VWVortex.com - The Official 1.8T forum turbo theory topic.
    Page 1 of 12 1234511 ... LastLast
    Results 1 to 25 of 281
    Thread: The Official 1.8T forum turbo theory topic.
    1. Global Moderator iThread's Avatar
      Sep 27th, 2005
      Portland, Or
      67 Bug, 92 Miata, 12 Golf R, 15 eGolf
      08-27-2009 03:42 PM #1
      This topic is going to be specifically for debate about turbos, how they work, and the theory involved.
      Hopefully hashing it all out here will keep the other topics free of the clutter this debate causes.
      The rules will be strictly enforced here, especially the rules about personal attacks.
    2. Member thom337's Avatar
      Oct 13th, 2007
      MD, VA, NC
      2002 GTI 337
      08-27-2009 03:43 PM #2
      Do bigger turbos flow more volume of air through the engine? No.
      Volumetric flow in an engine is controlled by engine displacement and RPM. The gains from a larger turbocharger come from its ability to flow air more efficiently.
      So, at the same RPM on the same engine, a k03 sport and GT-4088 are flowing the same VOLUME of air out of the compressor.
      Are they flowing the same mass of air? NO.
      Does volume flow have anything to do with performance by itself? NO!
      Performance comes from mass flow of air, because it gives you the ability to burn more mass fuel and release more heat energy, which creates pressure, which creates force, which when acting over a distance creates torque, which at a speed creates power, etc etc etc.
      Reading compressor maps for volume using pressure is not how its supposed to work. You are supposed to get your volume from the VOLUME FLOW of the engine, then you can use your boost pressure at that volume flow, combined with the compressor efficiency to calculate MASS flow.
      Modified by thom337 at 3:45 PM 8-27-2009
      Modified by thom337 at 3:48 PM 8-27-2009
      Self Tuned Motronic ME 7.5, MED 9.1.1
      ECU/Cluster SKC pin code extraction, Immobilizer off, Custom Tuned Files....PM me
    3. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '03 BMP 20th AE
      08-27-2009 03:44 PM #3
      aaahahahahahahahahahahahahaha
      :HOMEGROWN MOTORSPORTS:1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    4. Member 04VDubGLI's Avatar
      May 20th, 2005
      Pittsburgh, PA ish
      04.5 VW GLI 1.8T
      08-27-2009 03:49 PM #4
      I <3 Boost.
      So... I'm confused as to what exactly is to be debated here?
      Are we trying to explain that compressor wheels are rated in lb/min (easily converted to CFM) or... what?
    5. 08-27-2009 03:50 PM #5
      A long time ago a man invented intercoolers to fix the density problems
      I had no problems keeping my intake temperature down with K03S with very good intercooler so temperature is the same as GT28RS I have right now.
      Density is a function of pressure and temperature, both are the same for both turbos meaning flowing in 100g/s of air with k03s and flowing 100g/s with GT28RS ...same **** ..it's the same air volume. Now with
      GT28RS you will flow more air mass, meaning you are flowing more volume as well
    6. Global Moderator iThread's Avatar
      Sep 27th, 2005
      Portland, Or
      08-27-2009 03:52 PM #6
      Quote, originally posted by 04VDubGLI &raquo;
      Anything and everything relating to turbos and how they function.
      It's primarily so that people who want to debate about it can do it in here rather than in other topics.
      Hopefully it works.
    7. Member thom337's Avatar
      Oct 13th, 2007
      MD, VA, NC
      2002 GTI 337
      08-27-2009 03:53 PM #7
      I <3 Boost.
      People were basically trying to say that bigger turbos push more volume flow into the engine, which is incorrect. The do suck in a greater volume at the compressor inlet, but at the compressor outlet the volume flow is dictated by the engine volumetric flowrate which is dictated by the engine speed and displacement.
      Compressor maps are meant to be used at the compressor outlet...so the volume axes of the graph is dealing with how much volume the engine is flowing. Then, by using the working pressure ratio and efficiency, you can calculate mass flow which gives you a true idea of performance. CFM tells you very little about how much power the turbo will make without any density data.
