Page 1 of 2 1 2 LastLast
Results 1 to 35 of 39
Thread: vr6 mpg
  1. Member jmuscava's Avatar
    Sep 14th, 2009
    Morgantown, WV
    Too many bicycles
    09-26-2009 06:13 PM #1
    What does your average 12v vr6 get in the way of gas mileage? How about one with a CAI?
    8V Society #152
  2. Member marine24's Avatar
    Jan 19th, 2008
    Fallbrook, Ca
    1996 Volkswagen Passat VR6
    09-26-2009 06:24 PM #2
    I get about 20 to and from work ( about 55 there and back) and less in the city (around 16-18). But I also like the fun pedal a lot
    Don't bother me with little things like logic...
  3. Member jmuscava's Avatar
    Sep 14th, 2009
    Morgantown, WV
    Too many bicycles
    09-26-2009 06:40 PM #3
    hmm. Thought it would be more. Thanks though.
    8V Society #152
  4. Member Turrtlemk3vr6's Avatar
    Dec 9th, 2008
    Burnsville, MN
    Ginster Yellow 1998 VW GTI VR6
    09-26-2009 06:48 PM #4
    i can get 23mpg on the highway doin 80 or 27mpg when im stuck behind slow drivers doin 60. all i got is a short ram intake though
  5. Member jmuscava's Avatar
    Sep 14th, 2009
    Morgantown, WV
    Too many bicycles
    09-26-2009 06:50 PM #5
    a significant difference from the previous response. Is that because you're driving an mkIII not an mkIV?
    8V Society #152
  6. Member
    Jan 28th, 2000
    Northern California
    1998 GTI VR6 / 02 Passat GLX
    09-26-2009 07:10 PM #6
    My 98 MkIII gets around 27 MPG at 70 MPH cruise. When the weather is extremely hot, it drops to about 25 or so. I made 570 mile drive recently and averaged 26 MPH at speeds of 75-85 the whole time.
    On my 13 mile commute to work, there are 10 traffic lights and speeds run between 45 mph and 70 mph. I've been driving this route for 11 years and my mileage is a consistent 23 MPH average. Stock intake, GIAC chip, cat-back exhaust. Hope this helps. -Chris
    Apr 20th, 2003
    New York
    2007 UG GTI
    09-27-2009 11:50 PM #7
    My '95 VR with 215k miles gets 26.5-27.5 mpg on the highway averaging around 70 mph
    For trips of 10-25 miles of mixed suburban & highway it'll be in the 20.0-24.0 range.
    Short trips = garbage milage 15.0-21.0
    I replaced the head gasket(to MkIV) & Cat last year so that probably has notched up my mileage a bit.
    Vented air box, 256 cams, chip, high flow exhaust, lightened flywheel
  8. Member ogvr6's Avatar
    Nov 3rd, 2004
    fl
    a gas guzzler and a econobox
    09-28-2009 12:01 AM #8
    well in my case mk4 jetta vr6 with 5sp.on last trip from Florida to Nashville tn doing 75-80 mph I average 29-30 mpg
    indoctrinate through academia and media.
    why is that the ones that seek tolerance are the most intolerant.
    They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety. -Benjamin Franklin
  9. Member jmuscava's Avatar
    Sep 14th, 2009
    Morgantown, WV
    Too many bicycles
    09-28-2009 07:07 AM #9
    ok cool. That's what i was looking for. I may be getting a 5spd mk4 soon, and was just curious.
    8V Society #152
  10. 09-28-2009 01:28 PM #10
    I rarely ever get less than 23 mpg unless I'm getting on it a lot. I normally see 26-30mpg if I'm going for the mileage factor. I can pull 30mpg fairly easy in mixed driving if I'm not using my a/c.
  11. Member Jettaholichick's Avatar
    May 12th, 2009
    Smokey Point, Wa
    09-28-2009 01:43 PM #11
    I get an average 24-27 if im using unleaded. If im using premium I get closer to 26-30
    FACEBOOK
    B E E R
  12. 09-28-2009 01:48 PM #12
    I get 30 on my 45 minute drive that is 99% interstate ... while I was doing field service tech work (lots of downtown driving) I averaged 23mpg...
