VWVortex.com - Fault code - 01218 - Side Airbag Igniter; Front Passenger Side (N200): Resistance too High
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 26
    Thread: Fault code - 01218 - Side Airbag Igniter; Front Passenger Side (N200): Resistance too High
    1. 10-06-2009 07:45 PM #1
      First of all, i am new here so HI everyone!!
      I have a mark 4 golf.
      about a month ago my airbag light came on and stayed on, so i had it read by a mechanic...cost me £25!! He cleared the codes and said if it comes back then u will need to replace a "squib".
      anyway the fault code is:
      Now the problem is, the priced he quoated me is way too much...and i am kind of broke right now so i been doing some research to see if i can sort it out by myself.....as last time i did this i haved about £150!
      anyway my question is this:
      Can i us this item in the ebay link below to read and clear the codes?
      <link to cheap ebay 3rd party interface removed)
      Also can anyone provide any help/tips/pointers on what is wrong and what i should do?
      thanks in advance
      Modified by Gozer The Destructor at 9:16 AM 10-7-2009
    2. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      02 Gti, 12 Tiggy SEL
      10-06-2009 09:13 PM #2
      A interface like this will work for a Mk4 VW http://www.ross-tech.com/Merch...AGCOM
      There are known problems with some of the early Airbag systems on that vehicle. I would not scan a Airbag system with a tool other than VCDS or Dealer equipment. See this http://www.ross-tech.com/vag-com/vw_issues.html
      Lastly Airbag systems aren't something to play around with if you do not have training. Keep in mind that igniters are explosives and can cause serious injury. A repair manual is also needed.
      http://www.ross-tech.com/Merch...de=VW
      OR
      https://erwin.volkswagen.de/er...PVWE1
      Edit:
      You may need to remove the Ebay link to prevent this thread from being locked.
      http://forums.vwvortex.com/zerothread?id=1201719
      Modified by Dana @ Ross-Tech at 9:15 PM 10-6-2009
      Dana Marie
      P.S. No Scan = No Soup
    3. 10-07-2009 01:56 PM #3
      thanks for the reply.
      that interface is the same as the cheap one on ebay.....i understand why you are advising to use the proper one as it is guaranteed to work....but can i cause any damage by using the cheap one?
      I think i will take your advice and not mess around with it myself as i dont really know anything about it. what does the airbag igniter look like?
      All i am hoping for is, if i can clear this code then maybe it will not return again.
      otherwise i will need to take it to a garage
      thanks for the help
    4. 10-07-2009 02:06 PM #4
      Also why is that cable $249 and it does not come with any software?
    5. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      10-07-2009 07:20 PM #5
      The software is FREE The license is included with the interface, no hidden fees.
      Download is here: http://www.ross-tech.com/vcds/....html
      Dana Marie
    6. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      10-07-2009 07:23 PM #6
      Quote, originally posted by greengolf09 &raquo;
      YES the Airbag module can be damaged. "Please avoid scanning the airbag controller in these cars, unless you are prepared to buy a new one!"
      Dana Marie
    7. 10-07-2009 08:33 PM #7
      Your problem is under the passenger seat. Vw has a the. buletin about this problem. Your harnes has to be made 4 inc. longer to reduse the resistense. I fixed some cars with the same fault.
    8. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      10-07-2009 09:35 PM #8
      That TSB pertains to a 2005.5 + M.Y. Technical Bulletin # 2011271 / 69-08-02
      Edit:
      It does not apply to your car at all, to clear the confusion.
      Modified by Dana @ Ross-Tech at 5:54 PM 10-8-2009
      Dana Marie
    9. 10-08-2009 10:33 AM #9
      Yeh the mechanic said somthing about the seat causing this problem. Says if you move it back and forth too much it can cause this. Will clearing the codes still fix this?..
