Closed Thread
Page 2 of 32 FirstFirst 1 2 3 4 5 6 12 ... LastLast
Results 36 to 70 of 1090
Thread: 2871R or 50 Trim
  1. Member DK_GTI_racer's Avatar
    Oct 4th, 2007
    Denmark
    2000 mk4 1.8T - AGU
    09-14-2009 12:05 PM #36
    Quote, originally posted by Big_Tom »
    i was trying not to switch to external wg because i have never used them before. and i dont like the idea of them making my car loud as hell. even if i did switch to external wg, i'd still have my dump tube put back into the downpipe
    Hi Big tom, im at 320+whp so far at 19-20psi on a small GT28RS turbo, its a lot of fun and im going to see if 340-350whp is possible very soon, but durable and possible it is, and even more with a GT2871r of course, but if your end goal is 320-350whp then the route i have taken is fun and possible, but expensive as well...
    APR stage 3+ 393bhp & 466nm at 24psi - baby GT2860rs 0,64
    APR intake manifold, Aquamist 1s, milltek 2,75" with VES cutout, HGP IC - software by RH motorsport of denmark - EBC with remote and 2 boost settings for high low boost run.
    Goapr if you want your fast to be faster then everyone else
    www.goapr.com, www.inaengineering.com, www.qedpower.com, www.jvk-tuning.dk
  2. Member bjtgtr's Avatar
    Dec 13th, 2006
    MD
    2001 A6 2.7T 6sp
    09-14-2009 12:22 PM #37
    The 2871R is a great turbo. My old Pag Parts setup made 332whp and 321wtq @23psi on pump gas, stock AWP head and intake manifold, using a Eurodyne 630 file. Only put a set of IE rods in it. Motor and turbo have over 28,000 miles on them now and are now in my brother in laws 2004 A4 Q. We have meth on his set up now and that car screams! the response is great and recovery between shifts is top notch. The turbo is a T25 GT2871R .64 internally gated. I can't comment on the 50 trim as I have never had an oppertunity to use one.
  3. Member transient_analysis's Avatar
    Jan 28th, 2003
    San Diego
    2003 Silverstone 1.8t GTI daily, 1969 BMW 1600 project
    09-14-2009 12:24 PM #38
    Quote, originally posted by 20aeman »
    DBB will take me 30 minutes to install anyways, when this thing eats it.
    Isn't the DBB 50 trim a water cooled center section?
    maybe I'm a whiny little biotch, but going from -not- running water lines on the 50 trim to running -an hardlines for the water feed/return on a 3076 turned out to be a pain in my butt.. and took much longer than 30 minutes
    I used to be able to swap out exhaust housings in ~ 30 minutes on the old 50 trim though I'm sure you can too
    stock turbo 1.8t.. damn 2-year CA smog.. :/
  4. 09-14-2009 02:02 PM #39
    they do come water cooled
  5. 09-14-2009 02:42 PM #40
    I made 379whp on a 50trim and 346torque at 23 PSI its a great turbo. The only thing is in between shifts. I have Meth as well and its 5 degree advanced without issues...
  6. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    02-21-2010 11:55 AM #41
    Just So The World Knows, I Went 50 Trim... no dyno numbers yet but hopefully soon
    Modified by Big_Tom at 11:56 AM 2-21-2010
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
  7. Member HidRo's Avatar
    Sep 19th, 2003
    Portugal/Europe
    1986 mk2 GTi 20VT
    03-25-2010 07:11 AM #42
    And how does it run?
    EIGH-T6 // "Give me enough traction, and I will spin the WORLD!"
    Portugal // Europe
    MS II V3.0: http://eight620vt.tk/
  8. 03-25-2010 07:37 AM #43
    Ha Ha...all those 2871 recommendations and you went 50trim anyway.
    get some dynos up
  9. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    03-25-2010 07:49 AM #44
    Haha I'm working in getting a clutch now. The. Stock one definitely is not holding the power. Other than that I have a communication problem with my ecu. I have been trying to figure it out for weeks now. Nobodys vagcom or scanners will connect to it. I will dyno and hit the track with the homie Blu Pearl when I get these issues sorted out.
