Results 1 to 28 of 28
Thread: Phenoms Howtos : Gas hood struts or lifts for mk2 Scirocco
  1. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    Lewiston, Maine (USA)
    88 Scirocco, 78 bus, 91 Vanagon
    09-21-2009 11:32 PM #1
    Ladies and Gentlemen, the moment you have all been waiting for...
    PHENOMS GAS HOOD STRUT HOWTO!
    I got a set of gas hood struts from Black Forest Industries back in August, but I was pretty nervous about doing the install. the horror stories I have heard about the struts bending the hood where they mount up have certainly been on my mind.
    http://yhst-1918367471896.stor....html
    I spent a lot of time considering ways to reinforce the hood where the strut would mount up to prevent it from flexing, bending, denting, and so on, but most things involved welding and painting or other ugliness.
    So I chatted with TooClutchVW about the pictures he posted of his friends rocco and got a better idea of how he did it. I wanted to hear from the horses mouth whether the struts were going to wreck the hood or not. when he said his was working just fine, I decided I would just go for it.
    here are some pics to get you started...
    I decided to fasten to the hood in a place that seemed to have the most structural rigidity.
    I got myself a metric tap indenting on drilling and tapping the hood for the mount. the metal proved to be far too thin to thread, so I knew I would have to put a nut on the back but the nearest hole from the mount point was a few inches away, and at a funny angle.
    my clever solution for that was to tape the nut and a lock washer onto the end of a stick.
    I was able to align the nut and washer with the hole and then thread in the screw. I cranked this up really tight so it would have the best likelihood of holding on with all the pressure on it.
    you can see here where I was trying to tap the hole for the screw. utterly pointless, so please skip that step.
    the important thing here is that you put a big fat washer on the back and snug it up really tight. you will have to take your fender skirts out for this step if you dont have them out already.
    here you can see where the ball is mounted better.
    (Note: I think this is too close, and it should probably be full inch further out. see comments below)
    and the top mount is 11 inches from the corner/tip of the hood.
    and so on...
    just having one strut on was enough to hold the hood up, but it sagged on the passenger side and looked sketchy. so I just repeated the installation for the other side. took me about ten minutes.
    drilled the hole, taped washer and nut to the stick...
    lined up the nut with the hole...
    and thats it. all done.
    any questions?
    Modified by JonnyPhenomenon at 1:24 AM 9-23-2009
    www.rikerstardresser.com - I'm a donor, are you? - www.marrow.org
  2. Member DrFraserCrane's Avatar
    Oct 18th, 2006
    Baltimore County, MD
    M5, Scirocco, JSW
    09-21-2009 11:42 PM #2
    awesomeness as always
    -Dictated but not read to expedite report.
  3. Member Iroczgirl's Avatar
    Feb 17th, 2007
    Bend, OR
    '55 Ford 351C, '80 Rabbit AAZ
    09-22-2009 12:45 AM #3
    That's absolutely amazing!! I bet these will be popping up everywhere now! I know I'll be installing a set
  4. Member Lord_Verminaard's Avatar
    Apr 6th, 2004
    Mt. Vernon, OH
    09-22-2009 09:20 AM #4
    Schweet! Thanks man!!
    Brendan
    '81 Scirocco 'S <-- TDI swap, someday...
    '05 New Beetle TDI
    '86 Golf Diesel, built w/ turbo (Wife's car)
    '93 Corrado SLC <-- currently under the knife...
  5. Member veetarded's Avatar
    Jul 28th, 2004
    [OO==w==OO]
    09-22-2009 11:40 AM #5
    Quote, originally posted by JonnyPhenomenon »
    Loctite is your friend here. Good write-up Jonny.
    Red Leader - Team Infidel
    The Price of 7reedom is the Willingness 2 do Sudden Battle Anywhere, Anytime an6 With Utter Recklessness
    -Heinlein
  6. Member scirocco*joe's Avatar
    Feb 23rd, 2002
    Roughly
    things broken
    09-22-2009 01:56 PM #6
    Finally I can install that set that has been in my basement for 2 years. Thanks, Jonny.
