VWVortex.com - You might be an alcoholic when...
    Page 5 of 10 FirstFirst 123456789 ... LastLast
    Results 101 to 125 of 248
    Thread: You might be an alcoholic when...
    1. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      10-14-2010 12:20 AM #101
      I did sand the whole thing
    2. Member Slayer's Avatar
      Aug 8th, 2000
      Windham CT
      2008.5 GTI w/TSI motor, 1995 GTI Vr6
      10-14-2010 08:13 AM #102
      shoulda used krylon since it bonds with plastic.. don't need engine enamel on the intake, it doesnt get hot enough
      Check out my Garage build thread 2008.5 GTI 2.0 TSI 6MT / APR K04 V3.1, APR IC, CTS 3" turbo back, Carbonio full intake, GFB DV+, BSH TB pipe, SB Stg2 Endurance clutch, BSH mounts, DG Shortshifter, FFM bracket bushings, Forge big knob, Koni coils, Coolingmist CMGS Meth injection, USRT spacer (DO3 & Snow 100 nozzles), 19" Miro stp3's, Centric rotors, Stoptech pads and TyrolSport bushings
    3. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      10-14-2010 09:12 AM #103
      We had 4 or 5 cans of this stuff in the garage already and figured what the hell Id go ahead and use it.
      Figure it cant hurt and it might just keep temps down a teeny bit
      Jan 25th, 2007
      T Dot O
      2007 RS GTI
      10-15-2010 01:05 PM #104
      Quote Originally Posted by Krieger View Post
      you can do better than that man!
      sand the whole thing up so it bonds well, primer it, and then go ahead and paint it. its not going to get that hot, ESPECIALLY with WM in there to require that kind of paint either, so make it classy.
      do it right or you will find yourself probably doing it twice.
      THIS^^^ Kreiger I think you and I are sharing brainwaves or something bro, we both read and respond to the same posts all the time. LOL. How's you car doing? just had the dealer replace my PCV valve and they noticed my BSH Throttle Pipe and no big deal, but they kep t asking what the nylon tube coming from the (w/m)pump is. My response is to just ask another stupid question, then the GM of the dealer came to me( I used to work there, so its all good) and asked me what it was. Well apparently I forgot to turn off my w/m and one of the techs was talking to the service advisor as to howmy car was soo much faster than most lightly modded GTI's and the GM wanted to know how he cold tune his GTI to be the same. Great dealership family owned with an enthusiast for a General Manager= Most mod friendly dealer around(at least for me). This was all started cuz they saw this and drove the car.
      and this is what I like to call "Kill Mode"
      Here is a pic of of where I mounted my controller.
      How many of you have actually stolen a car??? Exactly! That's why I say it should be, "Drive like you have to SH!T!"
      [NEUSPEED P-FLO][FORGE DV][S3 INTERCOOLER][BSH THROTTLE PIPE][D.O DVC-30 W/M][ATP 3" DP][BSH PENDULUM MOUNT + DOG BONE INSERT][AWE VENT GUAGE][K-SPORT KONTROL PRO COILOVERS]
    5. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      10-15-2010 01:31 PM #105
      I have my controller mounted in the exact same spot
      Where did you get that button for your setup?
      I have been thinking about have a 2 stage system where the direct port injection will always be on but I can press a button and spray in the TB pipe for some extra cooling benefits as well
      Jan 25th, 2007
      T Dot O
      2007 RS GTI
      10-15-2010 02:14 PM #106
      Got the button from the dealership for $26.00 and $3.00 for the male connector to wire it up.
      If you want to do the 2 stage then here is how I would set it up. Have a main line run into a w/m distibution manifold that has at least 5 outlet ports. Run four lines to your intake mani for the direct port. Run a fifth line to a solenoid block and then run a line out of the solenoid to the TB pipe. Hook a switch up to the solenoid and you can trigger it whenever you want while have the direct port working all the time. I suggest putting a switch on the controller's power line as well so you can turn it off, if you haven't already.
