VWVortex.com - Modifying o2a/j Clutch fork for high RPM shifting...
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 41
    Thread: Modifying o2a/j Clutch fork for high RPM shifting...
    1. Forum Sponsor Quintin@USRT's Avatar
      Oct 6th, 2009
      Melbourne, FL
      A founding Member of the 8v 350+whp Club, Now rocking a B7 S4 mmmmm V8!
      11-30-2009 10:09 PM #1
      So since i had a spare one laying around i decided to try strengthening it up some...this included quenching it after each weld.
      I wanted to try something different from the typical plate that most people weld on top. I had a friend that bought one modified like that and it contacted the pressure plate.
      Anyway without further ado...
    2. Senior Member vdubspeed's Avatar
      Jul 18th, 2002
      Valdosta, GA
      I quit counting.
      12-01-2009 08:27 PM #2
      very nice. I'm lost though. Why do they need strengthing? What makes them bend? Stiff pressure plates? Why would high RPM shifting weaken them.
      Built > Bought
      58 Beetle | 79 Rabbit 20vT | 84 GTI TDI |84 GTI 16vT |12 Golf TDI ----89 325i | 99 QCSB Ram Cummins | 02 Burb 4x4 2500
    3. Forum Sponsor Quintin@USRT's Avatar
      Oct 6th, 2009
      Melbourne, FL
      12-04-2009 07:19 PM #3
      yes the higher pressure plate pressures cause them to flex and at high rpm centrifugal force forces the fingers out thus putting more stress on the clutch fork. So at high rpms full disengagement is very problematic making shifting a PITA.
    4. Member GTijoejoe's Avatar
      Oct 6th, 2001
      '06 Evo Mr, '15 CRV Touring, '16 Civic Touring
      12-04-2009 09:10 PM #4
      That should make it pretty darn stiff [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      2.0T+034efi+meth = 300+whp = RIP
      FS: 2015 Honda Civic Si
    5. Forum Sponsor Quintin@USRT's Avatar
      Oct 6th, 2009
      Melbourne, FL
      12-04-2009 09:21 PM #5
      yea but what sucked is there truly isnt chit for clearance in the o2j bellhousing...i had to grind down part of both sides (and all i did was at 1/16th to both sides!) to clear the bolts inside the bellhousing and part of the casting but still should suffice *hopefully* ill get some pics of it later.
    6. Member
      Aug 5th, 2003
      Centerport, NY 11721
      87 GTI, 03 GTI, 96 Ranger, 88 Shadow VT800C
      12-06-2009 10:55 AM #6
      Very nice.
      It would be nice to see a product like this come out for the community that was produced on some CNC machines with some steel billet stock. It wouldn't take more than a day to fab up a vise and a couple jigs rough cut both sides and then set up for the finish cuts.
      '87 GTI 1.8t, '03 20th GTI #2100, '96 Ranger 4x2, '88 Shadow VT800C
      '01 TT 180Q, '98 Ranger 4x4, '01 Catera, '90 GLI 16vT, '94 850 Turbo, '90 Golf, '89 Golf, '90 Mustang LX, '91 Jetta, '88 9000S, '86 Jetta, '91 Continental
    7. Forum Sponsor Quintin@USRT's Avatar
      Oct 6th, 2009
      Melbourne, FL
      12-06-2009 11:24 PM #7
      Quote, originally posted by L33t A2 »
      Very nice.
      shhhh
      Aug 5th, 2003
      12-07-2009 02:17 AM #8
      i am willing and able to do such work, god forbid we make some profit
    9. 12-07-2009 07:28 AM #9
      It would be pretty tough to improve on this with a made from scratch part. I personally would laser cut 4130, stamp or brake form, TIG and heat treat for wear resistance. I would need a 200 pc order. Judging by Quenton's comments, I don't think the envelop shape would allow the required 40% increase in area to use aluminum so CNC would be pretty costly.
      How would you do it?
    10. Member
      Aug 5th, 2003
      12-07-2009 11:36 AM #10
      I left the machine shop I had been working at to go back and finish my bachelors degree but I didn't forget how to use the machines. Steel alloys suck to work with on the machining centers. The stock part would have to be mapped out on a blue print as well as the clearance inside the bell housing to see where material could be added to promote strength. Carbide end mills and inserts should definitely be used.
      Get some .75" steel billet plates or whatever is just thick enough to make the part, you don't want to waste time cleaning off excess material. Skim one side, then flip it over and mount it on a jig/fixture to cut out the rough shape of one side, including the hole in the center. Flip it back over and mount it on another fixture to rough cut and then finish cut that side in one long operation. Mount it on the final fixture to finish cut the first side.
      A good programmer could whip this together in a few hours as well as the inverted shapes for making the fixtures from aluminum.
