#106
Update on my 1/4 mile adventures. I haven't re-entered the thread because after my last post I kept scoring worse and worse. So I have been picking at my build trying to find weak points and I found a couple.
Leaky header/cat gaskets
HEAVY rims (now running 16" steels with proper rubber)
Persistent code (O2 #2 took a dump)
Sloppy torque mount that kept snapping bolts
Now she spins her new sticky 205s and I give unchipped GTIs a run for their money. But we aren't going to leave it there for my reappearance at my local dragstrip. No sir, I am ordering a short runner intake manifold. I may be pushing it a little but I plan to have the SRI installed by the 30th and have it on the car for the week leading up to the 6th to get the ECU used to it. So intake, SRI, shorty header, catless exhaust, chip, pendulum mount and lw pulley in sligtly high altitude Vegas. What do y'all think I can do?
#107
#108
Glad to see people getting out to the track.
Andre and I are back at it again and are working with a few companies on a 2.5L n/a build, we would like to go 12's all motor.![]()
Douglas VW
Distributors for FFE Racing, GoAPR, CTSturbo, IE and HPA
Innovative Motorsports + UM
#109
joel, care to share???
not planning on NA anymore, but i'm always interested in 2.5 development!
#110
Glad to see this thread get some activity again. Our local track got shut down but hopefully will get bought and opened again soon.
#111
11.89 @ 117.96 no453
GT35R 12psi pump 94oct street tires (AWD) full interior (3075lbs) 100% street car daily driven even in winter
http://www.youtube.com/watch?v=iHjwMt-azMM
http://www.youtube.com/watch?v=pTimQbwMiNs
http://www.youtube.com/watch?v=4JllXhnEVyQ
#112
#114
"The republic dies unless a new generation is reinvigorated to secure our lost liberties and reject the addictive notion of empire."
#116
taking my car to the track after work...hopefully we can get a mk6 on that list!
magnaflow catback - Unitronic Stage 1+ -FK Coilovers - Neuspeed P-Flo Intake- NLS Short Shifter-c2 sri(pending install and tune)
#117
#118
#119
#120
thanks..i know i can get it lower if i could get a better launch. it was boggin down to like 2k after my wheels stopped spinning which it doesnt do on the street.i had my tires at like 30psi.i think next time im just gonna leave them at 35psi or whatev there suppose to be.
#121
#122
Havent been to the track in a while. I'll be taking my car soon too. Doubt it will do anything special with stretched tires and all but we'll see.
Also mk6
#123
doubt i'm making this list. all i have is revo now. 16.4 16.5 is normal
http://www.youtube.com/watch?v=u-jLFDOfYu0
#125
#126
oh btw this was done with nothing taken out of the car.spare and all seats intack
#129
my laste time 15.63@89
my new time...
1/4 15.51@91 mph
1/8 10.01@71 mph
2.29 60ft
15.510 @ 91mph summer 11
#130
I might do some 1/4mi pulls when I finally get back up on the dyno to setup my w/m just to get a general idea. Pretty sure I'm at least capable of mid 13s with my current gear
-2007 Rabbit 2.5::: Denvers: smoked clear sides: Textured GTI rear lower: Magnaflow exhaust: Techtonics High Flow Cat: Podi Boost Guage: VEI Dual Display Gauge Oil Pressure/ AFR: C2 Stg 2 turbo: Turbo XS MBC: Forge 007 DV : o2j swap: Quaife LSD: Southbend Stg 3 clutch, single mass flywheel
On deck::AEM w/m kit:: BSH mounts
#131
#133
when i did mine i never got into 4th. as i was crossing the line i was getting ready to **** but never quite made it...i suspect with a good launch you would but i kept boggin down after wheel spin.i also rev out high due to my tune so it really depend on what you have done to your car. hope that helps
#134
I have a carbonio intake and straight through exhaust, dogbone insert and weight reduction to 2700lbs with a low tank of fuel. Once I get the unitronic tune I suppose i may have to shift to 4th
5 cylinder FTW
#135
I need to get back for a new time. Since my last visit, I've added a bfi stage 2 tranny mount and the ecs crank pulley. I hope it does something...
#136
where do you guys expect a 2010 golf to land in terms of times. I have intake, exhaust, and bfi dogbone and car weighs a 2700 with weight reduction on steelies. I put down 163 whp on a dyno dynamics. Maybe low 15's? hopefully? at 90-92? thinking the lower weight would help. saw steevo's time of 15.1 at around 91 with just an intake on an 09. Oh and for people shifting below 6k on 09 and up its probably better to take it near redline as we make power later. My car actually made the most hp at 6200rpm I have a dyno post up somewhere in the forums. The car feels slower after 6k only because of the loss of torque but hp is what gets you up to speed quicker.
5 cylinder FTW
#137
just did 11.121 @ 126.33mph 1.795/60ft . i also ran an 11.281 with an impressive 129.73mph
very happy
will post slip asap
#138
#139
here are the time slip from my 129.7mph run and my 11.121 run . im #757
#140
Haha what car were you racing on the first slip that did the 1/4 in 14.2 but was only going 65!? How the hell is that even possible or was that just a computer error or something?
http://s529.photobucket.com/albums/d...abbit%20build/
2006 Sage Green Rabbit 5spd| UM SRI manifold | UM 93 SRI tune | NLS Cai | Custom Eurojet exhaust | USP testpipe | ECS lightweight crank pulley | BSH motor/trans mounts |034 Dogbone core| NLS SS w/42DD bushings | GTI brake swap w/SS lines | Koni yellows w/H&R race springs | GTI rear sway |
