VWVortex.com - Bluetooth audio on 2010 CC sport help
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 57
    Thread: Bluetooth audio on 2010 CC sport help
    1. 10-13-2009 09:24 PM #1
      I have a 2010 CC with the touch screen radio and factory bluetooth, I cannot get my Tmobile G1 to connect to the bluetooth audio feature under the "MEDIA" button, the regular phone option pairs flawlessly but not for the audio, any ideas why?
    2. 10-13-2009 09:28 PM #2
      Dude, i tried it with my iphone 3gs, total fail. Tried it with two other bluetooth audio phones.... also fail.
    3. 10-13-2009 09:32 PM #3
      its so weird, i cant figure it out at all, ive tried the option on aftermarket headunits like pioneer and it works fine so it cant be the G1.
      btw we got the same car and im also in BK!
    4. 10-13-2009 10:13 PM #4
      Yep, tried to sinc my phone to the media option also, no go. Can use it through the cell bluetooth just fine.
    5. 10-14-2009 10:27 AM #5
      Same problem here with my 2010 CC Sport. Even though there is a setting to enable Bluetooth Audio, I was not able to connect my blackberry. I am wondering if the dealer would be of any help.
    6. Member M3Tech's Avatar
      Jan 26th, 2007
      Ft Lauderdale, FL
      2012 M3/2010 CC
      10-14-2009 01:57 PM #6
      The question is, what OEM Bluetooth module the CC has installed from factory?
      The only VW published OEM Bluetooth module that supports A2DP is the Volk-L accessory. The report above that the "C" version of the "Skoda" module -729 supports A2DP is new. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      The "Bluetooth Audio" enable screen will show up in the RNS-510, regardless if the Bluetooth module supports it or not, so it is not necessarily an indication of the actual feature being present.
    7. 10-14-2009 02:37 PM #7
      You know... this it totally bull****! I was on the phone with v/w and they assured my that it was my iphone's fault that BT audio didn't work. ARGH. I i'm gonna call them a flip out, maybe they'll send me an MDI for all the trouble.
    8. 10-14-2009 04:06 PM #8
      I have the 2010 touch screen non nav (RCD-510) and I was able to hook up my iPhone via the bluetooth.
      The radio never asked or told me about the PIN/Code to use. The dealer told me it was "1111" or "0000" (i forgot).
      I turned on the bluetooth in the car and then turned it on on my phone. Then the phone recognized the car and I entered the code.
      Voila...it worked.
      The whole process was not like most other device connections where the radio tells you what code to enter into the phone. So I went with what the dealer told me.
      Good luck!
      Check out my VW CC Forum! http://dervwcc.com
      We need members looking for a great new forum. We're setup to easily find info about the Volkswagen CC.
    9. Banned iPinch's Avatar
      Oct 24th, 2008
      Chesapeake, VA
      askavwsalesguy.com
      10-14-2009 04:07 PM #9
      Bluetooth Audio must be enabled before you can use it
      http://askavwsalesguy.wordpres...ystem/
    10. 10-14-2009 04:12 PM #10
      I already tried that and it still does not work.
    11. 10-14-2009 04:20 PM #11
      Yeah same here. The BT-Audio button is greyed out.
      May 5th, 2003
      Atlanta, GA
      New 12 CC R-line , 10 CC, 08 GTI, 05 GTI 03.5 GTI
      10-14-2009 05:56 PM #12
      Same here..... my 10 Sport will not do BT audio either. Come on VW, if its as simple as a module not being there own up to it and let the customer have the option of getting it. Stop burying your head blaming it on the phone.
    13. Member M3Tech's Avatar
      Jan 26th, 2007
      Ft Lauderdale, FL
      2012 M3/2010 CC
      10-14-2009 05:56 PM #13
      Quote, originally posted by thisisnotdave »
      That looks like a 0360 firmware change (I'm running 0320)...
    14. Member M3Tech's Avatar
      Jan 26th, 2007
      Ft Lauderdale, FL
      2012 M3/2010 CC
      10-14-2009 05:59 PM #14
      Quote, originally posted by jaronbrass »
      M3Tech,
      According to ETKA, all 2010 CC's have the "C" module if they were built after 6/22/2009.
      The same module is specified for other models, as well, which do have A2DP support based on various comments on here and other forums. I believe this applies to Jettas and Tiguans.
      You said that you made the -C version work with the A2DP after some "significant amounts of trial, error, and calls to my buds"... what you actually did? Because it looks to me that it is not as simple as enabling the A2DP at the RNS-510.
    15. 10-14-2009 06:25 PM #15
      According to the RCD's manual (which is not presently in front of, so not in verbatim.) you need to change some setting on your phone and the button will ungray. Honestly this is pretty annoying. I'm lazy call them right this minute. But calls will happen.
