Results 1 to 21 of 21
Thread: Making a rear cargo cover for a fox wagon
  1. Member JGWarner's Avatar
    Oct 22nd, 2009
    Connecticut
    '88 VW Fox Wagon (Turbodiesel swap in progress)
    11-16-2009 07:30 PM #1
    I was really bummed that my new '88 wagon was missing it's rear cargo cover. A used one is rare, pricey, and often the wrong color. I suppose the original one is sitting in someone's garage, gathering dust, only to be unearthed decades from now with the obligatory "what the heck IS this thing?" In the meantime I've got nowhere to stash stuff safely when I'm out of the car.
    I decided to make one out of 3/16" thick high density fiberboard and automotive carpet. I also removed and re-covered the fixed speaker shelves on either side of the hinged cover area, so everything would match. Total expense: about $30 + one cheap yankee's time and frustration...
    I measured the space between the speaker shelves' obvious indentations and rounded it to around 39" wide, 36" deep front to back, divided into two sections. The smaller portion (that doesn't move with the hatch, locked in just behind the rear seat) was about 11" deep, the larger hinged part around 25" deep. The larger hinged section also needs a 1/2" x 12" bit removed where the cover has to fit around the "lump" for the spare tire. Since I've got a rear wiper I had to cut out a notch for the motor too. I just scored the HDF boards 2" in from the "angled" edges (front and back) and bent them the shape. I spray painted the undersides flat black. I drilled 3/4" holes about 2" in from the corners for the liftstrings.
    On the underside of the cover I attached several long 1"x2" poplar boards across the width for stiffness. On the smaller panel I drilled holes in the ends of these poplar strips and glued 1/4" dowels to lock into the speaker shelves.
    I then cut black automotive carpet (the kind available at cheezy wannabe auto stores, take your pick) and cut it to size. I cut two seperate panels of carpet. I made sure to leave about 1/4" overlap all round, and about 2" extra (on both panels) where the two sections meet/hinge.
    I used a fantastic spray adhesive that really did everything it says on the can (how refreshing!) and doesn't stink like chemicals either. It's called "heads up super duty interior adhesive" and is designed for carpet. I suppose you could use 3M 77 or 90- but in a closed car, it would stink to high heaven.
    I glued the carpet to the two boards seperately, then laid them back to back, lining up the hinge area, and riveted (I could have stitched but I'm lazy) the extra material together. On top, this gives a nice crease where the two boards meet and makes an effective hinge.
    I work on a lathe for a living, so I made grommets for the liftstring holes from black plastic. I guess that's cheating but you can find big grommets like this at a fabric store I'm sure.
    For the speaker shelves on the sides, they come out after removing bolts from underneath, and unplugging the speakers. I removed the speakers and seat release trim, ripped off the carpet and got to work re-tracing the shape onto the carpet.
    Notice that this car is an '88 with only lap belts in the rear, and yet the holes for the three-point belts are present. Interesting.
    I used the same spray adhesive, and the finished product looked better than stock, IMHO.
    Here's the whole sha-bang, reinstalled.
    You can see in this pic the poplar stiffening strips screwed to the underside. Most of the screws are actually from the top, countersunk to hide under the carpet.
    Overall, I think it looks almost as good as stock. If I had to do it over, I'd have used grey carpet, to better match the interior. Oh well.
    Thanks for reading, questions welcome. I hope this helps other folks who miss their cargo covers.
    Modified by JGWarner at 7:43 PM 11-16-2009
  2. Member Banned wagon's Avatar
    Mar 3rd, 2004
    2013 Model S P85s Outback 89 4Runner 90&89 fox wagons 89 4door fox 89 2Door GL Fox
    11-16-2009 07:49 PM #2
    Nice work!
  3. Member VWFOX407's Avatar
    May 10th, 2007
    Orlando Florida
    89 2drs Fox
    11-16-2009 08:32 PM #3
    It looks great, .
  4. Member DubbinChris's Avatar
    Dec 15th, 2005
    Columbus, OH
    85 Ur Quattro, 88 Fox Wagon (sold), 90 Golf, 83 Q Sedan TD, 88 QSW (soon tdi), 85 Q wgn, 03 A4 Avant
    11-16-2009 10:36 PM #4
    Wow....this should def go in the FAQ's
  5. Member greggearhead's Avatar
    Jul 28th, 2002
    Colorado Springs, CO
    11-17-2009 01:08 PM #5
    Very nice.
  6. Member reddfoxx's Avatar
    Sep 18th, 2005
    one-room schoolhouse, central Ohio
    87 Fox wagon turbo, 90 Fox 2-door
    11-17-2009 01:26 PM #6
    Wow- thanks for writing this up.
