VWVortex.com - Car shakes/vibrates when turning left, what is the problem?
    Results 1 to 10 of 10
    Thread: Car shakes/vibrates when turning left, what is the problem?
    1. Member EMVeeDub's Avatar
      Jul 2nd, 2004
      2015 MkVII GTI, 2006 MkV GTI, 2001 MKIV GTI, 1990 MKII Jetta GL
      09-25-2009 02:01 PM #1
      Recently my car started experiencing a shaking / vibrating whenever I turn left, especially during acceleration and a tight left turn.
      The vibrations remain momentarily after the car straightens back out but does go away after a bit.
      This is a 2006 MkV GTI bone stock with 25k miles and original suspension, tires, etc.
      Anyone know what could cause this?
      Thanks [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by EMVeeDub at 11:38 AM 9-25-2009
    2. Member GtiBoogiemann's Avatar
      Nov 16th, 2002
      Los Angeles
      08 4dr Gti + 03 2dr Gti
      09-25-2009 02:20 PM #2
      possibly cv joint? did you hit any huge pot holes? how about when you turn hard right?
      2003 Gti Black 2dr
      2008 Gti United Gray 4dr
      2013 Passat CC Sport Plus
    3. Member cxg231's Avatar
      Sep 24th, 2002
      Audubon, PA
      2008 GTI 6MT, 2005.5 A4 Avant 6MT
      09-25-2009 02:25 PM #3
      First thing first, before you drive the car again, make sure your wheel lugs are correctly torqued. If that's not it, I'm thinking a right-hand side wheel bearing.
    4. Member EMVeeDub's Avatar
      Jul 2nd, 2004
      09-25-2009 02:39 PM #4
      Quote, originally posted by GtiBoogiemann »
      I haven't hit any big potholes, and it does not do anything when I turn right.
    5. Member EMVeeDub's Avatar
      Jul 2nd, 2004
      09-25-2009 02:40 PM #5
      Quote, originally posted by cxg231 »
      I will check the lugs when I get out of work. Is there any way to tell if it's a wheel bearing without getting dirty?
    6. Member cxg231's Avatar
      Sep 24th, 2002
      Audubon, PA
      09-25-2009 02:51 PM #6
      Quote, originally posted by EMVeeDub »
      If you don't mind getting just your hands dirty you can grasp the top of the wheel/tire firmly and yank it hard in and out (in and out as you face the wheel). If the bearing is really bad you will feel play in the hub as you yank the wheel.
      If that passes, later on when you are not in your lilly whites Jack the car up, secure it properly on jack stands and yank the wheel again as above (but not so hard you knock the car off the jack stands!). If the bearing is medium-bad you will feel the play in the hub.
      If the bearing is just starting to go the only way to tell really is to inspect the bearing itself. Not a clean job.
    7. Member EMVeeDub's Avatar
      Jul 2nd, 2004
      09-25-2009 02:57 PM #7
      Ok cool, I will give it a shot Thanks! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Jun 1st, 2003
      Dearborn Heights, MI
      2005.5 MKV TDI
      09-25-2009 06:10 PM #8
      Yes, it means that your car is not qualified for NASCAR.
      Rain Closing Windows, goF raeR, Aspherical Mirrors, Remote Windows, Amber Club
    9. 09-25-2009 06:21 PM #9
      probebly cv joint,wheel bearings make a low wineing/hum noise when they go,have a look at the cv boot,they come off at one end and all the grease comes out which leads to the cv joint failing
    10. 11-28-2010 10:46 PM #10
      I'm pretty sure it's the outer tie rod end - left. I had the same exact problem. I took my car today at pep boys and they took a look at it. It was the outer tie rod end - left. They fixed it for me and the car was driving back to normal. This costs about $180.00 including labor and everything. You could find the part at NAPA, Advance Auto Parts or Pep Boys.
