VWVortex.com - Touareg 3.0 V6 TDI - BKS
    Results 1 to 6 of 6
    Thread: Touareg 3.0 V6 TDI - BKS
    1. 12-30-2009 01:42 PM #1
      Hi, Touareg with engine warning light and lack power! is the throttle actuator inside the throttle valve ?? MY2006, BKS engine code.thanks for any help!
      Wednesday,30,December,2009,10:25:08:31184
      VCDS Version: Beta 912.0
      Data version: 20091201
      Chassis Type: 7L - VW Touareg
      Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
      37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
      VIN: WVGZZZ7LZ6D061312 Mileage: 101800km/63255miles
      Address 01: Engine Labels: Redir Fail!
      Part No SW: 7L0 907 401 B HW:
      Component: 3.0L V6TDI G000AG 0070
      Revision: --H03--- Serial number: VWZ3Z0F1466675
      Coding: 0011779
      Shop #: WSC 31414 000 00000
      2 Faults Found:
      004203 - Throttle Valve: Stuck or difficult to move
      P106B - 001 - Upper Limit Exceeded - Intermittent
      Freeze Frame:
      Fault Status: 00100001
      Fault Priority: 0
      Fault Frequency: 254
      Mileage: 101134 km
      Time Indication: 0
      Freeze Frame:
      RPM: 1092 /min
      Torque: 50.7 Nm
      Voltage: 11.70 V
      Duty Cycle: 29.6 %
      Duty Cycle: 0.4 %
      005504 - Throttle Actuator (Bank 1): Malfunction
      P1580 - 008 - Implausible Signal
      Freeze Frame:
      Fault Status: 01111000
      Fault Priority: 0
      Fault Frequency: 1
      Time Indication: 0
      Freeze Frame:
      RPM: 0 /min
      Torque: 0.0 Nm
      Voltage: 13.00 V
      Duty Cycle: 0.4 %
      Duty Cycle: 0.4 %
      Readiness: 1 1 0 0 0
      Address 02: Auto Trans Labels: 09D-927-750.lbl
      Part No: 09D 927 750 EB
      Component: AL 750 6A 0879
      Coding: 0004200
      No fault code found.
      Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
      Part No: 7L0 907 379 G
      Component: ESP ALLRAD MK25 0203
      Coding: 0014338
      Shop #: WSC 31414 790 00001
      Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
      Part No SW: 3D0 909 139 HW: 5WK 484 94
      Component: Kessy 6700
      Revision: 67005915 Serial number: VWZ3Z0F1466675
      Coding: 0000232
      Part No: XXXXXXXXXXX
      Component: ELV XXXX
      Address 08: Auto HVAC Labels: None
      Part No: 7L6 907 040 T
      Component: CLIMAtronic R/L 4222
      Coding: 0000530
      Address 09: Cent. Elect. Labels: 7L6-937-049.lbl
      Part No: 7L6 937 049 M
      Component: 3002
      Coding: 0098404
      2 Faults Found:
      01117 - Generator Terminal DF Load Signal
      00907 - Intervention load Management
      000 - -
      Address 15: Airbags Labels: 3D0-909-601.lbl
      Part No: 3D0 909 601 F
      Component: 0C Airbag 8.4E+ H11 1151
      Coding: 0012355
      Address 16: Steering wheel Labels: 7L6-953-549.lbl
      Part No: 7L6 953 549 H
      Component: Lenksäulenmodul 3401
      Coding: 0010031
      Address 17: Instruments Labels: 7L6-920-xxx-17-7LA.lbl
      Part No: 7L6 920 971 F
      Component: KOMBIINSTRUMENT RB8 2111
      Coding: 0005411
      Shop #: WSC 00773 210 51810
      Address 18: Aux. Heat Labels: Redir Fail!
