VWVortex.com - Jetta Headlights not working
    Results 1 to 12 of 12
    Thread: Jetta Headlights not working
    1. Member piran21's Avatar
      Jul 28th, 2004
      GTA
      BRM, C30A
      09-01-2009 11:42 PM #1
      Wondering if someone had knew why the headlights on my jetta would all of a sudden not turn on. No, it's not a fuse. The car was driven for a week or so. There was some strange noise coming from the left side of the dash but not sure what it was. So, it's not a fuse, what else could cause it?
    2. Member deletedo1m's Avatar
      Jul 9th, 2007
      WC,PA
      97 TR jetta, 87 jetta, 81 caddy, 95 cbr600
      09-02-2009 06:27 AM #2
      Left side of the dash maybe coming from the area of your headlight switch? Just a thought.
      Give wildlife a brake! 4TSQ. WV, Almost Heaven. Where are the moose? Save the Frogs!. Save the whales. I birds. Iron City
    3. Member piran21's Avatar
      Jul 28th, 2004
      GTA
      BRM, C30A
      09-02-2009 09:19 AM #3
      To further clarify the situation. When I first started the car, the stereo powered on, then when i released the handbrake, it suddenly turned off, then powered on. When i tried to adjust the volume it kept turning on and off. And I am talking about the stereo. I'm wondering if this is someway related to the lowbeams which are the only lights not working on the car. Parking lights, high beams, turn signals and fogs all work.
    4. Member
      May 24th, 2005
      NJ
      97 Jetta GT, 12 Turbo Beetle
      09-02-2009 09:34 AM #4
      why not disconnect the radio and see if it helps you out.
    5. Member piran21's Avatar
      Jul 28th, 2004
      GTA
      BRM, C30A
      09-02-2009 09:42 AM #5
      Well after starting to drive for a bit, the stereo stopped doing the powering on/off thing and stayed on normally. Everything seems fine except the low-beams don't work now.
    6. 09-02-2009 09:44 AM #6
      My guess is the ignition switch for ur stereo related problems. Might not cause the same problems with ur headlights tho.
      May 24th, 2005
      NJ
      09-02-2009 09:50 AM #7
      does the dimmer work on the switch for the dash lights
    8. Member piran21's Avatar
      Jul 28th, 2004
      GTA
      BRM, C30A
      09-02-2009 09:58 AM #8
      Stereo is fine now. No issues.
      Dimmer works fine.
      May 24th, 2005
      NJ
      09-02-2009 10:36 AM #9
      did you atleast check the bulbs, i know it seems unlikely for both bulbs to go at once but stranger things have happened.
    10. Member piran21's Avatar
      Jul 28th, 2004
      GTA
      BRM, C30A
      09-02-2009 10:50 AM #10
      They are HID's but not cheap ones. So I really doubt it. Philips Ballasts and 4300K bulbs.
    11. Member
      May 24th, 2005
      NJ
      09-02-2009 11:02 AM #11
      you could try swapping out the headlight switch with one from a friends ride to eliminate that as a fault. other than that i dont know what else there is that would affect the headlights.
      fuses - good
      bulbs - good
      balast - ??
      headlight switch -- ??
      ignition switch -- ??
    12. Member sun98gtiVR6's Avatar
      Jan 7th, 2007
      Milwaukee Wisconsin
      2013 SB GTI Autobahn 2dr 6MT
      09-02-2009 11:05 AM #12
      check for power at the headlight plugs