    11. Forum Sponsor Quintin@USRT's Avatar
      Oct 6th, 2009
      Melbourne, FL
      12-07-2009 07:15 PM #11
      i agree CNC'ing a part to exceed the strength of the original would be difficult to achieve...
      Below i blacked out where i had to grind the flat bar back down to base metal...
    12. 12-08-2009 03:06 PM #12
      I'm not sure I understand the quenching ... this is a mild steel part, which as far as I know, will not harden with quenching. (As opposed to high-carbon steel). That being said, it is definitely stronger with the side reenforcements. I think JUST those would be sufficient, as that is where they tend to break.
      Markku Kivinen | Agtronic Motorsport
    13. Member 2pt. slo's Avatar
      Jan 4th, 2004
      Creedmoor, NC
      98' GTI 2.0T, 12' TDI SportWagen
      12-08-2009 03:54 PM #13
      Flipside customs has made these for quite some time now.
      stock on top reinforced bottom.
      Q your welding is improving greatly. looking good man [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    14. Forum Sponsor Quintin@USRT's Avatar
      Oct 6th, 2009
      Melbourne, FL
      12-08-2009 05:59 PM #14
      Quote, originally posted by 2pt. slo »
      yes i know
      Quote, originally posted by Quintin@USRT »
      Thanks!
    15. Forum Sponsor Quintin@USRT's Avatar
      Oct 6th, 2009
      Melbourne, FL
      12-08-2009 06:14 PM #15
      Quote, originally posted by Agtronic »
      it can be done with mild...using the right recipe http://lametalsmiths.org/news/robb_gunter.htm
      Standard quenching with water though may only just barely harden the surface.
    16. 12-08-2009 06:30 PM #16
      I don't see why Milling it from 4140 would be an issue. We machine it here all the time, cuts nice.
    17. Member GTijoejoe's Avatar
      Oct 6th, 2001
      12-08-2009 10:02 PM #17
      Quote, originally posted by Passenger Performance »
      I would agree, its not like its carbon carbon.
      IMO opinion the proper way to make this part because of clearance inside the bell housing would be to stamp it out of higher strenth steel, and/or be able to increase the thickness or change the geometry slightly (if that is possible judging by clearances)...
      This part can be easily backwards engineered, its geometry is not very complicated, although you would need to right kind of equiptment.
    18. Forum Sponsor Quintin@USRT's Avatar
      Oct 6th, 2009
      Melbourne, FL
      12-08-2009 10:30 PM #18
      there's no such thing as easy in the VW world Joe! lol
    19. 12-09-2009 01:13 PM #19
      Stamping would be ideal, but, I doubt there is enough demand to justify the custom dies. For qts under a few hundred milling them is likely your best bet, we machine 4140 lockout pins for the railway cars here, we mostly machine stainless and I find 4140 more forgiving.
    20. Member GTijoejoe's Avatar
      Oct 6th, 2001
      12-09-2009 09:11 PM #20
      Can't argue with that
      I would agree, stamping would be something like +$200/part for very low volume, or something crazy like that. I've had very small brkts made that were +$100/ea. Those though were a series of forming progress and tandem dies.
    21. Member boost_addict's Avatar
      Dec 4th, 2009
      souderton pa
      VEMS Audi S2 , & VEMS sponsored GTI.
      12-10-2009 11:49 PM #21
      Working hands.
      Fork looks great [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      PTE 67m VEMS powered VR6 Audi S2
    22. Forum Sponsor Quintin@USRT's Avatar
      Oct 6th, 2009
      Melbourne, FL
      12-11-2009 12:02 AM #22
      thanks brah!
    23. 12-11-2009 03:05 PM #23
      Wait up here.... is this one of the root causes of the dreaded 02J anything past 4000 rpm grinds like a mofo problem??
      I noticed that when I got my SPEC S3 clutch I actually grinded MORE between shifts. Even now with my rebuilt shift hubs i still grind a bit. However my 1 to 2 shift is nice, thanks to big tooth 02A shift hub and syncros!
      I too have a left over o2J case, another one of those bad boys in your hand and a TIG welder... I might have to give it a shot!
    24. 12-11-2009 03:06 PM #24
      Did the same kind of thing with mine, never really got to try it out but will this spring. Nicely done! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    25. Member mechsoldier's Avatar
      Aug 14th, 2004
      Seattle, WA
      Supercharged 6 spd 98GLX, Choptop 66 Beetle with Porsche 944 brakes and 5 Speed, 13 Sportwagen TDI
      12-12-2009 10:04 PM #25
      Quote, originally posted by vdubspeed »
      They break even in stock transmissions, I run across a couple a year that are snapped, usually due to the pressure plate becoming more stiff to disengage the clutch as the clutch disk wears. Just did one in a 98 GLX Jetta last week that was snapped.
      Dub Autowerks VW, Audi, Porsche, and BMW parts and service
      1723 West Valley Hwy E
      Sumner, WA 98390
      http://www.DubAutowerks.com
