Page 41 of 48 FirstFirst ... 31 37 38 39 40 41 42 43 44 45 ... LastLast
Results 1,401 to 1,435 of 1674
Thread: Switching to Bike Carbs. Heres a write up!
  1. 07-30-2012 10:15 PM #1401
    Quote Originally Posted by yeayeayea View Post
    what distributor are you using? do you have a picture?
    I'm running a vaccum advanced distributor off a mk1 rabbit off a 1.8
    Photobucket Pictures, Images and Photos
    Sorry about the size couldn't figur out how to shrink it down
  2. Member rysskii3's Avatar
    Apr 18th, 2006
    SoCal
    MKII Race Car
    07-31-2012 12:06 AM #1402
    Quote Originally Posted by forestgreenjett View Post
    The distributor is turned counter clockwise to the point that the hall sensor is resting against the motor is this wronge ?
    Get a timing gun and check your timing.
    OIF 06-07: Hospital Corpsman FMF. Al Habbaniyah, Al-Anbar Province, Iraq.
    Mk2 16v parts for sale.
    Mk2 Golf_GL 16v @ Streets of Willow Raceway.
    Project Гольф Мк2 (Carbed)
    May 17th, 2010
    Portland, OR
    '91 Jetta 16V on R1 Carbs
    07-31-2012 12:55 AM #1403
    Quote Originally Posted by oldschool eighty8 View Post
    Staccccks
    And yes they do clear the hood. I'm going to get some screen filters for them also. He said he can make filters to go directly on the carbs.
    Pjmotorsports.com awesome customer service. Ordered last Friday they were at my door yesterday.
    Whoa. Which kit is that??
    Need a 16V manifold flange to build your custom carb intake mani!?! I can get you one laser-cut for $85 shipped!!! PM me!
  4. Member oldschool eighty8's Avatar
    Apr 17th, 2009
    Way up theah, Maine
    CW mkv GTeye,BM20th toilet#461(dead to me),91 EA cabby, yellow C
    07-31-2012 04:57 AM #1404
    Pjm 45kit
    I spoke with them about also making filters to fit directly on the carbs and they can do it. You just need to call and tell them exactly what you need.
    May 17th, 2010
    Portland, OR
    08-01-2012 02:33 AM #1405
    Pjm 45kit
    Not bad for $79.99. How are they held on??
    I'd buy a set but then I'd also have to buy the filters at $30 a pop. Which is reasonable, but too much for me.
  6. Member oldschool eighty8's Avatar
    Apr 17th, 2009
    Way up theah, Maine
    08-01-2012 04:37 AM #1406
    They are held on with clamps. Your going to spend close to that for any filter kit you buy.
    Edit: anyone with r1 carbs played with the needle heights to get a little more fuel? It's so close that I think drilling the jets would be too much
  7. Member keeton's Avatar
    Aug 15th, 2010
    Winston Salem, NC
    '84 Jetta, '84 Mustang, '71 F250
    08-02-2012 12:37 AM #1407
    Question: Can anyone with a 16v in a Mk1 give me the approximate angle of the engine (maybe angle of the top of the valve cover) sitting in the car and the angle of the carbs mounted up to the engine? I need to build my manifold, but sitting the 16v in to take measurements isn't an option as I have to drive the car every day.
    Any help would be appreciated.
  8. Member 86Franklin's Avatar
    Apr 5th, 2008
    Goshen, Indiana
    1986 VW Cabriolet 1.8l 16v / 01 Audi A6 2.7T Quattro
    08-02-2012 04:16 PM #1408
    top of the valve cover should be level to the ground
    May 17th, 2010
    Portland, OR
    08-03-2012 02:08 AM #1409
    Please post pics with filters when you get them!
  10. Member
    May 17th, 2010
    Portland, OR
    08-09-2012 02:39 AM #1410
    Idle and WOT switches. Can someone please tell me how they affect ignition timing on the CIS-e knockbox setup?
    I've read the idle switch may be used to hold ignition timing steady so the idle doesn't hunt. Makes sense but what about the WOT switch?? Does it affect ignition timing at all?? I'd guess its for fuel enrichment but I'm only worried about timing.
    I fired up the car with with the knockbox setup but I dont have cooling hooked up yet so I couldn't test anything.
  11. Member yeayeayea's Avatar
    May 29th, 2005
    md
    89 GTI 16v with carbs, 99 528i, 95 gsx600
    08-09-2012 04:35 PM #1411
    i dont have either of the throttle switches hooked up. My car drives fine
    Feel free to follow me on instagram @wesmurphy for pictures of bikes, bimmers, vws, etc
    my "build" thread: 16v+carbs FOR SALE!!!
    My gti is for sale, check it out! http://forums.vwvortex.com/showthrea...7#post79821897
    May 17th, 2010
    Portland, OR
    08-10-2012 02:15 AM #1412
    After thinking about it more I would say the WOT switch most likely doesn't affect ignition. Think idle switch could though. Yeyyeayea how's you idle?? Steady?
