Page 20 of 34 FirstFirst ... 10 16 17 18 19 20 21 22 23 24 30 ... LastLast
Results 666 to 700 of 1178
Thread: NEW- Lets see your 16V TURBO 16VT with SPECS!
  1. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    2000 audi s4, 1990 corrado aba/16vt, 2004 audi A6, 2008 Aprillia 450svx, 2003 Kawasaki Z1000
    04-30-2012 10:06 PM #666
    Ok. Just realized video won't help cause tach doesn't work. So I'll post a log.
    CHECK OUT MY BUILDS AT WWW.BUILDMYS4.COM
    2000 AUDI S4 RS6/54MM BILLET WHEELS
    1990 VW CORRADO ABA/16VT PRECISION 5857 .63 A/RCORRADO BUILD THREAD
  2. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    91 Corrado 2.0l 16v on MS3X, Parked like Jurassic... 83 Cabby 1.8l 16v... 88 Powerplay XLT-185
    04-30-2012 11:47 PM #667
    Quote Originally Posted by vwflygti View Post
    Quote Originally Posted by crazynorweegian View Post
    Good luck, might want to get vaccinated for "while-I-am-in-there" syndrome.
    tek-euro.com SpoonFedTuning
    my Corrado's specs on corrado-database / My Corrado Build Thread / My Cabby Build Thread / My Boat Build: 18' Powerplay w/5.7l V8
  3. Member Evil16v's Avatar
    Nov 15th, 2000
    Texas!
    67 mile 1989 GTI 16V, 1993 Quattro Corrado-zilla 3.6 V8, 1990 Corrado ABA 16v k27turbo, 1980 Caddy
    05-01-2012 01:57 AM #668
    I guess I'll bite..... This 16vt has a long history .. It started w a k26 .... Roughly 12yrs later me and my son brought it off the engine stand (was fresh still) mounting a k26/27 hybrid 1.5 yrs to date it's now big turbo'd on a full k27 ... Its the daily....
    Here's the specs..sorry it's been awhile so some specs I don't remember lol..
    2.0 head reworked completely ported w shorter guides valves recut, springs etc.
    Metal head gasket
    One off "turbo" cams by crane cams yrs back... Like 290 something I forget the exacts
    Custom sidedraft carb intake modded for injection on single plenum (nothing was really avail in the late 90's)
    Remote FP regulator
    Custom fuel rail
    ABA stock bottom end , balanced rods
    Modded intermediate shaft
    Lightened flywheel with 4 puck
    Retained ABA serpentine setup w diesel bracket w/ g60 a/c compressor , modded n balanced crank pulley , PS retained as well
    Trans is combo g60 and vr6 gearing w modded linkage an short shifter
    The interesting stuff:
    Larger obd2 tb from r32/s4
    AEB , DBC (drive by cable) OBD2 ECU
    Upgraded larger MAF in blow-thru form
    ICM deleted and hardwired
    Rewired 2.0 FSI Coilpacks
    Modded distributor for home signal/cam sensor using 16v and Audi v8 shaft and 8v ABA sensor..
    Charcoal can relocated and wired as are both primary and secondary o2's, the latter is dead tho.
    Oil cooler looped for now till proper spot can be found , stocker is now removed
    Fully scannable ...
    True AN fittings / braided lines (there's a couple left still)
    Copper/brass radiator
    Swapped VR twin fan setup
    As mentioned K27 turbo
    Large log style manifold
    External 944 turbo wastegate 2" dump
    Wastegate modded to actuate as a twin port gate for faster spool ..
    RFL BOV ...
    Large Front mount (courtesy of a Saturn sky)
    1 pc 2.5" turbo to intercooler boost pipe
    3" intercooler to TB/intake piping
    3" turbo back side dump exhaust.. No kitty
    Manual HKS bleeder valve set @ 20 psi on 93 Pump , daily'd everyday all day ....
    But when it gets terrestrial out there, I've had it to 25....
    "Why yes it had 67 miles...and no i wont sell it.","Its not what you can buy, but what you can build"
    Quote Originally Posted by 88Jetta350 View Post
    Because it's not a Sheep car, or left original like others have said.
    I'm sure if he were dumping it on the ground with some BBS RS on it, the feedback would be more positive.
  4. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-04-2012 11:22 AM #669
    Should get back to logging this weened and I'll post one up chad.
  5. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-04-2012 11:23 AM #670
    No rush bro, was just curious
  6. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-04-2012 02:09 PM #671
    Quote Originally Posted by Sr. Karmann View Post
    Oh also. Xtremevdub should have something for you today...
  7. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-04-2012 02:26 PM #672
    Oh, surprises for me?
    He said you tossed something in with his air box, whatever it may be and a
  8. Member ncbrock's Avatar
    Sep 28th, 2010
    Raleigh, NC
    e36 M3 Sedan, M Coupe, FFR Cobra
    05-05-2012 01:57 PM #673
    the things I would do to have the tools\fab skills to make that front crossmember. I need something like this for my carb swap. radiator options are limited with the stock cross member
  9. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-05-2012 07:42 PM #674
    Quote Originally Posted by ncbrock View Post
    AFCO Scirocco rad FTW
  10. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-06-2012 11:24 AM #675
    Don't even know if it will work for you. But I'm sure you know someone who can use it.
  11. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-06-2012 07:40 PM #676
    werd, he got to the box yesterday and let me know there was a white ceramic turbo mani in there. Thanks a ton Fred, one step closer now ............
  12. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-06-2012 09:20 PM #677
    cheers
  13. Member Evil16v's Avatar
    Nov 15th, 2000
    Texas!
