VWVortex.com - DIY: Removal and Install of Rear Hatch Actuator (golf/gti)
    Results 1 to 15 of 15
    Thread: DIY: Removal and Install of Rear Hatch Actuator (golf/gti)
    1. Member VWeisgerber's Avatar
      May 2nd, 2008
      93 cabby 02 golf
      10-30-2009 12:46 AM #1
      This DIY will show how to remove old rear hatch actuator, transfer hardware and install new actuator...
      - Supplies -
      1– New/used working rear actuator (part Number - 1M0959781A) (1stVWParts has them for $24.08)
      - Tools -
      * Phillips screwdriver
      * Bullnose Pliers
      :::::::: On to the Removal :::::::
      Step 1: Remove rear hatch panel. There are two small Phillips screws, one in each handle. After removing them, the rear panel is held on by 8 metal clips, just grab and pry the panel off. It will sound like you are breaking it, but you aren't.
      (No pictures of removing the hatch panel. Will take pictures next week and add)
      [IMG]http://*****************.com/smile/star.gif[/IMG]
      Step 2: Locate actuator....
      Step 3: Disconnect power supply for the actuator. it is held in by a squeeze clip....
      Step 4: Find where rod connect to latch assembly. Pull it downwards to pop it out of its sleeve.
      Step 5: Remove rod from old actuator. It slides off the nose of the extending rod....
      Step 6: Now the actuator is ready to be removed. Locate the two silver hex screws. Grab these with the bull nose pliers and turn CLOCKWISE!! Just turn once or twice (each) to loosen the screws....
      Step 7: Now the actuator is loose, slide it towards the passenger side of the car. It will drop free after an inch or so......
      Step 8: Remove the two Phillips screws from the actuator.
      Step 9: Take the two Phillips screws and install in the new actuator. DO NOT tighten all the way down, you need to leave the heads up a little so that you can slide the new actuator back into place....
      NOW REVERSE REMOVAL INSTRUCTIONS:
      1. Reinstalled new actuator.
      2. Tighten two screws COUNTER-CLOCKWISE once seated in slots.
      3. Reconnect the rod to the actuator and to door latch.
      4. Reconnect power supply.
      5. Enjoy a working actuator....
      Work done by VWeisgerber and Steinosaur on steinosaur's 03 GTI
      Disclaimer: I am NOT responsible for the careless acts of others when using this DIY as a reference or anything you manage to break.
    2. Member dremhmrk2's Avatar
      Sep 19th, 2003
      Fort Lauderdale FL
      2001 Mojave GTI GLX
      10-30-2009 10:29 AM #2
      Nice writeup, got one for the lock assembly, too?
      "Turning right in fifth gear from the left hand lane into the wrong end of a one-way street while indicating left, if at all."
      All the custom, none of the cool.
      "Trying to be the cool kid is so cool." - MkIV Scene
    3. 10-30-2009 10:33 AM #3
      quality sir [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Thanks alot- I plan on doing this soon!
    4. Banned autobahmer's Avatar
      Jul 23rd, 2006
      10-30-2009 10:34 AM #4
      good deal. next time i take my hatch panel off i'll take it off.
    5. Banned autobahmer's Avatar
      Jul 23rd, 2006
      10-30-2009 10:35 AM #5
      Quote, originally posted by dremhmrk2 »
      i should of made one. there is one over on dk [IMG]http://*****************.com/smile/emthup.gif[/IMG] but there is a way to remove it without breaking it and of course i forgot how i did it.
    6. Member VWeisgerber's Avatar
      May 2nd, 2008
      93 cabby 02 golf
      10-30-2009 02:30 PM #6
      thanks everyone
      are you talk about this part of the lock set-up?
      or are you talking about the microswitch?
    7. 02-22-2010 01:20 PM #7
      I've got a problem with the microswitch not 'catching', I can't even flick it by hand when the hatch is in the air, so the door won't latch shut and the alarm won't arm (was intermittent for a long time, finally stop working altogether this winter). Will replacing the actuator fix that or will I need to replace the microswitch too? Is that any more difficult or involved?
    8. Member Powerage's Avatar
      Jun 9th, 2007
      Frederick, MD
      03-03-2010 05:25 PM #8
      Quote, originally posted by SteveK2005 »
      is it just sticking? try some white grease.
    9. Awaiting Email Confirmation fkunsten's Avatar
      Feb 22nd, 2009
      North York
      2016 GTI, 2011 Golf Sportline
      12-17-2011 12:06 AM #9
      Hi All
      If I put key in manually I can unlock and dissable the alarm but when i push a truck button remote 2 actuators do not work after a leak.
      Please help
    10. Awaiting Email Confirmation mungraker's Avatar
      Apr 8th, 2011
      Bellingham Wa
      2001 Passat B5 Wagon
      01-31-2012 10:16 AM #10
      Can anybody point me in the right direction to get my hatch open from the inside? I found a/the thread describing it a few weeks ago, but now I can't find it. I'm going to attempt to do this, but figured I would go in with a little guidance.
    11. Awaiting Email Confirmation mungraker's Avatar
      Apr 8th, 2011
      Bellingham Wa
      01-31-2012 11:19 AM #11
      Just succeeded in opening hatch from the inside. Luckily I have managed to keep the weight off and was just able to reach in and release it. Seemed the problem was road grime and salt. Just a few strategic squirts of WD-40 and we're back in business.
      Jul 8th, 2011
      Northern Cali
      01 GTI 1.8t
      08-16-2012 01:08 AM #12
      Anybody kno y my hatch won't pop open changed the actuator cleaned the mechanism I did everything but change the fuse can somebody help me plz
    13. Member
      Mar 4th, 2004
      Lacey, Washington
      2003 silverstone GTI VR6 24v
      02-23-2013 05:59 AM #13
      ha, turns out the actuator is not my issue... I think it is the lock it's self.. corrosion.. grrr..
    14. n00b capeman32's Avatar
      Jan 11th, 2012
      Austin Tx
      02/vw/gti/1.8T
      04-23-2014 12:17 PM #14
      This kicks tail thanks!
      german@<3
    15. Member TheLateGTI's Avatar
      Apr 16th, 2008
      Upstate NY
      06-18-2014 08:22 PM #15
      Awesome, this guide is bitchin!!
