Page 7 of 7 FirstFirst ... 3 4 5 6 7
Results 211 to 242 of 242
Thread: You might be an alcoholic when...
  1. Member Track5tar's Avatar
    Feb 16th, 2010
    Salt Lake City, UT and Las Vegas, NV
    Mine: 2010 Passat Hers: 2012 B8 A4
    03-05-2012 02:17 PM #211
    spoke too soon, there is still a slow leak
    fixed?
    Unitronic > APR Switched from APR to UNI and never looking back
    CW '10 Passat 2.0TSI: UNI Stage 2 VMR V705 19x8.5 et45 Podi Boost gauge/pod AWE DV, Turbo Outlet Pipe BSH Boost Tap BillyBoat 3" TBE BFI Stg2 Dogbone/motor mount/trans. mount KW V2 coils Forge Twintake(1st on Passat/CC) JBL W12GTi MKII HEX+CAN vagcom, Podi.ca podi free ship code: NINOSHIP, VMR | Wheels velocitymotoring.com, VolksBHAN in September
  2. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    03-05-2012 02:41 PM #212
    I thought I had it fixed AGAIN as over the last week I put 2L of w/m in it and never saw a leak.
    So this weekend I fileld it up, and it immediately started to leak. ugh
    Guess I'll just hold off till I order new SS lines from Devils Own.
    I wish they would respond back to my e-mail I sent last week.
    Guess, I'll be calling them shortly.
  3. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    03-26-2012 10:52 PM #213
    oh hai:
  4. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    04-25-2012 12:03 AM #214
    Christmas again!
    Im missing two AN nozzle fittings, AN Tee fitting, and a AN check valve.
    Plus I now have the bulkhead fitting so I need to figure out how the hell Im going to secure that to the spare WW tank I bought earlier.
    I think I need to order two more AN-4 90 degree bend fittings too.
    FML this AN **** is expensive.
    Oh but on a good note, I installed the new pump head fitting with AN fittings. It was a PITA but I took a break and did some vag-com work for a local and he paid me in beer so I wasn't to terribly pissed.
  5. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    04-25-2012 12:08 AM #215
    Oh and I finished sanding up the IM and put a few coats of paint on it.
    I also did a mild porting job on the IM
  6. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    04-25-2012 12:39 AM #216
    You can see my plumbin'
    bitches love my long lines
  7. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    04-25-2012 02:45 AM #217
    AN fitting and SS line fetish much? lmao. lookin good tho. My current setup is already more than enough for what my motor needs, but when I get my build done this year, might need to step up to direct port.
  8. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    04-25-2012 08:25 AM #218
    I had two major leaks with the ****ty push lock fittings.
    This will definitely solve that problem LOL
  9. Member Slayer's Avatar
    Aug 8th, 2000
    Windham CT
    2008.5 GTI w/TSI motor, 1995 GTI Vr6
    04-25-2012 08:26 AM #219
    Quote Originally Posted by Krieger View Post
    LOL, I would have hardlined that bitch and not used AN fittings.. them ****ers are outrageous
    Check out my Garage build thread - 08.5 GTI 2.0T TSI, APR stage2, APR intercooler, 42DD 3" Catless Downpipe, Autotech 3" Exhaust, Full Carbonio intake, AWE DV relocation, BSH Motormounts, Labonte S4 Meth injection, Dieselgeek Shortshifter, Southbend Stage2 Endurance clutch, Forge Shift knob, Newsouth boost gauge, Euro LED tails, Koni Coilovers, Miro STP3 19x8.5 rims, General Exclaim 225/35/19 Tires
  10. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    04-25-2012 02:43 PM #220
    Quote Originally Posted by Slayer View Post
    I dont have any means to do hardlines, and I've changed my plans on how to route the lines several times now, so that would have resulted in rebuying hardlines.
    Plus whenever this project is done I will keep all the AN stuff and use it for another project.
    It just so happens that -4AN fittings are used quite a bit for nitrous....
  11. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    04-25-2012 09:50 PM #221
    Went ahead and installed the bulkhead fitting in my new replacement (NON LEAKY!) OEM WW tank.
    The fitting you are seeing is a -6AN fuel safe bulkhead fitting made for use with fuel cells.
    On top of the bulkhead fitting I have a -4AN convertor as they don't make this kind of bulkhead fitting in -4AN.
    On top of the -4AN convertor I will install a 90 degree elbow.
    Now Im going to put a bit of (meth safe!) silicone sealer on the outside of it for safe keeping.
    I will install the new WW tank tomorrow and then I cant do anything till the rest of my AN goodies come in on Friday.
    I cant wait to get rid of the "LOW WASHER FLUID" warning message on my dash, ugh.
  12. n00b
    Apr 26th, 2012
    exit 384
    maxima, a4, 2 wrx
    04-26-2012 05:05 AM #222
    Or you could skip all of this meth/water injection crap
    Convert to e85, bigger fuel injectors, biggere fuel pump, bigger turbo. Forge your internal combustion engine. Tune and you will be on your way of breakng your tranny instead of breaking your engine and your tranny.
    just my ,02
  13. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    04-26-2012 11:06 AM #223
    Quote Originally Posted by ocean48 View Post
    just my ,02
    Let me just pull all those parts that don't exist (injectors and biggere fuel pump) out of my ass and then I will be set for e85
    and how would running e85 break my transmission?
