Page 2 of 14 FirstFirst 1 2 3 4 5 6 12 ... LastLast
Results 36 to 70 of 478
Thread: 06X-16V Hybrid - Thinking about building a new motor? STOP! READ THIS...
  1. Member evilrobot0's Avatar
    May 14th, 2004
    Groton, CT
    1990 Jetta GLI 16V, 1996 Jetta TREK, 1992 Jetta GL ABA (In progress)
    09-01-2009 04:56 PM #36
    yes; it works. in fact there is an AWESOME ABF clone (ABA, ABF pistons, 16V head) on Mot 5.9 FS in the MK3 calssifieds; saw the car in person on Sunday - and its even nicer than the pics.
    MK3 guys have been doing 16V head swaps on ABA's for a while now using stock management. C2 even makes a chip for it.
  2. Member Justin 123's Avatar
    Apr 10th, 2005
    Upstate NY
    2012 Golf TDI, 1992 GTI VR6
    09-01-2009 10:20 PM #37
    I'm getting an AEB block shortly to try this out. This is going to be a slow, as time and money allow, build. I'd like to run a TDI crank with 83.5mm (or bigger if safe) pistons. I need to see if anyone makes stroker 16v pistons or if they have to be made. Ideally I'd like 2.2L at 12:1 compression in an 06x block with a 16V head and MLS head gasket.
    ALBANY, NY // www.roflwagens.com
  3. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-01-2009 11:55 PM #38
    Quote, originally posted by Justin 123 »
    2.2L wont happen with a 95.5 crank BUT you will net 2.1L.
    If you need custom pistons I can get them made
  4. Member Justin 123's Avatar
    Apr 10th, 2005
    Upstate NY
    09-02-2009 08:15 AM #39
    I was hoping the extra bore would get me close. As far as pistons, we'll have to see how the budget goes. I never really thought about doing anything with an 06x block before you posted this and local has one in stock, so thanks for the inspiration and the new money pit. Haha
  5. 09-02-2009 11:56 AM #40
    will the stock mk2 motor mounts work on the 06x blocks? or is a mk3 subframe needed?
  6. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    98 VW Golf (AEG) RIP, 04 VW Golf 16VT (In Progress)
    09-02-2009 12:06 PM #41
    the MKII and MKIII have the same mounts.....
    not sure if you can put a MKIV 2L block in a MKII or MKIII without fabbing something though
    on the MKIIIs the kframe directly supports the motor....
    on the MKIV's the frame rails are what supports it...... id have to take a look to see if the blocks have mounting points on them for the older style mounts
    :bow Old Vortex
    Really Volvo? A failure of system that is supposed to save the inattentive would have been noticed by a real inattentive driver?
    Really?
  7. 09-02-2009 12:09 PM #42
    hm, that'd probably be the only thing holding me back. i dont want to have to fab my own mounts. thanks man
  8. 09-02-2009 12:48 PM #43
    Vary intresting, But my problem is that I've got a 9a/PL G60 setup on mine (16vg60). So my Question is could I run a g-lader bracket on a 06A/06B block?
  9. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-02-2009 03:30 PM #44
    Quote, originally posted by 20V_DUBBIN »
    MKII motor mount brackets bolt up direct to a 06A block.
    Seat Ibiza MKIII is a VW Golf MKII with a 06A motor
    Quote, originally posted by G60NUT »
    You could if you put it where the AC/COmpressor on the accessory bracket once was.Id love to do something like this for you
  10. 09-03-2009 10:22 AM #45
    Quote, originally posted by Issam Abed »
    Yea My G60 bracket has every thing on it (Alt and G60) would it bolt up or are we talking custom?
  11. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-03-2009 11:14 AM #46
    Most definitely custom but at least it will be fun
    Oct 29th, 2001
    2 piles of crap
    09-04-2009 10:57 AM #47
    I had a friend try to run an ABF clone on OBDII MkIII Golf wiring and software, it never ran right. He ended up importing an entire Digi3 wiring harness.
    Modified by dubdaze68 at 1:39 PM 9-7-2009
  13. Member -RalleyTuned-'s Avatar
    Nov 17th, 2008
    East of the Mountains, WA
    77' Rabbit 16v, '92 Passat Syncro Wagon1.8t
    09-09-2009 01:50 PM #48
    do mk1 mounts bolt up?