    Quote Originally Posted by sin bar View Post
    i don't even understand everything that's going on. i'm simply impressed.
    Philadelphia, PA
    1981 Scirocco
    2010 Sportwagen TDI
  7. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    09-22-2009 05:22 PM #7
    before anyone runs out and grabs a drill, I need to update. I have detected some bending on the metal where I mounted the top anchor.
    it is not pushing up like I thought it might, but rather when the hood is closed its trying to push the anchor rearward. I didnt put a washer between the hood and the anchor because I thought it would make it stick out too far. and it looks like that may have been a mistake. I'm going to try to take it out and get a washer in there to stabilize it some. this should be FUN.
    I will update soon..
    p.s. learn from my mistakes. since making them all yourself is just silly...
  8. Member jrgrinder's Avatar
    Dec 1st, 2008
    fixed gear ***
    09-22-2009 07:13 PM #8
    i don't know what to say.
  9. Member California Special's Avatar
    Dec 15th, 2005
    Garden Grove,CA
    1983 Scirocco Cal Special
    09-22-2009 11:58 PM #9
    Excellant !!
  10. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    09-23-2009 01:21 AM #10
    Hokay, so I pulled the mounts off the hood and reinstalled them with a washer between the stud and the hood. that should spread the force out a little bit and give it some strength. (yes, at 1am) I'll keep an eye on it and post as needed.
    In order to get the nut off the back without losing it in the hood, I taped a magnet to a piece of electrical wire. worked great!
    in regards to a slightly different detail, I wanted to mention that when I installed the struts I mounted them in a way that would make my hood stand way up. even higher up than the stock prop rod does.
    I didnt have a "spare rocco" to use as a guinnea pig, so I pretty much had to just take a guess and bolt it up and hope for the best. the problem with this is that the struts are almost fully compressed when the hood is closed, and then the angle of the socket on the bottom is maxed right out. almost so far that Im afraid it will pop off.
    so if I were to do it again, I would move the bottom stud further out, by probably a whole inch. it would mean a lower hood when opened, but it would also mean slightly les strain on the top bolt from the compression of the strut, and less strain on the bottom socket from the extreme angle.
    I apologize for being so wordy. I just want to be perfectly clear...
    Modified by JonnyPhenomenon at 1:25 AM 9-23-2009
  11. Member scirocco*joe's Avatar
    Feb 23rd, 2002
    Roughly
    things broken
    09-23-2009 07:52 AM #11
    By "bottom" I assume you mean the strut mount on the fender? I'll then assume that "top" means the strut mount on the hood?
    Philadelphia, PA
    1981 Scirocco
    2010 Sportwagen TDI
    Apr 9th, 2004
    long island, NY
    09-23-2009 09:48 AM #12
    nice work as always. Glad I could help. Just curious but why didnt you use the fender bolts instead of tapping a new hole??
  13. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    09-23-2009 12:28 PM #13
    Quote, originally posted by scirocco*joe »
    Yup.
    Quote, originally posted by TooClutchVW »
    because the fender bolt hole wasnt anywhere near where I needed to mount the strut.
    maybe the ones I have are a different length than the ones your friend used?
  14. Member
    Apr 9th, 2004
    long island, NY
    09-23-2009 07:22 PM #14
    maybe, he has WRD units. Glad I could help
  15. Member Beakersloco's Avatar
    Oct 9th, 2005
    Greenville,NC
    88 VW Scirocco 16v, 94 VW Jetta
    10-03-2009 12:12 AM #15
    Thats very nice!
    “All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”" Edmund Burke -Irish orator, philosopher, & politician
  16. Member mcdecontrol's Avatar
    Mar 25th, 2004
    Louisville, KY
    1987 16V Scirocco
    10-03-2009 10:47 AM #16
    i love this. looked so good at h2o
  17. Member Beakersloco's Avatar
    Oct 9th, 2005
    Greenville,NC
    10-05-2009 09:19 AM #17
    Where did you get thost strut tower covers ... I like.
