Page 13 of 14 FirstFirst ... 3 9 10 11 12 13 14 LastLast
Results 421 to 455 of 478
Thread: 06X-16V Hybrid - Thinking about building a new motor? STOP! READ THIS...
  1. Member jjensen's Avatar
    Jun 25th, 2009
    WAUS vegas
    2003 black gti 24v
    11-23-2011 07:17 PM #421
    they will work for an aeg block then correct?
  2. Member Mk1Madness's Avatar
    Nov 8th, 2009
    South Philly
    75 Rabbit, 84 GTi
    11-23-2011 08:24 PM #422
    What is the aluminum VW block?
    Mk1's, German Classics not Brazilian plastics.
    Sep 14th, 2005
    VA
    88 GLI 16V
    11-24-2011 12:58 AM #423
    Might have missed this but.....
    With a 16v head, will you get low compression just like using an ABA block? Gonna be building a 16vT and this info on this block caught my eye.
  4. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    11-24-2011 01:58 AM #424
    Quote Originally Posted by jjensen View Post
    yes.
    Quote Originally Posted by Turbo3 View Post
    both the 9A and the AZG/AEG have a 220mm deck height
    whatever CR you had in your 9A motor you will have in your AZG.
    Sep 14th, 2005
    VA
    88 GLI 16V
    11-24-2011 09:34 PM #425
    Quote Originally Posted by Issam Abed View Post
    yes.
    That's with the stock AZG/AEG pistons too right?
  6. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    11-25-2011 04:27 PM #426
    No
    You are not using your AZG/AEG pistons. They are paperweights at this point.
    INA Engineering Inc.
    Email | Facebook
    INA Billet | 034 EFI | Mahle Powerpak | DM Forged | Ferrea | Supertech | ARP | South Bend | HTA Turbochargers | Mocal Oil control | DBW Throttle Body Upgrades
    Sep 14th, 2005
    VA
    88 GLI 16V
    11-25-2011 09:02 PM #427
    I may have not been clear on my question..
    If i bolt my 16 head on this block with stock internals, will i have a low (lower) compression motor?
  8. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    11-25-2011 10:36 PM #428
    Yes but I dont see why you would do this considering AZG stock pistons are not very robust. Just get the right pistons...
    Sep 14th, 2005
    VA
    88 GLI 16V
    11-26-2011 01:12 AM #429
    That's what I was wondering too, as how strong the stock internals are. I'm building a boosted motor and its gonna be on MS. This is gonna be my first time messin with standalone and I'm gonna be tuning it myself. So I wanted to run the stock internals just in case I do something wrong and damage the bottom end. I don't wanna damage the good stuff
  10. Member jjensen's Avatar
    Jun 25th, 2009
    WAUS vegas
    2003 black gti 24v
    11-26-2011 01:45 PM #430
    im intrested in running a cam in this setup as well. probley just the abf cams from bbm. is there any worry of clearance issues? thanks for you help
  11. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    11-26-2011 06:10 PM #431
    Realistically speaking the only thing you are changing is the block . Internally everything is almost identical so if you found cams that would work with 9A pistons in a 9A block then they would also work with 9A pistons in an AZG block.
  12. Member jjensen's Avatar
    Jun 25th, 2009
    WAUS vegas
    2003 black gti 24v
    11-26-2011 09:59 PM #432
    will running an aeg block be terrible though due to lack of oil squirters? ive seen it posted on here that the aeg will not be a good choice for a daily driver type engine.
  13. Member
    Sep 14th, 2005
    VA
    88 GLI 16V
    11-27-2011 03:11 PM #433
    VW wouldn't have put it out if it was a bad choice for a daily
  14. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    11-27-2011 06:12 PM #434
    You do not *need* oil squirters all though it is recommended. If it that much of an issue any machine shop can install them for around $100 or so.
    We had around 15 AEG blocks that had no oil squirters or M14 coolant feed for a turbocharger and we just had them converted.Not that difficult to do.
  15. Member my02VR6's Avatar
    Jan 6th, 2005
    Sac, CA/ Gresham, OR
    24v 2.9 GTI/90 GLI 2.0 16v
    01-26-2012 01:23 AM #435
    I'm in the process of researching options for my 90.5 16v GLI. Either the block is cracked or the head gasket is done, i'm getting coolant mixed with oil. That's not the question though. What I want to know is, will this block mount in all the same spots as the original motor? And what will I have to do for engine management?