    8. 08-27-2009 03:56 PM #8
      Let me get this going!
      On a 1.8T motor, a K03S and a GT35R both set to 15 psi are flowing the same volume of air into the engine. (Not taking into account the increase in Volumetric Efficiency created by the larger hot side).
      Markku Kivinen | Agtronic Motorsport
    9. Member thom337's Avatar
      Oct 13th, 2007
      MD, VA, NC
      2002 GTI 337
      08-27-2009 03:58 PM #9
      Quote, originally posted by mescaline &raquo;
      How is temperature the same for both turbos? The k03 charge will likely be less efficient, and therefore hotter. The GT28rs charge will be more efficient, and therefor colder, and denser. It is the same volume of air, with a different density, which results in a different mass flow, which results in different power output.
      Now with GT28RS you will flow more air mass, meaning you are flowing more volume as well
      No...you cannot flow more volume than the engine has empty displacement space. If you are talking about compressor inlets, yes there is a great volume coming INTO the compressor (suction tube), but when its pumping at a pressure it is pumping the same volume INTO the engine as it would with any turbocharger.
    10. 08-27-2009 03:59 PM #10
      Quote, originally posted by thom337 &raquo;
      Density of air changes all the time (mountains, sea level), this is why VW is using MAF and not...VAF ...lol, engine doesn't know what kind of IC you have either.
      Will bigger turbo flow more dense air? Probably, not necessarily...but is it making power on more dense air only? Not a chance, more dense air is responsible for 2% of extra power you get. More air inside the engine (and I mean volume) is responsible for everything else (AND APR OF COURSE) (:
    11. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      08-27-2009 04:02 PM #11
      this is so funny stuff.
      MASS airflow sensor.
      What vegeta said.
    12. 08-27-2009 04:03 PM #12
      The part you are forgetting is that you cannot increase volume without increasing pressure, or decreasing restriction.
      There are 2 reasons why larger turbos make more power :
      1) The larger compressor is more efficient.
      2) The turbine is less restrictive.
    13. Member 04VDubGLI's Avatar
      May 20th, 2005
      Pittsburgh, PA ish
      04.5 VW GLI 1.8T
      08-27-2009 04:05 PM #13
    14. Member thom337's Avatar
      Oct 13th, 2007
      MD, VA, NC
      2002 GTI 337
      08-27-2009 04:06 PM #14
      If it is the same volume, colder, and at the same pressure must it not also be more dense? YES.
      Power output is DIRECTLY proportional to charge density. If density is doubled, power output must double. Again, basic thermodynamics and physics.
      There is not more volume of air in the engine with a larger compressor. The engine can only be filled until it is completely full, which is its volumetric capacity. Gains come from decreasing temperature and increasing pressure.
    15. Member 04VDubGLI's Avatar
      May 20th, 2005
      Pittsburgh, PA ish
      04.5 VW GLI 1.8T
      08-27-2009 04:08 PM #15
      Volumetric Efficiency.
      Density = Mass/Volume... Just something to keep in mind for everyone?
    16. 08-27-2009 04:09 PM #16
      Why would it be colder? I said at the begining that I had 50C intake temperature with both turbos. Pressure is also the same.
    17. Member thom337's Avatar
      Oct 13th, 2007
      MD, VA, NC
      2002 GTI 337
      08-27-2009 04:14 PM #17
      Why would it be colder? .
      Compressor efficiency. Are we talking about turbos or intercoolers?
    18. 08-27-2009 04:14 PM #18
      http://www.turbobygarrett.com/....html
      THank you, this proves the point rather well :
      Quote, originally posted by TurboByGarrett.com &raquo;
      EXAMPLE:
      I have an engine that I would like to use to make 400Hp, I want to choose an air/fuel ratio of 12 and use a BSFC of 0.55. Plugging these numbers into the formula from above:
      of air.
