Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 79
Thread: 16VG60 Edition One Project
  1. 09-06-2009 09:53 AM #1
    I own a 1990 Golf G60 edition one. pics and spec below. But i have always wanted to make it proper mint and turn it into a 16vg60 in edition one spec.
    Engine
     1.8 8v G60
     Stage 4 supercharger
     68mm pulley
     Chip
     Stainless steel custom exhaust
     De-cat exhaust
     Jabbasport induction kit
     New engine and gearbox mounts
    Exterior
     Standard mk2 golf G60 body
     Smoked crosshair crystal headlights
     Smoked LED indicators
     Smoked crystal fog lights (to be fitted soon)
     Smoked crystal M3 rear lamps
     Colour coded wiper arms
     Lay flat rear wiper
     Wolfsburg edition badges
     Chromolux glass
     Cl grill with black vw badge
     Wolfsburg number plate surrounds
     Porsche polished handles
    Chassis
     BBS RM split rims with 2” stainless outers, centers powder coated black
     G60 steels
     SPAX RSX coilovers
     Poly bushes
     Brembo discs
     Pagid fast road pads
     New suspension top mounts
    Interior
     Blue electric cloth RECARO seats
     Wolfsburg gear dangling rhubarb
     Wolfsburg door pins
     Mk3 chrome door pulls
     Boost gauge mounted in fischer centre console
     MPH speedo conversion
    ICE
     kenwood dvd headunit
     kenwood 12" sub
     kenwood 4 channel amp
     kenwood 2 channel amp
     kenwood components 6"
     kenwood bluetooth kit
    I am really worried i will get things wrong so i have labeled every single electrical connection, and bagged and tagged every single nut, bolt and washer. All the nuts and bolts will be replaced with new ones or zinc plated were i cant get replacments.
    engine has been pulled (my mate thought it would look good with a audi employee in the pic) :roll:
    most of the interior is out along with the dash and the front suspension is in bits.
    Currently colllecting all the bits that need cleaning, blasting and powdercoating to get the rolling front chassis put together so i can turn the car around and do the back end, when all thats done it will go off to be repaired and paint.
    sand blasted and zinc primered parts
    cleaned, etched primed and undersealed arches
    sound deadened front footwells and dash area
    bush set after i cut the old ones out the wishbones
    and this is what £500 worth of genuine VW parts look like, pathetic really
    Quick list of new parts
    Gearbox end plate
    power steering fluid res
    all suspension bolts
    most engine bolts and nuts
    driveshaft bolts
    rain tray
    brake clips
    side skirt brackets
    coolant flanges
    all new sensors
    gaskets
    ecu hose
    cross member rubbers
    ARP head studs i there too
    Still got a ton to get, so happy about changing everything, should be like a new car
  2. 09-06-2009 10:20 AM #2
    what did you use for sound deadening?
    Quote Originally Posted by -teknien- View Post
    weighing babies in grams is funny......
  3. 09-06-2009 10:24 AM #3
    sound X material from Ebay
  4. Member quadcammer32's Avatar
    Jan 20th, 2007
    NY
    GTI VR-T, mk2 jetta coupe
    09-06-2009 11:59 AM #4
    i want your recaros
  5. Member VW 16v's Avatar
    Dec 3rd, 2002
    Bethlehem, PA
    09-06-2009 12:33 PM #5
    cant wait to see this motor get built
  6. Senior Member Jman5000's Avatar
    Nov 8th, 1999
    Columbus Ohio
    VW & Audi
    09-06-2009 03:16 PM #6
    Drool-inducing. I can't wait to see updates.
    Many for going all the way to the base parts and doing everything right/better than stock.
    For the Firevortex users that like to use "in" to get a thread added to their watched topics: this thread would be great time to try the "watch this topic" button instead.
  7. 09-06-2009 03:29 PM #7
    In for updates
    Jul 2nd, 2009
    SoCal
    09-06-2009 04:40 PM #8
    Wow, nice car! to you.
    And I used my "watch this topic" button! I feel cool now
  9. 09-06-2009 08:17 PM #9
  10. Member YooFatBoy's Avatar
    Jun 27th, 2009
    SEPA
    mk3 vr gti-current
    09-06-2009 08:27 PM #10
    lookin good
  11. 09-06-2009 11:47 PM #11
    Keeping an eye on this
  12. 09-07-2009 02:48 PM #12
    Thanks for the support everyone
    Not a good evening
    found this
    but managed to finish the engine bay
    also picked these up from the blasters
    and my home recon'd starter motor
    Also had the guy thats painting the car round to have a proper look at the motor, pretty sure he can blow my socks off with the end result, sounds reassuring.
    off to VW agian tomorrow to pick up VR6 sachs clutch, brand new door seals, HT lead guide tube, and all manner of parts to rebuild the gear selector tower. think i need therepy.
    thanks for looking
  13. 09-07-2009 03:41 PM #13
    Quote, originally posted by editiononeg60 »
    Not a good evening
    found this
    Thats never a good sight..
    Talk about a major setback. If you found a little, there is always more.
  14. Member mk2gtd's Avatar
    Sep 17th, 2007
    Halifax, NS, Canada
    '91 GTD + '96 24v VR6
    09-08-2009 12:18 AM #14
    ^^ true. time to deal with the rust before all else.
