Page 1 of 5 1 2 3 ... LastLast
Results 1 to 35 of 166
Thread: A3 GT3071r build at A&L Performance
  1. Member LEWXCORE's Avatar
    Jul 6th, 2007
    Miami/Ft.Laud
    07 Audi A3
    08-29-2009 03:03 AM #1
    I've been piecing the kit together for a while now and getting the car ready for a big turbo setup. Hooked up with Luis @ A&L to install the turbo kit and rods and they finished up today, everything's running real good.
    Unitronic Tune
    South Bend stage 5 clutch
    GT 3071r
    Integrated Engineering rods with calico coated bearings
    ATP turbo kit
    Forge 007 DV with ATP re-route
    RS4 Injectors
    APR fuel pump coming soon
    W/M injection dual nozzle
    Eurojet FMIC kit
    Tial 38mm wastegate- open dump
    Greddy Profec B Spec 2 Electronic Boost controller
    AEM wideband
    N2MB WotBox (flat shift ftmfw)
    BSH motor mounts
    Cell Phone pics.
    Most boost I've run on the setup so far is 28 lbs and I had about an 11.9-12.0 AFR between the RS4 injectors and the meth injection.
    453WHP at 27psi
    466WHP at 29psi
    Two big thumbs up for A&L Performance & Unitronic.
    Modified by LEWXCORE at 3:23 PM 2-1-2010
  2. 08-29-2009 04:05 AM #2
    Dam nice, cant wait to see some numbers!
    pretty sweet setup there in the back seat
  3. Member LEWXCORE's Avatar
    Jul 6th, 2007
    Miami/Ft.Laud
    07 Audi A3
    08-29-2009 04:09 AM #3
    Thanks. I'll report back here as soon as we get some numbers on this baby.
    Instead of lightweight racing seats in the front, I have a light racing bean bag in the back lol. Passengers seem to enjoy it so far, thinking about maybe going big and getting another beanbag.
  4. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    08-29-2009 06:28 AM #4
    if u are ever up near Orlando, hit me up. id love to see this puppy pull.
    btw, balling beanbag man. lol
    nice build.
    btw, what did this all set u back?
    and one last question: N2MB WotBox < wtf? what is this? never heard of it.
    2006 Audi A3 | 2.0T | 6MT | APR Stage 2 | Fully loaded ECU | FK grill | Neuspeed P-FLO | EJ TBP |EJ DV Reloc.| ECS Dogbone Insert | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar pads | Neuspeed Sport Springs | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Water/Meth kit |
  5. 08-29-2009 11:16 AM #5
    Beautiful car!
    Hey, quick question about the Uni tune, how does the car idle? Silky smoothe I hope
  6. Member LEWXCORE's Avatar
    Jul 6th, 2007
    Miami/Ft.Laud
    07 Audi A3
    08-29-2009 12:03 PM #6
    Lol ok..i visit some friends of mine sometimes at UCF so maybe
    well, i bought:
    ATP kit and injectors used from jc@douglas,
    turbo, clutch, boost controller, FMIC, DV, all used local.
    so i saved alot of money in the end but still when all was said and done it cost me at least a nice 5k to get to this point.
    Quote, originally posted by Krieger »
    google is your friend bro. http://www.npcompleteperformance.com/wotbox
    2-step and flat shift. Holding boost while switching gears on a Manual Transmission is sweet, especially on a larger turbo
  7. Member LEWXCORE's Avatar
    Jul 6th, 2007
    Miami/Ft.Laud
    07 Audi A3
    08-29-2009 12:20 PM #7
    The Unitronic tune is great! I'm so glad I went with uni in the end. Idle is very smooth, runs nice and lean when cruising.
    I averaged about 36-37 mpg at 75 mph on the highway yesterday.
    And the tune is just asking for as much boost as I want to throw at it.
    I was running revo stage 2+ before and the upgrade to a big turbo file would have been pretty cheap.
    But ultimately biting the bullet on the Unitronic tune to make real power was so worth it.
    Coming this far and having a revo file that limited the setup to stock rods safety territory was not happening for me.
    No hard feelings for revo though. chris@revo has been very helpful whenever I had a question about anything. And my stage 2+ car with ripping on everyone elses stage 2+ car with revo
  8. Former Advertiser
    May 28th, 2009
    08-29-2009 01:20 PM #8
    nice dude we need to post some dyno vids
  9. 08-29-2009 02:59 PM #9
    Quote, originally posted by LEWXCORE »
    shoulda coulda woulda
  10. 08-30-2009 01:34 AM #10
    Congrats!
