| Quote, originally posted by Snowhere » |
How tough is it to remove the orange blinkers? |
two ways to do it. One is to pull the lens from the housing. To do this you need to heat the sealant and peel the two apart, some people put the lights in the oven for a bit (on low temp), i prefer to use a big halogen work light and just work my way around the unit heating. Once you get it open the amber reflector just pulls right out.
The other way is to drill a small hole in the top of the lens and use a small pick to dislodge the reflector, then working through the bulb hole, use some sort of snips to gradually break the reflector into small pieces so it falls out the bulb hole.
I actually used one method on one headlight and the other on the other one, the breaking method takes less time, but pulling the lens and just removing it is more straightforward (although somepeople balk at the idea of having to reseal their lights -doesn't bother me).
Anyway, today I pulled the driver side front axle in order to replace a cracked out CV boot. Everything went fine, in fact I was surprised to hear after the fact how many people had trouble with the upper pinch bolt -guess I was lucky on that one).
Also got some new snow tires and had them mounted. Went with dunlop wintersport 3ds. I had them on my old GTI and really like the compromise between snow traction and dry handling (I have found "grippier" tires like blizzak ws-50's too squirmy in the dry). I had them go ahead and mount the bent wheel, Put it on the back and it doesn't seem to be a big deal. Certainly the new tires make a big difference, the old tires were severely out of balance (according to the vibrations) and one had a nail in it.
Driving the car right now and everything seems to be fine. Still have more on my list though-
