VWVortex.com - NEW- Lets see your 16V TURBO 16VT with SPECS!
    Page 5 of 76 FirstFirst 1234567891555 ... LastLast
    Results 101 to 125 of 1894
    Thread: NEW- Lets see your 16V TURBO 16VT with SPECS!
      May 20th, 2009
      UK
      01-26-2010 01:12 AM #101
      16vT....One day....one day.
    2. Member BastardDuck's Avatar
      Dec 10th, 2006
      LAla land, CA
      1976 Porsche 911S, 1997 Jetta GLX, 1991 Jetta GLi 16vt
      01-26-2010 06:24 PM #102
      Quote, originally posted by yellowjet »
      92 b3 wagon
      9a head (stock)
      aba bottom end (stock)
      arp head studs
      custom turbo manifold
      Rhb5 VF4 IHI turbo (making killer boost of 7psi)
      MS1 w/ msnsextra
      36lb injectors
      top mount intercooler (draws air from back of headlight)
      35 shot of nitrous for giggles.
      Modified by yellowjet at 1:48 AM 12-14-2009
      More info on the intercooler setup please!!!
      Feb 17th, 2008
      ontario
      2 vw's
      01-26-2010 07:22 PM #103
      how well do those autotech sport cams work in a turbo application?
    4. Member
      Feb 17th, 2008
      ontario
      2 vw's
      01-26-2010 07:23 PM #104
      how well dop those autotech sport cams work in a turbo application?
    5. Member Greengt1's Avatar
      Aug 27th, 2006
      Lansing IL
      92 Monty Green GTi 16vt
      01-26-2010 07:47 PM #105
      excellent.. they are the biggest you should go without getting the overlapping out with internal cam gears..
      Plenty of parts for sale!
    6. Member
      Feb 17th, 2008
      ontario
      2 vw's
      01-26-2010 08:13 PM #106
      Alright nice... Thanks for the help!
    7. Member Amsterdam087's Avatar
      Dec 31st, 2007
      Gone Fishin'
      4x4
      01-27-2010 12:26 PM #107
      Quote, originally posted by weeblebiker »
      your car has been one of my favorites. tasteful black on white,
      kinda reminds me of the James Bond lotus esprit sub car
      wow dude, thank you kindly. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    8. Junior Member .Christiano.'s Avatar
      May 24th, 2005
      Curitiba/PR - Brazil
      01-27-2010 09:10 PM #108
      86.4mm oem lightweight crank
      144mm pauter rods
      83.5mm iasa pistons
      total seal rings
      clevitte bearings
      3 stage dry sump system (cicare external oil pump)
      oem lightweight flywheel
      single(!) disc (5 puck) clutch
      Fully rebuilt 16v ABA Head
      Supertech Valves (std size)
      Iskenderian valve springs
      Titanium Retainers
      Custom inox exhaust manifold
      Custom intake manifold (cast)
      70mm throttle body
      MSD 7AL2 Ignition Module
      MSD ProPower Coil
      8x160lb injectors
      Aeromotive belt driven fuel pump
      Aeromotive FPR
      EMS: Fueltech Racepro1Fi (www.fueltechusa.com)
      Bullseye S372 Race Cover
      Macktech 50mm wastegate
      4" exhaust
      3" piping
      1000hp water/air intercooler
      Never got dyno numbers but what really matter is the track time on the first (almost) clean run: 9.553@only 224km/h
      Videos showing the build/runs on my YT channel:
      http://www.youtube.com/christianop
      http://www.dragstrip.com.br - Your source for brazilian drag racing info
    9. Member ballski's Avatar
      Jun 13th, 2006
      Cincinnati
      alpine 135i
      01-27-2010 09:16 PM #109
      Quote, originally posted by .Christiano. »
      Holy monsta!
      Current Moneypits: e39 m5 lemans/caramel - bagged v70R - Corrado slc soon to be VRT - bagged 1961 Cadillac deVille
    10. 01-29-2010 01:07 AM #110
      Here's my Brother's a2 gti. It has been a long fun project. Gotta get a 3 bar map sensor to turn up the boost!
      ported head
      JE pistons
      Pauter rods
      arp studs
      Megasquirt
      72#injectors
      t58 turbo
      3" exhaust
      MSD6al
      FMIC
      custom piping
      Ford 5.0 throttle body
      255 Walbro fuel pump
      #8 fuel line
      http://www.youtube.com/watch?v=Aut2bsyQctI
    11. Member
      Nov 26th, 2000
      New Jersey
      A2 GTI,B5A4,B6A4, 2.7t
      01-29-2010 09:02 PM #111
      8x160lb injectors
      Voces estao a usar Metanol ou o Etanol?
      com injector assim ta mais virado pro Metanol [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. Junior Member .Christiano.'s Avatar
      May 24th, 2005
      01-30-2010 05:28 PM #112
      We are running on methanol, Killa
    13. Member
      Nov 26th, 2000
      New Jersey
      01-30-2010 08:00 PM #113
      Figures that 8 160cc injectors are only good for that, what's the power level of that? Those injectors can support 900+ at the wheels even on Methanol.
