VWVortex.com - Can't Solve: Very Low and Soft Brake Pedal!
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 28
    Thread: Can't Solve: Very Low and Soft Brake Pedal!
    1. Member '88Jetta16v's Avatar
      Sep 5th, 2005
      Bechtelsville, PA
      10-01-2009 08:11 PM #1
      Update/Conclusion at the bottom
      Okay, I have a full Corrado G60 11" front brake swap on my GLI. Here's a list of the parts in the entire braking system:
      -Brand new aluminum ATE master cylinder 22mm
      -Brand new (rebuilt) Girling 54 front calipers
      -Brand new (rebuilt) Girling 36 rear calipers
      -Brand new PBR MetalMaster pads (front and rear)
      -Brand new GLI proportioning valve properly adjusted to compensate for lowered ride height
      -Brand new Autotech stainless braided lines (all 6 of 'em)
      -Brand new hardlines (all of 'em)
      -Brand new Castrol GTLMA DOT 4 fluid
      What I'm trying to say is the entire braking system is NEW.
      The master cylinder was properly bench bled before installation.
      The entire system has been bled through completely THREE times now! The fluid is clear and clean each time w/ no bubbles.
      Brake fluid is at the proper level in resevoir.
      I have checked the system through entirely multiple times for leaks. There are NO leaks.
      Symptoms:
      1.) When I push the brake pedal, I get almost no response until the pedal is more than halfway through its travel.
      2.) It feels soft when it finally does engage the brakes. However, if I sit at rest, I cannot push the pedal to the floor (as if it were leaking) but it does feel soft.
      3.) It is too high effort to stop the car and I really need to stand on the pedal. This thing should stop like it slammed into a brick wall.
      My brother has the exact same setup on his '92 GTI and it is wonderful! The pedal is high, hard, and the car stops on a dime with little effort.
      Possible Fix
      The only variable left in the system that I can see is the vacuum booster. I'm not entirely sure how it would give the results I'm experiencing if it was worn out or leaking, but maybe?
      The booster is original to the car (which btw, came with 9.4" front discs) and has 205,000 miles on it.
      Please help!!
      Thanks [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by '88Jetta16v at 8:13 PM 10-1-2009
      Modified by '88Jetta16v at 12:59 AM 10-11-2009
      1988 Tornado Red Jetta GLI 16v / 1989 Cinnabar Red BMW 325is / 1989 Tornado Red Jetta GLI 16v / 1989 Bright Blue Metallic GTI 16v /
      1992 Montana Green GTI 16v / 1992 Black GTI 16v / 1992 Alpine White GTI 8v / 2001 Black Jetta GLX VR6 / 2001 Silver Metallic Audi A4 Avant TQM
    2. Member '88Jetta16v's Avatar
      Sep 5th, 2005
      Bechtelsville, PA
      10-01-2009 09:45 PM #2
      Autocrossing this weekend, hope to have this fixed.
    3. 10-01-2009 09:46 PM #3
      booster
    4. Member '88Jetta16v's Avatar
      Sep 5th, 2005
      Bechtelsville, PA
      10-01-2009 10:10 PM #4
      Would you mind explaining why you think the booster is the issue? Thanks. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    5. Member regendub's Avatar
      Mar 22nd, 2009
      Taco Ma Wa
      86 GLI, 66 Bug, 65 bug, 94 GLS
      10-01-2009 10:14 PM #5
      i second the booster idea. In class last semester we had a Toyota truck that went through multiple new master cylinders until we figured out that the booster had a bad seal and was leaking, causing the pedal to be soft, and no brakes.
      Need to know about your a2? Click Here
      Build Thread: Check It
      Quote Originally Posted by ennui_delphian View Post
      I set my mk2 on fire weekly, just to remind it who is boss
    6. Member
      Mar 31st, 2007
      Far from anywhere worth noting, VA
      Le Bomber.
      10-01-2009 10:47 PM #6
      Only thing left is booster. If everything is new (or like new) and the master cylinder was properly bled and the brakes are as well it has to be booster. You've got pressure just not enough right?
      Fifteen52's Official Facebook Page!
      Quote Originally Posted by rpmk4 View Post
      tl;dr = bitches be crazy
      If I have a post on here that has a dead pic PM me, I selfishly reorganized my photobucket in boredom.
    7. Member spoon!'s Avatar
      Sep 1st, 2005
      Bay Area, CA
      '05 A4 3.0Q 6MT | '92 Jetta | '69 T3 Squareback
      10-01-2009 10:55 PM #7
      It doesn't seem like you're getting any help here... probably because there are not many tech heads in this forum. Try thesamba.com
    8. Member '88Jetta16v's Avatar
      Sep 5th, 2005
      Bechtelsville, PA
      10-01-2009 10:57 PM #8
      Quote, originally posted by ennui_delphian »
      Correct.
