VWVortex.com - forge 007 diverter valve. which spring should i use?
    Results 1 to 15 of 15
    Thread: forge 007 diverter valve. which spring should i use?
    1. 09-17-2009 05:22 PM #1
      i have a 2005 jetta gli its pretty much stock. i just purchased a forge 007 diverter valve and was wondering which spring i should use?. right now i got the green spring in. and should i use the spacers that come with it.
    2. Member Dub-Nub's Avatar
      Sep 27th, 2005
      '86 BMW 528e, '01 VW Cabrio
      09-17-2009 05:28 PM #2
      its based on boost level. If you are runnign stock boost then the stock spring that came with it works.
    3. 09-17-2009 05:35 PM #3
      Everybody here says to run the weakest spring no matter what, unless you go BT. Which sounds kinda stupid to me...
      You kinda have to test them out. You definitly won't need the strongest spring though. But see how the engine performs with just the green spring. Do WOT, partial throttle... See how it feels when letting off the gas too.
      I posted a thread like this a few years ago, and again, everyone said use the green spring with a chip... I couldn't figure out why my GLI was bucking every time I let off the throttle, turns out I needed spacers in there too. The medium spring seemed to steal power from me... But for my buddy, the yellow one works fine (Same car, same mods).
      So sorry for the long post lol, but its up to the car, really. Just test things out. You won't hurt anything.
      Modified by Addicted II Speed at 1:36 PM 9-17-2009
    4. Member l88m22vette's Avatar
      Mar 1st, 2006
      Chicagoland, IL
      2003 TTq coupe, 2005 Outback XT, 2004 A6 3.0
      09-17-2009 08:37 PM #4
      Chicago Cubs, World Series Champions 2016, Holy Cow!
      Quote Originally Posted by hushypushy View Post
      Used manual GTI's are definitely rarer than DSG's. Get a brand new 6MT so you can be the first to dump the clutch and fart in the seats
    5. Member MightyDSM's Avatar
      Apr 16th, 2006
      St. Louis
      '15 Mustang GT,08 VW GTI
      09-17-2009 09:01 PM #5
      By searching, I found this for you:
      Quote, originally posted by VDuBPL »
      off of forge's website
      Valve Spring color coding
      Green - 5-15 PSI
      Yellow - 15-23 PSI
      Blue - 23-30 PSI
      Red - 30 + PSI
      which means that you should get the green spring, u are running around 12 psi max on stock programming.
    6. Member kalamaris20vt's Avatar
      Dec 16th, 2007
      GREECE
      VW POLO GT2871
      09-18-2009 03:57 AM #6
      So if we have a BT,let's say 2871@27-28 psi,the best solution is blue spring or at BT we need to use the red one??
      GREEK VW POLO
    7. Member HidRo's Avatar
      Sep 19th, 2003
      Portugal/Europe
      1986 mk2 GTi 20VT
      09-18-2009 04:29 AM #7
      I'm not really sure how the spring can rob power or whatever.
      When boosting, the spring will almost do nothing in there, because the boost pressure will be sent to the DV as well. So, if you boost 15psi it will create a 15psi pressure inside the DV+the spring.
      Isn't this correct?
      EIGH-T6 // "Give me enough traction, and I will spin the WORLD!"
      Portugal // Europe
      MS II V3.0: http://eight620vt.tk/
    8. 09-18-2009 05:45 AM #8
      Quote, originally posted by Addicted II Speed »
      Everybody here says to run the weakest spring possible no matter what, unless you go BT. Which sounds kinda stupid to me...
      You missed a crucial part.
      Obviously, if it's leaking, you need to go up, or shim.
      Also, if you're racing, shifting fast and want to keep lag at an absolute minimum going stiffer to shorten the duration of the valve opening/closing can help.
      ░░░░░░ .. R13 5
      ░░░░░░ .... 24
    9. Member kalamaris20vt's Avatar
      Dec 16th, 2007
      GREECE
      VW POLO GT2871
      09-18-2009 06:44 AM #9
      So which spring we use in a 2871@27 psi??
      Blue or red?
      GREEK VW POLO
    10. 09-18-2009 06:50 AM #10
      Quote, originally posted by kalamaris20vt »
      Blue or red?
      PSI is PSI. Blue, as a rough guide.
      ░░░░░░ .. R13 5
      ░░░░░░ .... 24
    11. Member kalamaris20vt's Avatar
      Dec 16th, 2007
      GREECE
      VW POLO GT2871
      09-18-2009 07:04 AM #11
      No matter what turbo we use?
      For example,if we have 27psi with a K03 and 27 psi with a GT35,the spring should be the same colour?
      GREEK VW POLO
    12. 09-18-2009 07:11 AM #12
      Yes, the pressure is the same: 27 PSI.
      It flows more air at the same pressure, but pressure is pressure.
      ░░░░░░ .. R13 5
      ░░░░░░ .... 24
    13. 09-20-2009 07:24 PM #13
      hey where do i but this forge 007 diverter valve? Is there a difference in makes?
    14. Member Blackfin's Avatar
      Mar 9th, 2006
      Ontario
      2010 WRX STi, 2002 Mustang GT (Kenne Bell S/C), 2002 GTI 1.8T (sold)
      09-20-2009 09:23 PM #14
      It bears repeating:
      Run the weakest spring that allows you to hold the desired boost.
      The DV, like a BOV, is intended to protect the compressor from surge by venting the outlet side of the compressor to its inlet. This prevents a pressure wave reflected from a suddenly-closed throttle from impinging on the compressor causing surge and high shaft torque.
      Running the weakest spring that will hold the boost you're running helps ensure that the valve opens in a timely fashion and actually does its job of protecting the turbo. Only if the valve is somehow leaking should you up the spring pressure. The higher the spring pressure the more manifold vacuum is required to open the valve. This slows the reaction time of the valve and may allow that pressure wave to reach the compressor.
      Follow Forge's instructions.
      As to where:
      http://www.forgemotorsport.com...oduct
    15. 09-21-2009 07:21 PM #15
      Quote, originally posted by l88m22vette »
      LMAO i see you posting this all the time.
      ME7.1 & ME7.5 ecu tuning,readiness dtc deletes, immo off, etc.. if you need any of this cheap email coreyj03@gmail.com
