Any local yamaha dealer will be able to order them and likely have them in stock. They usually have boxes and boxes of jets for various carbs
#1226
OIF 06-07: Hospital Corpsman FMF. Al Habbaniyah, Al-Anbar Province, Iraq.
Mk2 16v parts for sale.
Mk2 Golf_GL 16v @ Streets of Willow Raceway.
Project Гольф Мк2 (Carbed)
#1227
#1228
#1229
then looks like drilling is your best bet, its not hard at all just order a dozen or so small drill bits of the right size from mcmaster-carr
#1230
#1231
well if it comes down to it, drilling them is super easy with a drillpress, especially one with a vice.
Hell for less than the cost of a jet kit I bought my drillpress and vice off craigslist.
Feel free to follow me on instagram @wesmurphy for pictures of bikes, bimmers, vws, etc
my "build" thread: 16v+carbs FOR SALE!!!
My gti is for sale, check it out! http://forums.vwvortex.com/showthrea...7#post79821897
#1233
#1234
Help save the Boobies!! Dub 'N Rub VW/Audi Show & Shine to benefit breast cancer research.
#1235
on a side note, what size are the R1 carbs?
#1236
That'd be great, if only where I live had knowledgeable carb specialists. So no, there aren't. Also, the guy with these carbs is not near me (In Mexico City, Mexico), he's in the country of Guatemala, so I'd like to be able to help him as best to my ability.
Guesswork was what I did when I installed my R1 carbs, thanks to the knowledge of some awesome dudes on here, which gave me the guts to do the mod myself, instead of handing the job to someone else. I'm not saying it's not good, it's just different.
Anyways, I'll contnue to look for answers.
#1237
#1238
I haven't played with them too much, but here's a video I found on the basics of the Holley Carb's accelerator pump. IT should at least give you a better understanding of it works than I can!
http://www.youtube.com/watch?v=dW6YGxVTW5Y
#1239
#1240
which filters are the least restrictive for the carbs?
#1241
Screens. Then a nice paper filter such as k&n or a good foam filter for decent flow but best protection.
#1242
#1243
Here is what I did for my "filter" Took half of the R1 intake and mated up with half of an aircooled fuel injected airbox and doubled up some window screen as the filters. Works great and almost looks like it could be a factory item.
On a side note:
Are any of you monkeys going to be making it to SOWO next weekend?? It would be interesting to get as many R1 carb setups together.![]()
#1244
#1245
#1246
#1247
Mine fit no problem with filters, I just don't buy anything on eBay unless It's a known and respected brand. EBay sells lots of crappy products, and I learned that many years ago.They are cheap for a reason.
The set I have seem fine. But I can respect you wanting a known brand for something like an air filter. I dont even run filters. They hit my hood![]()
#1248
people run no filters all the time with webers, I dont see why cheaping out on ebay filters for the street is a problem. I run no filters unless its raining on my webers.
#1249
good luck with re-building your engine. im going to be racing the car, so there will be a need for filters.
So i was checking my timing, got the car warmed up and it cycled the radiator fans 2 times. The only time I saw the timing mark was when the dial on the gun was past 60. Where should the timing be set at?
#1250
people run open webers ALL the time up at the track. Every car ive seen at the vintage races with webers didnt have any filter on it. Id say 80% of people on here with webers run no filters also so I guess they all will be rebuilding their engine too?
just sayin, don't knock something till you actually know
#1251
Hes made it clear he wants to run filters, so no need to attack anyone.
I will say, running filters vs no filters makes a difference in what jets you run. My car will not run right with the filters on, the slight restriction is enough to make it pull too much fuel.
#1252
Since we're on the filter topic what does everyone think of these uni filters?
#1253
I'm not saying to run no filters I'm just saying that running "cheap" ebay filters on any type of road is fine. Unless your following someone costantly that's in the dirt or your track cleaners suck then it will be fine with cheap paper filters. If you feel like going overkill on everything then go ahead its not my money
The only reason I would go with a quality filter is if your carbs are tuned properly Nd your WOT all the time and fuel is atomizing out the front like they should the filters will break down eventually and I've seen filters do more harm than good. So id rather get a quality filter for that quality rather than believing they block out more particles
#1254
#1255
Any reusable paper style filter with k&n oil will be just as good as a k&n. Also keep in mind the dirtier a filter gets the more it filters and restricts flow. If you're tracking your car run screens if you want some kind of protection. If your carbs face the front don't run foam filters when its raining it'll suck up as much water as it wants. Paper does the same but not quite as bad. It'll also ruin the paper if soaks up enough water. I found if its raining my car only runs with the filters off. Not the best for the engine but I had to do it a couple times :/
#1256
#1257
No English at all. Set the timing at 60 you'll be fineseriously do you even read? I'm not saying run no filters I'm just saying don't bash ebay filters for street use because people run no filters all the time. Who speaks English now? I forgot why I left vortex a while ago, now I remember.
#1258
Your argument is flawed. Just because you can run no filters, does not mean that you can run cheap filters just fine. What if a cheap filter falls apart, and sucks in your intake? Then it would most certainly be worse than running no filter at all. This is likely what he is trying to avoid. I have had my car eat a set of screens I was running as an intake. I dont like to think about what it did to the inside of the engine, I just pretend it went through without causing any harm.
#1259
almost everything on ebay is crap. i rather spend more on quality and reliability.
just ignore ncbrock, he always talks out of his ass, half the comments he makes are completely meaningless.
now that we are dont conversating about filters, whats the timing should be at?![]()