      Part No: 7L6 815 071 D
      Component: Standheizung E1MAC
      Coding: 0000000
      2 Faults Found:
      00664 - Fuel gauge
      002 - Lower Limit Exceeded - Intermittent
      01126 - Engine Speed Signal
      Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
      Part No: 6N0 909 901
      Component: Gateway K<>CAN 0101
      Coding: 0000006
      Address 22: AWD Labels: None
      Part No: 0AD 927 755 AT
      Component: TRANSFERCASE 0114
      Shop #: WSC 00000 000 00000
      Address 46: Central Conv. Labels: 7L0-959-933.lbl
      Part No: 7L0 959 933 F
      Component: HSG 0300
      Coding: 0000069
      Shop #: WSC 00773 210 88422
      Part No: 7L0 959 701 K
      Component: Tuersteuergeraet FS 0201
      Part No: 7L0 959 702 K
      Component: Tuersteuergeraet BF 0201
      Part No: 7L6 959 703
      Component: Tuersteuergeraet HL 0202
      Part No: 7L6 959 704
      Component: Tuersteuergeraet HR 0202
      Part No: 7L0 907 719 A
      Component: Neigungssensor 0020
      Part No: 7L6 951 171 B
      Component: Innenraumsensor 0020
      5 Faults Found:
      00927 - Terminal 30 (Right)
      011 - Open Circuit - Intermittent
      01516 - Terminal 30; Left
      00926 - Terminal 30
      00668 - Supply Voltage Terminal 30
      00893 - Switch for Trunk Handle (E234)
      007 - Short to Ground
      Address 56: Radio Labels: 3B7-035-1xx-56.lbl
      Part No: 7L6 035 195 A
      Component: Radio DE2 0012
      Coding: 0001405
      1 Fault Found:
      00881 - Connection to Speaker Rear Right
      Address 68: Wiper Electr. Labels: None
      Part No: 7L0 955 119 L
      Component: Front Wiper 4027
      Coding: 0000336
      Shop #: WSC 31414 000 376832
      Component: RLS nicht vorhanden
      Coding: 00000000
      Shop #: WSC 00000
      Address 76: Park Assist Labels: 3D0-919-283.lbl
      Part No: 7L0 919 283 F
      Component: 0D Einparkhilfe 1107
      End ---------------------------------------------------------------------
      Modified by vag-mobile at 6:27 AM 12-31-2009
    2. 02-04-2010 01:18 PM #2
      Hello i am Marko from Serbia
      I hawe same fault code, please thell my how your fix this?
      Thanks
      Marko
    3. 11-29-2010 11:42 AM #3
      I have the same fault codes as well, how did this get resolved vag-mobile?
    4. Member jetta ,97's Avatar
      Jul 25th, 2009
      Dallas (Plano),TX
      Jetta TDI 2006 with MK6 cluster & Golf TDI 2004 with MFA cluster
      11-29-2010 10:52 PM #4
      For all guys,
      The throttle body is stuck or not working good.
      This may be problem with lot of carbon build up in throttle body and make butterfly getting stuck .
      First thing to do is to check throttle body and see is there carbon . If has carbon ,need to be clean and clear codes and see .Other wise if is clean something is going on with throttle body or wiring from ECU to throttle body.
      On 2009 you have to be really careful about what kind of diesel your putting in car and there is special additive you have to put it in tank time to time , (i think every 10000 miles.)Putting Incorrect diesel in newer cars can cause lot of problems and damage.
      This maybe same for 2006 but I am not sure as wee don't have those engines here.
      My Jetta TDI MK5 with MK6 Color cluster
    5. 11-30-2010 09:54 AM #5
      I checked my throttle body and it was ok, its only a 3yr old car so I didn't expect it to be gunked up so soon. The error codes also state a problem with the Throttle Actuator (Bank 1): Malfunction
      Are these the actuators (or air flap adjusters) which control the swirl flaps? Why would that cause a failure/error code on the throttle valve as well?
    6. Member jetta ,97's Avatar
      Jul 25th, 2009
      Dallas (Plano),TX
      11-30-2010 08:04 PM #6
      Throttle Actuator is part of throttle body.3 years old car does not mean is it good. There was jetta 2009 TDI with 4000 miles broke down on hwy and problem was water in fuel, and made damage $6000 .
      Any way something going on with your throttle body assemble.Motor and sensor is part of throttle body.
      Did any of you had battery disconnected while ignition was on.In this case throttle body needs to be adopted to ECU.
      I am not sure is it same as says here,you may want to contact Ross-Tech:
      http://wiki.ross-tech.com/wiki/index...ment_%28TBA%29