    Modified by Big_Tom at 7:51 AM 3-25-2010
  10. Member TheZooKeeper's Avatar
    Jan 28th, 2009
    Mid Town Phx AZ
    1987 StarQuest
    03-25-2010 12:07 PM #45
    Ball bearings and external gates!!!!!
  11. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    12-29-2011 06:42 PM #46
    Quote Originally Posted by TheZooKeeper View Post
    I def love the Tial 38mm, its reliable and hasnt given me a problem since day 1.
    journal bearing is str8. every intake mod i do seems to help the 50 trim spool better. as it sits right now with no exhaust leaks and a better intercooler, boost comes on nice. after i get the bottom end squared away and the abd intake mani on theres a possiblilty i may get a Garrett DBB 50 trim just because So far the setup has been reliable, I've got around 40 to 45k miles on it daily driven
  12. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    12-29-2011 06:56 PM #47
    As it sits right now
    ^^My turbo is on the left
  13. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01-01-2012 02:43 PM #48
    Couple More "in depth" pics
    CAI FTW
    Under The Intake Mani
    Big Ups to Forge Motorsports
    pic of my "hose to the floor"
    oil return line
  14. Member One-Eight GTI's Avatar
    Jan 4th, 2010
    Duluth MN
    01 GTI 1.8T
    01-01-2012 03:03 PM #49
    Your oil pan looks brand new, Which one is that?? ECS hybrid??? Gonna get a hybrid for next summer when engine is out, Too many close calls with my factory oil pan
    Brute 20mm Connecting Rods, ACL Bearings, Wiseco 83mm Pistons, FSI Crank, AEB Head, CatCams 3658, PagParts GT3076R Bottom Mount V-Banded Turbo Kit, PagParts Garret 550HP Core, VF Engineering Motor Mounts, SEM IM, Labonte W/M, 70mm TB, Tial Q BOV, Tial Wastgate, Turbosmart Dual Stage Boost Controller, Peloquin LSD, Clutchmasters FX400, 910cc Injectors, IE Surge Tank, Eurodyne with Maestro.... PAGPARTS Clear Water Dubs
  15. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01-01-2012 03:08 PM #50
    Quote Originally Posted by One-Eight GTI View Post
    ^^^ Thanks It's the ECS hybrid pan and is 2 years old now It's an awesome pan especially for $79
  16. Member One-Eight GTI's Avatar
    Jan 4th, 2010
    Duluth MN
    01 GTI 1.8T
    01-01-2012 03:13 PM #51
    Nice thanks Tom, gonna be getting one of those... Stinkin Florida, my wifes 2009 2.0T Jetta oil pan doesn't even look that good, damn winters
  17. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01-01-2012 05:47 PM #52
    ahaha, yeh it was 76 degrees here today
  18. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01-15-2012 10:28 AM #53
    I'm gonna be doing coolant ball and washer fluid reservoir deletes very soon as well as relocating the PS reservoir. Picked up a couple goodies today. I ordered the Moroso filler neck on Fri so it should be here soon. Hopefully I'll be able to throw up some new pics of a cleaner bay soon
  19. Member Twopnt016v's Avatar
    Jul 5th, 2009
    1983 2.0 16v turbo bunny, 1991 2.0 16v Gti, 1986 Jetta Coupe 2.0 16v, 2002 337 Gti, Giannini R1
    01-15-2012 11:13 AM #54
    Quote Originally Posted by Big_Tom View Post
    Hopefully ABD is making those intake manifolds better. I took mine off and both of the ears had broken off from where the flange obviously want straight. I talked to abd and they said this was common and you can send it back to them and they will have it repaired(at a cost of course). The AIT sensor hole is oversized so it leaks. The 4 holes for the throttle body were drilled by a retard so they aren't straight and the tbody won't go on there unless you hollow out the holes on the tbody...
    Here are some pics of the broken ears...
    This is as close as the throttle body will get to the manifold with the bolts threaded into the holes...
    The holes were drilled crooked...