    You got the same BT setup as me, and i have the unitronic BT software as well.
    It would be better to see some data log here, do you log CF(020)? does the timing retard much? and wht fuel do you run?93 or 91?
    My tune from mike is getting too much cf retard, like -7, -8. i put shell vpower already, it still got the same retard number. Now Mike is asking me to get a meth kit to solve the problem.
    i just want to know if you get the same problem as we have same BT setUP.
    Enjoy your cAR~!
  11. Former Advertiser
    May 28th, 2009
    08-30-2009 09:59 AM #11
    Quote, originally posted by smartyin »
    Congrats!
    Enjoy your cAR~!
    how much boost are you running, any faults, I had the same problem and it was a intank apr pump that failed on me
  12. Member LEWXCORE's Avatar
    Jul 6th, 2007
    Miami/Ft.Laud
    07 Audi A3
    08-30-2009 11:13 AM #12
    Congrats!
    Enjoy your cAR~!
    I always run 93 octane and water/meth which raises the octane more obviously. The meth will defiinitely help.
    We're planning on doing some logs soon at the shop and then we'll see what's going on with the car.
  13. 08-30-2009 11:22 AM #13
    Quote, originally posted by Luis@ALP-racing »
    there have 2 DTC i always got, for the N249 Code below is solved already. For the system too rich wolud come one times aweek..
    i think after i get the meth kit, the rich code would be solve.
    008568 - Bank 1; System Too Rich off Idle
    P2178 - 002 - Lower Limit Exceeded - Intermittent
    008801 - Boost Pressure Control Valve (N249): Mechanical Malfunction
    P2261 - 008 - Implausible Signal - Intermittent
    For the boost, i was running 23 psi, but for safety, mikez just advised me to run 15psi before i get meth kit. but i don't feel it is much better than runing 23psi.
    I don't know if it is the pump fail like you, but mikez is quite firm the CF retard is related to the fuel qulity(i am runing shell V-power already).
    Anyway, i ordered a apr fuel pump already, and i am runing AWE rebuil kit.
    Modified by smartyin at 8:27 AM 8/30/2009
  14. 08-30-2009 11:26 AM #14
    Yes, looking for your log. it is very important to data log to make sure your car is happy with the software. because i felt my car is very strong and power with first software from mike, after i logged it, it it got alot DTC and is too rich...(CF retard get me crazy...)
  15. Former Advertiser
    May 28th, 2009
    08-30-2009 03:28 PM #15
    run it of the wastegate spring first see how boost u got, fix ur faults first then run logs if u have a chance send me some logs I can help I fix some of ur problems
  16. Member eatmorice's Avatar
    May 8th, 2009
    MIAMI, FL
    08 GTI
    08-30-2009 07:25 PM #16
    one question how do you like the ATP kit?// does it come with intructions like the Apr gt28 kit. im thinking bout piecing one of these together in my garage hopefully next summer....
  17. Member LEWXCORE's Avatar
    Jul 6th, 2007
    Miami/Ft.Laud
    07 Audi A3
    08-30-2009 08:09 PM #17
    Quote, originally posted by eatmorice »
    I don't know, I bought it used from another member and did not include instructions. Like i wrote in the OP, the install was done by A&L.
    The ATP kit is good for my goals. The cast log-style manifold is not the greatest thing in the world, but it does the job and still makes power.
    One thing to note is that the oil return line that runs right under the turbo is prone to failure from all the heat. Previous owner of my kit replaced his with that blue heater hose you see in the picture of the turbo kit all over the floor.
    Lastly, the only thing that's concerning me for now is under-hood temps. this thing gets real hot under the hood for now and I'm considering getting a turbo blanket or something before things melt.
  18. 08-31-2009 12:24 AM #18
    could you PM your email address? i would like to send you some logs.
    and i tried to run off the EBC, it can reach up to 2 bar....scary
  19. Former Advertiser
    May 28th, 2009
    08-31-2009 12:35 AM #19
    info@alp-racing.com
  20. Member LEWXCORE's Avatar
    Jul 6th, 2007
    Miami/Ft.Laud
    07 Audi A3
    08-31-2009 12:48 AM #20
    A little update:
    I'm noticing things getting pretty damn hot under the hood after running the car hard, so once I get some more funds together for the car i'll probably be getting something like this to keep those underhood temps down.