    There are people with 500whp+ with DSG holding just fine...
  14. Member Slayer's Avatar
    Aug 8th, 2000
    Windham CT
    04-26-2012 11:25 AM #224
    not to mention the fact that e85 isn't available everywhere.. In ct, they sell Flex Fuel cars, but there are no e85 stations available to the public
  15. Member
    Mar 26th, 2008
    Fredericksburg, VA
    '12 R; Built GTI TSI 3+
    04-26-2012 12:21 PM #225
    Not to mention it is more corrosive than meth
    11.53@121.18
  16. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    04-26-2012 11:10 PM #226
    M85, anyone? anyone? Bueller?
  17. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    04-27-2012 06:01 PM #227
    Got my order of parts in from Summit Racing and Devils Own.
    I got all the lines put together and the intake manifold put together with the new AN fittings.
    Everything is coming together.....
  18. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    04-29-2012 07:17 PM #228
    Cleaned the valves and install the new intake manifold this weekend.
    I still have to finish plumbing everything , but ITS ALMOST DONE!
    Car had 71k miles
    VTA CC
    w/m
    Cylinder 1
    Cylinder 2
    Cylinder 3
    Cylinder 4
    Crankshaft bolt (24mm) used to turn the motor over to open/clsoe valves
    CLEAN
    Friend with a FSI motor helped me this weekend, he just about **** himself when he saw how clean my valves were.
    THANKS AGAIN ERIC!
  19. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    05-07-2012 11:06 AM #229
    oh hai
  20. Member MasterNele03's Avatar
    May 27th, 2008
    West Palm Beach, FL
    2000 C/W Jetta VRWookie, 2005 Volvo XC90, 2010 CW GTI, 2008 Yamaha R6
    05-07-2012 01:09 PM #230
    'ello looking sweet man I'm waiting on the logs.
    Drive it like you stole it!!!
    XBL GT: MasterNele 03
    Need a crank/cam locking tool for your 2.5T (Volvo), PM me.
  21. Member
    Mar 26th, 2008
    Fredericksburg, VA
    05-07-2012 02:52 PM #231
    IT's about time! Congrats. How's it running?
    11.53@121.18
  22. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    05-07-2012 03:00 PM #232
    Im going to hold off on logs for a bit as I am still checking to make sure everything is working fine.
    Logs will be posted sooner than later.
    BTW still running in 93 octane mode till I get it dialed in.
    Car is running like a champ, you can definitely feel when the w/m kicks in as there is a nice surge in throttle response.
    She was pulling hard despite being ran on the hottest (heat index) day of the year in STL so far.
    Oh and the Intake Manifold was lukewarm by the time I wsa done thrashing on her.
    The rest of the engine bay was scalding hot.
  23. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    05-29-2012 11:53 AM #233
    I rerouted the line for the 4th cylinder as there wasnt any slack in the line and was causing a leak.
    Everything seems to be working great now.
  24. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    05-29-2012 11:28 PM #234
    new line:
  25. Member
    Mar 26th, 2008
    Fredericksburg, VA
    05-30-2012 12:51 AM #235
    Logs?
    11.53@121.18
  26. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    05-30-2012 12:05 PM #236
    Logs will be out soon once setup is completed.
    Got to do one WOT pull today OMW to work and it blew the TB pipe coupler off (I adjusted it last night).
    Once I fix this I beleive I should be good to go.
    I think I will have to order a new coupler from BSH though as I cut my coupler to fit with my TB spacer.
  27. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    06-28-2012 08:18 PM #237
    Got my pressure gauge for my w/m system and a bottle of nitromethane to test out:
  28. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    06-29-2012 03:14 AM #238
    Looks like hell, but it'll do untill I can find a proper male 3/8"NPT 45 degree elbow to female 1/4"NPT fitting.
  29. Member MasterNele03's Avatar
    May 27th, 2008
    West Palm Beach, FL
    06-29-2012 09:43 AM #239
    Very cool, I'm sure you won't disappoint when you find the proper fitting. Waiting anxiously for those IAT's, but I know all in good time.
  30. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    06-29-2012 12:04 PM #240
    The nozzles are located after the IAT sensor so I woudl be able to get accurate IAT results.
    I will be logging temperature of the intake manifold with my laser temp gauge though.
    As well as logging with vagcom.
    This is the last component for the w/m system less later on I switch to a metal 70mm TB and put a DO2 nozzle in the TB pipe. I dont want to pay $500 for a TB though. Im already wayyyyyyyy over budget on this w/m setup LoL
  31. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    06-29-2012 02:37 PM #241
    get a smell nozzle pre-tb, like a 100cc or smaller. makes a HUGE difference. I ran just the spacer for a while and saw some temp drop, but then got two smaller nozzles, the larger one going in the TB pipe just after the intercooler... huge drops in temps. ~106F at WOT down to 69.8F-78.5
    it was over 90 degrees that day.
  32. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    06-29-2012 02:49 PM #242
    I already did pre TB injection and had my TB crap out on me while coming back from SoWo leaving me stranded 1,000 miles away from home on a Sunday.... Im not going back to pre TB unless I have a metal TB.