    Not red, not blue- red, white, and blue
  7. Member lilgreydentwagen's Avatar
    Sep 13th, 2005
    Lake Stevens, WA
    88 fox wagon> '90 jeep cherokee
    11-17-2009 01:38 PM #7
    pritty i have had the side rails for years. i think you've just inspired me to install. very nice write up.
    remember to spay or neuter your politicians
  8. Member JGWarner's Avatar
    Oct 22nd, 2009
    Connecticut
    11-17-2009 09:01 PM #8
    Wow, thanks for the kind words. I thought this would be at the bottom of the threads within hours.
    Yeah once I took the side speaker shelves out I was tempted to leave it all out, there's just so much room, it's like a four body trunk!
    But I'm glad I put it all back together, cuz the interior is now a lot quieter (easier to ignore those squealing rear brakes) and warms up quicker in the winter. Why heat the trunk?
  9. Member kerensky's Avatar
    Mar 5th, 2001
    Norman, OK
    '89 Fox GLS, '89 Fox wagon, '73 914, '72 'vert.
    11-17-2009 10:53 PM #9
    That's bloody awesome. Excellent write-up.
  10. Moderator the brit's Avatar
    Jun 23rd, 2003
    Pottstown, PA
    VW Fox 16v
    11-18-2009 01:32 PM #10
    Added to the FAQs.
    Look great
    | œ Orchid Euro Importation œ |
    Currently driving or working on...
    | '93 Fox 16v - PVW| '03 Sprinter - Build Thread | '99 Polo Greenland Polo - Build Thread | '85 Scirocco Storm RHD - Thread | '85 Polo RHD | '75 Swallowtail - Build Thread |
    | '99 Lupo 1.4TDI-S | '82 Caddy | '90 Jetta 8v | '96 Volkswagen LT35D | '02 GTI 337 | '03 GTI 20v |
    | '09 Aprilia RS125 | '81 Kawasaki AR80 | '78 Honda CB125 | '59 NSU Quickly | '64 Honda Cub C65 | '65 Honda Cub C105 |
    | Trek Madone 6.9 |
  11. Member reddfoxx's Avatar
    Sep 18th, 2005
    11-18-2009 02:55 PM #11
    I have a set of the speaker panels, and I think the cargo cover, if anyone wants them. I like having the space in mine, but to each his own.
  12. Moderator the brit's Avatar
    Jun 23rd, 2003
    Pottstown, PA
    VW Fox 16v
    11-18-2009 02:57 PM #12
    Quote, originally posted by reddfoxx »
    I think those will sell quickly and easily if you post them up in the classifieds..
    If you were closer I would consider it myself.
    | Trek Madone 6.9 |
  13. Member JGWarner's Avatar
    Oct 22nd, 2009
    Connecticut
    11-18-2009 03:13 PM #13
    Quote, originally posted by the brit »
    Added to the FAQs.
    Right on!
  14. Member reddfoxx's Avatar
    Sep 18th, 2005
    11-19-2009 10:33 AM #14
    Yeah, sorry, just seemed on subject, and I figured if someone weren't into making them...
    I've thought about it a lot, and I just can't see myself using them. So, they will sit in the garage, unless I decide to put them up for sale. Let me know if you get over this way.
  15. Moderator the brit's Avatar
    Jun 23rd, 2003
    Pottstown, PA
    VW Fox 16v
    11-19-2009 10:47 AM #15
    I wasn't trying to kick you out of the thread, just saying that the best way to sell them would be over in the classifieds, with photos etc
    | Trek Madone 6.9 |
  16. Member DubbinChris's Avatar
    Dec 15th, 2005
    Columbus, OH
    11-19-2009 05:27 PM #16
    What color?...you have local interest....PM me about it...
  17. 11-20-2009 06:26 PM #17
    super sweet.. ive been saying iam going to do it for months and now you have given me the boost to do it this weekend. nice write up
  18. 11-20-2009 10:09 PM #18
    Heeey man, that's a nice job!
    I see many people of Club of Gol Quadrado paying people to make that rear cargo cover... (And usually these rear cargo covers are made of plywood... So, often these parts spoil relatively quickly... )
  19. Member reddfoxx's Avatar
    Sep 18th, 2005
    11-21-2009 02:01 PM #19
    No worries, I knew that it was just a gentle suggestion I hadn't even considered the classifieds; I took the stuff to OSCR and got no interest, so figured they wouldn't be sought-after. Chris, I'll IM you. They're black, and I'll try to take pix.
  20. 11-21-2009 06:51 PM #20
    i open this thread just to look at how nice your work is!!
  21. Member JGWarner's Avatar
    Oct 22nd, 2009
    Connecticut
    11-22-2009 10:39 AM #21
    You guys are something else. My very first thread and it ends up in the FAQs.
    I work with my hands for a living, making musical instruments, So I suppose I have an eye for detail. I'm definitely a perfectionist, which as you can imagine makes living with a fox very hard!
    Thanks!
    Modified by JGWarner at 5:47 PM 12-30-2009