    7. Member Krieger's Avatar
      May 5th, 2009
      Orlando, FL
      Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
      10-15-2010 11:32 PM #107
      car is fantastic and ive been saving gobs of money on gas... been getting regular and saving like 60 cents a gallon... and i refill every other day now. lmao work is so damn far away!!!
      If i could hit my controller any better, I would, but im really torn between keeping this expensive car going with all of the known issues or going into a nice 240sx project and drop in a skyline motor and make crazy reliable power. gotten some CRAZY offers too...
      anyways, my controller is mounted on my steering column and stares me in the face... I LOOOVVVEEE watching those lights pop on, wait a second for the timing to advance like crazy and BAM she pulls harder than i have ever seen lately, especially with 70 degree days finally!
      if i do sell the car, the WM and boost gauge are totally coming with me.
      Mar 26th, 2008
      Fredericksburg, VA
      2012 Audi TT-RS
      10-27-2010 12:13 AM #108
      I figured I would provide an update on what I think is my problem behind dialing in my WMI. I know I said I was going to forget it but I can't quit now as I am determined to get this thing running right.
      Looks like my fuel pump is taking a ****. Explains my timing issues. I'll be in stock mode until I can replace the pump. Just when the weather is getting cold too,
      http://golfmkv.com/forums/showthread...=1#post2694512
      Krieger - That switch is beast. I'm tired of yanking this damn wire out of the fuse to shut it off.
      '09 GTI TSI 11.53@121.18
      '12 TT-RS TBD!
    9. Member Krieger's Avatar
      May 5th, 2009
      Orlando, FL
      10-27-2010 08:41 AM #109
      i knew the MKVI would have some fueling issues too... even if it is just a weak pump over time.
      I think I've decided Im going to keep this car for at least a bit longer, go BT and get her looking pretty and keep her as a nice show car and fun car and later on go buy a POS JDM or even just a shell and build that sucker from the ground up for either show or the track.
      Mar 26th, 2008
      Fredericksburg, VA
      2012 Audi TT-RS
      10-27-2010 09:51 AM #110
      Technically I'm an MKV w/ a TSI. Not sure if there is a difference in specified fuel rail with the MKVI.
      '12 TT-RS TBD!
    11. Member Slayer's Avatar
      Aug 8th, 2000
      Windham CT
      10-27-2010 10:45 AM #111
      That fuel pressure looks fine.. its right around what its requesting.. if it was 20-30 bar below in the midrange or something, then yeah you'd have an issue. Your pump is fine. Look at some FSI logs of the fuel pressure, there's always a huge dip somewhere
    12. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      10-27-2010 11:29 AM #112
      yeah, fuel pressure looks spot on
    13. Member
      Mar 26th, 2008
      Fredericksburg, VA
      2012 Audi TT-RS
      10-28-2010 07:50 AM #113
      Quote Originally Posted by Slayer View Post
      Well darn, I thought I was on to something. Glad to know that the pump isn't failing though but concerned with my timing pull on the 93 file with no meth. It may just be bad gas though.
      '12 TT-RS TBD!
    14. Member
      Mar 26th, 2008
      Fredericksburg, VA
      2012 Audi TT-RS
      11-06-2010 11:27 AM #114
      Virtual - You wouldn't happen to have the TSI intake mani part # do you? I may be replacing it soon but out of warranty so I might not be covered. Nice video on youtube BTW. Stumbled on it while looking for the part.
      http://www.youtube.com/watch?v=6McP_FmZ9Lk
      '12 TT-RS TBD!
    15. Member drppedfikse's Avatar
      Nov 6th, 2004
      Nevaduh
      2015 something
      11-06-2010 12:19 PM #115
      Part No.# 06J133201G
      Order from Paul at Keffer. Where I got mine and cheapest place to get it!!!
      http://www.trademotion.com/partlocat...?siteid=215844
      Previously --- 05jettagli /// 2015 Something
      flickr
      Zenfolio
    16. Member
      Mar 26th, 2008
      Fredericksburg, VA
      2012 Audi TT-RS
      11-06-2010 12:36 PM #116
      Quote Originally Posted by 05jettagli View Post
      Thanks 05jettagli. Keffer has it listed for MSRP on their website @ $208.00 but I found it on genuinevwparts.com for $60 of MSRP @ $149.76. Should I call and speak with Paul?
