Page 2 of 7 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 36 to 70 of 218
Thread: The Thread Build (BuildUp:)
  1. Member ENRGZR's Avatar
    Oct 11th, 2006
    Kunia, Hi.
    87 GTI, 91 Golf, 97 Cabrio, 99.5 Jetta, 07 Rabbit
    04-30-2010 11:57 AM #36
    Lavender
    XBL/PS3: ENRGZR
    AKeuro / CCA Motorsport / Air by Santi / Fifteen52 / C2 / Trac Wrap
    Quote Originally Posted by 5P4RK4 View Post
    A dozen 1000 miles is 120,000 not 12000, thats 1.2 1000 miles.
    edit. wow I fail. Im going to leave that there to remind myself not to do math.
  2. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    04-30-2010 12:06 PM #37
    LOL, Yeah I knew I would get some crazy responses from that. What "kind" of paint, not what color. Its going all black BTW. Should i just go with spray bomb stuff or should i use automotive epoxy primer and the factory body color black?
    96 Jetta 5pd
    worked head w/276
    C2 Stg2 (works like crap)
  3. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    05-01-2010 11:02 PM #38
    Got the distributor our, just needed a hammer. It's all broken down and ready for a trip to the machine shop. Only 1 main bearing was down to the copper.
    96 Jetta 5pd
    worked head w/276
  4. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    05-07-2010 07:55 AM #39
    CC'ed the chambers. Got around 33cc's. Does that sound right? Does anyone know any chamber size to comp ratio stuff figures? I've heard people say that these engines are anywhere from 9:1 to 10.7:1 comp ratio stock, what is it?? Of course the search is disabled while they rebuild.
    Got the trans back from the shop Thursday. IDK if it works yet. I can't spin the axles in opposite directions like I assumed I should be able to. Is this normal? Sometime I'll put a shift lever on it and try to run it through the gears.
    Does anyone have a good source to get fittings to install an oil pressure gauge?
  5. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    05-07-2010 08:07 AM #40
    Man I love my camera!
  6. Banned vento86's Avatar
    Oct 13th, 2008
    05-07-2010 02:49 PM #41
    whats the mileage on that motor? i pulled the head off of mine at 120xxx and it looked cleaner than that
  7. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    05-08-2010 11:54 AM #42
    I think it has about 176k on it. I was surprised at how clean the intake ports were.
  8. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    05-11-2010 08:09 AM #43
    So both heads I have are cracked in #1 chamber between the valve seats... I thought I read of people using the heads like this without problems. One of the heads i bought on a running engine and it ran strong. The concern I have is that i will be putting bigger valve seats in and I don't know if the head will hold up to the machining process. I don't want to have any problems with this thing when i put it back in the car. Should I just look for another head?
    The valve kit I'm going to be using.
    http://techtonicstuninginc.com/main/...roducts_id=142
  9. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    05-12-2010 10:13 PM #44
    Got my block back from my buddy who glass beaded it for me. Next it's off to the machine shop with the stuff. I'll try to post a pic of the block. A problem I noticed is that the sealing surface where the water pump bolts to the block is corroded where the o-ring sat. Hopefully some good RTV will hold it. It's pretty bad. Any suggestions on a fix?
  10. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    05-14-2010 08:28 AM #45
  11. Junior Member boost_man's Avatar
    Apr 29th, 2010
    spokane
    03 jetta
    05-14-2010 09:52 AM #46
    Looking good. good luck...
  12. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    05-17-2010 09:18 AM #47
    AEG Manifold
    OBD I Head
    TT 276 cam
    Adjustable Cam gear
    Light Weight Lifters
    Mildly Ported, Port Matched and Polished Runners and Chambers
    TT 42mm and 35mm valves
    Shaved Head, Amount to be determined
    83.5mm Forged Pistons stock comp.
    Stock rods & crank
    Light Weight Flywheel
    Will it make 140whp?
  13. 05-17-2010 10:29 AM #48
    Maybe/maybe not. Hard to say with a stock manifold. You will have retarded low end torque (below 4500rpms).
  14. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    05-22-2010 05:24 PM #49
    Block crank and rods off to APTuning! Going with JE pistons. Gotta schedule some dyno time to get a before reading.
  15. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    06-08-2010 02:00 PM #50
    I was working on port matching the exhaust and tried to set the header on the head and line up the holes.... Once I lined up one port the closest one was 1/8" off I hate crappy junk. But, I also hate spending $300 for some tubing. So I'm planning on using lots of heat and maybe having the flanges machined flat once i get them all lined up.
    Stupid OBX!!!
  16. 06-09-2010 12:05 PM #51
    wait wait wait...back on page 1 you said you were using 87 octane gas with the PEM stage 2? correct me if im wrong but dosent that require 93 octane? hence the ricockulous timing?
  17. 06-09-2010 12:47 PM #52
    Quote Originally Posted by drracing07 View Post
    I ran 87 with the S2 all winter long NO ISSUES. This was on a stock head/cam setup. For the hell of it, I dropped in a tank of 93 and the timing didnt advance all that much more at a lower rpm/load. Maybe 2*? At WOT, it advanced the same...about 27*-30* (rpm-dependent) And up until my car burnt, I was using 89 octane and there was no difference in timing.