    16. 10-14-2009 09:09 PM #16
      So noone else is able to simply just pair any phone? I dont even have a manual for the headunit, so I cant see what other types of setting i have to enable or change on my G1, and for the record the "activate bluetooth audio " is checked.
    17. 10-15-2009 12:34 AM #17
      Jaron,
      Thank you for your post. If you don't mind, I'm not as technically savvy as you and many others who post here, and I'd like to ask you a question.
      I've just purchased a 2009 CC, with tech package, and Bluetooth with Voice recognition. I am able to enable Bluetooth Audio in the Setup screen on my RNS-510, but like everyone else, I get no connection. If I understand your comments correctly, I still may need the C module for A2DP connectivity because my manufacture date is prior to 6/22/09?
      Thank you in advance,
      Dave
    18. Member M3Tech's Avatar
      Jan 26th, 2007
      Ft Lauderdale, FL
      2012 M3/2010 CC
      10-15-2009 07:08 AM #18
      I mentioned this in another thread... I used the Volk-L harness with both the C and D modules and A2DP worked on both modules. The Volk-L harness has both L and R audio channels going in to the RNS-510, whereas most of the aftermarket harnesses only use the L channel. This is because Volk-L supports A2DP.
      The VW engineers I've worked with on this (as I've said, VW is a client of the company I work for... the engineers are friends as are many other people throughout the company) state that the Bluetooth interface module needs to see both the L and R audio channels, even if it is coded to support A2DP.
      As for the coding, I don't have it handy because I don't have my vehicle. It's undergoing repair for something unrelated.
      They helped me do this and it works in both my CC and my R32.
      That's interesting, to say the least... however, that also tells me that either these factory-installed OEM Bluetooth modules harnesses are incorrect, that these modules are neither C- or D, so there is no A2DP at all, or that the C- or D modules are indeed installed but its controller coding is missing the A2DP enable bit.
      I remember seeing the Volk-L installation document somewhere here and it mentioned something about Bluetooth Audio coding depending on the OEM HU installed.
      A visit to a dealer can solve this very quick, and it should be a warranty visit -only if Bluetooth Audio was stated as an included feature in any of the CC documentation. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    19. 10-17-2009 12:02 PM #19
      Well, in the manual it is discussed. So I presume it is there. The fact that there is an option to enable it and disable it indicates that it should work. May be I will pay a visit to the dealer, I am not hopeful though.
    20. 10-25-2009 05:53 PM #20
      I have the same problem with my 2010 Jetta TDi w/ RCD 510. I had no problems connecting my the phone part of my Iphone via bluetooth, but getting the music to play via bluetooth has not been as simple.
      I have heard that the Iphone will only work with headphones and will not work car headsets via bluetooth
    21. Banned iPinch's Avatar
      Oct 24th, 2008
      Chesapeake, VA
      askavwsalesguy.com
      10-25-2009 06:50 PM #21
      ******** UPDATE************** ******** UPDATE**************
      The 9W3 option found on the CC does not support bluetooth audio streaming. only cars that support it is the Jetta S, SE, Wolfsburg, all Sportwagen models, Golf and GTi becuase they use the 9W2 option.
      Modified by iPinch at 3:51 PM 10-25-2009
    22. Member
      May 5th, 2003
      Atlanta, GA
      10-26-2009 11:21 AM #22
      See, this is another reason while its now the year 2009 and bluetooth audio should be standard. Here we have a radio that is capable, but thanks to VW not having things done across the board we get screwed again!!!!!!
    23. 10-26-2009 12:05 PM #23
      To let you guys know, I just got back from the VW Service department. Was told they couldn't help me with any aspect of the radio / nav. They told me my sales person would do that -- and my sales person told me the service department would.
      Considering I'm not getting all the functionality of the Phone feature either, this is frustrating. I know zero about the VAG-COM coding, but I'm wondering if I buy that kit, if there are any adjustments I can make to the core settings.
      I'm all about doing it myself if I can, not to mention the ability for anyadditional functionality beyond this BT Audio issue. I know, VAG-COM may not even be the solution to this, but I know people have used that to enable other features.
    24. Member M3Tech's Avatar
      Jan 26th, 2007
      Ft Lauderdale, FL
      2012 M3/2010 CC
      10-26-2009 03:22 PM #24
      Quote, originally posted by iPinch »
      That looks to me more like a hardware issue than anything else, as in the stereo wires in the back of the quadralock connector in the CC's RNS-510 are not present from factory, only the mono wires.
    25. 10-26-2009 03:51 PM #25
      Well I called VW today about that. I'm gonna try to get something out of them for this. It's pretty ridiculous to advertise an option but neglect to actual install it. I'm going for gold. Free MDI install!
      The person at customer support had no idea what I was talking about and said he'd research it and call me back.
