Page 3 of 12 FirstFirst 1 2 3 4 5 6 7 ... LastLast
Results 71 to 105 of 416
Thread: Project CAR (Coupe Air Ride) is under way!!!
  1. Banned WCHLVR's Avatar
    May 27th, 2002
    Bend, Oregon
    Project Doppelganger
    12-13-2009 04:25 AM #71
    Quote, originally posted by T3Bunny »
    VERY informaive article!
    Fascinating and air suspension works the way I would like it to too! Lower=stiffer! Perfect.
    The only thing not answered by that is reliability concerns.
    And seems I should pursue using the tokico's if I go about this. They are adjustable on top too so even better. I honestly don't think I would be going low enough to make it matter that they are stock length. Anyways back on track.
    Looking forward to seeing more on this thread!
    Like everything else on your car, an air ride setup is only as reliable as the amount of maintenance you put into it.
    Fittings
    Hoses
    Wiring
    Pumps
    Relays
    Switches
    Gauges
    Valves
    Driers.... the list goes on and on. If one sets it up correctly. Keep everything nice and neat. And is willing to give it"the once over" very once and a while... it will be as reliable as the rest of your car.
    On a related note- The kit I am building is designed to work with coilovers. If you are wanting it to work with stock struts I am certain we can work something out.
  2. Banned WCHLVR's Avatar
    May 27th, 2002
    Bend, Oregon
    12-18-2009 06:22 AM #72
    Update-
    Got back from my 'Jet guy with a stack of new goodies. Everything turned out awesome.
    Started some strut mockup... see how things fit.
    Busted out the drill press and countersunk the holes for the bag mount to use flat sockethead screws (gotta make every mm count)
    Had to countersink the bag a little so the screws would tighten down!
    Also using flat socket heads on the strut cap. These will be tack in place for easy mounting.
    Using standard socket head on the bottom. This work perfectly to lock the bag into the adjustment rings and keep it from spinning.
    Upper bag mount will have a pipe here (size to be just enough to clear everything)
    As you can see, if I run the numbers correctly, I should be able to calculate for strut bearing sag and close this gap up really tight and still have full function. (top plate is the lower mounting flange for the strut bearing cap.
    More to come! Next episode- Getting the Coupe back in the garage, mock this up and see where we're at!
  3. 12-18-2009 06:57 AM #73
    this is awesome!!!!
    dom
  4. Member MadTextureYo's Avatar
    Jun 10th, 2006
    CT
    Mk4 Tdi, The Easter Bunny
    12-18-2009 07:58 AM #74
    drove my mk1 on air for about 9 months with literally no issues, even throughout the winter. also daily'd my tdi on air for the last year or so with out any problems.
    this thread looks great, only concern i have is that the struts may still hold you up. i couldnt get the height i wanted up front on the aero over coils on my mk1 even with my 2 1/2 inch raised towers.
    i ended up having to get custom shortened struts from bagyard.
    im sure you will figure something out though.
    oh, and im jealous of your fabrication skills.
  5. Member wantacad's Avatar
    Apr 3rd, 2003
    Belleville,Ill
    I haz a bunnah
    12-18-2009 09:00 AM #75
    I'm curious as to how they came up with that.
    In my bagged chevy S10 I had it was the opposite effect. Less PSI (lower) = softer more bouncy the ride. More PSI (higher) firmer/stiff ride.
    Quote Originally Posted by WackyWabbitRacer View Post
    You're new here but don't be a DORK.....
    Cheers, WWR.
    Quote Originally Posted by dsleggett View Post
    I have a great idea, upgrade to the big 3: periods, commas and capital letters! I realize I'm old but I cannot read some of this s**t.
  6. Member
    Feb 10th, 2002
    Pittsburgh, PA
    '94 Jetta, '08 Rabbit, '12 2500HD
    12-18-2009 09:08 AM #76
    They used sleeve bags with weird shaped lower mounts and internals, which changed the internal volume to change the stiffness. It worked so well, the company went out of business!
