VWVortex.com - Downpipe install DIY
    Results 1 to 12 of 12
    Thread: Downpipe install DIY
    1. Member Rantu's Avatar
      Feb 23rd, 2009
      San Angelo, TX
      Mkiv Gti 1.8t
      11-18-2009 04:33 PM #1
      I ordered a Eurocustom 3" Downpipe w/ Testpipe and Ive never done any exhaust work on my car. I have a mkiv gti 1.8t and if anyone could give me some tips or anything I would greatly appreciate it...The main thing I might need help with is how to remove the stock dp/cat..
      "Get Low or Die trying"
    2. Member shook1db's Avatar
      Nov 27th, 2008
      Battle Creek, MI
      2002 VW Jetta GLS (Sold), 2008 r32 (Sold), 2012 Golf R (Lovin It!)
      11-18-2009 04:38 PM #2
      Well to be honest it's quite simple. Jack the front of the car up take off the heat shield that goes over, I think the axle, I dont really know I havent done it in forever. then unbolt the 4 bolts on the DP, make sure you have a gasket for it. The most annoying part is getting it out of there but it just takes patience. We actually just cut mine into two pieces so I didnt have that issue. ;D Good luck
      Professional Detailing @ Refined Reflections Detailing
      2012 Golf R | IE450T Kit | IE FDS Intercooler | CTS Catback | IE Cold Air Intake | H&R Sway Bars | IE HPFP | VWR Springs | Stoptech Slotted Rotors | Whiteline Endlinks | Stage 4 BFI Clutch Kit | HPA Comp Controller |
    3. 11-18-2009 05:49 PM #3
      Do you have stock cat back? replacing the DP is not that bad. Losen the sleeve clamp connecting the DP/catback. Remove the bolts on the DP and take out. Carefully remove O2 sensors. Ur new DP should come w/ the gasket. Reverse the process. On the cat back, if u have the stock one u need a new sleeve clamp to mate ur 3" DP to whatever size ur cat back is. A muffler shop can do this by cutting a piece of pipe and expanding the ends to mate to your system...
      Pag Parts kit, PTE 5130, Brute rods, Eurodyne 630cc, Stg 2 water/meth, Pag Parts FMIC Kit with TT225 intake mani, Stage 3 Clutchnet n 17lb FW, 398whp @ 24psi
    4. Member Rantu's Avatar
      Feb 23rd, 2009
      San Angelo, TX
      Mkiv Gti 1.8t
      11-18-2009 06:02 PM #4
      Ok cool thanks for the advice! And yes I do have a stock cat back..Sounds fairly easy to me..and also is the downpipe and catalytic converter all one piece? it looks like it...
    5. 11-18-2009 06:05 PM #5
      Some things you might want to have handy:
      -PB Blaster
      -Hammer
      -Torch
      I would recommend giving it a good coat of PB Blaster the night before. Anything you can do to ensure the studs don't break will save you time and money. Most dealers (at least around me) don't carry studs on hand.
      EDIT: And I would suggest an OEM gasket...their like $5 from the dealer.
      Road Farmin'
    6. Member Rantu's Avatar
      Feb 23rd, 2009
      San Angelo, TX
      Mkiv Gti 1.8t
      11-19-2009 12:40 AM #6
      Ok ill probably do that also, and yea i might pick up a OEM gasket while im at it...and like i said above...can i separate the stock dp and catalytic converter? or are they one piece?
      May 25th, 2006
      Doylestown PA
      11-19-2009 12:53 AM #7
      Its fairly easy, just finding the angles to get some of the nuts and if any of them get stuck is the hardest part.
      http://ottawa-vdubbing.com/for...13394
    8. Member Rantu's Avatar
      Feb 23rd, 2009
      San Angelo, TX
      Mkiv Gti 1.8t
      11-19-2009 02:30 AM #8
      wow thanks motoo that DIY will definitely be some good guidelines for me to follow..I think I have a good understanding of this now and I thank everyone for helpin me out. Now its time for me to install this thing.
    9. Member jettawlfsbrg01's Avatar
      Apr 30th, 2008
      SoCo
      '01 BT family sedan
      11-19-2009 02:57 AM #9
      Quote, originally posted by McBee »
      -PB Blaster
      -Hammer
      -Torch
      Sh*t does miracles!! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    10. Member 19jetta91's Avatar
      Apr 25th, 2006
      91 jetta, 15 jetta SE conn/nav
      01-06-2010 10:40 AM #10
      I crawled up under my car last week and could barely see the bolts let alone get to them. My dads good friend owns a shop and I'm going there tomorrow..
      If I had taken off that heat shield the bolts would have been wide open?
      Spell Check?
      91 Calypso Green Jetta
      15 Reflex Silver Jetta SE Conn/Nav
      00 1.8t satin silver gti (sold)
    11. 01-06-2010 10:43 AM #11
      The bolts should be pretty obvious... I mean just followed the exhaust and they're right there.
      I dunno about the shield, as I've done away with mine long ago, but I don't believe it should get in the way.
      ░░░░░░ .. R13 5
      ░░░░░░ .... 24
    12. Member 19jetta91's Avatar
      Apr 25th, 2006
      01-06-2010 11:02 AM #12
      Yeah there def isn't much room. It looked like I needed a 2ft extension for the socket wrench. Lol.
      Spell Check?
