VWVortex.com - Jetta- How do I find my Transmission Code
    Results 1 to 9 of 9
    Thread: Jetta- How do I find my Transmission Code
    1. 08-28-2009 12:41 PM #1
      How do I find my trans code? Where do I look for this?
      My Car Specification is as below-
      2001 Volkswagen Jetta GLS
      Body Style: SEDAN 4 DR
      Engine Size: 2.0L L4 FI
      Drivetrain: Front Wheel Drive
      Auto Transmission
      1,984 cc 2 liters 4 in-line engine with 82.5 mm bore, 92.8 mm stroke, 10 compression ratio, overhead cam and two valves per cylinder
      Unleaded fuel
    2. Member CoolAirVw's Avatar
      Mar 8th, 2007
      Kansas City Missouri
      85 Jetta TD sold 2001 Jetta Tdi, 2000 Jetta Tdi
      08-28-2009 12:56 PM #2
      immediatly to the right of the starter.
      Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
      ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
      www.KansasCityTdi.com
    3. 08-28-2009 01:11 PM #3
      Thanks Richard!
      isnt the starter a part of the engine? How do I see the starter to begin with?..I opened the hood and looked...I can see a cover on top of the engine...cant read it from outside as the cover seems to be getting in the way.... ...Do I have to open the cover by removing the screws on top of it?
      Thanks,
      Aby
    4. Member CoolAirVw's Avatar
      Mar 8th, 2007
      08-28-2009 02:38 PM #4
      Cant find the starter????
      Its bolted to the trans, torward the front of the car. Trans is on left side of car, under breather/battery area.
    5. 08-31-2009 12:49 AM #5
      I just cant the three letter code for mine...vw part number for mine is 01m 300 032 LX
    6. 05-23-2012 11:12 AM #6
      I have a 2001 tdi, should the code be in the same spot? Looked to the right of the starter and can't see it.
    7. 06-14-2012 03:38 PM #7
      Try this site for location of transmission codes:
      http://www.zelek.com/trany_data.htm
    8. Member CoolAirVw's Avatar
      Mar 8th, 2007
      06-15-2012 01:43 PM #8
      Quote Originally Posted by deanstoneburner View Post
      Thats a nice link for manual transmissions... This is the auto trans section.
      Try this link for auto trans.
      http://www.kansascitytdi.com/01m%20faq.htm
      You'll have to scroll down a bit.
    9. 02-25-2017 08:35 PM #9
      Ok so I am having the bump and flare issue with the 09G Transmission
      I bought a new transmission and I want to be sure that is compatible with my car
      My VIN is: WVWEK73C56P126143 and i have been told by the dealer that based on my VIN my Transmission is the 09G with code is HRN (Hotel Romeo November)
      The transmission that I purchased based on the VIN (WVWAK73C36P069925) says that it's the 09G with Code HRN as above. I have confirmed that it's the 09G but I can't find code HRN anywhere.......
      Does anyone know where this code is located ?