    I really want to hook them up so I can take full advantage of the knockbox setup but there's no reason if they wont affect ignition timing. Anyone have any input??
  13. Member yeayeayea's Avatar
    May 29th, 2005
    md
    08-10-2012 09:07 PM #1413
    Mine idles fine I suppose. It may help when you shift into neutral coming to a stop, im not sure. I have never tried the idle switch.
  14. Member
    Jun 28th, 2006
    Elizabethtown, PA
    '97 Golf daily beater, '82 Rabbit 'vert project/toy, '92 Jetta VRT project/toy
    08-12-2012 10:09 AM #1414
    Quote Originally Posted by bmwquick View Post
    From all of my digging they both have a purpose. Granted, mine still isn't running, yet, but that's because I want it all right!
    The idle switch puts the ICM/knockbox into a default timing curve to help keep the idle smooth.
    Now for the full throttle switch, I've heard it does have an effect on the ignition system, not just fuel enrichment. OTH, what I've heard it does doesn't make much sense to me. I've heard the full throttle switch cuts out the knock sensor to keep it from pulling timing from valvetrain noise. This seems to me to counter the purpose of the knock sensor, so I may still opt out of the full throttle switch. I still have to think that with hydraulic cam followers there should be much less "extra" valvetrain noise then in the early solid follower engines.
    I've already picked up a NOS micro switch for my idle switch and have started the template for my bracket. I plan to include a bit of a adjustment to fine tune it's switching point.
    Help save the Boobies!! Dub 'N Rub VW/Audi Show & Shine to benefit breast cancer research.
  15. Member rysskii3's Avatar
    Apr 18th, 2006
    SoCal
    MKII Race Car
    08-12-2012 11:13 AM #1415
    Quote Originally Posted by YJSAABMAN View Post
    are you guys trying to run the carbs with stock ignition?
    i run MSD setup (coil, start/retard, tach adapter, spark box 6a, oem ICM). i dont use any of the switched and my car idles perfectly while its still untuned.
  16. Member oldschool eighty8's Avatar
    Apr 17th, 2009
    Way up theah, Maine
    08-12-2012 12:48 PM #1416
    Quote Originally Posted by rysskii3 View Post
    Same here, I have no switches. Running a ms1 board to control the coil. Idle is steady and right at 1k once it's up to temp.
  17. Member
    May 17th, 2010
    Portland, OR
    08-13-2012 12:42 AM #1417
    Well you guys are only running the ICM without the knockbox. Deleting the knockbox automatically deletes the idle/wot switches since they're wired to the knockbox. Thats probably the best way to go but MSD costs money compared to the 100% OEM knockbox setup I ripped out of picknpull for $30.
    Well I pm'ed B4S here who's run the setup before and he said pretty much exactly that.
    "Yep, the idle switch locks the timing at idle. The WOT switch may be for fueling, but I have no idea. I'm fairly certain that it also disables the knock sensor above a certain RPM, to account for valvetrain noise. You can run without the WOT switch with no ill effects, and even the idle switch if you have a mild cam. A lumpy cam might idle better with the switch, IMO. I ran with them both and without them both and noticed barely any difference in the car when carbed ."
    If you get a custom cut bracket for your switches I'll gladly pay for an extra!
  18. Member
    Jun 28th, 2006
    Elizabethtown, PA
    08-14-2012 12:32 PM #1418
    Yup, that's who I heard it from, too. And with the compression ratio of an ABA and screwing around with timing and fuel in this manner I definitely want that knock sensor!
  19. 08-19-2012 08:23 PM #1419
    Am I seeing this right? You've got a vacuum line coming off of cylinder #4, then the check valve, then your vacuum line to the distributor? With this setup the distributor will always see high vacuum, even when you are at WOT! Does this work for you?
    -Alex
  20. Member keeton's Avatar
    Aug 15th, 2010
    Winston Salem, NC
    08-19-2012 08:29 PM #1420
    Quote Originally Posted by 20v_boost View Post
    -Alex
    Same here. Confuzzled.
  21. 08-22-2012 02:46 AM #1421
    I've been looking over this thread for a few hours now and I haven't completely gone through it, but I'm interested in knowing do any of you guys daily drive these cars? How reliable have they been so far? Has the fuel consumption improved or gotten worse? I'm debating doing as similar set up on one of my 16v engines I have laying around, I plan on DD the car.
    Thanks.
  22. Member 86Franklin's Avatar
    Apr 5th, 2008
    Goshen, Indiana
    08-22-2012 11:21 AM #1422
    I daily my rabbit during the summer. Once the temps in the morning get around freezing it takes a little bit to start but it does. Also with my carbs facing the front of the car, when I rains hard or I'm in heavy traffic it likes sucking in water and stalling. I want to make a plenum for it someday. Other than that it runs wonderfully and is fun.
