VWVortex.com - DIY -- changing the thermostat
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 63
    Thread: DIY -- changing the thermostat
    1. Member VeeRsixx's Avatar
      Jan 5th, 2004
      Harrisburg PA
      '04 R32 Black Magic
      10-17-2009 06:41 PM #1
      This is a quick DIY about how to replace the thermostat in your R32.
      It seems that a lot of them are getting stuck and are causing a MIL at this time of the year, particularly as the cars are turning 5 years old. In my case, it generated DTC 18613 P2181. Make sure your cooling fans are operating properly before proceeding, as it will save you time.
      Removing the entire [plastic] thermostat assembly from the side of the head is the easiest way to do this, and is the recommended method in the Bentley service manual. There are helpful diagrams in the manual, but i cannot post them because they are copywrited. I would advise you to review them prior to this project just because it helps.
      Required tools:
      - hose clip pliers, unless you want to use a more difficult method like vise-grips, etc.
      - 5mm hex bit
      - ratchet for the above
      - 6" extension for the above
      - T-20 torx bit / wrench to remove plastic plenum(s) under engine (bellypan)
      - normal assortment of screwdrivers
      - nitrile gloves and a small piece of plastic sheeting, 2 mil thick is ok
      Required parts:
      - thermostat: 022 121 113
      - gasket ring for the above: N 901 368 02
      - gasket between t-stat assembly and head: 021 121 119 A
      - G12 coolant and distilled water to mix 50/50 or so and refill the system
      Other parts upon your choice:
      - coolant distribution (crack) pipe O-ring: N 101 392 01
      - new green-top coolant temp sensor: 059 919 501 A
      - O-ring or 'seal' for the above: N 903 168 02
      - retaining clip for CTS above: 032 121 142
      - the 3 metal clamps for the coolant hoses on the thermostat assembly:
      N 909 265 01
      N 906 871 01
      N 906 872 01
      To replace the entire plastic coolant flange on the side of engine if it is suspect or warped:
      top part that bolts to head: 022 121 117 C
      bottom part under the thermostat: 022 121 121 E
      DON'T OVERTIGHTEN ANYTHING PLASTIC, IT WILL BREAK !!
      I could not fit a torque wrench in the area needed.
      Ok, here we go, basic prep:
      Use the torx T-20 bit to remove the center and left side belly pan (plastic plenums) under the car. I chose to drain all of the coolant out prior to this job because i did not want excess to spill onto my shifter assembly, the grounding point that is near it, the SAI pump, starter, and the associated electrical connectors. It is manageable if you use some old towels to clean up what leaks out. I am not proud; i drained the coolant into a [new] cat litter pan.
      Wear eye and hand protection; try not to take a bath in G12; it is toxic. Please make sure to dispose of or recycle it properly in compliance w. your local laws. It cannot be dumped outside or flushed down a sewer.
      Time to start, cooling things off w. fans.
      Remove the engine and battery box cover:
      Remove the center and left side plastic undertrays (bellypans, whatever..) so you can drain the coolant. When you have the plastic shields off, get under the car and look up towards the left side of the radiator and observe the connecting hose and how to remove it. It is held in place by a metal clip over the plastic 'quick' connector. Pry the bottom prongs loose w. a screwdriver, then pop the whole clip up and off where the green arrow is pointing:
      I threw this together quickly, so my arrows, circles, pics, and whatever are not very good.
      This what the lost coolant looked like when completely finished; the black debris is dirt that was washed from the engine bay on its way down to the kitty pan:
      Remove the battery and battery tray:
      This is what we are going to remove:
      Put in some plastic to protects the vitals:
      Take the biggest hose off first, note the hose-clamp pliers:
      All 3 hoses removed:
      Remove these bolts w. the 5mm. hex bit:
      Use the 6" ratchet extension to get the smallest one last (to the left you can see where the 2 longer bolts have been removed):
      Here are the bolts on the garage floor. Not sure why i took this pic:
      Pull the t-stat assembly away from the head. Pull it back straight and smoothly off of the 'crackpipe'. We don't want to dislodge the other end which is on the other side of the head at the water pump.
      Remove CTS and its retaining clip:
      Remember to replace the O-ring.
      Up and out !
      Now there is easy access to the thermostat:
      I cleaned up the flange on the head w. only a paper towel:
      Here is the infamous crack pipe O-ring. Lube a new one w. coolant and replace.
      NOTE: NEVER twist an O-ring. Just apply firm pressure and push straightly. It won't hop over the lip on the flange, don't worry-- but if you twist it will tear and be ruined !
