is normal for the fuel mileage to go down. I would imagine that your friend is pretty excited to have so much extra power in his car, so he's probably driving around with a heavier than normal right foot. If you can drive around lightly, you should see your MPG go back up.
  25. 09-01-2011 08:33 PM #136
    It will depend on how you drive the car, but the kit uses much larger injectors than stock. So yes, it is normal for the fuel mileage to go down. I would imagine that your friend is pretty excited to have so much extra power in his car, so he's probably driving around with a heavier than normal right foot. If you can drive around lightly, you should see your MPG go back up.:thumbup:
    Lol yes i was serious unfortunately. Thanks for the info though, much appreciated.:beer:
  26. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    09-02-2011 12:18 PM #137
    haha. No problem, man. We're just teasin ya.
    Your MPG should stay around the same when you aren't boosting all the time. Your MFA will not read accurately because the injectors are bigger than stock, so you will have to calculate your fuel mileage manually.
    Full Tank / Distance driven =
  27. Member kevinescobar15's Avatar
    Apr 27th, 2010
    Auburn, Wa
    Mk4 2.0T on megasquirtII
    09-02-2011 12:37 PM #138
    i just bought the stage 3 from (BBM ) and its already installed and everything, im waiting for the ecu to get back but my question is, do you guys dyno tune? im located in Washington.
    One slow MK4 8vT
  28. Banner Advertiser CTS Turbo's Avatar
    Oct 2nd, 2008
    Vancouver, BC
    09-06-2011 01:22 PM #139
    Holler at Blitzkrieg Autowerks. 604.253.6586. Bob and Cheyne can dyno tune.
  29. Member kevinescobar15's Avatar
    Apr 27th, 2010
    Auburn, Wa
    09-06-2011 06:49 PM #140
    alright cool. i give them a call once my damn ECU gets back from C2.
    are they located in WA or BC?
    One slow MK4 8vT
