VWVortex.com - Outside Temperature Sensor
    Results 1 to 7 of 7
    Thread: Outside Temperature Sensor
    1. Member pjung23551's Avatar
      Jun 17th, 2008
      San Diego
      2004/VW/24V VR6
      12-20-2009 04:16 PM #1
      Hey guys, I have a faulty outside temperature sensor, says its always snowing when its 90 degrees outside!
      I know its under the weather tray that covers the ECU, where exactly is this sensor found? Anyone have a DIY with photos?
      2004 GTI 24V VR6 - RAXLES Stg 2.1b - VF Engineering RSS28 - BBS - Peloquin - FSTuning 2+ RED - Porsche BBK STG 2V2 - Koni FSD/Prokit - Autotech - Image Dynamics - Arc Audio - Elemental Designs - Alpine - Eclipse ------ PENDING TRADE-IN for MK4 R32@VW. YAHOO
    2. Member koko5869's Avatar
      Feb 15th, 2006
      Lehigh Valley, PA 18042
      04 BDF O2M / C5 A6 3.0Q
      12-20-2009 05:12 PM #2
      you are talking about the sensor that tells the MFA what temp it is outside?
      that is located on the front bumper. behind the driver side vent. (mine got ripped off long ago, and i have ---F for my temp ) (call the outside temp sensor)
      the one up in the rain tray is for climatronic (called the ambient temp sensor)
      you may be able to recalibrate the outside air with vag-com?
      Modified by koko5869 at 4:13 PM 12-20-2009
    3. Member pjung23551's Avatar
      Jun 17th, 2008
      San Diego
      2004/VW/24V VR6
      12-20-2009 05:37 PM #3
      Correct, I am referring to the outside temperature sensor that displays on the MFA cluster.
      Does the climatronic ambient temp sensor give a different reading than that of the MFA cluster? I thought they shared the same outside reading
    4. Member koko5869's Avatar
      Feb 15th, 2006
      12-20-2009 05:55 PM #4
      i dont know much about climatronic, i dont have it, and personally i like the three knobs better.
      but if they did the same thing, they wouldnt have put 2 on ya know?
      and climatronic was an add on as was the mfa. so different components all together. from factory they only put on what they have to (obviously keeping costs down) so its just different systems.
    5. Member apstguy's Avatar
      Apr 3rd, 2006
      Chico, CA
      2008 VW R32
      12-21-2009 01:49 AM #5
      Climatronic and the MFA have different sensors. The MFA is behind the drivers side bumper cover like said before, and the climatronic one is in the duct. They do the same exact thing but the are different system and the modules didn't do CAN yet (don't talk to eachother). They are usually the same but I get different readings often. One is near the asphalt and the other is up high.
      My V-Flow Stage 2 DIY has a puc of the sensor and shows where I relocated it (onlu moved it a couple inches). No DIY is needed for its replacement. Take off the grill, pull the sensor off, unclip it from the wiring. Done.
      http://forums.vwvortex.com/zerothread?id=3852820
      Gone: 2008 VW R32
      Gone: 2002.5 VW GTI 24v VR6 - 180k+ miles
    6. 03-07-2015 05:26 PM #6
      Quote Originally Posted by pjung23551 View Post
      Hi. New to this forum. I've got 04 mk4 gti and my climatronic and mad were - - - .
      I pulled out the climatronic from the dash and with the car running disconnected all plugs and plugged back in yellow red small black and last larhe one, all the numbers were flashing with the addition off diagnose on the top left of screen I then hit econ while flashing and outside temp began working. Hope it helps..