    OH pertinent<sp> mods, GIAC Chip, custom cold air intake (made of PVC), and lightweight flywheel
    Modified by ExtremeVR6 at 1:51 PM 9-28-2009
    Looking for ONE Luff M1 19x8.5 5x112 et48 wheel... please let me know if you have one available.
  13. Member -=GTI=- Zach's Avatar
    Sep 16th, 2007
    St. Peters, MO
    00 GTI 12v
    09-28-2009 02:12 PM #13
    I just picked up my girlfriend from MST a week ago. The highway's speed limit was 70 so I was going anywhere from 80-90 at most points. I got about 335 miles on about 12 gallons so a little over 27mpg
    I've never got that much before and I've owned the car coming on four years... Faster = more efficient? As far as I'm concerned
  14. 09-28-2009 02:15 PM #14
    the recent weather (GLORIOUS!!!!) I'm sure is doing wonders for my MPG ... I'm loving the 60 degree'ish weather!
  15. 09-28-2009 06:26 PM #15
    Stock, I was getting 26 or 27 in my 2K VR.
    After under drive pullies, CAI, Ignition system upgrade, Synthetic Oil, 1 size larger diameter tires, about 15 - 20 less turns per mile, I am getting 30+ MPG. I get about 405 miles to a tank full driving 100% highway keeping it under 65.
    I have 256 cams and GIAC chip too and use regular spark plugs
    202K miles in this car now.......
    Mad Dope Silly MK1 Love!
    WWW.MK1DUBZ.COM
  16. Member marine24's Avatar
    Jan 19th, 2008
    Fallbrook, Ca
    09-28-2009 07:26 PM #16
    I have a cold air, exhaust and Q-chip; but like I said I gun it sort of hard. I can get around 25-26 on long trips; I drive mostly in the city
  17. Member Grabbit's Avatar
    Apr 27th, 2001
    SEA128021
    Mk1, Mk2
    09-28-2009 07:38 PM #17
    I get around 30 mixed. MFA says about 33-34 higway but its in a Mk2 with no ac or ps. AT 262s, GIAC 2.5 TT exh and test pipe
  18. Member jmuscava's Avatar
    Sep 14th, 2009
    Morgantown, WV
    Too many bicycles
    09-28-2009 10:09 PM #18
    pretty clean engine for 202k miles
    8V Society #152
  19. 09-29-2009 01:02 AM #19
    on a trip to palm springs i got 34mpg total there and back, the drive though was very diverse. lots of hills and stuff to roll on. took about 3/4 tank to do 400 miles. thats my personal best. i had intake exhaust and suspension on my mk3 97 vr6 plan on getting 32 at best on the freeway if you're really economical
  20. Member jmuscava's Avatar
    Sep 14th, 2009
    Morgantown, WV
    Too many bicycles
    10-05-2009 10:31 AM #20
    Does the mpg increase, decrease, or stay the same once a turbo is added?
    8V Society #152
  21. 10-05-2009 11:07 AM #21
    depends on exactly when you mean ... immediately after install mpg goes WAY down ... 6-8 months later (assuming you're on on an upgrade path because you realized that the world is better at 2g's of acceleration) some do see a marked increase in mpg...
    joking aside, theoretically, you can/should see an increase in mpg. instead of relying strictly on ambiant airflow to push air into the engine, you've got the turbo that is pumping air into the engine in a closed system. Apart from that, I'd venture to say that the air is probably more turbulant than ambiant airflow into the engine.
  22. Member Flipdriver80's Avatar
    Jul 16th, 2004
    Central NJ
    87 Jetta 2.0T, 89 golf
    10-05-2009 12:47 PM #22
    I have a TT chip and i get 30-32 on the highway at 65-70. around town i only get about 22 though. car doesn't have a/c, tires are at 42lbs.
    Modified by Flipdriver80 at 12:48 PM 10-5-2009
    Quote Originally Posted by dirtbaggg View Post
    is there anyway to get a new uni body?
    like can yu take the uni body off
  23. 07-06-2012 01:28 PM #23
    My 2.8L Vr6 95 Passat Glx Can Get 35 Mpg on a 15 mile trip doing 50-55 i have a picture of my passat getting 34.5mpg
  24. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    94 JTI Vrt 60-1 .58ar exh obd2 440 racefile 20psi/meth
    07-06-2012 01:48 PM #24
    If I did my math correctly I get about 16mpg, around town. Up in the low 20's on highway.