  23. Member ncbrock's Avatar
    Sep 28th, 2010
    Raleigh, NC
    e36 M3 Sedan, M Coupe, FFR Cobra
    08-22-2012 01:32 PM #1423
    I daily'd mine for a month (webers) if I would have left it alone and stopped tinkering on it it would have been fine for a while. I got mine to start within 5 seconds even in the morning, every time. Fuel consumption sucked probably ~10mpg around town, but it sounded good
  24. Member oldschool eighty8's Avatar
    Apr 17th, 2009
    Way up theah, Maine
    08-22-2012 01:47 PM #1424
    Quote Originally Posted by ncbrock View Post
    Running Msd I take it? Sound is all that matters anyway
  25. Member 86Franklin's Avatar
    Apr 5th, 2008
    Goshen, Indiana
    08-22-2012 08:32 PM #1425
    Wow 10 mpg? I at least get mid to upper teens depending on how I drive. a big 5th on the highway gives me low to mid twenties.
  26. Member ncbrock's Avatar
    Sep 28th, 2010
    Raleigh, NC
    08-22-2012 10:00 PM #1426
    yeah msd programmable, made starting a breeze. Never happened to take it on the highway, but my route to school everyday was stop sign to stop sign so it was constant stop and go. So 10mpg isnt unrealistic.
  27. Member vswords32's Avatar
    Mar 14th, 2007
    dublin eire
    08-23-2012 06:57 PM #1427
    has anyone ever dynojetted their carbs?
    ive heard of lads drilling out their jets etc...but surely the needle will have to be compsenated for this?
    the reason im asking is because i also ride a zx6r,which was always going a bit rough on idle and cutting out every now and again on tick over,but on wide open throttle it seemed fine,so i got them chemically cleaned up and balanced correctly and the difference was night and day.
    the lad that did the job said they were badly gunked up and the floats were way off cusing it to run on 3 cylinders also causing it to run rich on idle and up to about 3-5k rpm.
    while i was chatting to him i asked him bout my r1's and he basically said not to drill out the jets as it will cause running issues,and be missmatched with the the needles etc.
    any ideas?
    sort of has me thinking bout getting a dynojet kit?
  28. Member oldschool eighty8's Avatar
    Apr 17th, 2009
    Way up theah, Maine
    08-23-2012 07:25 PM #1428
    From what ive seen and herd those kits don't have big enough jets for a car motor.
  29. 08-24-2012 01:40 AM #1429
    so in other words, poor fuel economy? Has everyone had the same fuel economy? or is it just once case. I want to DD my car and i need somewhat decent fuel economy, and that will depend on if i want to do this set up or not.
  30. Member yeayeayea's Avatar
    May 29th, 2005
    md
    08-24-2012 06:20 AM #1430
    I dont remember what mine gets, I will check it out and report back
    Last night
    1/8th mile into last night serpentine belt.
  31. Member 86Franklin's Avatar
    Apr 5th, 2008
    Goshen, Indiana
    08-24-2012 08:44 AM #1431
    What do you consider poor fuel economy. The four carbs should instantly be a flag for, this will probably be worse on gas than F.I. like I said for me, mid twenties on highway depending on speed. Mid to upper teens around town if I drive it normal. Has better mpg in the city than my a6.
  32. Member rysskii3's Avatar
    Apr 18th, 2006
    SoCal
    MKII Race Car
    08-24-2012 03:15 PM #1432
    Quote Originally Posted by 86Franklin View Post
    i go through 1/4 of gas in less than an hour of city driving
  33. Member oldschool eighty8's Avatar
    Apr 17th, 2009
    Way up theah, Maine
    08-24-2012 04:09 PM #1433
    Any of you guys tried shimming the stock r1 needles? I have what I think is a transitional lean going on at part throttle.
  34. Member 86Franklin's Avatar
    Apr 5th, 2008
    Goshen, Indiana
    08-24-2012 08:23 PM #1434
    Ive gone through 1/2 a tank this week driving around 20 miles a day. Both city and highway combined.
    Edit to oldschool: I've changed the height of my needles ones and it didn't run very well. It was very boogy.
  35. 08-25-2012 01:52 PM #1435
    If memory serves me well enough, it is essentaily the same as alling about 8-10k oms resistance to the coolant sensor which advances the timing and increased differential fuel pressure in the cis-e system. So yes, finding a way to keep that WOT sensor functional on a carb setup with CIS-E knock box would be benifical. Let me know how you manage to set it up if you do. I haven't got that far yet.
    It is just a switch though, you could use any switch to activate a coolant sensor resistor to the same effect and pick your level of resistance hence the level of timing advance.
    I do wonder though if there are any electronics geeks out there who could intergrate this concept into the throttle position sensor that came standard on the r1 carb set up., to generate a resistance value that equates into a desireable range of timing advance through the coolant sensor directly..
    I wonder???
