VWVortex.com - Switching to Bike Carbs. Heres a write up!
    Page 5 of 80 FirstFirst 1234567891555 ... LastLast
    Results 101 to 125 of 1992
    Thread: Switching to Bike Carbs. Heres a write up!
    1. Member 86Franklin's Avatar
      Apr 5th, 2008
      Goshen, Indiana
      1986 VW Cabriolet 1.8l 16v / 01 Audi A6 2.7T Quattro
      01-10-2010 02:39 AM #101
      i was just wondering cause i found a few at some local stores (not carter) that were around $50. everyone on here says, thats what to use. so im just trying to figure out if its worth ordering or just going with one of the ones i found locally.
    2. Member Miami Blue's Avatar
      Jan 12th, 2009
      Avondale, AZ
      1981 VW Rabbit. 2.0 16V Currently on R1 carbs
      01-10-2010 01:43 PM #102
      I have thought of going to the local auto parts store to get a fuel pump but i dont know how much i can trust one of those things. I'd rather just stick to something that people have used and works for em.
      If other people have used them and say they work i suppose you should give it a try!
    3. Member impulse byer's Avatar
      Mar 8th, 2003
      Georgetown,ON
      98 5.9 Grand cherokee, VW other again...
      01-10-2010 05:57 PM #103
      Thats what i use CarQuest brand low pressure pump. I bought 2 just in case but have never needed the second one yet. 3 years i believe i've been running it now.
      I love the Ls series of motors my next project will involve one for sure...in a 3 gen RX-7 of some sort
      Quote Originally Posted by prasina2 View Post
      I thought the steps were:
      1. Buy car you're unfamiliar with 2. Buy turbo, having no knowledge of turbos or cars 3. Buy bolts and bolt on turbo 4. Tow-truck drivers and mechanics profit.
      Did I miss anything?
    4. Member Miami Blue's Avatar
      Jan 12th, 2009
      Avondale, AZ
      01-11-2010 12:41 AM #104
      You wanting to get that extra pump off your hands?
      Id like to get some engineering skills and some day build a RWD LS1 Caddy. I know... non german engine in a VW... but imagine catching EVERYONE off guard!
    5. Member FROZEN337's Avatar
      Sep 12th, 2005
      3 story double wide
      337/01 A6 4.2/03 S8
      01-11-2010 07:38 PM #105
      I went through 2 cheaper pumps before the carter, 1 off ebay, rotary vain like the carter, it was junk. The second was the Mr. Gasket 4-7 psi. After fueling issues with both, I bought the carter. Works awesome!
      Quote Originally Posted by PA-VDUB View Post
      *no Logan is a form of no homo. Its when I wanna sound like a douche but say I'm just kidding at the same time
      Tell your mom I said hi. instagram @The_Fat_Stig
    6. Member Miami Blue's Avatar
      Jan 12th, 2009
      Avondale, AZ
      01-12-2010 01:30 AM #106
      Ha Ha maybe i should reconsider the cheaper pump....
      Page 4 SIKKKK
    7. 01-12-2010 07:59 AM #107
      This is Great post. Do you mind putting up a list of what was required for this build. Maybe some prices too. Wanting to do one of the three, but this seems the best.
    8. Member Miami Blue's Avatar
      Jan 12th, 2009
      Avondale, AZ
      01-15-2010 12:14 AM #108
      Carbs: $130 (You can find them cheaper)
      Pump: $70
      FPR: $40
      Manifold: $20 and an In-and-Out Burger
      Silicone couplers: $10
      Fuel Hose: $15
      Fuel Gauge: $25
      NPT Fittings: $15
      Air Filters: $70
      Air Filter Oil: $10
      Vacuum Hose: $10
      Fuel Filter: $5
      Pipe Clamps: $15
      Prices arent exact, but close. Total comes out to around $435. Not bad considering its a whole fuel system. Starts right up every time! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    9. Member i4turbo's Avatar
      Oct 25th, 2006
      London, Ont
      '86 Jetta TDI
      01-19-2010 11:35 AM #109
      What year R1 did the carbs come from... 98-01?
      Im thinking of doing this in the future and im going to starts collecting parts... btw thanks for the thread really helps...
    10. Member Miami Blue's Avatar
      Jan 12th, 2009
      Avondale, AZ
      01-19-2010 04:48 PM #110
      Yep, 98-01.
      Searcing for good info can be difficult, so i tried to get it all in one place
    11. Member
      Jun 28th, 2006
      Elizabethtown, PA
      '97 Golf (sold), '82 Rabbit 'vert, '92 Jetta VRT, '01 BMW 325i wagon
      01-19-2010 04:59 PM #111
      Yeah, I'm not suprised FROZEN had issues with a Mr. Gasket pump, they're pretty crappy. Heard of a lot of people having problems with them on various vehicles.
      I'm still planning on giving the CIS pump and bypass regulator a shot. Really just don't want to have to re-do the fuel lines at this point!
    12. Member FROZEN337's Avatar
      Sep 12th, 2005
      3 story double wide
      337/01 A6 4.2/03 S8
      01-19-2010 05:41 PM #112
      Mr. Gasket pump was a try at keeping things under $300!! FAIL!
      Anyone looking for carbs, I have 2 sets (not selling the other!) both off ebay for under $50 each shipped. When you do get the carbs, or ask before you buy, they came with adjustable needles, will make tuning easy, one set I bought did not have the stock needles in them. I have not priced new/adjustable set yet either.
      You dont have to re-do your fuel lines at all to make it work, I'm running off the "end" of the hard line on the drivers side. I am going to re-do it after its running right and the bay is finished, just not that big a deal right now.
