Page 1 of 2 1 2 LastLast
Results 1 to 35 of 39
Thread: How To: NAVTV's AllGIG-USB HS Install in a 2009 Routan - Video and Nav input in motion !
  1. Moderator 71sbeetle's Avatar
    Apr 12th, 2002
    West Palm Beach, Florida
    1971 Super Beetle, 2010 Golf TDI, 2012 Jetta TDI
    09-02-2009 10:04 PM #1
    The one thing that bothered me most on my RER radio was the fact that you cannot enter an address in the GPS while in motion ! Although I do not recommend the driver doing it, I don't see why a front passenger couldn't do it.
    There are 2 companies out there that offer a product to correct that, and more.
    Coastaletech's Lockpick 2.0 (www.coastaletech.com)
    NAVTV's AllGIG-USB HS (www.navtv.com)
    I chose the AllGIG USB over the Lockpick for a few reasons:
    * It's firmware is USB upgradable (Lockpick 2.0 is not user upgradable)
    * The options are selected with a computer via supplied USB cable (manual with dip switches on Lockpick)
    * They are local to me, and I was able to pick up the unit directly from them. I also met the owner (didn't know he was the owner till later when I got his card, real cool down to earth guy) and he showed me around the place, what I liked most about the place is the "family" atmosphere for their employees, no BS involved.
    Anyway, so I went in, got my AllGIG-USB HS (high speed CAN Bus) and drove home to install it. The whole install from start (walking into my garage) to finish (walking back into the house) took me less than 10 minutes, and I must have spend 2-3 minutes looking for a flashlight (which I ended up not using) and I was taking a few pics (which are not the best I know, point and shoot ).
    Anyway, enough with the talking, here is the How To:
    Here is the box the unit comes in, nice and simple:
    A shot of the unit itself, notice how small it is:
    And a shot of the plug and play adapter:
    Here is the radio you will be working with, mine is an RER, Touchscreen Navigation:
    What you need to do is remove the radio surrounding trim, it is quite easy, only 4 metal tbs are holding it in, you can start from the bottom (as shown) or from the top:
    Get it loose all around and pull it off:
    Here it is with the trim off, easy wasn't it ?
    Here is a shot of the back of the trim so that you can see the 4 locking tabs, one on each side and two on the top:
    Now, if you look on each side of the radio, you will see 2 screws (4 total):
    Take those screws out and pull the radio out (it's a tight fit, don't be afraid of pulling it):
    On the back of the radio, there are 6 connectors. The one that we need to look for is the gray one on the far left (driver's side):
    Unplug it from the radio (little locking tab on the bottom of the plug) and plug that into the female end of the plug and play adapter (notice I disconnected all 6 plugs, it was to make it easier to take pics and not have to hold the radio, but all you need to remove is the gray plug):
    Then plug the male end of the plug and play adapter into the radio (where you just took the plug out from), and plug the smaller white plug of the plug and play adapter into the NAVTV AllGIG-USB HS unit:
    And then tuck the unit just under the metal frame that supports the radio, it fits in there perfectly with room to spare:
    Then slide the radio back in, re-install the 4 screws (do not overtighten them) and clip the surrounding trim back on ... that's it ! It's in !
    And now enjoy the movie in motion, address input in motion, turn the camera screen on even when driving forward (great to check out what you are towing, or the cop behind you, or even that hot chick in the car behind you at the light lol)
    You can also add a second camera (baby camera, front bumper camera to help when parking nose first, or if you are super rich, buy a FLIR night vision camera), and if you don't have VES (RSE) then you can add a DVD and 2 AUX (with optional A/V cable) !!!
    This How To is for informational purpose only, install this at your own risk, I am not responsible for any damage or anything that occurs when you are doing this install, blah blah blah blah blah
  2. Member jsmyle1%...'s Avatar
    Jun 6th, 2006
    '89 Cabriolet, His & Hers '13 Passat SEL TDIs
    09-03-2009 08:19 AM #2
    Verrrrry Niiiiiiice, verrrrrry niiiiiiice........
    Can't wait to see the step-by-step install in person.
