Page 1 of 7 1 2 3 4 5 ... LastLast
Results 1 to 35 of 223
Thread: Bi-Xenon retrofit on golf mk6
  1. 10-01-2009 09:49 AM #1
    Hi there,
    I am attempting to retrofit the bi-xenons to my golf mk6. I'd like to know if anyone there has done the same job..
    And, if you know, if I can mount them without the auto-leveling sensors in a first time, only headlights and cornering lights.
    For the cabling, I'm getting the adapters from kufatec. They say they are compatible with the mk6, but they cannot provide support and installation infos since they haven't done the retrofit to a mk6, yet.
    Any help is appreciated..
    Thank you very much
  2. Member CosmicSki's Avatar
    Jul 16th, 2007
    Queens NY
    2013 CC Sport + woohoo
    10-01-2009 10:09 AM #2
    What's the cost of the retrofit?
  3. 10-01-2009 11:40 AM #3
    I bought the two headlights, lamps, cornering power module and xenon mgmt module for ~800 EUR from a guy in Germany.
  4. Member CosmicSki's Avatar
    Jul 16th, 2007
    Queens NY
    10-01-2009 11:56 AM #4
    I thought you were going to retro fit the new GTI, wouldn't make sense since the option is under a grand in the US. I just noticed you have the 2010 1.4tsi. Good luck! would be cool if you did a write up with pics.
  5. 10-05-2009 04:33 PM #5
    Here in Italy it costs like 1600 EUR with auto leveling and cornering system. I'd had bought it, but at the time I ordered it wasn't available. I'll try to take some pics.. for now I'm not installing the auto leveling (350 more euros...)
  6. Member sebasEuRo's Avatar
    Feb 26th, 2006
    Seattle/Europe
    2010 Jetta
    12-01-2009 05:47 PM #6
    in for pics
    *****AMBER CluB*****
    Volkswagen Audi Group In North America
    For Sale OEM 18" Laguna/Watkins Glen wheels & tires: http://forums.vwvortex.com/showthrea...2#post81808652
  7. 12-01-2009 07:35 PM #7
    Ditto. Must See. Oemplus has these for $2K USD I think. Anyone else install them?
  8. 03-02-2010 01:11 PM #8
    Did you install the xenon??
  9. 04-22-2010 07:09 PM #9
    hi, retrofitted some xenon lights 2day to my bro'S MK6 GTI. sourced all the relevent bits. When finished the lights work fine except for full beam which wont light up at all. Can anyone shed any light on this/ Thanks.
  10. Member romanl's Avatar
    Apr 2nd, 2010
    Denver, CO
    '10 GOLF TDI
    04-22-2010 07:13 PM #10
    what is this auto-leveling ?
    my 2010 GOLF TDI thats comming in with bi-xenons as far as i understand it has that adaptive feature when you're turning at certain speed, but what is auto-leveling?
  11. Member
    Apr 19th, 2006
    2010 Golf TDI
    04-22-2010 08:15 PM #11
    Quote, originally posted by Denver »
    Your best bet is to post a full scan to the VAGCom forum.
    Quote, originally posted by romanl »
    They level according to the load (more in the back would raise the front, screwing up the beam path). Every car I had in Germany save my Ascona B had some mechanism for adjusting the headlights due to the load.
    2010 Golf TDI 4 Door Shark Blue. DSG, Sunroof, Dynaudio, Nav, Rear airbags
    Quote Originally Posted by Outie5000 View Post
    And lets be honest, owning a diesel car is nifty.
  12. Member echoout's Avatar
    Aug 11th, 2008
    Austin, Texas
    2009 MKV JSW TDI, 2010 MKVI Golf TDI
    04-22-2010 08:36 PM #12
    I would love to see what you learn about aiming your new lights. I'm REALLY disappointed in the ones on my Golf as I can only see a VERY short distance in front of me and they seem beyond dangerous as they are currently functioning.
  13. Banned BarryT82's Avatar
    Nov 12th, 2005
    Charleston, WV
    '12 F-150 FX4 Super Crew, '11 JSW TDI
    04-22-2010 10:11 PM #13
    Use a vag com and raise them if they're too low.
  14. 04-22-2010 10:51 PM #14
    Marked
    I'd be doing the same some time later this year.