      Also can anyone tell me where the airbag control uni is located in these cars?
      thankss
    10. 10-08-2009 10:34 AM #10
      I didnt get what you mean here? tsb? ...
      thanks
    11. Former Advertiser
      May 27th, 2002
      10-08-2009 10:48 AM #11
      TECHNICAL SERVICE BULLETIN
    12. 10-14-2009 04:01 PM #12
      oh ok thanks.
      can anyone tell me where to find the airbag controller on a gold mk4? and where would i plug in the vag com cable?
      thanks
    13. Former Advertiser
      May 27th, 2002
      10-15-2009 12:08 PM #13
      componet locations in the repair manual RTFB
      Look for what is called ALDL connector for OBD2 connector for Vag-Com
      Look for air bag controller location in reapir manual.
      READ READ READ
    14. 10-15-2009 04:30 PM #14
      i cant find it....ive been looking for ages...thats why i thought someone can decribe it to me.
    15. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      10-15-2009 05:53 PM #15
      http://www.ross-tech.com/vag-c...4.GIF
      Why do you have to find the module? Have you scanned it yet with VCDS via the OBD-II connector?
      With one of ....
      Modified by Dana @ Ross-Tech at 5:55 PM 10-15-2009
      Dana Marie
    16. 10-15-2009 08:14 PM #16
      no not yet....i wanted to check the model number on the airbag controller......where do i plug in the vag com?...same place? thanks
    17. 10-15-2009 08:20 PM #17
      also.....does the vag com software work with windows 7? thanks
    18. Member
      Feb 11th, 2004
      Magdeburg, Germany
      '67 Ford Mustang Conv.
      10-15-2009 08:37 PM #18
      http://www.ross-tech.com/vag-com/faq_1.html#1.16
    19. 10-16-2009 05:34 PM #19
      one mroe thing....where do i plug in the vag com cable?
    20. 10-17-2009 01:07 PM #20
      oh its ok i got it now. thank you all for all your help. really appreciate it. thanks
    21. 10-27-2009 03:59 PM #21
      Check wires underneath the driver seat, especially which connect with yellow connector.
    22. Member Lams's Avatar
      Jun 16th, 2003
      Brisbane Australia
      07 Eos 07 Caddy Camper 76 Bug 56 Bug
      11-08-2010 03:15 AM #22
      I have this fault every 3 weeks in my 3C Passat... usually I disconnect the yellow plug on the floor, replug it, clear the fault and it's OK for another few weeks.
      The under-seat plug has already been eliminated under both seats, and I'd like a more permanent fix... any ideas?
    23. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      11-09-2010 12:05 AM #23
      Hi Lams,
      That is not normal. If the wiring was already repaired as per the TSB under the seat and the connection to the floor is temporally resolving this problem, something's wrong.
      If that car is still under warranty I would take it to the dealer. If you want to look at live values post the Auto-Scan from this car with the fault code stored.
    24. Member Lams's Avatar
      Jun 16th, 2003
      Brisbane Australia
      11-12-2010 01:51 AM #24
      Hi Dana, that'd be great thanks. Here's my autoscan:
      VCDS Version: Release 10.6.1
      Data version: 20100831
      Friday,12,November,2010,16:50:17:11228
      Chassis Type: 3C0
      Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 53 55 56 62 72
      76 77
      VIN: WVWZZZ3CZ7E026574 Mileage: 87840km/54581miles
      00-Steering Angle Sensor -- Status: OK 0000
      01-Engine -- Status: OK 0000
      02-Auto Trans -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: Malfunction 0010
      15-Airbags -- Status: Malfunction 0010
      19-CAN Gateway -- Status: OK 0000
      37-Navigation -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      53-Parking Brake -- Status: OK 0000
      55-Xenon Range -- Status: OK 0000
      56-Radio -- Status: Malfunction 0010
      62-Door, Rear Left -- Status: OK 0000
      76-Park Assist -- Status: OK 0000
      77-Telephone -- Status: OK 0000
      Address 01: Engine Labels: 06F-907-115-AXX.lbl
      Part No SW: 3C0 907 115 Q HW: 8P0 907 115 B
      Component: 2.0l R4/4V TFSI 0030
      Revision: --H14--- Serial number: VWZCZ000000000
      Coding: 040C004319070160
      Shop #: WSC 22040 959 86313
      VCID: 2E58E141C065
      No fault code found.
