Page 4 of 33 FirstFirst 1 2 3 4 5 6 7 8 14 ... LastLast
Results 106 to 140 of 1134
Thread: NEW- Lets see your 16V TURBO 16VT with SPECS!
    Feb 17th, 2008
    ontario
    2 vw's
    01-26-2010 07:13 PM #106
    Alright nice... Thanks for the help!
  2. Member Amsterdam087's Avatar
    Dec 31st, 2007
    Gone Fishin'
    4x4
    01-27-2010 11:26 AM #107
    Quote, originally posted by weeblebiker »
    your car has been one of my favorites. tasteful black on white,
    kinda reminds me of the James Bond lotus esprit sub car
    wow dude, thank you kindly.
    I am an apex predator, and hatchery zombies are my target
    ****BPC****
  3. Junior Member .Christiano.'s Avatar
    May 24th, 2005
    Curitiba/PR - Brazil
    01-27-2010 08:10 PM #108
    86.4mm oem lightweight crank
    144mm pauter rods
    83.5mm iasa pistons
    total seal rings
    clevitte bearings
    3 stage dry sump system (cicare external oil pump)
    oem lightweight flywheel
    single(!) disc (5 puck) clutch
    Fully rebuilt 16v ABA Head
    Supertech Valves (std size)
    Iskenderian valve springs
    Titanium Retainers
    Custom inox exhaust manifold
    Custom intake manifold (cast)
    70mm throttle body
    MSD 7AL2 Ignition Module
    MSD ProPower Coil
    8x160lb injectors
    Aeromotive belt driven fuel pump
    Aeromotive FPR
    EMS: Fueltech Racepro1Fi (www.fueltechusa.com)
    Bullseye S372 Race Cover
    Macktech 50mm wastegate
    4" exhaust
    3" piping
    1000hp water/air intercooler
    Never got dyno numbers but what really matter is the track time on the first (almost) clean run: 9.553@only 224km/h
    Videos showing the build/runs on my YT channel:
    http://www.youtube.com/christianop
    http://www.dragstrip.com.br - Your source for brazilian drag racing info
  4. Member ballski's Avatar
    Jun 13th, 2006
    Cincinnati
    alpine 135i
    01-27-2010 08:16 PM #109
    Quote, originally posted by .Christiano. »
    Holy monsta!
    Corrado 16vT SOLD
    BMW 135i stage 2
    e30 350is sbf v8 <-------go kart
    e30 325i calypsorot Vert daily FOR SALE
    '61 Cadillac DeVille project
  5. 01-29-2010 12:07 AM #110
    Here's my Brother's a2 gti. It has been a long fun project. Gotta get a 3 bar map sensor to turn up the boost!
    ported head
    JE pistons
    Pauter rods
    arp studs
    Megasquirt
    72#injectors
    t58 turbo
    3" exhaust
    MSD6al
    FMIC
    custom piping
    Ford 5.0 throttle body
    255 Walbro fuel pump
    #8 fuel line
    http://www.youtube.com/watch?v=Aut2bsyQctI
  6. Member
    Nov 26th, 2000
    New Jersey
    A2 GTI,B5A4,B6A4, 2.7t
    01-29-2010 08:02 PM #111
    8x160lb injectors
    Voces estao a usar Metanol ou o Etanol?
    com injector assim ta mais virado pro Metanol
  7. Junior Member .Christiano.'s Avatar
    May 24th, 2005
    01-30-2010 04:28 PM #112
    We are running on methanol, Killa
    Nov 26th, 2000
    New Jersey
    01-30-2010 07:00 PM #113
    Figures that 8 160cc injectors are only good for that, what's the power level of that? Those injectors can support 900+ at the wheels even on Methanol.
  9. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    01-30-2010 08:47 PM #114
    Aeromotive FPR
    You sir know what is up!
  10. 01-30-2010 10:21 PM #115
    can anybody ive me a guestimate about how much it would be to do a 16VT?...im 18 and got a part time job runnin me maybe 900 a month so its tight i guess...guestimates??
    P.S i got a 89 1.8 16v jetta trophy
    Engine covers are like condoms. Sure your suppost to use them, but it's better without them.
  11. Junior Member .Christiano.'s Avatar
    May 24th, 2005
    01-31-2010 08:13 AM #116
    I think we have a 750-800hp+ engine here.
    We tried to make a pass on the dyno but in the very first pass the MTs (both) blew up (http://www.youtube.com/watch?v=9xUbwGBkty4) and we got a failure on the dyno rpm sensor, causing a wrong read of the pass.
    We never get back on the dyno since this time.
  12. Junior Member .Christiano.'s Avatar
    May 24th, 2005
    01-31-2010 08:23 AM #117
    Quote, originally posted by Issam Abed »
    Thanks Issam!
