VWVortex.com - P1626
    Results 1 to 15 of 15
    Thread: P1626
    1. Member Turbo_Pumpkin's Avatar
      Feb 21st, 2002
      Melbourne FL
      2000 GTI
      12-08-2009 06:58 AM #1
      Recently I replaced a transmission and transmission control unit in a 2000 Audi A4 1.8T.
      I have followed the procedures to readapt the TCU but I recieve the following code.
      Error: "Powertrain databus: missing message from TCU P1626"
      This is the procedure that I followed to adapt the tcu:
      Note: In some newer Audi vehicles, you may find that Group 000 in Auto Trans. is unavailable. If that is the case, you should follow this procedure:
      First, make sure there are no fault codes in the Auto Trans. Then, with the key in the on position, and engine OFF. Do not touch the accelerator pedal.
      [Select]
      [01 - Engine]
      [Basic Settings - 04]
      Set Group to "063"
      [Go!]
      Press accelerator pedal all the way to the floor and count out loud 3 seconds.
      [Done, Go Back]
      Release the accelerator pedal.
      Any suggestions are appreciated. TIA
      HomeGrown Motorsports
    2. Member Bahltech's Avatar
      Oct 9th, 2008
      Quebec
      12-08-2009 08:19 AM #2
      Is your trans in limp mode?
      Did you install the same TCM part number?
    3. Member Turbo_Pumpkin's Avatar
      Feb 21st, 2002
      Melbourne FL
      2000 GTI
      12-08-2009 09:04 AM #3
      Quote, originally posted by Bahltech »
      I don;t know how to tell if it is in limp mode. There are no error codes.
      I installed the TCU that corresponds with the trans I installed. The old trans was bad so I had to source a replacement. The trans code and the module came out of the same car.
    4. Member Bahltech's Avatar
      Oct 9th, 2008
      Quebec
      12-08-2009 09:24 AM #4
      What year model does your TCM come from?
      Might not be compatable with the rest of the car systems.
    5. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      02 Gti, 12 Tiggy SEL
      12-08-2009 09:28 AM #5
      Yea, post before and after auto scans. This will show if the vehicle configuration is with OR without CAN-Databus.
      Dana Marie
      P.S. No Scan = No Soup
    6. Member Turbo_Pumpkin's Avatar
      Feb 21st, 2002
      Melbourne FL
      2000 GTI
      12-08-2009 09:40 AM #6
      Quote, originally posted by Dana @ Ross-Tech »
      Ok, I don't have before scans. I will do a full scan today when I get home. Then should I put the old module in, adapt it and do that scan too? I was told that the old TCU would nto work with the new trans.
    7. Member Turbo_Pumpkin's Avatar
      Feb 21st, 2002
      Melbourne FL
      2000 GTI
      12-10-2009 12:25 PM #7
      So here are my scans. I scanned it witht he "new" TCU first and then put the original one in and rescanned.
      "new TCU" 8DO 927 156BN
      VCDS Version: Release 805.4
      Data version: 20090602
      Tuesday,08,December,2009,17:05:28:62423
      Chassis Type: 8D - Audi A4 B5
      Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
      Address 01: Engine Labels: 4B0-906-018.lbl
      Part No: 4B0 906 018 Q
      Component: 1.8L R4/5VT G 0006
      Coding: 07251
      Shop #: WSC 06325
      1 Fault Found:
      18034 - Powertrain Data Bus: Missing Message from TCU
      P1626 - 35-00 - -
      Readiness: 0010 1101
      Address 02: Auto Trans Labels: 8D0-927-156.lbl
      Part No: 8D0 927 156 BN
      Component: AG5 01V 1.8l5VT USA 8508
      Coding: 00000
      Shop #: WSC 00000
      1 Fault Found:
      00526 - Brake Light Switch-F
      27-00 - Implausible Signal
      Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
      Part No: 8E0 614 111 A
      Component: ABS/EDS 5.3 QUATTRO D10
      Shop #: BB 24334
      No fault code found.
      Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
      Part No: 8D0 820 043 Q
      Component: A4 KLIMAAUTOMAT D57
      Coding: 00140
      Shop #: WSC 06325
      Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
      Part No: 8D0 959 655 K
      Component: Airbag Front+Seite 1002
      Coding: 00106
      Shop #: WSC 06325
      Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
      Part No: 8D0 920 980 C
      Component: B5-KOMBIINSTR. VDO D11
      Coding: 02244
      Shop #: WSC 00000
      Address 35: Centr. Locks Labels: 8D0-862-257.lbl
      Part No: 8L0 862 257 N
      Component: CV-Pump D11
      Coding: 16232
      Shop #: WSC 06325
      7 Faults Found:
      01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
      35-00 - -
      01371 - Alarm triggered by Door Contact Switch; Driver's Side
      35-00 - -
      01374 - Alarm triggered by Terminal 15
      35-00 - -
      01370 - Alarm triggered by Interior Monitoring
      35-00 - -
      01369 - Alarm triggered by Hood Switch
      35-00 - -
      00991 - Interior Lights
      28-00 - Short to Plus
      00955 - Key 1
      09-00 - Adaptation Limit Surpassed
      Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
      Part No: 4B0 951 173
      Component: Innenraumueberw. D03
      Coding: 00102
      Shop #: WSC 06325
      2 Faults Found:
      01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
      35-00 - -
      01382 - Alarm triggered by Anti-Theft Sensor; Front Left
      35-00 - -
      Address 56: Radio Labels: 8D0-035-1xx-56.lbl
      Part No: 8D0 035 195 A
      Component: Radio D00
      Coding: 00205
      Shop #: WSC 06325
      1 Fault Found:
      00852 - Loudspeaker(s); Front
      29-10 - Short to Ground - Intermittent
      End ---------------------------------------------------------------------
      OE TCU 8DO 927 156AP
      Tuesday,08,December,2009,17:23:37:62423
      Coding: 07251
      Shop #: WSC 06325
      Readiness: 0110 1101
      Part No: 8D0 927 156 AP
      Component: AG5 01V 1.8l5VT USA 3132
      Coding: 00002
      Shop #: WSC 06325
      Shop #: BB 24334
      Coding: 00140
      Shop #: WSC 06325
      Coding: 00106
      Shop #: WSC 06325
      Coding: 02244
      Shop #: WSC 00000
      Coding: 16232
      Shop #: WSC 06325
      7 Faults Found:
      35-00 - -
      35-00 - -
      35-00 - -
      35-00 - -
      35-00 - -
      00955 - Key 1
      Coding: 00102
      Shop #: WSC 06325
      2 Faults Found:
      35-00 - -
      35-00 - -
      Coding: 00205
      Shop #: WSC 06325
      1 Fault Found:
      It looks to me like the original TCU works but may be faulty. the symptoms are the same now as they were before I replaced the trans.
    8. Member Bahltech's Avatar
      Oct 9th, 2008
      Quebec
      12-10-2009 07:51 PM #8
      I think you just answered your question about your TCM.
      Why did you change all that in the first place?
    9. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      12-10-2009 10:50 PM #9
      It looks like you have a DBW 1999-2000 1.8T ATW vehicle with can bus communication (to cluster) vehicle.
      The TCM you have looks like an old school DBC 1.8T AEB with K line diagnosis. This will not work properly.
      Dana Marie
    10. Member Turbo_Pumpkin's Avatar
      Feb 21st, 2002
      Melbourne FL
      2000 GTI
      12-11-2009 06:47 AM #10
      That's what I thought. The car belongs to a friend of mine and it was diagnosed by a reputable shop in the area as having a "bad" transmission. To help him out, I sourced a trans from a parts dealer that I do a lot of busniess with. They told me that I had to use the tcm that matches the trans, so they threw it in the deal. I am hoping that they will swap the one that does not work in the car with the correct one and this will be finished. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by Turbo_Pumpkin at 7:27 AM 12-11-2009
    11. Member Turbo_Pumpkin's Avatar
      Feb 21st, 2002
      Melbourne FL
      2000 GTI
      12-11-2009 06:49 AM #11
      Thanks. Is there a place that I can find a list of TCU's that will work with the ATW ECU (can-bus) so that I can possibly source a ne-used TCU for the car?
    12. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      12-11-2009 10:20 AM #12
      Not that I'm aware of. Possibly check with the parts dealer you got the unit from. They should have interchange guides.
      I have always replaced a failed unit with new or used with the same transmission code, no need to replace the Tcm in that case.
      Dana Marie
    13. Member Turbo_Pumpkin's Avatar
      Feb 21st, 2002
      Melbourne FL
      2000 GTI
      12-11-2009 10:36 AM #13
      Ok, thanks. I have a call into them.
      BTW, thanks for not reminiding me to upgrade my vagcom to the newer version. I'm planning on doing that on Monday. No internet at my house makes it difficult...
    14. Former Advertiser
      May 27th, 2002
      12-11-2009 10:49 AM #14
      If you want I can swap the programming data for you.
      Just send me the ecus.
      Cost you nothing but a box of really good chocolate.
      Best,
      Jack
    15. Member Turbo_Pumpkin's Avatar
      Feb 21st, 2002
      Melbourne FL
      2000 GTI
      12-11-2009 12:32 PM #15
      Quote, originally posted by vwemporium »
      Best,
      Jack
      I'm not sure what you mean by "swap the program data".
      My main concern is that the original TCU was bad to begin with. I'm not sure that's the case but it seems like a distinct possibility.