    Copied from my pm...
    02.5 24v GTI: 2.9L, JE pistons, IE rods, eurospec 264/260° cams, Wavetrack LSD, TT dp/hiflow cat, 2.5" TT catback/ borla, Oettinger, 18x8 RS-GT on BF Goodrich, Brembo GT front BBK, 28mm/25mm Neuspeed swaybars, H&R coilovers, etc. More info & pics
    90.5 16v GLI: Calypso green, >30mpg, 15x7.5 RMs, 195/50 Yoko Sdrives, PSS9s, 2.25" TT catback/ borla, USRT shift kit, .80 5th.
  16. Member elRey's Avatar
    May 15th, 2001
    16vt 2.0L MK4 Jetta Wagon | B6 A4 Avant
    01-26-2012 01:48 AM #436
    Quote Originally Posted by my02VR6 View Post
    Since I have an AZG in my 90 jetta, I'd say yes. 06x will mount into a mk2.
  17. Member my02VR6's Avatar
    Jan 6th, 2005
    01-26-2012 03:37 AM #437
    Thanks, thats what I was hoping for. I wrote that before reading the whole thread. Your build sounds very nice.
    My goal is to stay as close to stock as possible, but with this block. Reading through this, it seems I should just buy the kit and source my own AZG and rebuild my head. Everything else sounds like it remains stock.
    Is there a serp kit for a/c, p/s and alternator?
    And just to make sure, I can still use my 2y, right? Besides this kit and a block, is there anything else I'll need for a 90 GLI install?
  18. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    01-27-2012 03:37 PM #438
    Use the AZG serpentine belt set up. It will have everything you need.
    You can use the 2Y yes as that will bolt up to the block. Anything else you need? Just the pistons and a rebuild kit.
  19. 02-08-2012 09:58 PM #439
    Hi,
    Loking to build a 2.1L been looking at a few options and since I'm running an 02J regardless of engine This seems like a semi reasonable alreative to the ABA/a6 setup I had previously considered.
    Here's are a few questions that have not be answered.
    1) MK4 tdi is 236mm deck height correct?
    2) what size head blots does it use I know they are larger are they m12?
    3) With the ALH crank what toner ring should be used (ALH or BEW)?
    for reference this is what I have looked into on my math.
    using a 236mm deck height block with 95.5mm crank and 159mm rods and 9A pistons. Now before anyone goes screaming it works.
    9a pistons compression height is 29.6mm. The required compression hieght for same cr in my setup would need to be 29.25, a difference of .35mm or .0138". Same as decking a block the pistons would have more protrusion. This will reduce quish and increase CR. should yield about a static CR of 11.6-8 cr depending on MK4 HG thickness.
    My question is what belt do you use with the taller deck hieght? and are there any other differences besides the oil filter bracket between an MK4 gas and TDi block?
    TIA
  20. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    02-09-2012 12:33 PM #440
    Quote Originally Posted by v86sp View Post
    TIA
    I will answer this as best as I can:
    1. Correct
    2. M12 x 1.75 - you wont find Head bolts in this length for use with a 16V head. You will find studs but helicoiling and stepping down to a more common size (M11) might be a better choice.
    3. Neither... you can use ABA if you wish.
    4. Problem with 9A pistons on ABA rods is you will need to rebush the rods from 21mm pin to 20mm pin.
    5. You will need to figure out the timing belt on your own , as well as the water pump and deck of the block.
    6. Very big difference between the 2. If you are using an ALH block it will be cheaper for you to use a remote oil filter than trying to adapt another oil filter housing.
  21. Member elRey's Avatar
    May 15th, 2001
    02-09-2012 05:05 PM #441
    Issam, is an timing belt idler roller including in your kit to increase crank gear wrap? Is it necessary?
    Thanks,
    Rey
  22. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    02-10-2012 10:07 AM #442
    Quote Originally Posted by elRey View Post
    Thanks,
    Rey
    Rey,
    We have one where the OEM 1.8T unit but you can also include one @ the upper right hand corner of the block (where a MKIV engine mount tab once was).
  23. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    02-14-2012 10:46 PM #443
    Guys,
    please ask questions in the thread. Sending me a PM to privately address questions which have been asked in this thread is sellfish. Let others learn and you can as well.