    9. 10-01-2009 11:28 PM #9
      booster is leaking or filled with fluid
    10. Member F3t1sh's Avatar
      Oct 17th, 2008
      Gatineau, Quebec
      01 Allroad 2.7t
      10-01-2009 11:43 PM #10
      I say the booster might be the issue and I'd upgrade the MC to a 24mm one...
      Quote Originally Posted by Capt.Dreadz View Post
      Who's knows...it was the 80's...alotta coke was going around.
    11. Member mimisan's Avatar
      Jul 17th, 2005
      Twin Falls,Idaho
      10-02-2009 12:11 AM #11
      First you can check the booster vacuum source and check valve simply by starting the engine.As the engine runs,depress the brake pedal.If the idle drops,you have a leaking booster diaphragm.
      Next,actually pull the hose off the booster.You should have LOTS of vacuum at hose from motor.Try it also with engine off after idleing for a few minutes.You should also hear vacuum from booster being replaced by air as you pull it off.
      Backing up a couple of steps,pull the master back of and make sure there isn't any fluid in the bottom of the booster.Usually the engine would suck this in,but just check.
      The next thing I would check is the freeplay in the pedal.Pushing down on the pedal,it should be about a 1/4 inch before you "feel" the pedal hit the rod.Adjust if necessary.
      The last thing and maybe what the problem may be is the rod between the booster and the master cylinder.The depth of where these would touch may be different now that you've got a M/C that was not originaly for this car! Your bentley has the measurement for what it should be,no matter what size the M/C is now.
      Good luck with the project,and let us know the fix!!!
    12. 10-02-2009 07:52 AM #12
      Quote, originally posted by mimisan »
      good point, this happened to my buddy. the rod that contacts the plunger in the MC actually broke off and wasnt making full contact
    13. 10-02-2009 09:36 AM #13
      I would also double check and make sure the rear calipers have the bleeder screw in the proper orientation..
    14. Member '88Jetta16v's Avatar
      Sep 5th, 2005
      Bechtelsville, PA
      10-02-2009 04:29 PM #14
      Quote, originally posted by weefek »
      What do you mean by this?
    15. Member '88Jetta16v's Avatar
      Sep 5th, 2005
      Bechtelsville, PA
      10-02-2009 04:30 PM #15
      Great advice, thanks! I'll look into each of these. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by '88Jetta16v at 7:38 PM 10-2-2009
    16. Member '88Jetta16v's Avatar
      Sep 5th, 2005
      Bechtelsville, PA
      10-02-2009 07:38 PM #16
      No problem here, it seems. Idle does not drop when depressing the brake pedal.
      Haven't tried this yet. I'm a little worried about breaking the old brittle plastic elbow fitting at the booster.
      No problem here.
      This checks out correctly, too. Almost exactly a 1/4" travel before pedal hits the rod.
      Haven't check the measurement or anything, but...
      I have read in more than one place that the booster for all non-ABS Mk2s and G60 Corrados is the same exact specification unit.
      Further supporting that this would not be the issue is the fact that my brother's '92 16v GTI has the same brake setup I do and is not having this problem. And he's using the original booster. And that car also came with 9.4" front discs and a 20mm MC.
    17. Member '88Jetta16v's Avatar
      Sep 5th, 2005
      Bechtelsville, PA
      10-02-2009 07:44 PM #17
      Observations I just made:
      1.) When the engine is off, I cannot pump up the brake pedal enough to make it sit right at the top and move only a half inch or so under pressure as it should. Now matter how much I pump it, it still sinks 3 inches or so before becoming immovable.
      2.) Looking at the rear of the booster from inside the car where the rod passes into the booster: There is a lot of rotten orange foam around the rod that is crumbling. Much of it is missing already.
      3.) I hear lots of air rushing out down in the driver's footwell when depressing the pedal and sticking my head in the footwell.
      Does that help at all?
    18. Member waterwagon's Avatar
      Apr 7th, 2002
      Branchville, NJ
      '93 Cabriolet '89 Jetta
      10-02-2009 08:19 PM #18
      Sound like the booster is bad to me. If you can hear air rushing out of it, than it is shot.
    19. Member mimisan's Avatar
      Jul 17th, 2005
      Twin Falls,Idaho
      10-02-2009 09:35 PM #19
      You can also try to isolate each corner by pinching off brake hoses.If pedal gets firm,problem at calipers,then release one at a time to find which one is bad.
      If pedal still soft,is it possible master cylinder is bad?Is this NEW master or used
      from????