  3. Member GTI-2007's Avatar
    Mar 26th, 2008
    Ottawa, ON
    2002 NB GLS TDI, 2007 GTI, 2009 VW Routan Execline, 2012 Passat Highline TDI sport navi
    09-03-2009 08:37 AM #3
    Great pics! and thank you.... I will be doing my install tonight! We pick up our Routan today finally!!! Like you, I could have driven to port twice to pick it up myself in the time it took to get here.
  4. Moderator 71sbeetle's Avatar
    Apr 12th, 2002
    09-03-2009 08:52 PM #4
    I just installed one in jsmyle1%...'s car today, we timed the install from when I entered the car to until I got back out, it took me 3 minutes and 15 seconds !
  5. Member 2008cc's Avatar
    Apr 16th, 2001
    Charlotte, NC
    01 Audi Avant, 09 VW Croutan, 75 Dodge Dart "Hang Ten"
    09-03-2009 09:15 PM #5
    so does that add navigation to your radio? or just bypass the safety features? I have the same looking radio just no navigation
    Chapter 11 Dubs - 054
  6. Moderator 71sbeetle's Avatar
    Apr 12th, 2002
    09-03-2009 09:19 PM #6
    no, it does not add navigation, here is what it does:
    Enables video in motion.
    Enables navigation entry in motion.
    Enables VES display in motion.
    The following features are available with the purchase of optional components: Enables Bluetooth and voice recognition on RER radios. (Requires microphone assembly, sold separately)
    Enables automatic backup camera input when in reverse. (Requires GIGCam or AV harness + Camera)
    Enables VES Emulation mode for auxiliary audio/video input. (Requires AV harness)
    Enables a full-time video input for a front or rear camera or FLIR night-vision system. (Requires AV harness & optionally, a video switch for a second camera)
    Enables a video output to display built-in DVD image on aftermarket monitor(s). (Requires AV harness)
    Enables an external navigation display input for international use. (Requires AV harness)
    Installation Manual
    http://www.navtv.com/userfiles...B.pdf
  7. Member GTI-2007's Avatar
    Mar 26th, 2008
    Ottawa, ON
    09-03-2009 10:34 PM #7
    Did mine tonight, what a simple procedure. I had it done in less than 5 minutes! The hardest part was tucking the box away behind the dash.
    works like a charm, well worth the money for the NAV in motion feature alone which is why I really bought it.
  8. Moderator 71sbeetle's Avatar
    Apr 12th, 2002
    09-04-2009 10:28 AM #8
    both of the installs I did the box slid right under that support bar.
    but same here, that's the #1 reason for me too, nav in motion.
    and I am also thinking about adding a baby cam too.
    I also have to take the factory rear cam and bring it over to NAVTV, we're going to look for a direct fit replacement that creates a better image.
  9. Member GTI-2007's Avatar
    Mar 26th, 2008
    Ottawa, ON
    09-04-2009 12:47 PM #9
    If you find a better reverse cam image I'd love to know. I find the image very fuzzy. There was another post about there being an adjustment hole under the lens bezel, which I can see, but I have not tried that yet. I'm also looking at putting in the baby cam as well.
    I put the box just off to the side near the glovebox area, and I wrapped it in a little packing foam to avoid plastic on plastic noises or vibrations. Seems to work great!
    Modified by GTI-2007 at 10:45 PM 9-4-2009
  10. 09-04-2009 08:15 PM #10
    How much dows that thing cost?
  11. Member GTI-2007's Avatar
    Mar 26th, 2008
    Ottawa, ON
    09-04-2009 10:46 PM #11
    I got mine on eBay for $199 USD with free shipping.
  12. Member Whataguy's Avatar
    Sep 5th, 2003
    Far East of the Western world - St. John's Newfoundland CAN A1B1C2
    10 Golf wagon highline (lowered 1" with GTI suspension, 17" Goal wheels, RNS-510)
    09-04-2009 11:56 PM #12
    I have not seen any NATV's on eBay, just Lockpick - is that what you mean?
    NATV is $289 versus $189 for Lockpick (eBay). Paying the extra $100 for NATV's unit gives you future programmability via the USB (and gives you a graphical user interface on a PC via a USB connection - versus selecting dipswitches on the Lockpick).