  24. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    03-12-2012 01:00 PM #444
    Kris Clewell shows off his new 06A-16V Motor.
    Quote Originally Posted by Digital K. View Post
    short block showed up from issam at INA engineering on friday. really impressed with everything. I'm not sure what it's going to make for power. I have high hopes though. Any armchair speculation is welcome....Here is the build for the block:
    • JE Forged Pistons - 2618 Alloy - 83.5mm bore w/11.5 CR - 92.8mm stroke (9A)
    • DM Forged H-beam 144|25|20-S Connecting Rods w/ARP 2000
    • ARP Main Stud Hardware
    • KB 9A Connecting Rod & Main bearings
    • INA Engineering 06A Bottom End Rebuild kit
    • INA Engineering Steel 06F Oil Pan
  25. Senior Member skidplate's Avatar
    May 4th, 2004
    Beaverton, OR
    89 GTI 90 Audi Coupe Quattro 06 Xterra
    03-19-2012 11:04 PM #445
    Quote Originally Posted by Mk1Madness View Post
    AXW is one of the codes. From what I understand, there are two aluminum block codes. I haven't figured the other one out yet.
    Flickr
    Quote Originally Posted by Mr. Knappy View Post
    We really need breeding standards like they have with dogs.
    Quote Originally Posted by pete@blackforest View Post
    I remember when people modified their Volkswagen to enhance the driving experience. What ever happened to Fahrvergnugen? Bags are for kids that grew up watching Pimp My Ride. Turbo is for all of us that enjoy actual motorsport.
  26. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    03-20-2012 01:06 PM #446
    Quote Originally Posted by skidplate View Post
    AKL
  27. Senior Member skidplate's Avatar
    May 4th, 2004
    Beaverton, OR
    03-21-2012 12:52 AM #447
    AKL
    Flickr
  28. 03-24-2012 02:23 PM #448
    okay. a hypothetical situation here
    AWM block - bored to max 83mm
    - mk4 aeg 92.8mm stroke crank
    = 2.0L right
    now . . . . . thing is, to run a 16v head or not. as far as flow comparrison to a 20v head, lets just say an aeb head. either one will be ported and polished. but which one flows better at its max?
  29. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    03-25-2012 01:29 AM #449
    Quote Originally Posted by 87wolfsburg View Post
    = 2.0L right
    The newer the head the better the flow but lets not turn this into a 20V vs 16V head. This set up is for someone who has a 16V engine currently (9A | PL | KR | 6A | ABF | etc) and is looking to move past old school external water pump / IM Shaft to Internal water pump no IM Shaft.
  30. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    04-06-2012 01:15 AM #450
  31. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    90 Jetta GLI 16v, 99.5 Cabrio Highline
    04-14-2012 10:35 PM #451
    I was showed this thread... I feel like it could do dangerous things to me. I have a 16v 9A Jetta, and an ABA Cabrio. I have thought, for my own reasons, of installing one of these "06x" blocks into the Cabrio, possibly with the 16v head, just for fun. Now you've gone and got me thinking, that it is really easy. From my quick rundown of what is compatible, I "should' be able to get an AEG block, and swap the 16v head and 9A internals into it? And then run it on chipped Motronic from the Cabrio. Hmm... Lots of reading will take place shortly
    A2Resource
  32. Junior Member
    Aug 26th, 2011
    Toronto
    2001 VR6 Golf 4dr
    04-15-2012 09:54 AM #452
    so im looking at doing something not very many people have done, looking at 16v head onto AVH w/ITB setup any recommendations on getting this thing up and running as far as fuel management goes? Going into Mk4.
  33. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    04-15-2012 09:04 PM #453
    Quote Originally Posted by NeedBo0st View Post
    AVH should be the same as AZG.
    Look above at what Kris has done and what chassis is this going into?
  34. Junior Member
    Aug 26th, 2011
    Toronto
    2001 VR6 Golf 4dr
    04-15-2012 09:05 PM #454
    A4 mkiV golf
  35. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    07-11-2012 11:02 PM #455
    A4 mkiV golf
    I would start by using a 1.8T harness & ECU and grafting it to suite. You will need to convert the distributor to a 1 window hall but at least you have access to Maestro.
    Enjoy the video:
