VWVortex.com - P2188 - System too Rich at Idle
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 90
    Thread: P2188 - System too Rich at Idle
    1. Member staulkor's Avatar
      May 21st, 2007
      Phoenix, Arizona
      2007 Fahrenheit GTI #776
      10-13-2009 08:42 PM #1
      I have been getting these codes for the past few weeks. I get quite a few throughout the week, all soft codes. However, every Tuesday night for the past 3 weeks my CEL pops on and this is what it shows:
      Quote »
      Tuesday,13,October,2009,21:14:26:04256
      VCDS Version: Release 908.0
      Address 01: Engine Labels: 06F-907-115-AXX.LBL
      Control Module Part Number: 1K0 907 115 H HW: 8P0 907 115 B
      Component and/or Version: 2.0l R4/4V TFSI 0040
      Software Coding: 0403010A1C070160
      Work Shop Code: WSC 78897 155 403174
      1 Fault Found:
      008584 - Bank 1; System too Rich at Idle
      P2188 - 008 - Implausible Signal - MIL ON
      Freeze Frame:
      Fault Status: 11101000
      Fault Priority: 2
      Fault Frequency: 10
      Mileage: 80535 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 11:42:42
      Freeze Frame:
      RPM: 767 /min
      Load: 24.7 %
      Speed: 0.0 km/h
      Temperature: 87.0°C
      Temperature: 21.0°C
      Absolute Pres.: 990.0 mbar
      Voltage: 14.351 V
      Readiness: 0000 0000
      I can't find much information about the code on vortex and there is no entry on ross-tech's wiki.
      Car runs fine. It blows a quite bit of black smoke from the RS4 injectors, but nothing different from day one of the injectors.
    2. 10-13-2009 09:04 PM #2
      I've encountered that on my MK5 GTI recently as well.
      I swapped out the existing MAF sensor with a spare one.
      Viola! No more codes...
    3. Member staulkor's Avatar
      May 21st, 2007
      Phoenix, Arizona
      10-13-2009 09:13 PM #3
      I have a spare MAF I can swap out. I will try cleaning mine first though. It has been a looong time since it was cleaned.
    4. 10-16-2009 12:37 AM #4
      any luck getting rid of the CEL?
    5. Member staulkor's Avatar
      May 21st, 2007
      Phoenix, Arizona
      12-08-2009 04:31 PM #5
      Time to bump this. I have had this CEL on constant since I created this thread. If I clear it, it comes back in 30 miles.
      I turned on the car earlier to move it up to my driveway. It was stone cold. I swapped the MAF with one I have laying around (works fine). After the MAF was swapped, I get back in and turn it on. It has passed the cat warmup period and the revs have dropped to normal idle. I look at the a/f and it is richer than normal. I give it a quick blip to 2000 and the a/f stays at 10.7 for a good 10 seconds after the revs have dropped back to idle. Is this normal? Might I have a failing O2 sensor?
      I have emailed revo twice about this CEL and got no response...
      When do they switch to winter blend gas? I would think mid October is a bit early for this area as it doesnt get col until mid November.
      Revo settings are on B9 T7 F9
    6. Member Krieger's Avatar
      May 5th, 2009
      Orlando, FL
      Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
      12-08-2009 04:51 PM #6
      what are u using to show ur AFR and EGT on ur head unit?
      and yeah, id say ur O2 might need to be replaced if all else fails.
      2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
    7. Member staulkor's Avatar
      May 21st, 2007
      Phoenix, Arizona
      12-08-2009 05:38 PM #7
      Quote, originally posted by Krieger »
      Car pc and a bluetooth OBD2 scanner with Dash Command running on the computer [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      On the way to class I noticed when I am coming to a stop, just before the car stop, the a/f plummets and goes to 9.5-10 for a short period of time and then comes back up to 14.6-14.7...
    8. Forum Sponsor Arin@APR's Avatar
      Jul 29th, 2008
      Auburn, Al
      B8 S4, MK7 TDI Golf SW, MK5 GTI, MK4 Jetta
      12-08-2009 05:46 PM #8
      So you clear the code and it comes right back after very little time? I take it your fuel trims go very out of whack in almost no time, right? Does your oil smell like gasoline? How bout if you change your oil, clear codes, and then drive around? Does it come on quite as quickly or does it suddenly take a bit longer?
      If that was a whole bunch of Yeses I think you may have lots of fuel in your oil either caused by the RS4 injectors washing down the cylinder walls or a leaky KMD HPFP. The fuel will get into your oil, then into your intake tract, finally messing with your fuel trims which will throw a rich off idle code.
      GoAPR.com | Facebook | YouTube | Twitter | Instagram
      Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
      Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    9. 12-08-2009 06:40 PM #9
      Hmmmmmm.... In your Sig it says "KMD Fuel Pump". You were looking for the cause of your CEL? Wellp there it is. It seized up on you, I've got $100.00 that says that's your problem.
      Sold the VAG COM
    10. Member staulkor's Avatar
      May 21st, 2007
      Phoenix, Arizona
      12-08-2009 08:50 PM #10
      er, double post >.<
      Modified by staulkor at 8:52 PM 12-8-2009
    11. Member staulkor's Avatar
      May 21st, 2007
      Phoenix, Arizona
      12-08-2009 08:51 PM #11
      Quote, originally posted by Arin@APR &raquo;
      Code comes back after 30 miles of driving. Fuel trims are actually ok for RS4 injectors, -0.3% short -4.5% long. Well I need an oil change so of course it will smell like gas since it has 5000 miles on it. I will have to wait a short time once the new oil is in to get a fair reading on that. And same goes to see if the CELs go away with new oil.
      Quote, originally posted by rippie74 &raquo;
      Where is my $100 because I still push my 130 bar all day long. Ive had a seized pump, I know what they do and how they act when they are seized...it aint seized [IMG]http://*****************.com/smile/emthup.gif[/IMG] Leaking? Possibly. But there are some other, more likely, things that it could be before that imo.
      On a side note, replaced MAF and cleared codes before I went to class. 25 mile drive each way, CEL came on on the way home, lol.
    12. 12-08-2009 10:11 PM #12
      I'm telling ya bro, it's the hpfp
      Sold the VAG COM
    13. 12-08-2009 11:18 PM #13
      The pump internals are not the ones responsible of the possible leaks, we have had hpfp failures in oem pumps, kmd pumps and autotech pumps, so ill be carefull to call out a certain brand here.
      the possible fail is caused because the spring seal of the oem hpfp goes bananas, cause you install a brand new pump into a allready used seal so the used seal, seals so to speak around the oem shaft, you put a brand new shaft in there call it kmd, autotech or awe and the seal its never going to be perfect, in some cases it fails in some it doesnt, so its better to install the internals in a brand new pump.
      to the OP smell your oil if it smells too much to gas, then likely your hpfp its gone, if thats the case just buy a new one swap your kmd internals and you shouldnt have any more problems, if the problem persists send me a PM i now a little secret that also causes this problem and its a 35 dlls piece
      Modified by mexico@unitronic.ca at 8:22 PM 12-8-2009
    14. Member vwgtimk41088's Avatar
      Oct 31st, 2007
      Henrietta, Ny
      06 Jetta GLi,
      12-08-2009 11:44 PM #14
      Hasn't been mentioned yet, are you running OEM PCV or an aftermarket setup.
      IIRC this could be associated with the PCV system.
    15. 12-08-2009 11:46 PM #15
      Quote, originally posted by vwgtimk41088 &raquo;
      I've still got that $100.00 on it that it's the hpfp, any takers?
      Modified by rippie74 at 6:45 PM 12-10-2009
      Sold the VAG COM
    16. Member Krieger's Avatar
      May 5th, 2009
      Orlando, FL
      12-09-2009 12:40 AM #16
      if its the HPFP, its the seals, not the internals.
      otherwise im still saying O2.
    17. Member staulkor's Avatar
      May 21st, 2007
      Phoenix, Arizona
      12-09-2009 12:48 AM #17
      Quote, originally posted by Krieger &raquo;
      I am going to "borrow" my sister's O2 sensor and see what happens
    18. Member jhines_06gli's Avatar
      Feb 2nd, 2006
      Wesley Chapel, NC
      65 Bug, 81 Caddy+trailer, 83 GTI, 84 GTI, 92 GTI VR, 01 TT225, 02 TDI Beetle, 06 GLI, 68 Mustang
      12-09-2009 07:08 AM #18
      what value do you have in block 32, field 2? Make sure you have not cleared code for about 100 miles or so and let me know what that reading is......
      -J. Hines
      Oil cap smell like gas?
      Volkswagen South Charlotte
      a.k.a. VSC Tuning
      Unitronic through the
      dealership environment!!
    19. 12-09-2009 07:15 AM #19
      When the seals fail the pump piston gets scored/scratched up & then seizes. That's why I said previously that it's a hpfp failure. I speak from personal experience on this one.
      Sold the VAG COM
    20. 12-09-2009 07:58 AM #20
      I had similar symptoms but my fuel trims were way worse. It was a leaking seal on the HPFP.
      -Cad
    21. 12-09-2009 08:10 AM #21
      O2 sensors don't just go bad, and replacing them is just a bandaid to whatever the real problem is. Silicone is a big no no for O2 sensors but the fact the you have this code is actually telling you that your O2 sensor is working properly. They generate a voltage based on the amount of HCs in the gas stream, varying from about 100mV to 900mV averaging about 450mV. If they are generating consistently higher or lower than this your ECU will take note.
      Pulling your HPFP is easier than swapping O2 sensors.
    22. Member jhines_06gli's Avatar
      Feb 2nd, 2006
      Wesley Chapel, NC
      12-09-2009 09:17 AM #22
      The KMD pump internals are about 0.098mm larger in diameter than the factory pump shaft.
      Say you have 30K miles on your factory pump.......the spring-loaded seal is formed to the EXACT size of the shaft and when you shove the slightly larger KMD shaft through, it stretched the seal ever so slightly. But we are dealing with EXTREME heats here since it's bolted to the head and fuel which can get about anywhere!!
      And yes, if you let the issue go on long enough, you will scar the shaft and will need new internals, BUT if you have the latest version with the coating, this is not an issue! If the fuel in oil continues to go on for a even longer, you compromise having the bearing shells seperate from the materials on your rods and mains.......so BE CAREFUL how long you let this go on! You need to get the HPFP out and internals swapped to new unit ASAP!
      -J. Hines
      PM me, I have multiple pumps brand new in bags for this reason.....you should put a 100% UNUSED HPFP in with rebuild to ensure there are no issues!
      a.k.a. VSC Tuning
    23. Forum Sponsor Arin@APR's Avatar
      Jul 29th, 2008
      Auburn, Al
      12-09-2009 10:11 AM #23
      Quote, originally posted by mexico@unitronic.ca &raquo;
      I meant no disrespect by mentioning the KMD pump, however as you mentioned the spring seals do 'go bananas' and leak. We discovered this early on in our fuel pump development program and as such install brand new seals with every pump. KMD pump reuses these seals, thus increasing chances of damage and leaking.
      For the record, I have not seen an alarming rate of OEM pumps leaking. I actually don't think I've ever personally seen it happen. I've only see the issue after the internals were swapped and the spring seal was reused.
      Quote, originally posted by staulkor &raquo;
      So when the code comes on your fuel trims are only at -4.5%? In the cases I've seen similar to yours (rich/lean) fuel trims were above +-15% all the way to the max limit.
    24. Member wazzap1101's Avatar
      May 1st, 2009
      Long Island
      APR STG 3 2007 VW MKV GTi DSG
      12-09-2009 02:09 PM #24
      X2, O2 sensors will mess with the A/F ratio
    25. Member staulkor's Avatar
      May 21st, 2007
      Phoenix, Arizona
      12-09-2009 04:02 PM #25
      On a side note, I just passed emissions, LOL. Maryland fail
