VWVortex.com - Help! Hood wont close after jetta front end swap
    Results 1 to 18 of 18
    Thread: Help! Hood wont close after jetta front end swap
    1. 10-14-2009 12:23 PM #1
      So i swapped front ends with a Jetta and for some odd reason i am not able to close my hood now. It wont completely latch and i have no clue why.
      I know the fenders and hood are aligned properly. Well at least i think so everything matches up really well but close the hood and it wont fully latch. Gti hood would close and latch no problems, but this jetta hood is giving me problems. Please help.
      Modified by Michael744526 at 9:34 AM 10-14-2009
    2. Member ColonelJTI08's Avatar
      Mar 30th, 2009
      Cincinnati, Oh
      2003 JTI 1.8T, 1997 Honda Civic (RIP)
      10-14-2009 01:33 PM #2
      It's your car saying, "remove these damn eyelids, or i will fling the hood up at the windshield while you are going 70 on the interstate."
      May 25th, 2006
      Doylestown PA
      10-14-2009 01:41 PM #3
      Will the hood latch on the first hood catch, but then you can not get it to lock? Try raising the hood latch assembly.
    4. Member ruetzal's Avatar
      Dec 17th, 2007
      Wisco
      '13 WRX, 2009 A3 sold, '03 GTI sold
      10-14-2009 01:41 PM #4
      there has to be something in the way check the side of your engine bays something stupid may be in the way. its not going down far enough then.
      dam dude u guyz have enough dogs?
      Modified by ruetzal at 10:44 AM 10-14-2009
    5. 10-14-2009 01:42 PM #5
      Quote, originally posted by ColonelJTI08 »
      werd.
      Quote Originally Posted by Imola4 View Post
      I recently graduate harvard and now am a lawyer and making what you call "bank" and now officially a "balla" since i make the bank and slap hoes
    6. 10-14-2009 01:44 PM #6
      Quote, originally posted by motoo344 »
      Yes it will latch just not lock and i have messed around with the assembly numerous times still no luck. I also think the headlights might be the problem but then again i dont know because it would not lock when they where off.
    7. Member ruetzal's Avatar
      Dec 17th, 2007
      Wisco
      10-14-2009 01:47 PM #7
      if it looks like it fits right just raise the latch assembly up a hair
    8. 10-14-2009 01:55 PM #8
      Quote, originally posted by ruetzal »
      You think the assembly can go bad? Ill try raising it again, but i dont think it will help.
    9. Banned 6aJettaChick's Avatar
      Apr 24th, 2007
      In The Kitchen.
      2002 1.8T.
      10-14-2009 01:59 PM #9
      You have lots of pupperdoodles. And eyelids.
    10. Member ruetzal's Avatar
      Dec 17th, 2007
      Wisco
      10-14-2009 01:59 PM #10
      why don't you just test it. take a bolt and push it down to see if it locks.
    11. 10-14-2009 02:06 PM #11
      Ill try that first once i can get a chance. If it locks though how will i get it to lock the actual hood down
    12. Member DubCityVR6's Avatar
      Jun 26th, 2006
      Jacksonville, FL
      2004 BMP R32, Mk5 Jetta (wifes ride)
      10-14-2009 02:10 PM #12
      adjust the latch assembly up higher
    13. Member ruetzal's Avatar
      Dec 17th, 2007
      Wisco
      10-14-2009 02:11 PM #13
      well if you latch is working then something is off. how is the fitment of your front quarter panels? Go over all the panels you put on making sure everything looks right. Also make sure nothing is in the way of the hood going down all the way. Also check the gaps between your side of your hood and the fenders there should be that 1/2 gap all the way down if not then the panels are on incorrectly
      I have never swapped out front ends but I don't think anything was different on the latch assemblies throughout the years with mk4's but someone may know something I don't. But I would measure and take a look at your old hood just to be safe. Otherwise try raising the latch assembly a little more and that may do it
      Also take those eyelids out it just ruins it.
      Modified by ruetzal at 11:14 AM 10-14-2009
    14. 10-14-2009 03:03 PM #14
      lower it
    15. Member Skinner's Avatar
      Oct 11th, 2005
      SoFLA and Tampa, FL
      2001 Jetta VR6 GLX
      10-14-2009 03:05 PM #15
      have you tried slamming it? My latch is just internally rusty and stuck and you really have to give it a slam when closing it.
      SixDigitClub
      (FiSHBOWLSTAtUS) ><(((*>
      Suede is Played
      ♥ Mila
    16. Member Ignapu's Avatar
      Nov 24th, 2007
      Portland, OR
      1996 Golf
      10-14-2009 04:05 PM #16
      same thing happened to me when i changed out my radiator support, you just need to adjust the latch, it might take a few tries but im sure thats the problem.
    17. Member ....shane......'s Avatar
      Oct 27th, 2008
      mississauga
      03 jetta 1.8t
      10-14-2009 04:49 PM #17
      same thing happened when i put my golf front end i hade to adjust the hood bolts and slide hood till it latched
      Quote Originally Posted by Turbo_Joe View Post
      I didn't buy the car to treat is like someone I love...I am gonna treat it like my ugly red-headed step child and beat the sh!t out of it everyday.
    18. 10-14-2009 04:56 PM #18
      I have no input but when you do this swap do you need to swap rad support also? If not then maybe just need to adjust latch or hood hight adjustments at the nose of the hood, i dont have any so im not sure if they are supposed to be there or not.
