VWVortex.com - Silencing horn while locking - MkVI GTI
    Results 1 to 7 of 7
    Thread: Silencing horn while locking - MkVI GTI
      Sep 25th, 2003
      Connecticut
      MkVII R / BMW R1200GSA
      12-12-2009 01:46 PM #1
      2010 GTI
      MacBook 2.4 GHz Duo core intel running Parallels 4.0
      VCDS release 908
      Trying to inactivate horn while locking car.
      Central electrics - 09 > block 11 (audible locking) > getting "not available" error for that adaptation channel.
      Is there somewhere else to do this?
    2. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      02 Gti, 12 Tiggy SEL
      12-12-2009 11:14 PM #2
      If you have 908.1, go into coding > long coding helper, look around in Byte 5. You should find confirmation via horn.
      Post an auto scan with the current release if not.
      Dana Marie
      P.S. No Scan = No Soup
      Sep 25th, 2003
      Connecticut
      12-13-2009 03:52 PM #3
      Hey Dana:
      Looks like byte 05 is 27 (00100111). I think this was the headlight washer delay on the MkV. I don't have the car right now because its at the shop having some venture film put on, but I'll check Monday. Can I do this directly by changing the long coding or do I need to go through the helper?
      Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
      Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
      Component: BCM PQ35 H+ 103 0536
      Revision: 00103 AD
      Coding: 6D180A1E90272A048088008550000D0441050086434D8D6064 8020200000
      Shop #: WSC 01357 011 00200
      Part No: 1K1 955 119 E
      Component: Wischer 02070 21 0501
      Coding: 009795
      BTW, I spent the first 10 years of life in Leechburg PA! Small world...
    4. 12-16-2009 07:48 AM #4
      Hi,
      Were you able to get this to work and if so would you mind posting how you did it. I'm taking my car in to a shop with a VAG-COM today to hopefully have this done. That horn drives me up the wall. Thanks.
    5. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      12-16-2009 09:10 AM #5
      This did work, on my 2010 Gti at least.
      Have your shop go into (09) Central electronics. (doors must be unlocked)
      Go to coding (07)
      Long coding helper
      Byte 5. Bit 1. They should find a Locking/Unlocking confirmation via horn active box to un-check.
      Dana Marie
    6. Member
      Sep 25th, 2003
      Connecticut
      12-16-2009 10:41 PM #6
      Got it. Thank you.
    7. Junior Member Dieseldom's Avatar
      Apr 25th, 2001
      SE PA
      MKIV TDI,MKVI GTI,MKVI golf
      12-23-2009 10:41 AM #7
      excellent news! the horn is bugging me also. frankly its not the horn itself just the duration. about a few milleseconds longer than my MkIV TDI. a little chirp is okay by me but a full note is obnoxious IMO. Is there a code for reducing the duration of the horn note during lock?
      thx, dom