  15. 09-08-2009 06:19 PM #15
    cheers guys
    will need to put the front on its wheels first then turn around to get to the back end, then i can get a proper veiw and sort it out.
    Before my car came off the road to be stripped down a problem developed with the ABS system, like it wern't working.
    I stripped it down to find the cable feeding the motor on the pump had become broken from the terminal of the motor. Some solder and a test across the terminals from a battery and it worked. yeehaa
    next i saved myself a few quid by rebuilding the clutch master cylinder, found nothing wrong at all, so painted, lubed and rebuilt. all ok.
    I managed to deliver all the parts i had sandblasted to the powdercoaters about 11am. Then to my surprise the guy called me at 5pm to say all my stuff was ready to pick up, said its because he new i only had one day off, sweet.
    Front chassis rebuild on the cards soon.
  16. Member EuRoGTI86's Avatar
    Sep 27th, 2008
    LongIsland, NY
    91 JETTA GLI 16V (LA9V), 95 PASSAT WAGON GLX
    09-08-2009 08:24 PM #16
    looking good man. keep up the good work!
  17. Member sin bar's Avatar
    Jan 12th, 2008
    sin bar ga
    sooter, cooter
    09-08-2009 09:33 PM #17
    love it when people clean up their stuff so well
    there.
    i should probably be sleeping.
  18. 09-12-2009 01:27 AM #18
    good job, I'm going to be watching this one
  19. 09-12-2009 01:14 PM #19
    Love the car, and I've always wanted to build a 16VG60.
    Keep up the good work.
  20. 09-12-2009 07:06 PM #20
    I second that, I will be watching this thread pretty close.
  21. 09-18-2009 11:44 PM #21
    If you have spare parts from your gti g60 let me know i would love them.
    If you ever get bored of your edition one interrior I call dibs!!!
    love the car man, I am slowly but surely cloning an edition one gti here in the us.
  22. 09-23-2009 04:49 PM #22
    thanks everyone
    sorry but the interior is mine forever
    few pics for you dude and dudettes
    more sandblasted bits
    new outer cv's
    built front crossmember
    polybushed font with new VAG bolts
    powdercoated rocker too
    cheers ya'll
  23. 09-23-2009 05:01 PM #23
    subscribed ! solid work man.
  24. 09-23-2009 05:38 PM #24
    S.O.L.I.D work indeed !!
    .:Let no man who is not a VAG owner judge the elements of my ride:.
    Click to view best page EVER made by vtexers!
  25. 09-26-2009 01:37 PM #25
    Thanks guys
    this is not what you want your crank pulley to look like.
    had to grind down the pulley bolt to get the crank off, i hate working on 20 year old engines.
    but it did come off
    got the powersteering rack refurbed and put back on the car, stripped the sound deadening and stuff from the bonnet, put the panels on the front of the car and bolted some wheels on. then......
    and cut my windscreen out, it took me over and hour and a half.
    After i got it back in the garage i jacked the back up and chucked some axle stands under it, unbolted the rear bumper and started to cry, why why why did i decide it would be a good idea to poke my car
    this sucks
    guess more welding will take place
    on another note, dont forget to prop the fuel tank before unbolting the straps
    bump on the head
    cheers for looking
  26. 09-26-2009 01:42 PM #26
    Hell yeah!
    Sick project. Keep it OEM! Just dont let a g-ladder ruin it all. Lysholm FTW!
  27. 09-28-2009 03:00 AM #27
    Gladder!!!!
  28. 10-01-2009 01:38 PM #28
    Would it still be a G60 without the G-lader
    Will go turbo if the charger blows.
    Thanks for looking
  29. 10-07-2009 04:39 PM #29
    just a small progress update
    The damage to the sill and rear end, definitely had some previous accident damage in the faterland.
    found some wiring issues between the body and boot lid
    I also decided what i will trim the roof lining and A,B,C pillars in, and this is a comparison shot.
    After shots of fully trimmed trim parts.
    Stripped down the rad fan and painted, cleaned and assembled. Bolted together with stainless nyloc nuts and washers.
    O and the car put back on all four wheels
    And then........................
    she's gone to paint
    should have her back in a couple of months
    till next time peeps
  30. Member stealthmk3's Avatar
    Nov 30th, 2007
    Maryland
    '63 Beetle, '71 Super
    10-07-2009 06:33 PM #30
    Watching
  31. 10-07-2009 06:38 PM #31
    Very nice, can't wait to see it all gleaming!
  32. 10-07-2009 06:42 PM #32
    subscribe!
  33. 10-09-2009 06:07 PM #33
    Had another trip to the powdercoaters and ended up with some nice looking bits
    close ups of some of the parts
    got the rear bea done too and another load of stuff.
    show you soon
    cheers all
  34. Member newarknj15's Avatar
    Dec 20th, 2008
    newark / garfield nj
    1992 Vw Gti --83 Vw Jetta-Turbo Diesel
    10-09-2009 07:25 PM #34
    will def watch this. great job
  35. 10-09-2009 08:44 PM #35
    how much does the powdercoater charge you?