    Here is the manifold in the oven after welding the ears back on and powdercoating
  20. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01-15-2012 03:53 PM #55
    wooooow , yeaaa i'll probably just have one custom made. i dont want to go driver side TB or i would get SEM. I'll have to see what Pagparts can do about this when the time comes
  21. Member Twopnt016v's Avatar
    Jul 5th, 2009
    01-15-2012 03:57 PM #56
    yeah...very disappointing
  22. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01-15-2012 04:00 PM #57
    ^^^ i appreciate the heads up tho
  23. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01-15-2012 08:30 PM #58
    Quote Originally Posted by Twopnt016v View Post
    how long have you had this thing btw?
    I might have to show some love to the FL guys
    http://uspmotorsports.com/product_in...roducts_id=819
  24. 01-16-2012 01:26 AM #59
    For a daily driver with those goals get a T3 flanged GT2871r .63 A/R
    the old T series turbo don't give as good a response in the mid range as the GT series do and that really where a street car lives.
  25. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01-16-2012 09:11 AM #60
    Quote Originally Posted by Cryser View Post
    ur a lil late tho 50 trim FTW
  26. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01-23-2012 02:03 PM #61
    I managed to pull off the coolant ball and washer fluid reservoir deletes this weekend I love how the bay looks now. I actually finished last night since my water distribution pipe cracked after i got the car back together and test drove it. I had improvise w/ another OEM vw/audi pc I pulled from LKQ on sunday. No problems w/ overheating today on the drive to UCF. To get the air out of the cooling system, I let the car warm up fully w/ hood open and rad cap off. Put cap on went for a short drive 1/2 mile or so up the street and back just to get the water pump spinning, parked car back in my garage until this morning and topped off the coolant again this morning before i left it took quite a bit more water this morning even tho it appeared to be full last night before the test drive. i expected this, hence the 2 part fill up) I'll throw up a few more pics this afternoon
  27. Member HidRo's Avatar
    Sep 19th, 2003
    Portugal/Europe
    1986 mk2 GTi 20VT
    01-23-2012 03:01 PM #62
    So, pics of that?
    And what about a dyno? Have you done any? Do you know how much you are putting down?
    Portugal // Europe
  28. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01-23-2012 03:10 PM #63
    Quote Originally Posted by HidRo View Post
    So, pics of that?
    yes i've been to the dyno before, but not recently(summer 2010). put down 298whp running hella rich on low boost. i'm in the 330-340whp range now on ~22 psi if i had to guess.
  29. Member HidRo's Avatar
    Sep 19th, 2003
    Portugal/Europe
    1986 mk2 GTi 20VT
    01-23-2012 03:20 PM #64
    Sounds healthy
    Do you have any videos of it?
    Portugal // Europe
  30. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01-23-2012 04:20 PM #65
    yea i do, look at cts turbo's facebook page one of them is on there
  31. Member HidRo's Avatar
    Sep 19th, 2003
    Portugal/Europe
    1986 mk2 GTi 20VT
    01-23-2012 05:36 PM #66
    The tinypic one? I think that's the one. If so, looking good
    Portugal // Europe
  32. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01-23-2012 07:47 PM #67
    yup, the tiny pic one is mine. and i fell asleep when i got home so pics will have to be tomorrow
  33. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01-24-2012 12:20 AM #68
    also, i've been dealing with this foolishness for the past week after i get a new downpipe i'll hop back on the dyno. i think the car is ready now other than that. i suspect mine has a hairline crack somewhere around the flange from before when I didn't have mounts
    http://forums.vwvortex.com/showthrea...1#post75540293
  34. 01-24-2012 02:58 AM #69
    ****tttttg. Ttt
    Unitronic830cc/Racetronix 846cc flowmatched injectors/HP6262SP-b/ TurboSmart Race Port/PrecisionPW39/TurboSmart MBC/Snow W/M Injection/IE Rods/AEB pistons/ARP Main cap studs/ARP headstuds/3" turboback/ FMIC/Custom fuel surge tank/ Wally 255/AEB head/supertech single keeper valves/ IECVA1 cams/IE valve springs and retainers/034 motor mounts. SPEC Stg 4 6 puck clutch, Vr6 lightweight flywheel. KRM intake manifold/80mm tb
  35. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01-24-2012 03:01 AM #70
    Original Video - More videos at TinyPic
Closed Thread