    Most air suspension setups get softer as you go lower, the Praxis stuff was different - I'm not sure how it performed in the real world, perhaps the difference between actual and theoretical was the reason they didn't sell anything.
    Cool project, watching this thread for sure
  7. Member wantacad's Avatar
    Apr 3rd, 2003
    Belleville,Ill
    I haz a bunnah
    12-18-2009 09:13 AM #77
    Quote, originally posted by Afazz »
    gotcha...
    Cheers, WWR.
    Nov 16th, 2004
    Baldwin, LI
    12-18-2009 04:35 PM #78
    you've probably figured it out already but you can get those bolts counter sunk flush.
    edit: well more flush. that pic was a first attempt that later i had 100% flush.
    Modified by Swoops at 1:36 PM 12-18-2009
    dub cult
    HardlinesBySwoops@gmail.com. PM or email me for hardline and airride installs.
  9. Senior Member Muffler Bearing's Avatar
    Apr 4th, 2004
    54 green, 67 yellow, 77 gold, 84 brown
    12-18-2009 06:16 PM #79
    lookin good terry
    A Rabbit is not to be wasted on the tentative or weak. Only the worthy are invited, and then only at your own risk. If you have even a modicum of hesitation, DO NOT buy one of these cars. Instead, leave it for a worthy soul who has already matriculated to the sublime ecstasy of what those in the know refer to as a "MK1"
    OLDSKOOLVW.COM Custom MK1 parts.
  10. Banned WCHLVR's Avatar
    May 27th, 2002
    Bend, Oregon
    12-19-2009 05:24 AM #80
    Quote, originally posted by MadTextureYo »
    ...this thread looks great, only concern i have is that the struts may still hold you up. i couldnt get the height i wanted up front on the aero over coils on my mk1 even with my 2 1/2 inch raised towers.
    My goal is to be able to compress the bag further than you were able to. You were only able to lay out the air spring on the sleeve inside... mine will be able to do this-
    That said, I will come right out and say this is going VERY CLOSE. I am hoping to set the car on blocks this weekend in a mock up and get a better idea!
    BTW- Thanks for the props. The Easter Bunny is certainly inspiration for this build.
    Quote, originally posted by Swoops »
    Yeah... I was just done for the day. I already "over drilled" bags. I just need to slap the plates back on the drill press! Great pic though!
  11. Member
    Feb 10th, 2002
    Pittsburgh, PA
    12-19-2009 02:34 PM #81
    http://www.universalairsuspens...t.pdf
    Check out Figure 8. Be careful you'e not pinching the internal bag right where #92 and #86 are in the drawing.
  12. Banned WCHLVR's Avatar
    May 27th, 2002
    Bend, Oregon
    12-19-2009 02:52 PM #82
    This is their OG strut bag design. The newer bags are nothing like this. Still a pinch factor but nothing to this degree.
    Good looking out though!!
  13. Member syracusegli's Avatar
    Jan 21st, 2005
    syracuse, NY
    twin charged mk1 cabby
    12-19-2009 03:49 PM #83
    Quote Originally Posted by 2mAn View Post
    go crash into a hybrid
    For all things Metal ---> www.roguemetalworks.com
  14. Banned WCHLVR's Avatar
    May 27th, 2002
    Bend, Oregon
    12-22-2009 12:48 AM #84
    Had a little time today to finish countersinking the upper mounts. Its all I could get done... Did I mention I hate Xmas time?
    Check out these super shorty custom bolts!
    Enjoy!
  15. Member 16v_HOR's Avatar
    Jul 21st, 2005
    stable of silver
    12-22-2009 12:52 AM #85
    Looking good. Impatiently awaiting the finished product
    www.oldskoolvw.comSupport custom parts & solutions for the Mk1 community
    Quote Originally Posted by SGLoki View Post
    Mk1people > Mkrestofpeople.