      Thus, a compressor map that has the capability of at least 44 pounds per minute of airflow capacity is a good starting point.
      Note that nowhere in this calculation did we enter any engine displacement or RPM numbers. This means that for any engine, in order to make 400 Hp, it needs to flow about 44 lb/min (this assumes that BSFC remains constant across all engine types).
      Naturally, a smaller displacement engine will require more boost or higher engine speed to meet this target than a larger engine will. So how much boost pressure would be required?
      The only way to get 44 lb/min into the motor is by increasing the boost.
    19. 08-27-2009 04:19 PM #19
      Turbo or intercoolers? Are you saying if I add a good intercooler that will cool down K03S air to 40C and GT28RS is at 40C they will make the same power? That would be cheap heh.
      I am telling you that intake temperature of both turbos were the same, 50C...this is logged...I have a log here somewhere, also both turbos were operating at 18 psi @ 4000 rpm. Now why would MAF report ~100g/s more for GT28RS if all parameters are the same?
    20. 08-27-2009 04:21 PM #20
      Quote, originally posted by Agtronic &raquo;
      Wrong again, bigger turbo will get 44lb/min into engine at the same boost level as smaller turbo. 44lb/min which you can easily convert to CFM.
      Modified by mescaline at 1:22 PM 8-27-2009
    21. Member thom337's Avatar
      Oct 13th, 2007
      MD, VA, NC
      2002 GTI 337
      08-27-2009 04:25 PM #21
      That's exactly right. If you have a GT28RS making the same pressure and temperature at the same RPM as a K03, they will make exactly the same power. Now, cooling down a K03 that much and operating it reliably would be quite the task, but yes if you were able to do that they would make the same power and be flowing the same mass flow of air.
      It wouldn't. The situation you are describing is only possible if the IAT sensor is taking too long to register a temperature change. Try going steady state on a dyno at that same rpm and situation and then tell me the results. At the same manifold temperature, pressure, and RPM, the mass flowrates must be the same.
      Modified by thom337 at 4:30 PM 8-27-2009
    22. Member thom337's Avatar
      Oct 13th, 2007
      MD, VA, NC
      2002 GTI 337
      08-27-2009 04:27 PM #22
      Nope, it can do it at a lower boost level because the compressor exit temperatures won't be as high.
    23. Member The*Fall*Guy's Avatar
      Aug 10th, 2009
      There
      08-27-2009 04:31 PM #23
      Let's interupt this ummm discussion to welcome our new moderator.. Welcome to the forum ithread And no.. I'm not being sarcastic..
    24. 08-27-2009 04:34 PM #24
      This is just...dumb.
      I told you that I had 50C intake temperatures with K03S and with GT28RS, 18 psi @ 4000rpm. This is not faulty IAT sensor, ask around...lots of people have 50C intake temperatures with K03S...this is nothing unusual.
      Bigger turbo can't double the air density man.
      Anyway am going for a run, lots of dense air outside... i will burn off this fat i gained over vacation tonight ha ha (:
      Modified by iThread at 1:37 PM 8-27-2009
    25. Member dubchuck117's Avatar
      Feb 5th, 2009
      rockledge fl
      2003 vw gti 1.8t
      08-27-2009 04:36 PM #25
      the way a turbo works is by effectively cramming air into an engine, increasing its volumetric effeciency. this is why a gt28 at the same psi as a k03 will undoubtely make more power, because it is a) lowering charge temps and b) forcing more air into the engine. by your logic a bigger turbo just decreases charge temps and increases density. this makes sense to a point. but as you get into bigger turbos the temps arent going to change much more but cfm's are going to go up. its all about efficient volume [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      2.5" Megan Racing turboback, Fujita SRI, DIY dual stage boost controller (stock and 20psi), diode, self tuned
      Raceland Coilovers, Euro Image 5/8" driver side motor mount spacer (22.75 daily driven)
      Quote Originally Posted by SoIAteAPancakeToday View Post
      if im paying 2k for coils those ****s better hover