    I tried to fix all the mistakes I made with my old cars. Its better to spend some money one time than spend money during all the season trying to fix things that will fail again and again.
  13. Member Greengt1's Avatar
    Aug 27th, 2006
    Lansing IL
    92 Monty Green GTi 16vt
    02-18-2010 03:01 PM #118
    WOO HOO!!!
    Plenty of parts for sale!
  14. Member NJRrado's Avatar
    Jul 10th, 2003
    VA
    Trucks...
    02-20-2010 02:16 PM #119
    Here's mine:
    Motor:
    -OBD I ABA bottom end
    -9a 16v head
    -ABA pistons
    -ARP rod bolts
    -ARP head studs
    -ABA headgasket
    Turbo Stuff:
    -Racecraft Intake w/air bells and fuel rail
    -Mustang TB
    -Tubular SS exhaust manifold (not equal length)
    -RC 550cc injectors
    -Garret GT28RS
    -350HP bar and plate IC
    Management:
    -034 Stage IC 16v kit w/034 harness
    -Ignition triggered off of stock ABA crank position sensor
    Misc:
    -Setrab oil cooler + -8an lines and sandwich plate
    -Knocksense MS (knock detector circuitry w/output to standalone ems and warning light)
  15. 02-23-2010 03:41 AM #120
    been working on getting this in the last few days. We're still waiting on a bunch of parts and the trans to get finished before dropping it in.
  16. Member MK1 Rabbit GTI's Avatar
    Jan 12th, 2006
    Niagara
    83 GTI, 90 90, 92 GTI, 00 a4
    02-23-2010 06:30 PM #121
    i like the coils
  17. Banned ellocolindo's Avatar
    Jan 14th, 2010
    02-23-2010 08:35 PM #122
    that last engine on a stand. is that a oem valve cover? from what car?
  18. Member Hustlin's Avatar
    Nov 21st, 2004
    Stroudsburg PA
    E46 M, B5 1.8TQM Avant, GSXR 750
    02-23-2010 08:44 PM #123
    That's a stock valve cover.
    pm for air freshener installs. master certified, high rates.
  19. 02-25-2010 11:11 PM #124
    Quote, originally posted by BastardDuck »
    More info on the intercooler setup please!!!
    Its a modified Intercooler off a early turbocoupe. It actually works well (at 7psi) even under long periods of boost.
  20. Member REPOMAN's Avatar
    May 3rd, 2001
    Portland OR
    1990 VW Corrado
    02-26-2010 12:09 AM #125
    That build looks familure, i have alot of the same parts.
    What T/B plate is that on the BBM intake?
    Are you going to run 034? I recognise the ignition coil.
    http://www.youtube.com/watch?v=-Yh98OFjJqc
    500HP 1990 Cowrado
  21. 03-03-2010 05:27 AM #126
    Quote, originally posted by REPOMAN »
    Its the obd I vr tb plate, the car is gonna be running on spectre ems pro. We are just trying to figure out most of the finally touches to the swap before the car gets sent out to have all the IC piping fab'd and exhaust. Haven't seena anyone running the DP on the passanger side so hopefully there's enough room. Had trouble with the cable to hydro clutch conversion also, I think I figured it out and I just need to add a clip to the aba clutch pedal to hold the clutch master clyinder push rod thingy. On the mk4 2.0 throttle cable the little ball that snaps onto the gas pedal is a tad bit smaller so I might see if the mk4 one will fit on the mk3 gas pedal. On top of everything else the side to side o2a shift bracket we got dosn't seem like the right one but even the gruvenparts bullet one looks like the same design, just dosn't fit right...
  22. Member
    Jul 5th, 2005
    St. Paul, MN
    mk1 Tankwagen
    03-22-2010 02:21 PM #127
    bump
  23. Member sp_golf's Avatar
    Nov 28th, 2007
    Toronto
    88 Golf 16vT
    03-22-2010 07:30 PM #128
    Quote, originally posted by s4quattro187 »
    It's gonna be tight.. What exhaust mani are you running and which subframe/rear mount?
    Message me for tuning solutions.
  24. Member
    Apr 2nd, 2003
    Richmond IN
    03-23-2010 07:19 PM #129
    I run a pass side dp in my rocco. 3" turbo to cat.
    dunno about an A2.