    05-07-2012 07:32 PM #678
    X2 .....
  14. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-07-2012 08:07 PM #679
    cheers
    Laid my hands on it today and is being stashed for the build, thanks again Fred
  15. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-07-2012 09:09 PM #680
    No prob man. Got something else for you.....
    1.2 bar at 4700
    And then this.....
    boom goes the dynamite
  16. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-07-2012 09:24 PM #681
    1.2 bar at 4700
    And then this.....
    What the Fu(k happened man?
  17. Member
    Jun 23rd, 2004
    ever changing
    91 Golf syncro 16vT, 01 jetta wagon 2.slow
    05-07-2012 09:37 PM #682
    thinking turbo went pop
  18. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-07-2012 09:45 PM #683
    Quote Originally Posted by clove911 View Post
    No. Bottom end rattling. stock aba rod went or rod bearing spun. Loss of oil pressure so could be either or.....
  19. Member Evil16v's Avatar
    Nov 15th, 2000
    Texas!
    05-07-2012 10:07 PM #684
    Damn....
  20. Member
    Jun 23rd, 2004
    ever changing
    05-09-2012 09:10 AM #685
    time for some new rods and bearings. i'm thinking SKAT
  21. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-09-2012 01:42 PM #686
    Will be building a built block for this thing. In the meantime I'm going to clean the crank, polish and throw a set of rid bearings in. New bottom end build coming soon. Obd1 aba again of course.
  22. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-09-2012 02:37 PM #687
  23. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-10-2012 01:26 PM #688
    So I used some real fine emery cloth on the crank. Looks really good. Gonna check with plastigauge today when the bearing get here. Might be able to save this after all. Time will tell.
  24. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-10-2012 09:37 PM #689
    Nice man, fingers crossed for you
  25. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-10-2012 10:12 PM #690
    So I got the bearings installed plastigauge tonight. Limit on rod bearings is .12 and mine measured .08. So I'm going for it. For those interested I'm building another obd1 aba block while driving this one. Will have aftermarket rods and pistons. Thinking 2.1 liter.
  26. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-10-2012 10:14 PM #691
    Hell ya
  27. Junior Member
    May 13th, 2012
    Boynton Beach, FL
    1997 VW Jetta TDi
    05-13-2012 10:05 PM #692
    There are lot of sweet builds in here. Hopefully I'll be able to share some pictures and video with you guys by the end of the summer. I just need more money so I can finish.
    '08 BMW 335i
    '97 Jetta TDi
    '04.5 Nissan 350z 475whp 505wtq Sold
    '00 BMW 323i Sold
    '97 Jetta TDi: Turbo 16v ABA Swap in Progress
  28. 05-14-2012 11:47 AM #693
    ok. here's mine thats waits for some things to be finished..
    KR 1.8L
    S2 rods and pistons
    mk1 oil cooler block connections
    051 head casting with KR cams
    audi S3 intake manifoold
    S2 exhaust manifold
    S3 injectors
    passat 20vt fuel rail
    RS2 k24 7200 turbocharger
    Mercedes sprinter intercooler
    02a vr6 CHN gearbox with g60 bellhousing
    passat g60 cable shifter
    i have digi1 with 16vt chip but it will be replaced with VEMS.
    I really hope that I will get it runnin this year...
    Pictures will come as this thing sits into its place..
    edit here's one of turbo
  29. Member MOTA BOY's Avatar
    Aug 21st, 2007
    Daruvar Croatia
    VW Golf MKII GTI KR(T) 1990
    05-15-2012 05:23 PM #694
    To si ti polirao?
  30. 05-15-2012 10:20 PM #695
    I know this is probably a dumb question and everyone's gonna say use the search button but I'm thinking of attempting a 16vt build and I was wondering what is a common fuel system to run on. My cabriolet is on CIS right now. Would I be able to push about 15-20 psi or would I have to swap the fuel system?
    I am here: http://tapatalk.com/map.php?ikvws2
  31. Semi-n00b meinDUB's Avatar
    Oct 5th, 2010
    Colorado Springs, CO
    07 Jetta GLI
    05-16-2012 11:55 AM #696
    [QUOTE=89cabrioletmarc;77404414]I know this is probably a dumb question and everyone's gonna say use the search button but I'm thinking of attempting a 16vt build and I was wondering what is a common fuel system to run on. My cabriolet is on CIS right now. Would I be able to push about 15-20 psi or would I have to swap the fuel system?
    I hear the entire cis system is good to about 8 lbs.. I'd say stand alone like megasquirt or digi 1 with bbm chip but that's just from research not from experience.. I'm piecing together my digi swap from motronic, just dealing with maintenance issues atm.
    Sent from my toilet..
  32. 05-16-2012 03:43 PM #697
    2: Mota.. skoro... to je boja
    2: 89cabriomarc you can use K-jet but that's not gonna give you that power you are looking for, and it will never do what will MegaSquirt or VEMS do...
  33. 05-16-2012 03:56 PM #698
    Quote Originally Posted by LamaMk1 View Post
    Thanks guys. I'll do more megasquirt Research.
    I am here: http://tapatalk.com/map.php?dpcgaq
  34. Member vwflygti's Avatar
    Sep 10th, 2002
    Pennsburg, Pa
    05-17-2012 06:55 PM #699
    Do more vems research ;-)
  35. Member Sr. Karmann's Avatar
    Feb 4th, 2009
    Ft. Lauderdale, FL
    05-18-2012 12:11 AM #700
    Building a MS3 as we speak, another 16v of course