      I think the foam was mostly a sound dampner and filter for dust not to enter into back half of master.
      Is a power booster required with disc brakes? No. Although a power booster gives a good pedal feel, manual brakes work fine.
      What are the symptoms of a bad power booster? A bad power booster will give a very hard pedal, it will feel like you need two feet to stop the car.
      What does a booster do? A power booster helps assist pushing the master cylinder piston when you apply the brakes.
      How much pressure should I be getting to the wheels with a power booster?
      Typically you should expect about 1000 psi. to the wheels for a disc brake system. A disc brake system requires this amount of pressure so be careful when using a smaller 7" booster that puts out only 900 psi pressure.
      How much vacuum is needed to operate a booster properly? For a power booster to function properly you will need at least 18" of vacuum. Anything lower will give you a hard pedal.
      I have power drum brakes, can I use the same booster if I change to disc brakes? Yes. Just be sure to use a disc brake master cylinder.
      What happens if the vacuum is too low?
      If your vacuum level is too low you will experience a hard pedal and it will feel like the vehicle won't stop.
      How will I know if my booster is bad? A bad booster will give a very hard pedal and it will feel like the vehicle will not stop.
      How do I check to see if my booster is operating properly? Shut off the engine. Depress the brake pedal a few times to evacuate the booster Apply a steady pressure to the pedal and start the engine. The pedal should fall slightly.
      Will I need a special booster with 4 wheel disc brakes? The main consideration with 4 wheel disc brakes is that you have plenty of power assist. Don't undersize your booster with a 4 wheel disc set up.
      When I step on the brakes the pedal feels good but I get no braking.What could cause this? One of the causes of this is a mismatch between the booster pin length and the depth of the master cylinder piston hole. Be sure the hole is not too deep for the booster pin.
      I have installed a new booster on my car and now the brakes drag. Again this can be due to a mismatch between the booster pin and the master cylinder piston. Too long a pin will cause this.
      I have installed power brakes on my origional manual brake car and now the brakes are extremely sensitive. There are two attachment points on the brake pedal.For power brakes you need to use the lower attachment hole. Using the upper hole will make the brakes too sensitive.
      Power boosters keep going bad on my vehicles. You are probably getting corrosive vapors back into the booster. Install a vapor trap and that should eliminate the problem.
      CanI rebuild my own booster? This is not a good idea. There are many parts inside the booster that will require special tools to assemble and re assemble.
      How does a booster work?
      A power booster uses atmospheric pressure to help assist the pushing of the master cylinder piston. Basically, a power booster is divided into two chambers internally with a rubber diaphragm seperating each. With no force applied to the booster there will be vacuum on both sides of the diaphragm. This vacuum is supplied by the engine either from the intake manifold or the back of the carburetor.
      When you press on the pedal, the rod opens a poppit valve in the booster that allows atmospheric pressure on the firewall side of the diaphragm. This causes the diaphragm to push on the master cylinder piston thru a plastic hub, providing power assist to the master cylinder.
      [ Back ]
      Register / Login
      Remember meLost Password?Register Video Spotlight
      1) Front Disc Brake Video 2) Rear Disc Brake Video
      3) Boosters Assembly Video .
      Modified by mimisan at 7:41 PM 10-2-2009
    20. 10-02-2009 09:45 PM #20
      mk2 forum at its best
    21. 10-02-2009 10:07 PM #21
      Quote, originally posted by ’88Jetta16v »
      The bleeder screws must be pointed up , and be at the highest point on the caliper possible. I had mine on backwards once and bled the sh*t out of them, no air came out, but there was still air in there because the bleeders were pointed down
    22. Member '88Jetta16v's Avatar
      Sep 5th, 2005
      Bechtelsville, PA
      10-03-2009 10:06 AM #22
      I see what you mean, now. Both rear calipers are on correctly. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. 10-03-2009 11:15 AM #23
      i had to fully compress my rear calipers and use a block of wood to hold it at full in, then bleed. there were tiny air bubbles hiding
    24. Member '88Jetta16v's Avatar
      Sep 5th, 2005
      Bechtelsville, PA
      10-03-2009 02:32 PM #24
      Any more opinions or thoughts? Consensus seems to be the brake booster. I'll see if I can get a good used one. GAP doesn't carry them and AutohausAZ has them for $210.
    25. Member GTIMaxx's Avatar
      Feb 12th, 2003
      BPT, CT
      91 GTi 16v
      10-03-2009 07:27 PM #25
      i got my booster at 800-vw-parts for about $80.
      Also i seen a few newer VW that i worked on at my job is to pull the e-brake (parking brake as some would say) as far up as it can go then bleed the brakes.
      If it's worth building, it's worth over building.