    The MyGig functions are likely not going to change significantly for a few years so the requirement for modifications will likely be remote. An extra program/version upgrade in the future is likely going to cost something. Considering this, and considering both units provide almost identical features, it seems the $189 lockpick may be a better value?
    Modified by Whataguy at 12:59 AM 9-5-2009
  13. Member GTI-2007's Avatar
    Mar 26th, 2008
    Ottawa, ON
    09-05-2009 08:45 AM #13
    Sorry for the confusion. I installed a Lockpick 2.0 TVandNAV2GO which I purchsed off of eBay for $199 shipping included. Delivery next day, and simple installation that took less than 5 minutes. Best $199 ever! Unlocking the NAV in motion alone was worth it.
    Modified by GTI-2007 at 4:57 PM 9-5-2009
  14. Moderator 71sbeetle's Avatar
    Apr 12th, 2002
    09-05-2009 09:45 AM #14
    Maybe the lockpick 2.0 case a is a little bigger than NAVTV's which is why you couldn't fit it where I fit mine ?
    What scare me the most about Lockpick was customer service, even as a potential buyer they didn't help me out ...
    Anyway, yes the AllGIG is listed at $289, I got mine for less thru them because I bought a few units at once for a few local Routan owners, so if you guys did a group buy you could save on them
    http://www.navtv.com/product/9...uct=1
  15. Member GTI-2007's Avatar
    Mar 26th, 2008
    Ottawa, ON
    09-05-2009 04:50 PM #15
    Hard to tell, judging by the units they are similar in size. However, I did wrap the lockpick in a foam packing which did add size. I just didn't want any annoying vibration noises coming from under the dash. I didn't buy my lockpick from Coastaltech direct, I bought it from a dealer on eBay who actually answered all my questions within an hour, and were very quick to ship and email me the instructions once purchased. I don't think you can go wrong with either unit. I did like the fact that you could upgrade the NAVTV unit via USB, but given my propencity to change cars every few years, I'll likely trade the Routan in 3 years once the kiddos get older and we can get into a 7 passenger next gen Touareg. Mind you I have to say, not being a van guy, this van rocks!
  16. 11-07-2009 04:47 AM #16
    thanks
  17. 01-24-2010 10:29 AM #17
    I just purchased a 2009 Routan. It is an SE with RSE. I didn't realize that you could get NAV TV with this system. My system does not have the Navigation feature though. Can you still install this unit in my van to get SAT TV? I imagine you will have to get the antenna and so forth, but will my VES accept this upgrade to get TV?
  18. Moderator 71sbeetle's Avatar
    Apr 12th, 2002
    01-24-2010 11:41 AM #18
    NAV TV is the brand. This unit allows you to enter addresses in the navigation while in motion, it also allows you a few other things like video in motion, enable rear view camera while going forward (to check on a trailer for example), etc ...
  19. 01-24-2010 12:02 PM #19
    Does it also allow you to watch television. In the multimedia manual it says that you can watch Television with TV Siris Backseat TV, if so equipped. I am assuming that feature is available with the NAV package as I don't have that and I don't have the backseat TV option on my display.
  20. Moderator 71sbeetle's Avatar
    Apr 12th, 2002
    01-24-2010 12:12 PM #20
    yes it will let you add monitors, and you would need a sat tv receiver and antenna too
  21. 01-24-2010 12:15 PM #21
    Thanks, I will look at what the satalite reciever and antenna would be $$.
  22. Junior Member
    Aug 30th, 2004
    NoVA
    07 B6 Wagon 09 Routan SEL
    04-16-2010 04:30 PM #22
    Anyone try the new v3.0 on the routan?
  23. 08-18-2010 11:17 AM #23
    I did, works like a charm!
  24. Moderator 71sbeetle's Avatar
    Apr 12th, 2002
    08-21-2010 04:11 PM #24
    v3.0 of what ?
  25. 09-21-2010 08:04 PM #25
    Hello,
    Has anyone tried this with a 2010 model?
    I already have the bluetooth with the stock nav unit, this won't change the stock settings other than allowing the in motion up grade will it?