      All cleaned up and on the operating table:
      I took this shot for ian (Daemon42). In an old thread he talked about etching in points of grip on the small hex bolts w. a Dremel. Mine seemed to have them from the factory, dunno:
      Take out the 3 5mm alllen bolts:
      Carefully pry out the old thermostat w. a flat blade screw driver. Put the new one in after lubing the new gasket w. coolant:
      Replace this important gasket. Pry the old one out very carefully w. a small flatblade screwdriver, then lube the new one w. coolant before working it back into the channel in the plastic housing:
      Back in:
      Buttoned up:
      Done:
      Post Script:
      Gaskets and O-rings:
      Hose clamps and clamp pliers:
      Correction to pic above: the smallest clamp, the rightmost one, is p/n N 906 871 01
      credits to the Above-and-Beyond crowd:
      graeme86
      vwapasionado
      newcreation
      BLU R32 (Joe)
      all the rest of 'ya
      edited to correct a part #.
      Modified by VeeRsixx at 6:51 PM 10-20-2009
      past dubs: (all black) - 1984 GTI - 1992 GTI 16v - 2001 GTI VR6
    2. Member newcreation's Avatar
      Nov 23rd, 2003
      HBG, PA
      04 R32T
      10-17-2009 06:45 PM #2
      Good Job Rob proud of your work!!!!
      -JAMES CRIST JR-
      DRIVEN/Built /UM Turbo R
    3. Member rabbitgtibbar's Avatar
      Apr 29th, 2002
      Merlin
      uR32T, 2015 A3 P+, 2003 Jetta GLS 1.8T Wagon
      10-17-2009 07:23 PM #3
      Quote, originally posted by VeeRsixx »
      I recently changed the t-stat in my wife's car ('03 Jetta) and noticed that when the coolant got on my bare hands it would start burning after a few seconds (the coolant itself was cool), so heed this warning.
      Yes, I know I'm a jerk. That doesn't make me wrong, though.
    4. Member Gundem's Avatar
      Jul 1st, 2006
      Los Angeles, CA
      MKIV R32, B5 A4, MKV Jetta, Mini
      10-17-2009 07:35 PM #4
      holy s***... No wonder labor is that expensive.
      Nice job on DIY
    5. Member Daemon42's Avatar
      Feb 9th, 2001
      colorado
      04 R32T, 95/98 4runner
      10-17-2009 08:02 PM #5
      Quote, originally posted by Gundem »
      Nice job on DIY
      Honestly anyone who's done it more than once (a mechanic) should
      be able to do that whole job in under an hour. Certainly easier
      to do it the way he did, removing the whole housing rather
      than trying to get just the T-stat cover off and back on again, in-situ
      as I did.
      Added to the FAQ/DIY thread.
      ian
    6. Member robocopywriter's Avatar
      Jun 17th, 2004
      Los Angeles
      Mk IV R32, Mk II 16v Gti
      10-17-2009 10:33 PM #6
      ha ha just what I was thinking. I took mine off just to change to a green top sensor when I was going my cams. It's not that big a deal. Everyone says what a POA it is. If you want a POA try changing the thermostat on a 16v.
      Rent my house in Greece.
      http://kastro-greece.com
    7. Member Basil Fawlty's Avatar
      Sep 7th, 2003
      Wisco
      fcuk all
      10-17-2009 10:53 PM #7
      The local dealership quoted me 370.00 to do this job.
    8. 10-18-2009 12:42 AM #8
      Excellent documentation Man.
      I am glad to see that you got rid of the damn code...
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    9. Former Advertiser
      Jun 29th, 2009
      Summit, NJ
      10-18-2009 12:15 PM #9
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] for a great DIY!
    10. Senior Member PowerDubs's Avatar
      Jul 22nd, 2001
      NWNJ
      10-18-2009 01:08 PM #10
      Quote, originally posted by robocopywriter »
      Whhaaaa?? I changed the thermostat on my first 16v in a parking lot with minimal hand tools. I didn't even have a jack, I drove the passenger wheel up onto the curb and crawled underneath.
      -Josh
      1-12-5-8-3-10-6-7-2-11-4-9
    11. 10-18-2009 01:44 PM #11
      great DIY write up. this reminded me of a heart transplant.
    12. Member Slampig's Avatar
      Jun 20th, 2008
      Rhode Island
      24vT GTI
      10-18-2009 04:49 PM #12
      got to do this sometime
    13. 10-18-2009 05:37 PM #13
      So how much did everything cost to do the thermostat change? Also does everything have to be bought at a VW dealership or will a auto parts store carry the parts required?