    '87 rocco ,ABA16VitbT, 9a pistons, dual exhaust cams, megasquirt v2.2 2-extra, E85,
    volvo TD0-14T turbo, celica intercooler, corolla manifold, gsxr itbs, water injection, staged injection.
    exhaust cam mod info: http://forums.vwvortex.com/showthread.php?2508013
  25. 03-24-2010 03:59 PM #130
    want to show me valve cover
    made for the 115 M coils
  26. Member elRey's Avatar
    May 15th, 2001
    16vt 2.0L MK4 Jetta Wagon | B6 A4 Avant
    03-24-2010 05:43 PM #131
    CNC is great! How does the stock oil cap fit with coil in place?
    New coils for me:
    Modified by elRey at 5:50 PM 3-24-2010
  27. 03-25-2010 03:50 PM #132
    it fits perfect
    And it is not made with a cnc machine
  28. Member elRey's Avatar
    May 15th, 2001
    03-26-2010 12:15 PM #133
    Quote, originally posted by tp-denmark »
    it fits perfect
    Care to explain then?
  29. 03-26-2010 04:04 PM #134
    what kind of alternator are you running ??
  30. Member MK1 Rabbit GTI's Avatar
    Jan 12th, 2006
    Niagara
    03-27-2010 04:09 PM #135
    Quote, originally posted by elRey »
    probably did it on a mill
  31. Member dogger's Avatar
    Jul 29th, 2005
    Pasadena, CA
    1990 Corrado 2L 16V, 2004 Audi TT 3.2 Quattro S-Line
    04-02-2010 12:30 AM #136
    Looks like it from the marks left in the cover.
  32. Member artspeed's Avatar
    Dec 19th, 2005
    Chattanooga, TN
    90 Jetta GLI 16VT, 03 20th AE 1.8T BT
    04-09-2010 04:45 AM #137
    Chassis: MK2 Jetta GLI
    2.0L 9A Factory Bottom End
    Autotech Baffeled Oil Pan with Windage Tray
    Single Layer Low Compression Head Gasket 9.5:1
    ARP Head Studs
    ARP Main Studs
    ARP Rod Bolts
    Knife Edged Crank
    Stage 3 Port and Polished Head
    3 Angle Valve Job
    Autotech 252 Intake Cam
    Autotech 264 Exhaust Cam
    Techtonics Titanium Valve Springs & Retainers
    Autotech Lightweight Intermediate Shaft Pulley
    Techtonics Tuning Adjustable Cam Gear
    Kent Cams Competition Timing Belt
    Custom short runner intake manifold
    Edelbrock 75mm Throttle Body
    Custom Short Runner Fuel Rail
    42# Racetronix Injectors
    Custom Tubular Exhaust Manifold
    2.5" Intercooler Piping
    Spearco Vertical Bar & Plate Intercooler
    Turbonetics 62-1 T3/T4 Stage 5 Ball Bearing Turbo
    Boost Logic Turbo Blanket
    Turbonetics Raptor Blow Off Valve
    Tial 38mm External Wastegate vented to atmosphere
    TurboXS Boost Controller set at 18psi
    TEC 3 Electromotive Stand Alone Engine Management System
    Moroso Polished Vented Catch Can
    Custom Taylor Spark Plug Wire Set
    NGK BKR7E .027
    Aeromotive Fuel Pressure Regulator
    020 2Y gear box with .80 5th and Peloquin Limited Slip
    8 Puck Copper Clutch
    8.5# steel flywheel
    Passat 16V Dual Radiator Fan
    Setrab Oil Cooler with Mocal Thermostatic Sandwich Adapter
    3" Stainless Steel Downpipe with DEI Exhaust Wrap
    2.5" Stainless Steel Exhaust w/ Borla Muffler
    MBC set at 18psi. Boost starts coming on at 4K. New dyno with new tune, larger injectors, and more boost to come.
  33. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    1989 Helios GLI 1997 Mk3 ****box
    04-09-2010 12:28 PM #138
    Seems like your running a bit lean artspeed.....I see 13:1 a/f the whole way
  34. Member artspeed's Avatar
    Dec 19th, 2005
    Chattanooga, TN
    04-09-2010 12:58 PM #139
    This was the first dyno after doing some street tuning. I have since made some changes to the VE table but before I make changes I am going to drop in some 630cc or 730cc injectors. My setup is currently running narrow-band and I will be switching over to wide-band here shortly. I'm not to sure about the A/F readout from the dyno because the car runs and smells rich. The narrow band gauge seems to read more on the rich side. The A/F readouts at dyno day were also showing other cars running on the lean side as well even though their on board-wide band was reading different. The car idles great and runs and pulls great all the way to redline. I have been beating on it this way for a few years now with no problems. It definitely has more potential.
  35. Member Golf 16v fpos's Avatar
    Jun 18th, 2009
    North Jersey
    1985 Golf 16v, Mk4 GTI 24v
    04-13-2010 02:11 PM #140
    what turbo manifold should i get thats cheap and is good anyone ?
