VWVortex.com - 2008 Jetta How to reset tire pressure warning
    Results 1 to 16 of 16
    Thread: 2008 Jetta How to reset tire pressure warning
    1. 09-08-2009 04:15 PM #1
      Hi
      We have 2008 Jetta. One of the front driver side tire had a nail and it shown the warning flat tire on the instrument. After the tire has been repair but the warning light is still there.
      Does any one know how the reset the warning.
      Thanks
    2. 09-08-2009 04:44 PM #2
      refill every tire to about 45psi. How much mine is. Just because it was repaired doesnt mean they filled it up. Or that another tire isnt low too. So just do that and see if that fixes anything. QT has free air pumps if you dont have the equipment to do it yourself.
    3. 09-08-2009 05:04 PM #3
      Is it the 45 Lbs is listed on your driver side door tag?
    4. 09-08-2009 06:25 PM #4
      What do you mean? If your wondering what your psi should but it is usually stamped on the fine print on the tire. Just read the print on the side of your tire. Should tell you. If you have factory tires, i believe it is 45psi
    5. 09-08-2009 06:25 PM #5
      I think I read somewhere that it resets itself after driving a few times when things are okay.
    6. 09-08-2009 06:33 PM #6
      Quote, originally posted by Jon1983 »
      Mine reset itself right after refilling. I had a nail in two of mine last week. After i got it repaired the light was still there so i checked the pressure and they didn't refill it. Once i did, it was gone right away. So idk. That is just from my experience.
    7. Member MKVJET08's Avatar
      Feb 12th, 2008
      Manassas, VA
      2008 Jetta 2.5, 1996 Rustbucket
      09-08-2009 07:51 PM #7
      Quote, originally posted by Jettakid18 »
      You don't get your recommended psi level from your tire, you get it from the sticker you see when you open up your driver side door.
      Modified by MKVJET08 at 7:54 PM 9-8-2009
      They're going to their house over there.
      You're not utilizing your education properly.
    8. Member seanmcd72's Avatar
      May 13th, 2008
      SC
      2016 GTI Autobahn
      09-08-2009 07:58 PM #8
      Correct, your tire is going to show you the MAX safe PSI not the suggested psi. On our cars get that from the door jam area.
      Make sure your tires have at least 34 PSI and then go on a drive. You have to go over a certain speed, for a certain amount of time.
      I just put on a new set of wheels. When I got them they had really bald tires, but I wanted to test the TPMS. I threw the wheels on, drove around - TPMS light came on. Tires had about 32psi. I put them all at 34-35psi, then drove around. I drove for about 5 miles @ 40-50mph, then once I came to a complete stop - light went out.
    9. 09-08-2009 11:11 PM #9
      I had a flat and once the tire was aired up over 30, the TPMS went away.
      And the number on the tires is half the exploding pressure...
      Quote Originally Posted by TechEd View Post
      Long-story-short: Outie5000 is right on all accounts.
    10. 09-18-2009 05:19 PM #10
      I rechecked again all the tires and a spare.
      I found the spare was 20 lbs. Put in 32 lbs and the problem is solved.
      Thanks for all of your comments.
    11. Member MKVJET08's Avatar
      Feb 12th, 2008
      Manassas, VA
      09-20-2009 06:54 PM #11
      Quote, originally posted by ttnguyen23 »
      The car doesn't recognize the spare unless it's installed on the car
    12. Member DUSlider's Avatar
      Nov 14th, 2007
      PA
      2008 Rabbit, 2016 GTI
      09-20-2009 08:39 PM #12
      TPMS are only active if the tire has been spinning for a bit. Thus the spare isn't active. That said...
      I had my Goals off the car with VMR's w/o sensors, installed for a day and the warning never went on...
    13. Member jtrujillo86's Avatar
      Aug 21st, 2005
      Denver, CO
      2016 Jetta 1.8T SEL, 2016.5 Mazda CX-5 Touring, 2002 Passat GLX V6 4Motion
      10-01-2009 12:03 AM #13
      I thought the spare was active. It notes in your owners manual that having low pressure in the spare can cause the light to come on, too.
      - Jeremy.
      Quote Originally Posted by BluMagic View Post
      It's a VW; the sensors are as sensitive as women on that time of the month . . . and the dash is as anxious to light up as a stoner.
    14. Member Schagephonic's Avatar
      Feb 5th, 2009
      Colorado
      2013 Tiguan SE 4Motion
      10-04-2009 11:56 PM #14
      This makes sense to me because each sensor is a small radio transmitter. The car doesn't know if the spare is mounted or not. Nor should it care if the wheel is rotating or not, relating to TPMS.
    15. 10-05-2009 12:41 AM #15
      mine reset as soon as i put air in the tires...
    16. 10-06-2009 05:53 AM #16
      the spare is active at all times even in the trunk also tires should only me at about 32-35 psi 45 is way to much. big cars like audi a8's dont even run that much.
