Page 2 of 2 FirstFirst 1 2
Results 36 to 41 of 41
Thread: Modifying o2a/j Clutch fork for high RPM shifting...
  1. Member GTijoejoe's Avatar
    Oct 5th, 2001
    OH
    '98 GTi, '06 Evo Mr
    12-15-2009 08:58 PM #36
    Quote, originally posted by Eganx »
    when I harden anything I quench in used motor oil. the way I understand it, the metal will actually draw carbon out of the oil to harden the surface of the metal. it has worked quite well for me for a while.
    Than you understand correctly....
    The key feature to harndening is depth, normally this type of 'I did it myself' hardening is very shallow, unless you know exactly what you are doing, and what temp is needed, and duration etc etc...
    2.0T+034efi+meth = 300+whp = Part out PM me for anything
  2. Banner Advertiser pete@integrated's Avatar
    Jan 1st, 2009
    Salt Lake City, UT
    '92 Gti 20v, '96 M3, '10 Shop Van :)
    12-15-2009 09:03 PM #37
    I'd say yes and no- You can take a piece of welding rod and quench it a couple of times and it's so brittle it won't bend 1/10th of what it did before you hardened it. But, it's also a small cross section so you don't need a lot of depth to do anything.
    This particular part isn't exactly thick either though.
    .:IntEngineering.com:. .:Facebook:.
    Check out some cutting edge R&D Work on our blog! IE Behind the scenes Blog!
  3. Member Eganx's Avatar
    Apr 30th, 2004
    Poulsbo WA
    built 90 jetta coupe
    12-16-2009 07:06 PM #38
    right, I usually call it case hardening. If I ever need to harden something this has worked for me, but then again I have never had to harden anything really thick, or under enough stress to need anything more than a good .020-.030 hardened shell/case
  4. Member GTijoejoe's Avatar
    Oct 5th, 2001
    OH
    '98 GTi, '06 Evo Mr
    12-16-2009 08:08 PM #39
    Quote, originally posted by pete@integrated »
    I'd agree, I was speaking in generalities
  5. 08-06-2012 12:42 PM #40
    Hi guys
    just wanted to show you how we made our reinforced fork in tuning garage called Herc tuning in Cacak Serbia from the guy who makes all the champion geraboxes here from the first class steel from Kosovo that is normaly exported to Italy.
    He did my 02J gearbox to 6 speed one and incorporated my Quaife LSD into it.
    Ratios are:
    1. 3.7
    2. 2.2
    3. 1.6
    4. 1.25
    5. 1.04
    6. 0.87
    Final Drive 3.64
    First two remained OE for the comfortable daily driving without killing the clutch and the rest is killing machine.
    It is calculated for shifting on 7200rpm and drops only to 6000rpom where I do have 375Nm - meaning pulls like hell all the way.
    Than we added reinforced fork that I have seen at inaeng.
    Ours looks even better I think.
    Still no billet pinion brace but to come.
    I'll share my results than.
    Here is the link to the pics:
    http://s537.photobucket.com/albums/f...box/?start=all
  6. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    A founding Member of the 8v 350+whp Club, Now rocking a B7 S4 mmmmm V8!
    09-20-2012 10:52 PM #41
    Quote Originally Posted by davojuri View Post
    Hi guys
    Ratios are:
    1. 3.7
    2. 2.2
    3. 1.6
    4. 1.25
    5. 1.04
    6. 0.87
    Final Drive 3.64
    I like