    Thanks for the help.
    -Q.
  26. Moderator Raring 2 Go's Avatar
    May 22nd, 2000
    Richmond, VA
    '08 GTI
    01-17-2011 05:04 PM #26
    Quote Originally Posted by quattro1.8t03 View Post
    Hello,
    -Q.
    I had that question. Reading the setup .pdf made it unclear. For instance, it defaults uconnect to "off" and requires a mic be installed if you turn it on. However, I assume that is if you don't have uconnect to start with.
    I thought how much can FLIR be...then I found the pricing on NAV TV. Yikes.
  27. 01-19-2011 12:04 PM #27
    Anyone know which one is best for my RER version (2010 SEL Nav radio).
    http://navtv.com/search.php?phrase=mygig
    Options:
    ALLGIG-USB-HS , AllGIG_XG-HS or AllGIG_XG-FT
    Separate question - the new mygig allows for Bluetooth streaming - any chance this unit will allow that in the future? Perhaps Lockpick is trying to offer - either way, that would rock.
    Thanks everyone.
  28. Member
    Jun 27th, 2007
    58 Ragtop Bug, 2005 Passat Wagon, 2010 Routan SEL
    01-20-2011 01:13 PM #28
    There is also the LockPick from Coastal tech
    http://www.coastaletech.com/MYGIG.htm
    And this one if your a super iPhone user. Gives you more interface than any other out there
    http://www.coastaletech.com/CHR550.htm
    Coastaltech's website seems to answer more of your questions. I'll eventually be getting the lockpick to add to ours.
  29. Moderator Raring 2 Go's Avatar
    May 22nd, 2000
    Richmond, VA
    '08 GTI
    01-20-2011 10:57 PM #29
    Quote Originally Posted by 58kafer View Post
    Wife would love the iPod compatibility. We've had ours for less than a week and I was curious tonight if I could bluetooth stream music from her iPod to the stock RER. No go, I guess.
  30. Member Indigo20v's Avatar
    Mar 6th, 2002
    The Woodlands
    2010 Routan SE, 2007 Forester Sports XT 5MT
    01-21-2011 08:57 AM #30
    There's always the option (potentially) of swapping the RER for the latest stock one from a 2011 that will allow BT streaming. The lockpick will still be needed for destination entry and backup camera while in motion.
    Anthony
  31. 04-15-2011 07:34 PM #31
    Got the lockpick and installed it tonight. It was very easy to hook it up to allow video in motion and nav in motion. However, to allow the viewing of the backup camera anytime it states: "If you would like to enable ful control and viewing of you FACTORY REAR VIEW CAMERA while in drive or other gears, the included REVERSE CAMERA POWER output wire must be connected as the power source for your camera."
    Has anyone done this or seen instructions (more than the documentation that comes w/ the lockpick) or a video on how to hook this power wire up to the factory camera?
    Thanks for any information you can provide!
    jc
  32. Member
    May 30th, 2012
    Chicago, IL
    2011 Volkswagen Routan SEL Premium
    06-01-2012 05:29 PM #32
    Lockpick v4 is out and $199 on ebay. It has USB updates available, so Lockpick seems like the winner.
    I'll probably get the CHR550 LOCKPICK to use my iPhone.
  33. 06-04-2012 05:02 PM #33
    Quote Originally Posted by Chedman13 View Post
    The CHR550 is on the internet for as low as $242 now (Google it, not sure about the vendor that has it for $242) , so I'd definitely get the CHR550. The extra features are worth it. $289 at Amazon.
  34. Member
    May 30th, 2012
    Chicago, IL
    06-08-2012 05:09 PM #34
    I'm seeing reviews of some issues with eBay or online sellers. I might just spend the extra $$ and buy direct not to worry about anything.
    2011 Calla Lily White Volkswagen Routan SEL Premium
  35. Member
    May 30th, 2012
    Chicago, IL
    06-12-2012 03:15 PM #35
    In case anyone is getting a fuzzy picture on any screen, it's because you have an old harness and need a new re-designed one from Costaletech.
    It happens on the rear two screens. I'd buy new, direct to be safe again.