      Readiness: 0000 0000
      Address 02: Auto Trans Labels: 09G-927-750.lbl
      Part No SW: 09G 927 750 T HW: 09G 927 750 T
      Component: AQ 250 6F 0937
      Revision: 00H38000 Serial number:
      Coding: 0000072
      Shop #: WSC 22040 959 68361
      VCID: 4280A5F164FD
      Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
      Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
      Component: ESP 440 C2 H015 0004
      Revision: H015 Serial number: 0667566244
      Coding: 0015779
      Shop #: WSC 05311 000 00000
      VCID: 3260F531D45D
      Address 08: Auto HVAC Labels: 3C0-907-044.lbl
      Part No SW: 3C0 907 044 AF HW: 3C0 907 044 AF
      Component: ClimatronicPQ46 050 0505
      Revision: 00050005 Serial number: 00000000000000
      Shop #: WSC 00000 000 00000
      VCID: 65CA5E6DD513
      Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
      Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
      Component: Bordnetz-SG H37 1301
      Revision: 00H37000 Serial number: 00000005823289
      Coding: E28E0F2700041A13000A00000F000000000A5D435C0000
      VCID: 3064FF39DA51
      Part No: 3C2 955 119
      Component: Wischer VW461 012 0503
      Coding: 00063445
      Shop #: WSC 05311
      Part No: 1K0 955 559 AE
      Component: RLS 060606 014 1201
      Coding: 00471077
      Shop #: WSC 05311
      1 Fault Found:
      01497 - Bulb for Blinkers; Front Right (M7)
      012 - Electrical Fault in Circuit - Intermittent
      Freeze Frame:
      Fault Status: 00101100
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 79
      Mileage: 87794 km
      Time Indication: 0
      Date: 2010.11.11
      Time: 17:34:00
      Freeze Frame:
      OFF
      Voltage: 12.40 V
      OFF
      ON
      OFF
      OFF
      OFF
      Address 15: Airbags Labels: 3C0-909-605.lbl
      Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
      Component: 16 AIRBAG VW8R 029 2521
      Revision: 10029000 Serial number: 003A3PA50X58
      Coding: 0012598
      VCID: 2E58E141C065
      1 Fault Found:
      01218 - Side Airbag Igniter; Passenger Side (N200)
      001 - Upper Limit Exceeded - Intermittent - MIL ON
      Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
      Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
      Component: J0527 0015
      Revision: 00005000 Serial number: 3C9953507P
      Coding: 0001312
      VCID: 2E58E141C065
      Part No: XXXXXXXXXXX
      Component: E0221 002 0010
      Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
      Part No SW: 3C0 920 870 T HW: 3C0 920 870 T
      Component: KOMBIINSTRUMENT VD1 1614
      Revision: X0006000 Serial number: 00000000000000
      Coding: 0007705
      Shop #: WSC 00999 444 64523
      VCID: 346CF3292E49
      Address 19: CAN Gateway Labels: 3C0-907-530.lbl
      Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
      Component: Gateway 007 0040
      Revision: 00007000 Serial number: 0700C0660208D2
      Coding: 7FFD1C44C62003
      Shop #: WSC 22040 959 65106
      VCID: 21420A7D81BB
      Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
      Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
      Component: IMMO 042 0383
      Revision: 00042000 Serial number: VWZCZ000000000
      Shop #: WSC 131071 1023 2097151
      VCID: 3972C21D092B
      Part No: 3C0 905 861 F
      Component: ELV 026 0380
      3C0905861F ELV 026 0380
      Address 37: Navigation Labels: 1K0-919-887-MFD2.lbl
      Part No: 1K0 919 887 B
      Component: Navigation 0001
      Coding: 0000101
      VCID: 3874C7193221
      Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
      Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