    And every time you wreck a westy, god kills a puppy and stuffs a live kitten inside it before burying it.
  16. Member JLF's Avatar
    Oct 14th, 2008
    PNW
    No Current Project
    12-22-2009 02:27 AM #86
    Quality is Job One!
    Well done Sir!
  17. Member dmitry88's Avatar
    Apr 26th, 2006
    NJ
    1981 Jetta Coupe VR6, 2005.5 Jetta, 2001 Audi TT
    12-22-2009 11:03 AM #87
  18. Junior Member MK2NIS's Avatar
    Aug 31st, 2004
    PDX
    83 jetta coupe
    12-24-2009 01:06 AM #88
    I hope Santa likes Jettas!! maybe he will kick me down some flow for the rest of this project!
  19. Junior Member MK2NIS's Avatar
    Aug 31st, 2004
    PDX
    83 jetta coupe
    12-25-2009 08:41 PM #89
    BTW if anyone wants more info on the coupe.....or to see what it looked like stock
    Merry Xmas all.....cant wait to see what 2010 brings for the dub world! http://forums.vwvortex.com/zerothread?id=4548443
  20. Banned WCHLVR's Avatar
    May 27th, 2002
    Bend, Oregon
    01-05-2010 05:06 AM #90
    update bump!
    Finally got some time to get the Jetta back in the shop to do a mock up with all the new pieces I picked up a few weeks ago.
    Got the car on blocks to get a better prospective of where we sit... and I have to say it is looking promising!
    Full weight of the car... compressed quite nicely. Everything is within millimeter's!
    Look at how high the ass looks now!
    All the plates look like they will work perfectly!
    So where does this leave the car in relation to the ground? Let me show you!
    The blocks are 7.75" tall-
    The car is-
    That'll work! Now I will loose a little bit up top when it is all said and done but I have a little trick in mind to minimize the damage.
    Enjoy!
  21. Member joezeeuw's Avatar
    Feb 23rd, 2003
    Grand Rapids, MI
    01-05-2010 08:56 AM #91
    I guess I'm not 100% clear on how this all will work. The bag won't be resting on the inside of the tower will it? Seems like you would need quite a bit of space in there to allow turning and changes in king pin angle as the bag will not always be square with the top of the tower. I'm looking forward to seeing how this all unfolds. Great work so far. The idea to have the strut body come up past the tower is brilliant!
  22. Member phill0046's Avatar
    Oct 14th, 2005
    South East
    The wagen and the wagon
    01-05-2010 09:01 AM #92
    Awesome
    Makes me want a mk1
    Pelican club VIP
  23. Member
    Jun 5th, 2001
    Royal Oak, MI
    86 Jetta Coupe, 99.5 A4
    01-05-2010 09:19 AM #93
    Quote, originally posted by joezeeuw »
    I don't think he has built everything out yet.
  24. Banned WCHLVR's Avatar
    May 27th, 2002
    Bend, Oregon
    01-05-2010 04:44 PM #94
    Joe, detvw is correct. There will be a gap at the top, I just haven't gotten to that point of the build. Always best to do as many mockups as you can... helps prevent doing things multiple times. The great part to my "trick" I mentioned is it will be adjustable so I can get every millimeter out of this setup.
    Modified by WCHLVR at 1:46 PM 1-5-2010
  25. Member mad caddy16v's Avatar
    Jan 21st, 2004
    madtown wisco.
    BensVeeDubShop.com,Madisons coolest vw shop.
    01-05-2010 05:14 PM #95
    ..as usual, joe and i are on the same page ... as i mentioned earlier, i was concerned about over roll of the bags on deflate,if that inner sleeve is altered...you say the new versions of the the UA bags seem different?...cool
    and as joe said im also concerned about being able to turn on moderate to complete deflate,and its up and down movement, as even on my set up without the inner stop altered, i had to clearance the **** out of the tower on the inside where the pinch welds come together, or the bag would have pinched.
    just brain storming as usual, looks awesome, cant wait to see the finished product. ...and may need to get a set of those raised USB things for the next "project". keep it up dude
    bensveedubshop.com
    madspeed oldskoolvw.com
    vortex success does not equal car culture success.