    About the header not lining up.....They all come like that. Its not a big deal. You just persuade it on with a rubber mallet. NOT a big deal. I had to do that to both of mine when I put it on. And the OBX isnt a crap header.
  18. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    06-11-2010 08:38 AM #53
    Yeah, you are supposed to run 93 with the stg 2. I wanted to see if and how much timing it would pull on 87. I do think it runs better on 93 as opposed to 87.
    I did get the header on an old head that still had the studs in it. I think I'm going to sand down the flange to try to get it to seal. When you put a straight edge across the flanges there is also an 1/8 inch gap and one of the flanges isn't even straight. If this isn't a cheap poorly made header, I would hate to see one. But, I cant say I wasn't expecting to have this problem.
    Maybe if I was bolting this to a iron head I would be able to draw the nuts down tight enough to make it seal, MAYBE. I don't feel like stripping out the threads on my good ported head....
    Got the intake ports finished up last night. Now I just have to figure out if there is anything else I can do with the exhaust ports. I can't really open them up any because the header is the same size as the factory ports. I already did the short side radius.
  19. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    06-28-2010 09:53 PM #54
    FINALLY! Got the head done tonight. Couldn't do much with the exhaust ports because the header so closely matches it. Cleaned up the chamber side as well. Off to get the bigger seats put in and check it out again to make sure everything is still smooth. After that I just have to get on APTuning to get that crap done!
    Then put it all back together...
  20. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    06-30-2010 09:33 PM #55
    Got the header wrapped tonight. I need the tool to tighten the wrap straps... I broke one so now I gotta order more. I think it turned out decent. I'll post some pics then.
  21. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    07-03-2010 08:53 PM #56
    Waiting for more straps...
  22. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    07-08-2010 08:07 PM #57
    Does anyone know where i can get a complete parts list of all the seals and things I would need for a rebuild? I have a FelPro kit # CS26164 but it doesn't include every single thing.
  23. Junior Member
    Jul 7th, 2010
    CT
    1996 gti vr6
    07-09-2010 08:31 PM #58
    Love the thread awesome to see another person building a 2.0 good luck!
  24. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    08-16-2010 11:52 AM #59
    Got the block back from the shop. Now waiting on the head and parts.... This had better be good!
    I'm the only one I know of who will be running this valve kit. Also, I don't think anyone else will do it with a stock MK3 mani! i will be eventually going to a modified MK4 but i'm hoping it makes some serious tq down low for daily driving with this mani. My cam will be a mis-match, but well see how it runs.
    How is the baffle setup in the oil pan. There is a baffle that clips onto the pump pickup right? Whats the purpose? I assume to keep the oil in the sump for cornering and such. Is that all?
  25. 08-16-2010 12:12 PM #60
    Let me know when you're ready to ditch stock manifolds and want to spend the coin on an SRI. {I.E. when you're ready to make some real hp.)
  26. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    08-17-2010 12:41 PM #61
    I'm pretty sure I won't ever want to do that. If I need more hp than this, I think I'll get something else. It's just not worth it.
  27. 08-17-2010 01:07 PM #62
    Just saying...stock manifolds are a major bottleneck. All that head work and you limit yourself.
  28. Member redzone98's Avatar
    Jun 10th, 2004
    Cape May NJ
    90 Cabby, CRoutan
    08-18-2010 11:54 AM #63
    Something is just not rite here with that timing graph. and you were running 87 octane? with 40*+ degrees of time. ?
    i call shenanigans
  29. 08-18-2010 12:17 PM #64
    looking back at that chart, I just noticed that his timing spiked to 40* right when he let off the gas. So he wanst running WOT when it spiked. His timing looks about right under acceleration low-mid 30's.
  30. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    08-19-2010 09:39 PM #65
    Quote Originally Posted by redzone98 View Post
    i call shenanigans
    If there are any shenanigans its VAG-COM not me.
    I'm gona swap in a modified MKIV mani once I get it fixed up. We'll see how that goes.
    Got the motor almost ready to come out!
  31. Member redzone98's Avatar
    Jun 10th, 2004
    Cape May NJ
    90 Cabby, CRoutan
    08-19-2010 09:46 PM #66
    naaa, its true about the timing relation with being off-FOT. i didnt notice that part.
  32. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    08-23-2010 09:43 AM #67
    Thats OK. I just wanted to type shenanigans.
  33. Member redzone98's Avatar
    Jun 10th, 2004
    Cape May NJ
    90 Cabby, CRoutan
    08-23-2010 11:07 AM #68
    Quote Originally Posted by macanic21 View Post
    i know... its a great word !
  34. Member macanic21's Avatar
    Feb 19th, 2007
    Womelsdorf PA
    1996 Jetta
    08-24-2010 09:35 PM #69
    APTuning is severely aggravating me! They have screwed around for 2 months getting my parts together. Then I went in last week and they told me "yeah, we have all the stuff but we can't find the cam caps..." Great, now the head I spend weeks on is now junk! I'm going in tomorrow and pick up the parts and I'm not paying for them until they produce a ported 8v head! I'm never going to these people again.
  35. Member
    Nov 18th, 2007
    Chattanooga, TN
    1992 MR2 turbo
    08-25-2010 12:08 AM #70
    bah go grab some off a junkyard head and have a shop line-bore the cam journals. easy peasy.