    14. Member AaronD's Avatar
      May 5th, 2002
      NJ
      '04 R32 DBP
      10-18-2009 05:53 PM #14
      next weekends project..unfortunatley. thanks this should make it quicker than the way ive done it before on 2.8's
    15. Member VeeRsixx's Avatar
      Jan 5th, 2004
      Harrisburg PA
      '04 R32 Black Magic
      10-20-2009 07:58 PM #15
      Quote, originally posted by Dartdude »
      IM sent about where to buy parts. Best prices are online. Items are not available at the "usual" auto parts stores. These are impex prices:
      Absolutely required:
      thermostat - $56.53
      gasket for the above - $2.75
      gasket from housing to head - $5.00
      1 gallon G12 coolant - $20
      total = $84.28 plus shipping
      Should do it while you are in there:
      CTS - $22.69
      CTS O-ring - $1.25
      crack pipe O-ring - $2.80
      = another $26.74 plus shipping
      let me know how it goes, good luck ! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    16. Member VeeRsixx's Avatar
      Jan 5th, 2004
      Harrisburg PA
      '04 R32 Black Magic
      10-20-2009 08:01 PM #16
      Quote, originally posted by Patryk@DouglasVW »
      Thank you Pat, that really means a lot to me coming from a technician like you. As a matter of fact, one of the reasons i decided to proceed was because in an obscure post somewhere i found that you said most of the cars w. my DTC normally don't come back after the thermostat is changed. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    17. 10-22-2009 05:35 PM #17
      I think I found what my problem was.
      The plug that is in between the two open holes is broken so hopefully the local VW store has one in stock.
    18. Member TXR32's Avatar
      Jun 4th, 2006
      Webberville, TX
      '04 R32 '07 Cayman '11 TRD Tacoma
      10-22-2009 05:55 PM #18
      Well done [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    19. Member Kstyle's Avatar
      Sep 12th, 2007
      Fort Worth
      04 R32//05 TReg V8 sold//06 A3 2.0T//2012 F150 Eco
      10-22-2009 06:07 PM #19
      1stvwparts has some cheap prices, thermostat: $36.74 [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    20. Member itej's Avatar
      Jan 29th, 2008
      NE PDX
      BMP MKIV .:R [sold]; Plum 91 Corrado G60 [sold]; 96 24V Jetta [sold]; '03 A4 Avant
      10-30-2009 06:17 PM #20
      great write-up!
      is there a way (i seem to remember seeing it in a thread, but now i can't find it to save my life) to diagnose the t-stat before ripping my car apart and doing a heart transplant?
      i've got the green top sensor in, but it's not OEM so that's probably the issue, but while i'm in there replacing that i'd like to do the t-stat if it needs to be done, too... but obviously i'd like to know that before i dive in
      .:PNW
      my fast wants to know if your fast can come out to play
    21. Member Daemon42's Avatar
      Feb 9th, 2001
      colorado
      10-30-2009 09:07 PM #21
      If the car overheats when the car is not moving (and the fans are working
      properly), then the t-stat is stuck closed.
      If the car overcools when the car is moving then the t-stat is stuck open.
      ian
    22. Member MKranz's Avatar
      May 14th, 2000
      Denver CO
      2016 Golf R
      01-14-2010 09:51 AM #22
      Just did this. (Twice actually, thanks to my not paying attention to the thermostat/o-ring order.) The total coolant required when you drain the system from the lower rad hose is just shy of 2 gallons. That's 1 gallon of G12 and 1 gallon of water. I think I had a smidge left over.
      Modified by MKranz at 8:45 PM 1-14-2010
      I'mafastcopilot
    23. Member r32vw04's Avatar
      Dec 16th, 2008
      04 .:R
      01-28-2010 04:29 PM #23
      fun fun.... I gotta do this on my .:R this weekend. I've done on my old 2.8 vr Getta so we'll see how close the two car are for the t-stat fix. Will be taking pictures for others, plan on not taking off the house from the motor but just pop the 3 5mm bolts loose and take off the bottom of the housing and replacing the t-stat only. Wish me luck...
      Don't hate what you can't afford, you will sleep better...
    24. Member Daemon42's Avatar
      Feb 9th, 2001
      colorado
      01-28-2010 04:36 PM #24
      Trust me when I say that "just pop the 3 5mm bolts loose" is MUCH more painful
      than taking the whole housing off the motor. There just is no room to
      work on those allen head bolts. It's a 30-40 minute job that'll take
      you an hour an a half if you do it that way.
      ian
    25. Member Wilhelm0075's Avatar
      Mar 2nd, 2005
      Reno, NV
      2011 Cadillac CTS-V (manual), 2015 Nissan XTerra PRO-4X
      01-28-2010 06:33 PM #25
      My buddy and I just did this job. It wasn't as bad as I thought it would be. I decided to change a lot of stuff while we were in there, namely the thermostat, coolant temp switch (still had the oem one in there) the housing and all the gaskets. The biggest pain was trying to drain all the coolant and getting the housing off the crack pipe. It would be helpful if they didn't build these engines dry with no sort of lubricant to get these things off . Luckily my buddy works at a VW dealership and I get parts cheap and the mechanics gave us some hints. Gloves probably would have helped
      Modified by Wilhelm R32 at 2:34 PM 1-28-2010
      Modified by Wilhelm R32 at 2:36 PM 1-28-2010
      CTS-V 1st dyno: 461/472
      CTS-V 2nd dyno: 500/501
      CTS-V 3rd dyno: 521/510
      CTS-V 4th dyno: 529/521
      CTS-V 5th dyno: 586/618