    13. Member 86Franklin's Avatar
      Apr 5th, 2008
      Goshen, Indiana
      01-19-2010 06:07 PM #113
      for the fuel line i cut the soft line (for the return line) off the barb fitting where it bolts to the hard line. then put the barb fitting on the feed line and ran soft to my carbs. now i just need to cap the return line so it doesnt leak fumes. after i get that all i need is the aluminum water neck i bought to arrive so i can have it cut and welded differently to clear my carbs. also for my uncle to come and make me a throttle cable.
    14. Member Miami Blue's Avatar
      Jan 12th, 2009
      Avondale, AZ
      01-19-2010 06:18 PM #114
      Looks like its time for a throttle cable post, ill go take some pics.
    15. Member i4turbo's Avatar
      Oct 25th, 2006
      London, Ont
      '86 Jetta TDI
      01-19-2010 08:34 PM #115
      Im ready to buy a set off you Frozen, let me know how we can do that...
      thanks
    16. Member Miami Blue's Avatar
      Jan 12th, 2009
      Avondale, AZ
      01-19-2010 10:25 PM #116
      Throttle cable time! To be able to make a proper throttle cable you need only two things: A stock cable, and some cable stoppers. You need the specific kind i posted a picture of on here. I suggest buying a throttle cable to a diesel rabbit since they are long enough to easily reach the front of the engine.
      First thing youll have to do is cut the cable stop off the throttle or diesel pump (depending on what cable you get) side of the cable. Cut it as close as you can.
      Then pull the cable out of the guide so you can trim the guide. Put the guide in the firewall and cut it so that it fits in to where the throttle cable holder is on the carbs.
      Once the cutting is complete you can insert the cable back in to the guide on the pedal side of the firewall. Put the hook on the cable in to the busing on the pedal lever.
      Now wrap the cable around the throttle lever on the carbs and then put one of the cable stops on there. The cable stop may be a little big for the spot on the throttle lever, all you have to do is file the stop down a little evenly on all sides. Once the cable stop is where you want it, leave it attached to the cable and then take it off the carbs. Tighten the screw down as much as you can and then cut the screw flush with the brass part of the stop. The reason for this is that the screw will hit the carbs when the throttle is part of the way open.
      Finally you can put the cable back on to the carbs! There ya go!
      Highly technical and semi pointless conseptual drawing:
      Modified by Miami Blue at 6:27 PM 1-19-2010
    17. Member 86Franklin's Avatar
      Apr 5th, 2008
      Goshen, Indiana
      01-19-2010 11:46 PM #117
      where did you get those? i've been looking for something similar but having a hard time. i was going to use a solder on end but if i can find those id go that route.
    18. Member Miami Blue's Avatar
      Jan 12th, 2009
      Avondale, AZ
      01-20-2010 12:01 AM #118
      I ordered them off here: http://www.oreillyauto.com/sit...C0142
    19. Member Miami Blue's Avatar
      Jan 12th, 2009
      Avondale, AZ
      01-20-2010 01:51 AM #119
      Quote, originally posted by GoFaster »
      Something's been bugging me, and I just put my finger on it ...
      Are you planning to mount these carbs horizontally, or vertically (in the same orientation as the photos a few posts up?
      Those carbs are designed to be downdraft carbs, as are most late model Yamaha sport bike carbs.
      I do not know what will happen if you try to mount them in side-draft orientation. You might want to pull one of those float bowls off (easy, 4 screws) and see what's going on in there. It could possibly still work, but you need to make sure the jets will still be submerged, the vent is NOT submerged, and that the floats will work correctly in that orientation.
      Modified by GoFaster at 5:34 PM 12-27-2009
      Hey... what ever happened to this guy?...
    20. Member FROZEN337's Avatar
      Sep 12th, 2005
      3 story double wide
      337/01 A6 4.2/03 S8
      01-20-2010 07:13 AM #120
      When I did my cable, I used a TON of JB Weld! Only because when I floored it, the cable pulled out EVERYTIME I put JB Weld in the cable end, from both sides, before putting the set screw in. Let it set for a few days (better safe then buying another cable!) and ground off the head of the set screw and hand sanded the brass till it rolled smooth in the wheel.
    21. Member Miami Blue's Avatar
      Jan 12th, 2009
      Avondale, AZ
      01-20-2010 08:49 AM #121
      I wonder if solder would also do the trick.... Ill try it out when i go to do my permanant throttle cable.
    22. Member FROZEN337's Avatar
      Sep 12th, 2005
      3 story double wide
      337/01 A6 4.2/03 S8
      01-20-2010 11:45 AM #122
      I read up on soldering a cable end, if you google "homemade/custom cables" there are a few good sites. However, the best way, from what I found, was to use a cool guy solder pot thingy and dip it in. I looked for a place around me that had one, S.O.L. There is NOTHING where I live . . . So I did the cable end and JB Weld and it is wicked strong! If there is a GOOD bike shop around, they should have the stuff to custom make a cable from scratch.
    23. Member i4turbo's Avatar
      Oct 25th, 2006
      London, Ont
      '86 Jetta TDI
      01-20-2010 01:17 PM #123
      Does anyone have any carbs for sale? or were to find them for not too too expensive, from what im seeing, their around the 220cnd mark for me... im looking to spend 150ish max
      thanks
    24. Member 86Franklin's Avatar
      Apr 5th, 2008
      Goshen, Indiana
      01-20-2010 04:15 PM #124
      ebay or try and find a bike yard some where and pull some off of a 90s bike
    25. Member Miami Blue's Avatar
      Jan 12th, 2009
      Avondale, AZ
      01-20-2010 09:27 PM #125
      Youve had good luck with the JB weld so ill give that a shot when its time!
      FROZEN has some carbs for sell...