  15. Member echoout's Avatar
    Aug 11th, 2008
    Austin, Texas
    04-22-2010 11:12 PM #15
    Quote, originally posted by BarryT82 »
    Nice, is that all there is to it? I now have two recent TDIs and can definitely justify it. Cool!
  16. Member romanl's Avatar
    Apr 2nd, 2010
    Denver, CO
    '10 GOLF TDI
    04-23-2010 01:57 AM #16
    nice, but are those EU specs, or do GTI and TDI xenons have autoleveler as well?
    thanks
  17. 04-23-2010 05:07 AM #17
    Hi, i have bought the adapter plugs from kufotec. There are two long wires that come from the plugs which have small connectors on them! Does anybody know of there purpose or to where they connect to?? Thanks!!
  18. Member
    Oct 5th, 2004
    Sterling, VA
    2K6 1K2 BRM & 2K8 7L6 BWF & 85 19 MF
    04-23-2010 10:06 AM #18
    Most likely these are hi-beam shutter triggers that should be wired to the CECM or Central Power Supply Unit (or whatever the current name os this module is).
  19. Member
    Oct 5th, 2004
    Sterling, VA
    04-23-2010 10:12 AM #19
    Quote, originally posted by bubez »
    It should be more less the same job as in mk5: http://furmanka.blogspot.com/2....html
    Cornering and autolevelling are controlled by the same module. Not sure if it will work without auto-leveling sensors, but you may try.
    That's not exactly true. mk6 HIDs w/AFS use 14-pin plug, while mk5 HIDs use 12-pin plug. One of the difference is there is a CAN BUS connection between the leveling/cornering module and the headlight in mk6, while in mk5 it does not exist. Hence the wiring harness for mk5 would not probably work.
    I would rather try using Passat B6 HIDs w/AFS wiring harness. Not sure if the plugs are exactly the same, but at least the number of wires should work.
  20. Junior Member vw siej's Avatar
    Sep 20th, 2009
    West Warrick, RI
    2012 Tiguan SEL
    04-25-2010 07:59 AM #20
    Please post pics. I plan on doing this mod as well
  21. Banner Advertiser TECH@RSWORX's Avatar
    Jun 27th, 2009
    New Jersey
    B5 Passat/MK6
    04-25-2010 12:47 PM #21
    I will be doing this also once I gather all Necessary information..
    Redline Speed Worx
    German Repair, Performance, & Fabrication
    New Jersey's Premier APR Distributor
    www.RedlineSpeedWorx.com
    Find us on Facebook
  22. Member TXRanger83's Avatar
    Nov 8th, 2009
    Midland, TX
    2010 VW Jetta TDI Sedan
    04-25-2010 10:16 PM #22
    did you switch out your cecm?
    2010 Salsa Red TDI Sedan
    Current Mods
    OEM
    is the only way
  23. Banner Advertiser TECH@RSWORX's Avatar
    Jun 27th, 2009
    New Jersey
    B5 Passat/MK6
    04-26-2010 08:28 PM #23
    Redline Speed Worx
    Find us on Facebook
  24. 05-22-2010 05:57 PM #24
    Did this ever end up working? Going to be doing the same thing here shortly.
  25. Member Live-Wire's Avatar
    Jun 9th, 2005
    Guelph Ontario
    2008 BMW 335i
    05-22-2010 08:50 PM #25
    A good write-up would be appreciated from me too. I couldn't order Xenons on my TDI in Canada (can in the USA, don't know why we can't here)... I will retrofit in a year or so. I'd also like to retrofit in the Dynaudio system too - if anyone has a link to that - post plz, or private msg me.
    Quote Originally Posted by echoout View Post
    Aim them, most cars from Germany (Europe in general really... we had a Volvo 960 and a new 10' XC70 that needed some aiming adjustment too) come "too low" for some bizarre reason. Mine are aimed fine on my Mk6, but my dads old 07' Passat (with HID) was aimed almost at the ground... once I adjusted them the car had excellent lights.
    I think they do it so they for-sure pass the DOT test if randomly tested. Cars from Acura seem to always have spot-on aim - and you can see when looking at a concrete side barrier on the highway that their aim is a lot less of a severe angle of drop then on almost any German car - yet the lights basically have the same beam pattern. Correct the aim - and the European car will be "perfect" and have a similar degree of drop... and the owner won't complain about the lights. I had people compliment how good the lights on our old Volvo were just because they were adjusted correctly.