    Had some free time tonight so I wrapped up the downpipe and dump tube with some exhaust wrap I had laying around in my garage. Best i could do with jack stands by myself and used exhaust wrap, but it didn't come out too bad
  21. Former Advertiser
    May 28th, 2009
    08-31-2009 10:29 AM #21
    A little update:
    looking good
  22. Senior Member MFZERO's Avatar
    Mar 13th, 2002
    Haverhill, Ma.
    1987 Audi 4000csq, 2000 Haro Blammo
    08-31-2009 11:52 AM #22
    nice dude!
    nek.cbs.csd Broke.Down '10
    That retahd pahked right on tawp of that othah cah.
  23. 09-01-2009 12:52 AM #23
    i just came
  24. Member Amsterdam087's Avatar
    Dec 31st, 2007
    Turbo Scirocco, Wide Body Celica, 32 Stude, and a Jeep
    09-03-2009 05:31 PM #24
    keep the updates coming guys. good work!
    » ...George Straight is my co-pilot
  25. Member skateboy918's Avatar
    Apr 26th, 2008
    Boston, MA
    07 Fahrenheit GLI (REVO K04)
    09-03-2009 11:23 PM #25
    what intake is that?
  26. Member LEWXCORE's Avatar
    Jul 6th, 2007
    Miami/Ft.Laud
    07 Audi A3
    09-04-2009 02:02 AM #26
    Quote, originally posted by skateboy918 »
    That's the ATP 3" intake that comes with their big turbo kit. The little piece that turns towards the fender at the end is a little custom bit that jc@douglas added to it.
  27. 09-04-2009 10:15 AM #27
    surprised arin@apr hasnt tried to sell you some software lol
  28. 09-05-2009 11:34 AM #28
    hit the dyno yet?
  29. Member LEWXCORE's Avatar
    Jul 6th, 2007
    Miami/Ft.Laud
    07 Audi A3
    09-05-2009 09:02 PM #29
    No man, the weather's been terrible this past week haven't even thought about going down there yet. Hopefully will go this coming week. Will keep you guys posted for when I get the dyno done.
  30. 09-06-2009 05:28 AM #30
    Nice build
    Same turbo-kit im running on mine
    It really kicks ass - and not many can follow you!
    Mine made 500+HP and 475+LB/FT on pure 93octane without meth
    So get this baby measured asap!
  31. Member LEWXCORE's Avatar
    Jul 6th, 2007
    Miami/Ft.Laud
    07 Audi A3
    09-06-2009 11:25 AM #31
    Quote, originally posted by marc1171 »
    Nice build
    crank horse power or to the wheels? Is it even safe to run that much boost with no meth or race gas?? sounds dangerous man..I'm shooting for 450whp. Doubt I will make 500WHP unless I can get a file to run more aggressive timing and run at least 28+ psi. I wonder if fueling will allow for that though.
  32. Member rracerguy717's Avatar
    Apr 8th, 2003
    NYC northern suburbs
    06 VW GLI
    09-06-2009 11:59 AM #32
    IMO I dont think there more that 430ish whp fueling with rs4 injectors and upgraded intank pump and or course a HPFP upgrade unless you use a secondary fueling source .
    This is with a Safe A/F with aggressive tune. Bob.G
  33. Member
    Sep 13th, 2008
    Germany
    07 MKV GTI
    09-06-2009 12:40 PM #33
    I read of 470whp limit of rs4 and APR injectors.
    marc reached 500 crank hp as far as I know and could go 2 bar because of dropping the CR to 9.5:1.
    BTW: "APRs" Supercopa killer made more than 430 whp without a secondary fueling source. The only thing I don´t understand how the lpfp can be able to support 500hp ?! I have seens K04´s with fueling issues when fuel tank was more than 1/2 empty.
  34. Member LEWXCORE's Avatar
    Jul 6th, 2007
    Miami/Ft.Laud
    07 Audi A3
    09-06-2009 12:46 PM #34
    the intank doesn't have to be changed to make that much power if you're on stock compression.
    people make more than 430 with rs4's and meth, before the in-tank solution or any 5th injectors. Remember that the water/meth injection richens up the ratio as well.
  35. Member
    Sep 13th, 2008
    Germany
    07 MKV GTI
    09-06-2009 12:47 PM #35
    I think we talked about pump gas only...