      Thanks again.
      '12 TT-RS TBD!
    17. Member drppedfikse's Avatar
      Nov 6th, 2004
      Nevaduh
      2015 something
      11-06-2010 12:45 PM #117
      Yeah no problem. Yeah I would send him a message. He has a code to enter on his site for vortex members. I paid a little more than that shipped to NM. Other part is its a special order part. I waited about a month to get my hands on it.
      flickr
      Zenfolio
    18. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      11-08-2010 08:51 AM #118
      Thank for covering for me 05JettaGLI
    19. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      11-24-2010 03:22 PM #119
      I just ordered all my goodies for my direct port injection setup.
      Got all my parts from Devils own.
      Im going with four DO.75 nozzles for octane boost and a DO1 nozzle to go in the TB pipe for cooling
    20. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      12-03-2010 03:34 AM #120
      Whats that? Got new parts wooohoo!
      bunch of extra tubing:
      Heres a mock up of how the system is going to be setup:
      Y split to a check to a Y with both lines going in to the direct port tap post then out to each runner
      Another angle (sorry the meth gives me the shakes):
      closeup:
      direct port tap setup:
      nozzle holder:
      four DO.75 nozzles:
      one DO1 nozzle (for the TB pipe):
      mock up showing the nozzle slightly screwed into the nozzle holder:
    21. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      12-29-2010 08:46 AM #121
      So its time for me to start installing the nozzles for the direct port setup and Ive hit a small roadblock (due to poor planning).
      Basically what the problem is that when I smoothed down the intake manifold I had to cut out the mounting points for a hard line that passes right over the intake manifold.
      pic for reference (yeah yeah the motor looks all stock, but I took the pic shortly after I bought my car lol):
      In the pic look at the shiny hard line that passes right over the intake manifold.
      Now here are the options that I have come up with.
      1) I can remove the entire hard line section and replace it with a flexible line, either braided stainles or a durable more flexible line like Earl's Performance Pro Lite hose:
      If I were to use the Pro Lite hose I could cut the stock hoses back and convert it over to use this type of line exclusively for a cleaner look, plus then I could reroute the line to get it out of the way.
      2) I havent tested to see how much "give" is in the current line but I could move the hard line and secure it to another mounting location via a custom bracket or a folding clasp of some sort.
      3) Get a custom hardline bent to replace the stock piece that would use a different mounting point.
      What do you guys think?
      Im leaning towards using the Pro Lite hose, but im worried about removing the hard line. My concern is why did VW use a hardline at that specific point instead of keeping the rubber hose all the way through?
    22. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      12-29-2010 12:06 PM #122
      After doing some research the hardline appears to be used for the EVAP system so it shouldnt matter if I use a non hardline.
      Its looking like I will relocate the hose under the Intake Manifold then
    23. 01-01-2011 02:16 PM #123
      ViRtUaLheretic, have you had a chance to dismantle the head? I would like to see if the WMI has a positive effect for the carbon buildup issue. thanx.
    24. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      01-02-2011 12:22 PM #124
      Quote Originally Posted by naemcivic View Post
      Not yet, I need to finish the Intake Manifold then wait for a good weekend to install it
      Im thinking 2 or 3 weeks from now
    25. Member guesswho's Avatar
      May 9th, 2009
      Washington, Home of the meth
      mkiv jetta RIP, mkv gti... loooong gone... 69 Triumph (it's euro)... 29 roadster (better than a vw)
      03-24-2011 12:27 PM #125
      soooo?
      a.k.a. vdub-ranger, a.k.a. ChrisTheBlackGuy, a.k.a. Banned....again
      MOD LIST: blood, sweat, tears... mixed with a tad bit of semen on the rear seat. what a night... My BOUGHT Thread
      My man-piece is longer than Mike Kippen's Build Thread... and just as pretty