  26. 09-16-2010 05:29 AM #26
    Bumping this thread. Anyone done this yet that can provide some info? I have found these parts for the US cars for some of the conversion:
    1 5k1-941-753-b headlamp 1 365.73
    2 5k1-941-754-b headlamp 1 365.73
    3 5m0-907-391 ballast 2 132.13 ea 264.26
    4 7l6-941-329-b power mod 2 232.14 ea 464.28
    5 5m0-907-357-c ecu 1 164.25
    Total is 1624.25 for all parts above. This is. both headlamps, both ballasts, the cecu that needs to be change. Plus here are the kufatec adapters:
    http://kufatec.com/index.php?main_pa...oducts_id=1044
    $68.So total so far is $1700 is roughly what you will need to spend to get this directly from
    volkswagen, plus the adapters. I am not sure if this includes AFS.
    Here is some more info:
    http://translate.google.com/translat...%26prmd%3Divdf
  27. Junior Member
    Sep 4th, 2010
    Edmonton, AB
    2010 VW Golf TDI 5D
    09-30-2010 04:18 PM #27
    So if those parts will do the retro, what then is this kit for?
    http://kufatec.com/index.php?main_pa...839c81249ef6fe
    Product Description:
    Complete set for the retrofit of xenon - headlights including auto-leveling headlamp control
    Suitable for vehicles with electronic shock absorber - What is the electronic shock absorber?
    For vehicles without electronic shock absorber items
    36850 or
    36850-1 is required
    The control unit for central electric has to be replaced (item 37197)
    What are the full part numbers for these?
    And has anyone found out about cornering ability yet?
  28. 09-30-2010 07:59 PM #28
    The last part number listed is the CECM. I am not sure if halogen equipped cars have a different CECM, or just require coding to get it to work.
    As far as the electronic shock absorber (going to say ESA) is involved, I think that's for Euro cars. I know they have different suspension for us and have the ability to be in sport mode or daily mode. I do know that xenon cars have a leveler attached to the rear suspension.
    No idea on AFS
  29. n00b
    Nov 26th, 2010
    London - UK
    2009 VW Golf, 1998 BMW 840Ci
    11-26-2010 05:30 PM #29
    hi, found your post here, just wondering if you had a chance to finish the job on your car? im in the middle of retrofitting bi-xenons in my 2009 golf mk6 and got to the point where the lights are installed with all 4 modules underneeth. i used kufatec adapters and connected two long long leads to central unit. i coded them with vag but cant get my high beam and cornering lights working and i got the yellow bulb warning on my dashboard. the low beam are working fine. did you changed central unit? did you get high beam and cornering lights working. can you help me with it? thanks. Maciek
  30. Member
    Feb 18th, 2002
    OH
    2010 JSW
    11-26-2010 10:38 PM #30
    Do you have a high line cecm?
  31. Member MAGICGTI's Avatar
    Jul 2nd, 2003
    Sterling, VA
    11-27-2010 01:02 AM #31
    Quote Originally Posted by JR@RedlineSpeedWorx View Post
    Ditto, but I'm a follower. Bring out the wallet rape
    2012 C30 T5 R-Design / 2003 V70 T5
  32. Member
    Aug 6th, 2010
    So Cal, LA/OC Area
    11-27-2010 03:36 PM #32
    hrm, could anyone whose familiar w/ mk5's explain to me why a highline cecm is necessary just for high beam shutter? on the mk6, we have our own separate high beam, couldn't the adapters just use the stock high beam wire to connect w/ the xenon shutters??
  33. Member
    Feb 18th, 2002
    OH
    2010 JSW
    11-27-2010 05:14 PM #33
    You could try it, I think you'd throw a code though, the shutter won't draw nearly enough power.
    Quote Originally Posted by sukanas View Post
  34. n00b
    Nov 26th, 2010
    London - UK
    11-27-2010 06:14 PM #34
    how can u check it? i think i got standart one that came with the car. do you have vw part number for the one I should use?
  35. n00b
    Nov 26th, 2010
    London - UK
    11-27-2010 06:18 PM #35
    i think in mk6 they running of the can bus signal
