VWVortex.com - Code 01166 - Engine Torque Signal...any idea?
    Results 1 to 3 of 3
    Thread: Code 01166 - Engine Torque Signal...any idea?
    1. Member heshootznscores's Avatar
      Aug 3rd, 2006
      From Florida, lived in Ohio and now am in Texas!
      New: 2011 Hyundai Elantra. Old: RIP 2002 1.8t
      09-29-2009 03:56 PM #1
      Hey kids, my car was scanned and this code came up. It was 01166 Engine Torque Signal – Signal outside specifications, intermittent. Could this just be from really bad vibrations? I've never seen or even heard of this code. My passenger side drive shaft was toast and thus it vibrated terribly and drove like hell.
      thanks in advance
      -Case
      I love my Ohio State Buckeyes!
      Why yes, I am a girl.
    2. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      09-29-2009 08:54 PM #2
      Case, did you scan only with an generic OBDII scanner?
      There's something more underlying with that code.
      You need access to a VAG-COM which will give you specific details on the current issue at hand.
      Otherwise, currently, you can't do much other than clearing out the code, and checking wiring to the ECU.
      - Erik
      PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    3. Member heshootznscores's Avatar
      Aug 3rd, 2006
      09-30-2009 12:11 AM #3
      Quote, originally posted by bluefox280 »
      - Erik
      Erik, I knew I could count on you to reply. I was tempted just to PM you!
      I'm not sure what the shop used to scan in..I took it in to a local place/a friend and I didn't even think to check out their equipment (to see if it was a generic scanner or vag-com). Either way, they cleared the code and it hasn't come back up after driving it today. I really think it might've been because of how much movement was happening. If it comes back up, i'll PM you and let you know whats up.
      Thanks again for replying