  14. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-09-2009 02:47 PM #49
    As soon as I get the parts I am having made/ordered I will be updating this thread
    Quote, originally posted by -RalleyTuned- »
    No but we have a solution for that now
  15. Member -RalleyTuned-'s Avatar
    Nov 17th, 2008
    09-09-2009 03:04 PM #50
    whats that cost? or estimate for cost?
    i'm assuming the front mount will work with the 020 trans
  16. Member duke_seb's Avatar
    Jul 29th, 2003
    Halifax, Canada
    09-09-2009 03:06 PM #51
    dammit.. if i knew about this I would have told a friend about it before he hacked his out.... hes shoehorning a VRinto a rabbit
    :bow Old Vortex
    Really?
  17. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-09-2009 03:15 PM #52
    We will be selling all 3 mounts for 399 USD + shipping
    The mount will come in either 65A durometer or 80A durometer and will surpass what is currently available on the market.
  18. Member woodrowstar's Avatar
    Jun 17th, 2005
    Southern Md
    86 Cabbie, 82 Rabbit
    09-09-2009 09:21 PM #53
    i'm lost... what head gasket and bolts are you suggesting?
    Follow my dog and I cycling across America for adventure Teamdarb Cycle America Tour
    New Adventure- Get SoWo or Swollen While Trying 2013
  19. Member timmy5150's Avatar
    Jul 31st, 2004
    PNW
    90 Corrado G60
    09-10-2009 07:46 PM #54
    Any pics of this setup yet?
    I think this will be the route I go when it is time for a fresh bottom end...I think my rings are leaking.
  20. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-10-2009 09:28 PM #55
    Quote, originally posted by timmy5150 »
    working on getting a valve cover for pics
  21. Member timmy5150's Avatar
    Jul 31st, 2004
    PNW
    90 Corrado G60
    09-10-2009 09:52 PM #56
    Looking forward to them! Good info BTW! Thanks!
  22. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-12-2009 06:18 PM #57
    Quote, originally posted by woodrowstar »
    * AEG/AZG head gasket
    * ARP head studs
    ABF kit adapeted to 06A block.
  23. Member -RalleyTuned-'s Avatar
    Nov 17th, 2008
    09-12-2009 11:54 PM #58
    so what model cars came with these? you said mkIV golf? anything else? i think we are gonna start searching for one of these for our rally car, if we can find a bottom end for a reasonable price
  24. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-13-2009 02:41 AM #59
    Any MKIV Golf/Jetta 2.0 8V should be an affordable candidate.
  25. Member -RalleyTuned-'s Avatar
    Nov 17th, 2008
    09-13-2009 11:27 AM #60
    alright the search is on!
  26. Member #6jettaC's Avatar
    Oct 16th, 2004
    ortley beach, nj
    w114, 07 tacoma, gy6 vino classic
    09-15-2009 12:54 PM #61
    so could i use a 06x block and internals and bolt a 16v head a top? what would the cr be like? and what head gasket would i use?
    Quote Originally Posted by richardbachman
    Blow me you piece of crap punk. You will never own a car this nice. Scum like you shouldn't be allowed to have children. Stay out of my thread and die soon. Rich
    ...vortex: where people feel the need to pm hate like that...
  27. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-15-2009 01:25 PM #62
    Quote, originally posted by #6jettaC »
    use your 9A internals and an AZG head gasket.
  28. Member Justin 123's Avatar
    Apr 10th, 2005
    Upstate NY
    09-16-2009 07:48 PM #63
    What had to be done to the ABF bracket to make it mount? I should be getting my AEG block shortly and would love you use my ABF setup.
  29. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-17-2009 02:02 AM #64
    You need an adapter block and machining of the ABF bracket.
    Send me back yours and I will send you a machined one for the cost of machining.
  30. 09-17-2009 01:58 PM #65
    Still to early for me... I can buy 4 ABAs for the price of your 06x mounts alone. There has been ONE MKIV at my local junkyard (I did buy the aluminum valve cover, intake and exhaust manifolds though. )
  31. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-17-2009 08:43 PM #66
    Quote, originally posted by frrtbkr »
    Hey if it works for you then use it
  32. 09-18-2009 12:34 PM #67
    why not just take a 20v head and build it on this block instead of using the old 16v heads? no custom head studs then
  33. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    09-18-2009 06:03 PM #68
    Quote, originally posted by calituner »
    Why not swap a full 1.8T motor and done?
    Because....some people want to keep there 16V motor.
  34. Member Justin 123's Avatar
    Apr 10th, 2005
    Upstate NY
    09-19-2009 09:57 PM #69
  35. 09-22-2009 01:41 PM #70
    well one of your arguments is to get away from changing pistons with a aba/16v combo in NA applications. im assuming a 20v head on a 06x bottom would yeld a good ratio to run it NA, no? thats why i suggest that.
    Modified by calituner at 10:44 AM 9-22-2009