    14. Member Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      91 Audi 80 2.0T
      01-30-2010 09:47 PM #114
      Aeromotive FPR
      You sir know what is up! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    15. 01-30-2010 11:21 PM #115
      can anybody ive me a guestimate about how much it would be to do a 16VT?...im 18 and got a part time job runnin me maybe 900 a month so its tight i guess...guestimates??
      P.S i got a 89 1.8 16v jetta trophy
      Engine covers are like condoms. Sure your suppost to use them, but it's better without them.
    16. Junior Member .Christiano.'s Avatar
      May 24th, 2005
      01-31-2010 09:13 AM #116
      I think we have a 750-800hp+ engine here.
      We tried to make a pass on the dyno but in the very first pass the MTs (both) blew up (http://www.youtube.com/watch?v=9xUbwGBkty4) and we got a failure on the dyno rpm sensor, causing a wrong read of the pass.
      We never get back on the dyno since this time.
    17. Junior Member .Christiano.'s Avatar
      May 24th, 2005
      01-31-2010 09:23 AM #117
      Quote, originally posted by Issam Abed »
      Thanks Issam!
      I tried to fix all the mistakes I made with my old cars. Its better to spend some money one time than spend money during all the season trying to fix things that will fail again and again.
    18. Member Greengt1's Avatar
      Aug 27th, 2006
      Lansing IL
      02-18-2010 04:01 PM #118
      WOO HOO!!!
    19. Member NJRrado's Avatar
      Jul 11th, 2003
      VA
      Trucks...
      02-20-2010 03:16 PM #119
      Here's mine:
      Motor:
      -OBD I ABA bottom end
      -9a 16v head
      -ABA pistons
      -ARP rod bolts
      -ARP head studs
      -ABA headgasket
      Turbo Stuff:
      -Racecraft Intake w/air bells and fuel rail
      -Mustang TB
      -Tubular SS exhaust manifold (not equal length)
      -RC 550cc injectors
      -Garret GT28RS
      -350HP bar and plate IC
      Management:
      -034 Stage IC 16v kit w/034 harness
      -Ignition triggered off of stock ABA crank position sensor
      Misc:
      -Setrab oil cooler + -8an lines and sandwich plate
      -Knocksense MS (knock detector circuitry w/output to standalone ems and warning light)
    20. 02-23-2010 04:41 AM #120
      been working on getting this in the last few days. We're still waiting on a bunch of parts and the trans to get finished before dropping it in.
    21. Member MK1 Rabbit GTI's Avatar
      Jan 12th, 2006
      Fonthill
      83 GTI, 00 a4, 81 scirocco, 98 a4, 01 a4
      02-23-2010 07:30 PM #121
      i like the coils [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    22. Banned ellocolindo's Avatar
      Jan 14th, 2010
      02-23-2010 09:35 PM #122
      that last engine on a stand. is that a oem valve cover? from what car?
    23. Member Hustlin's Avatar
      Nov 21st, 2004
      Stroudsburg PA
      E46 M, 981 Cayman S, E36 318i, 2500HD, '59 Ragtop
      02-23-2010 09:44 PM #123
      That's a stock valve cover.
      pm for air freshener installs. master certified, high rates.
    24. 02-26-2010 12:11 AM #124
      Quote, originally posted by BastardDuck »
      Its a modified Intercooler off a early turbocoupe. It actually works well (at 7psi) even under long periods of boost.
    25. Member REPOMAN's Avatar
      May 3rd, 2001
      Portland OR
      1990 VW Corrado
      02-26-2010 01:09 AM #125
      That build looks familure, i have alot of the same parts.
      What T/B plate is that on the BBM intake?
      Are you going to run 034? I recognise the ignition coil.
      http://www.youtube.com/watch?v=-Yh98OFjJqc
      500HP 1990 Cowrado
      Have a great Orwellian Day
      https://www.youtube.com/user/RepomanPro
