VWVortex.com - rear wheel bearing torque specs?
    Results 1 to 7 of 7
    Thread: rear wheel bearing torque specs?
    1. Member vw95golf_00's Avatar
      Jan 23rd, 2008
      cincinnati
      11-26-2009 08:20 PM #1
      can anyone help me out with these specs i HAVE searched but couldn find em
    2. Member vw95golf_00's Avatar
      Jan 23rd, 2008
      cincinnati
      11-27-2009 12:22 PM #2
      BUMP
      Jul 13th, 2001
      Oakland, CA
      11-27-2009 02:09 PM #3
      Uh, exactly what year and model?
      Kenji
    4. 11-27-2009 02:14 PM #4
      IIRC to put enough torque on it to even measure would be too much (not to mention that it's such a big nut that you would be forced to use a 1/2" torquewrench which starts at 20 ftlbs. - too much). You want to hand spin it down until it just starts to squeeze. Any more than that will prematurely wear the bearing. Then just put on your little castellated nut and throw that cotter pin in there.
      Modified by geecyber at 1:17 PM 11-27-2009
    5. Member vw95golf_00's Avatar
      Jan 23rd, 2008
      cincinnati
      11-27-2009 06:39 PM #5
      1997 jetta vr, and iv alreay put the bearings and rotor on, and thats what we did was hand tighten it to be snug (just hand tight). then when we were done i drove it down the street and back, jacked it up and shook the wheel for bearing play and it had some pretty noticable too, but no noise while i drive. its my daily ive driven under 100 miles since and i plan on tightening it a little more b4 i get to 300 miles.
      Modified by vw95golf_00 at 2:44 PM 11-27-2009
    6. Member der_Architekt's Avatar
      Jul 5th, 2005
      ATL- Durty South
      88 Coupe VR6: 04 A4 1.8T
      11-27-2009 08:26 PM #6
      i think the process for tightening the nut is to spin the wheel while you hand tighten, then 1/4 turn counterclockwise. <-- you may or may not need to tho
    7. Member vw95golf_00's Avatar
      Jan 23rd, 2008
      cincinnati
      11-27-2009 10:05 PM #7
      thanks