  26. Banned WCHLVR's Avatar
    May 27th, 2002
    Bend, Oregon
    01-05-2010 06:27 PM #96
    Quote, originally posted by mad caddy16v »
    I appreciate everyone's input. Thanks! It keeps me on my toes and helps to insure I haven't left out something vital.
    The inner sleeve is completely intact/unaltered as sent by UA. Truth be told, this isn't that much different than setups that have already been built. As you can see, even under full body weight the inner sleeve doesn't protrude past the top of the bag. I have concluded that the reason it shows it "sticking out" in the other pics is because I didn't have my mounting plates in place (this helps take up space) and I was supporting almost the entire front of the car with jack under one wheel/tire. When the car is resting on all fours, this does not seem to be an issue.
    However, the big difference/change here is I am allowing for the top of the strut to pass through the plane of the top bag mount. This has not been done in the past and hence has limited the capable drop of the setup. Once the coilover is bottomed out on the strut bearing your done. Now I can push past that limitation and gain a little more drop.
    All that said, yes I have allowed for the inner sleeve to be able to extend past the top of the bag but looking at the construction of the bag and considering the weight of our cars (or lack there of in our case) I dont see this being much of an issue. No more than already exists.
    As an added related note- I recently come to understand that VA will rebuild your bags for around $50. Look at it this way, this is no worse than the fact that we need replace our strut bearings every year (or sooner) because they fail.
  27. Member Mk1Madness's Avatar
    Nov 8th, 2009
    South Philly
    75 Rabbit, 84 GTi
    01-05-2010 07:27 PM #97
    This is taking way to long....
    Mk1's, German Classics not Brazilian plastics.
  28. Banned WCHLVR's Avatar
    May 27th, 2002
    Bend, Oregon
    01-05-2010 07:35 PM #98
    Quote, originally posted by Mk1Madness »
    x2
  29. Senior Member Muffler Bearing's Avatar
    Apr 4th, 2004
    01-05-2010 08:27 PM #99
    most of the pics are borked
  30. Banned WCHLVR's Avatar
    May 27th, 2002
    Bend, Oregon
    01-05-2010 08:30 PM #100
    Quote, originally posted by Muffler Bearing »
    I think your comp is borked. All working fine on this end. Try grabbing the URL and see if that works?
  31. Member watchxmexdie's Avatar
    Sep 26th, 2008
    no hope
    1988 Jetta
    01-05-2010 08:31 PM #101
    maybe you should come to my place, and put air ride on my bunny, ill give you 20$ and two sets of vw steelies . i call this the best deal ever!
    donald + Mk1 Rabbit = happy
  32. Banned WCHLVR's Avatar
    May 27th, 2002
    Bend, Oregon
    01-05-2010 08:35 PM #102
    Quote, originally posted by watchxmexdie »
    Outstanding offer
  33. Member watchxmexdie's Avatar
    Sep 26th, 2008
    no hope
    1988 Jetta
    01-05-2010 08:38 PM #103
    yeah i tryed. but the car looks great slammed man. love it!
  34. Banned WCHLVR's Avatar
    May 27th, 2002
    Bend, Oregon
    01-05-2010 08:40 PM #104
    Thx... Cant wait to get the front done so we can get to the back... but that is the easy part!
  35. Member JLF's Avatar
    Oct 14th, 2008
    PNW
    No Current Project
    01-06-2010 12:43 AM #105
    Im really liking how this is coming together Terry!
    The front looks so slammed and tucked!
    This thread is like the gift that keeps on giving!
    Keep up the great work!
