For the guys running the base Eurodyne 630CC file..
During your logging at what boost level have you seen knock starting to show up? Through my logs running 14-17ish psi I have no knock. I have the boost set @ 19psi-20psi now (T3/T4 50 trim) and I started getting 2.25 degrees on cyl #2. I assume this is still within acceptable parameters but should I physically be able to feel the engine getting this knock because I can feel a very slight letup in power during this point. I'm still combing over the logs but I believe actual A/F is still matching requested.
**And do I have a correct understanding of this? It is indeed knock or is it timing pull? Is the computer actually backing off timing at this point? Could I be feeling something more than just knock like my fuel pump is hiccuping?**