      Component: J386 TUER-SG FT 1124
      Revision: 12006001 Serial number: 00000561168520
      Coding: 0000693
      VCID: 3B7ED8150317
      Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
      Part No: 1K2 909 144 L
      Component: EPS_ZFLS Kl.136 H07 1806
      Shop #: WSC 02069 000 90108
      VCID: 356ACE2D2533
      Address 46: Central Conv. Labels: 3C0-959-433-46.clb
      Component: KSG PQ46 ELV 042 0472
      Coding: 1891020051030E763002941D7008DFCE107800
      VCID: 3972C21D092B
      Part No: 1K0 951 605 B
      Component: LIN BACKUP HORN H07 7001
      Part No: 3C0 951 171 A
      Component: Neigungssensor 002 0508
      Component: Innenraumueberw.002 0508
      Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
      Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
      Component: J387 TUER-SG BT 1124
      Revision: 12006001 Serial number: 00000548368531
      Coding: 0000692
      VCID: 3C7CDB090619
      Address 53: Parking Brake Labels: 3C0-907-801-53.lbl
      Part No SW: 3C0 907 801 G HW: 3C0 907 801 G
      Component: EPB VD8HC005 013 0005
      Revision: 013
      Coding: 0000012
      Shop #: WSC 40084 959 64233
      VCID: 26481961E895
      Address 55: Xenon Range Labels: 5M0-907-357.lbl
      Part No SW: 5M0 907 357 HW: 5M0 907 357
      Component: AFS-Steuergeraet 0003
      Revision: H09 Serial number:
      Coding: 0000006
      VCID: F1E2BA3D91DB
      Part No: 7L6 941 329
      Component: AFS-Lst.-Modul l X018
      Coding: 00000035
      Part No: 7L6 941 330
      Component: AFS-Lst.-Modul r X018
      Coding: 00000035
      Address 56: Radio Labels: 1K0-035-095.lbl
      Part No: 1K0 035 095
      Component: Radio 0001
      Coding: 0032402
      VCID: E2C0C571443D
      2 Faults Found:
      00877 - Treble Speaker Rear Right (R16)
      011 - Open Circuit
      00873 - Bass Speaker Rear Right (R17)
      011 - Open Circuit
      Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
      Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
      Component: J388 TUER-SG HL 1111
      Revision: 11004001 Serial number: 00000000170388
      Coding: 0000144
      VCID: 3D7AD60D1D03
      Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
      Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
      Component: J389 TUER-SG HR 1111
      Revision: 11004001 Serial number: 00000000177488
      Coding: 0000144
      VCID: 3E78D1011005
      Address 76: Park Assist Labels: 3C0-919-283.lbl
      Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
      Component: Parkhilfe 8-Kan 004 0011
      Revision: 00004000 Serial number: 82930617005949
      Coding: 0001024
      VCID: 28541759E281
      Address 77: Telephone Labels: 5P0-862-335.lbl
      Part No SW: 1Z0 035 729 B HW: 1Z0 035 729 B
      Component: FSE_2P7x H31 0050
      Revision: 00000001 Serial number: 00000005011435
      Coding: 0000422
      VCID: 3776C4253F3F
      End ---------------------------------------------------------------------
    25. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      11-12-2010 11:10 AM #25
      Quote Originally Posted by Lams View Post
      Coding: 0012598
      VCID: 2E58E141C065
      1 Fault Found:
      Hi Lams,
      Take a look in MB 5 for the live readings. You should see readings like: Correct, Signal too Low, Signal too High, etc..
      You can look at the live values and move the seat. Do not clear the fault code while you are near or under that seat! The Airbag system runs a self check after faults are cleared and with each key cycle...so I don't want to see a bag blow (if the wiring is shorted for example) while you are very near it.
      -Dana