  18. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    10-19-2009 02:18 PM #18
    I made em
    check out the video here...
    http://www.angrymods.com/proje...S.wmv
    the build thread here...
    http://forums.vwvortex.com/zerothread?id=4274286
    Modified by JonnyPhenomenon at 2:20 PM 10-19-2009
  19. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    02-17-2010 08:25 PM #19
    update on the hood struts:
    after a few months of hibernation, the mounting studs seem to be holding fast. no more bending at all.
  20. 02-17-2010 11:12 PM #20
    Ive been wanting to do this for some time now. Thanks for the write up
  21. Member falcon2000aj's Avatar
    Jun 26th, 2004
    Minneapolis
    1998 Jetta VrT, 1977 Scirocco 20vt- SOLD
    02-17-2010 11:16 PM #21
    Sweetness!! Anyone tried this on a mk1?
    1977 Scirocco 20vT
  22. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    02-17-2010 11:31 PM #22
    Quote, originally posted by falcon2000aj »
    actually, I think its easier on a mk1 since there are better places to mount them this diy was targeted to the mk2 owners who dont have that luxury.
  23. Member
    Apr 9th, 2004
    long island, NY
    02-18-2010 10:06 AM #23
    hood still holding up ok with the weight and all??
  24. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    03-04-2010 07:43 PM #24
    aside from the bike that landed on the hood, the struts are holding up just fine.
  25. Member Rays-Rocco's Avatar
    Aug 10th, 2002
    Somewhere between Georgia and Missouri
    nothing but Mk1's '80,2-'81's, 2000 :O)
    03-05-2010 06:34 AM #25
    Nice scirocco!
    Why didn't you use one of the hood bolts for the top bolt? I would think that bending would be less likely at that point.
  26. Member 16volt's Avatar
    Oct 26th, 2000
    Seattle
    86 635CSi, 01 Allroad
    03-05-2010 11:06 AM #26
    Thats a fantastic writeup.
  27. 03-05-2010 02:18 PM #27
    I was going to recomend using the stock hood bolt location as its somewhat reinforced in that area VS the thin sheet metal area you drilled thru. The only additional mod is a notch of the weather stripping.
    That location is even better on a MK-I
    (Ive had the hood lifts on both.)
    Shawn Meze
    02' Beetle Turbo "S" 84' Scirocco 8V 80' Scirocco "S" 99' F250
    NASA SoCal Spec E30 Series Director.
  28. Member JonnyPhenomenon's Avatar
    Jan 27th, 2005
    03-05-2010 04:18 PM #28
    Quote, originally posted by Rays-Rocco »
    Nice scirocco!
    the bolt holes aren't anywhere near the gutters where I wanted to mount the struts. there really isn't any good place to put them on the mk2. the mk1's have bolt holes over there so its possible that way, but not the mk2.
    Quote, originally posted by 16volt »
    That's a fantastic writeup.
    thanks
    Quote, originally posted by Monster8V »
    I was going to recommend using the stock hood bolt location as its somewhat reinforced in that area VS the thin sheet metal area you drilled thru. The only additional mod is a notch of the weather stripping.
    I think that mounting them in the engine bay with the cut rain tray is not as attractive as keeping them in the gutter. hence why I installed them where I did.
    as I said in my original post, there was some bending before I took them out an added more washers. since I have added the washers the bending has stopped. I said later on that if I had moved the mounting points on the body a little bit farther forward, that there would be less stress on them when the hood was fully closed. where they are now they are fully compressed when the hood is closed, and there is a ton of force on that little screw.
    if I had mounted them an 1" to 1.5" further forward, this stress would have been a lot less. but when I am using my own car is the guinnea pig, I don't get to just drill more holes when I don't like where they were at first..
    so to summarize, the top mounting points are fine, but the bottom mounting points should be moved further forward so they put less stress on the hood when it is closed.
    Modified by JonnyPhenomenon at 4:20 PM 3-5-2010