    We work with liters here
    Forced convection.... Now we grillin.
    Some times she goes, some times she doesn't.... Way of the road
    Rem 870 super mag in max 4 camo for sale. Pm me
  25. 07-13-2012 11:02 PM #25
    Today I got 36.0 mpg And yes I do have a picture to prove it
  26. Member mtn_dub's Avatar
    Jun 23rd, 2009
    Seattle,wa
    09 rabbit (totaled) 08 GTI (sold) 97 GTI VR (sploded) 96 GTI VR (sold) 10 Gti foe doe
    07-13-2012 11:56 PM #26
    I average about 29-32 highway, 33 on a recent trip using neutral whenever I could. I have A homemade intake and 1.8t sensor and running on the stock 15's on 205/50's and 195/55 rear, on my 16's with 205/40's I get about 25-28. Make sure your TB and intake parts are clean, maf is clean, etc. I gained about 2 mpg from cleaning everything a few months ago. Make sure you're using maf specific and TB specific cleaner though.
  27. 07-14-2012 02:55 PM #27
    just drove from widbey island WA to central california, about 1,100 miles and averaged 28.8MPG 70-75mph
    combined city/highway i usually get low 26
    MKIV vr 5spd
    -factory engine with k&n and exhaust, factory plugs factory sized pirelli P6 tires, on factory wheels
    the VR has so much tq im considering changing my 5th gear and or if i ever have the trans out again, one upping the final drive for lower rpms.
    i use cruise control as much as possible
  28. Member krager54's Avatar
    Aug 6th, 2011
    Aloha/Beaveton, Oregon
    1984 VW Jetta 1.7 gas
    07-14-2012 03:43 PM #28
    My 92 SLC with 262 cams can get me 22 on average, and that's with the occasional spirited driving
    Quote Originally Posted by DUBZAK View Post
    Welcome to Corrado ownership 101. Cheap out or hold off on important items, it will cost you 3 fold vs doing it right one time.
  29. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    92 Corrado SLC, '12 Golf R
    07-15-2012 03:09 PM #29
    Quote Originally Posted by krager54 View Post
    Ya our shorter gear ratios don't help.
    I average about 24-25 mpg every tank with probably 60% city 40% highway driving. And that includes having fun with on ramps/off ramps/back roads. My MFA usually only says 19ish, no idea why it's off.... but I do the math every time I fill up. Best I ever got while trying to hyper mile in the city and doing ~75 on the highways was 28mpg.
    2002.5 Jetta 1.8T - TOTALED (dodging deer)
    2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
    1992 Corrado SLC - The toy & DD
    2012 Golf R - The weekender
  30. 07-15-2012 07:19 PM #30
    The last two tanks in my 94 VR6.
    Autotech 10lb flywheel, ported intake and exhaust manifolds, q45 throttle body (possible chip)
    I've got 34-36mpg
  31. Member
    Jan 27th, 2010
    Cape Town, South Africa
    1996 golf 3 vr6
    07-16-2012 09:35 AM #31
    Hi guys
    Mine does 26 - 30 mpg. This is a bone dead standard mk3 vr6
    Sent from my BlackBerry 9780 using Tapatalk
  32. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    07-17-2012 12:43 AM #32
    Quote Originally Posted by marc vr6 View Post
    Hi guys
    Nog n boer op die forums ne! Julle betaal darm maar swar op petrol daar ook, amper dubled wat ons hier betaal.
  33. 10-05-2012 11:16 AM #33
    I got 38.8
  34. 10-05-2012 08:45 PM #34
    34 highway, 25 city. Consistent.
    Stock cams, dyno's at ~180-185whp. Mk3, 2550lbs, Mk4 12v O2j gearing.
    Are you from New Jersey, or did you just get the paint job in New Jersey?
  35. Member izzo's Avatar
    Mar 19th, 2004
    Manassas
    '89 Golf
    10-05-2012 09:59 PM #35
    I can't believe another one of these is up.
